Impossible first boot opi5 4GB v1.2
DimonKyiv
Tried 5 diferrent microSD cards, 3 card readers, multiple redownloads on Mac and Windows. Diferrent power supplies, including 100W charger and 52pi EP-0136 direct 5v supply.
No green LED, no LAN communication, no HDMI output.
Everything i get is in log (via UART)
Please help... i've got no more ideas.
DDR Version V1.08 20220617
LPDDR4X, 2112MHz
channel[0] BW=16 Col=10 Bk=8 CS0 Row=16 CS=1 Die BW=16 Size=1024MB
channel[1] BW=16 Col=10 Bk=8 CS0 Row=16 CS=1 Die BW=16 Size=1024MB
channel[2] BW=16 Col=10 Bk=8 CS0 Row=16 CS=1 Die BW=16 Size=1024MB
channel[3] BW=16 Col=10 Bk=8 CS0 Row=16 CS=1 Die BW=16 Size=1024MB
Manufacturer ID:0x1 Samsung
CH0 RX Vref:32.7%, TX Vref:19.8%,0.0%
CH1 RX Vref:32.7%, TX Vref:18.8%,0.0%
CH2 RX Vref:32.7%, TX Vref:20.8%,0.0%
CH3 RX Vref:31.7%, TX Vref:19.8%,0.0%
change to F1: 528MHz
change to F2: 1068MHz
change to F3: 1560MHz
change to F0: 2112MHz
out
U-Boot SPL board init
U-Boot SPL 2017.09-armbian (Jan 23 2023 - 12:54:28)
unknown raw ID 0 0 0
unrecognized JEDEC id bytes: 00, 00, 00
Trying to boot from MMC2
Trying fit image at 0x4000 sector
## Verified-boot: 0
## Checking atf-1 0x00040000 ... sha256(806278dba1...) + OK
## Checking uboot 0x00200000 ... sha256(8c9fc64da7...) + OK
## Checking fdt 0x0034b500 ... sha256(feafd7cda6...) + OK
## Checking atf-2 0x000f0000 ... sha256(c00c7fd75b...) + OK
## Checking atf-3 0xff100000 ... sha256(71c3a5841b...) + OK
## Checking atf-4 0xff001000 ... sha256(2301cf73be...) + OK
Jumping to U-Boot(0x00200000) via ARM Trusted Firmware(0x00040000)
Total: 211.727 ms
INFO:    Preloader serial: 2
NOTICE:  BL31: v2.3():v2.3-405-gb52c2eadd:derrick.huang
NOTICE:  BL31: Built : 11:23:47, Aug 15 2022
INFO:    spec: 0x13
INFO:    ext 32k is valid
INFO:    GICv3 without legacy support detected.
INFO:    ARM GICv3 driver initialized in EL3
INFO:    system boots from cpu-hwid-0
INFO:    idle_st=0x21fff, pd_st=0x11fff9, repair_st=0xfff70001
INFO:    dfs DDR fsp_params[0].freq_mhz= 2112MHz
INFO:    dfs DDR fsp_params[1].freq_mhz= 528MHz
INFO:    dfs DDR fsp_params[2].freq_mhz= 1068MHz
INFO:    dfs DDR fsp_params[3].freq_mhz= 1560MHz
INFO:    BL31: Initialising Exception Handling Framework
INFO:    BL31: Initializing runtime services
WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK
ERROR:   Error initializing runtime service opteed_fast
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x200000
INFO:    SPSR = 0x3c9
U-Boot 2017.09-armbian (Jan 23 2023 - 12:54:28 +0100)
Model: Orange Pi 5
PreSerial: 2, raw, 0xfeb50000
DRAM:  3.7 GiB
Sysmem: init
Relocation Offset: eda2b000
Relocation fdt: eb9f91c8 - eb9fecc8
CR: M/C/I
Using default environment
no mmc device at slot 1
mmc@fe2c0000: 1 (SD), mmc@fe2e0000: 0
Bootdev(atags): mmc 1
MMC1: Legacy, 52Mhz
PartType: EFI
DM: v1
boot mode: None
Model: Orange Pi 5
CLK: (sync kernel. arm: enter 1008000 KHz, init 1008000 KHz, kernel 0N/A)
  b0pll 24000 KHz
  b1pll 24000 KHz
  lpll 24000 KHz
  v0pll 24000 KHz
  aupll 24000 KHz
  cpll 1500000 KHz
  gpll 1188000 KHz
  npll 24000 KHz
  ppll 1100000 KHz
  aclk_center_root 702000 KHz
  pclk_center_root 100000 KHz
  hclk_center_root 396000 KHz
  aclk_center_low_root 500000 KHz
  aclk_top_root 750000 KHz
  pclk_top_root 100000 KHz
  aclk_low_top_root 396000 KHz
Net:   No ethernet found.
Hit key to stop autoboot('CTRL+C'):  0
mmc@fe2e0000: 0
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1...
Found U-Boot script /boot.scr
reading /boot.scr
3252 bytes read in 3 ms (1 MiB/s)
## Executing script at 00500000
Boot script loaded from mmc 1
reading /armbianEnv.txt
164 bytes read in 2 ms (80.1 KiB/s)
reading /uInitrd
15344077 bytes read in 1245 ms (11.8 MiB/s)
reading /Image
33020416 bytes read in 2676 ms (11.8 MiB/s)
** Unable to read file /dtb/rockchip/rk3588s-orangepi-5.dtb **
libfdt fdt_check_header(): FDT_ERR_BADMAGIC
No FDT memory address configured. Default at 0xeb9f91c8
** Unable to read file /dtb/rockchip/overlay/rockchip-rk3588-fixup.scr **
Unknown command 'kaslrseed' - try 'help'
Fdt Ramdisk skip relocation
## Loading init Ramdisk from Legacy Image at 0a200000 ...
   Image Name:   uInitrd
   Image Type:   AArch64 Linux RAMDisk Image (gzip compressed)
   Data Size:    15344013 Bytes = 14.6 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
ERROR: Did not find a cmdline Flattened Device Tree
Could not find a valid device tree
SCRIPT FAILED: continuing...
Device 0: unknown device
scanning bus for devices...
Device 2: Could not get clock for spi@fe2b0000: -2
unknown device
Device 1: Could not get clock for spi@fe2b0000: -2
unknown device
starting USB...
Bus usb@fc000000: "Error" handler, esr 0xbe000011
* Reason:        Exception from SError interrupt
* PC         =   00000000002c2904
* LR         =   00000000002c1798
* SP         =   00000000eb9f8190
* ESR_EL2    =   00000000be000011
* Reloc Off  =   00000000eda2b000
x0 : 0000000000000000 x1 : 0000000000000000
x2 : ffffffffffffffe0 x3 : ffffffffffffffe0
x4 : 0000000000000080 x5 : 0000000000000000
x6 : 1ffffffffffffffc x7 : ffffffffffffffe8
x8 : 0000000000000044 x9 : 0000000000000008
x10: 00000000ffffffd0 x11: 00000000ebc33f68
x12: 0000000000000000 x13: 0000000000000004
x14: 000000000000000e x15: 00000000ffffffff
x16: 0000000000000084 x17: 0000000000000032
x18: 00000000eb9ffcd0 x19: ffffffffffffffe0
x20: 0000000000000000 x21: 0000000000008000
x22: 00000000fffffffe x23: 00000000ebc2ab90
x24: 00000000edd77448 x25: 0000000000000000
x26: 0000000000000000 x27: 0000000000000000
x28: 00000000ebc4eea0 x29: 00000000eb9f8370
Call trace:
  PC:   [< 002c2904 >]
  LR:   [< 002c1798 >]
Stack:
        [< 002c2904 >]
        [< 00235460 >]
        [< 00291958 >]
        [< 00238ffc >]
        [< 00238f70 >]
        [< 0029999c >]
        [< 002142cc >]
        [< 0021436c >]
        [< 002304cc >]
        [< 002194f0 >]
        [< 00219694 >]
        [< 00218da0 >]
        [< 0022faa8 >]
        [< 002304cc >]
        [< 002194f0 >]
        [< 00219694 >]
        [< 00218da0 >]
        [< 0022faa8 >]
        [< 002304cc >]
        [< 002194f0 >]
        [< 00219694 >]
        [< 00218de4 >]
        [< 002192ac >]
        [< 00219168 >]
        [< 00219694 >]
        [< 00218da0 >]
        [< 0022faa8 >]
        [< 002304cc >]
        [< 002194f0 >]
        [< 00219694 >]
        [< 00218da0 >]
        [< 0022fa14 >]
        [< 00219d3c >]
        [< 00217b68 >]
        [< 0021a3dc >]
        [< 002a9a70 >]
        [< 0021a618 >]
        [< 00201e40 >]
Copy info from "Call trace..." to a file(eg. dump.txt), and run
command in your U-Boot project: ./scripts/stacktrace.sh dump.txt
Resetting CPU ...
### ERROR ### Please RESET the board ###
Link to comment
Share on other sites
I have used manual from https://wiki.radxa.com/Rock5/install/spi
An i switched from microSDXC to microsdHC 32Gb U1
To switch official RKDevTool_Release_v2.96 to English
edit config.ini
change language to "2" like that:
[Language]
Selected=2
Option 3: Erase with Windows PC
Before Erasing, please confirm that ROCK 5B is in maskrom mode
Step 1: Download
Choose the "Advanced features" button, then select rk3588_spl_loader_v1.08.111.bin, next click the "Download" button
Step 2: Erase all
Click the "erase all" button
Step 3: Reboot device
Link to comment
