I have found my old Media-Player and I will use them for a special task. It´s labeled "MK808B Plus"
OpenELEC 5.95.5.2 is installed. Now I will run Armbian_5.67_Aml-s805_Ubuntu_bionic_default_3.10.108_desktop_20181207 from @Balbes150. I use the meson8b_mk808bplus.btb. But the WLAN is not working. For the first run I have change the "armbian_first_run.txt" the value "FR_net_wifi_enabled=1"
How can I use the WLAN?
How can I make a new "fresh" run that the "armbian_first_run.txt" is execute?
How can I put the armbian to the NAND?
First off read:
Expand
You are asking about a build that is over three years old, for a kernel that is much older than that from a developer that has stopped working on amlogic tv boxes.  This isn't likely to lead to the results you are looking for.  The best advise I can give you is to read this thread:
which contains the historic info about supporting the s805 cpu
