Hello. Connected via PuTTY. I'm trying to connect to WIFI and I get an error: Connection activation failed: (53) The Wi-Fi network could not be found. Further, all Wi-Fi networks disappear, appear only after a reboot.
Цитата
22.039972] WCN: dumpmem_rx_callback
[   22.041911] WCN: dumpmem_rx_callback
[   22.043816] WCN: dumpmem_rx_callback
[   22.045734] WCN: dumpmem_rx_callback
[   22.047640] WCN: dumpmem_rx_callback
[   22.049613] WCN: dumpmem_rx_callback
[   22.051593] WCN: dumpmem_rx_callback
[   22.053670] WCN: dumpmem_rx_callback
[   22.055897] WCN: dumpmem_rx_callback
[   22.058100] WCN: dumpmem_rx_callback
[   22.060168] WCN: dumpmem_rx_callback
[   22.062184] WCN: dumpmem_rx_callback
[   22.064464] WCN: dumpmem_rx_callback
[   22.066929] WCN: dumpmem_rx_callback
[   22.068991] WCN: dumpmem_rx_callback
[   22.071304] WCN: dumpmem_rx_callback
[   22.073235] WCN: dumpmem_rx_callback
[   22.075221] WCN: dumpmem_rx_callback
[   22.077260] WCN: dumpmem_rx_callback
[   22.079287] WCN: dumpmem_rx_callback
[   22.081246] WCN: dumpmem_rx_callback
[   22.083320] WCN: dumpmem_rx_callback
[   22.085260] WCN: dumpmem_rx_callback
[   22.087296] WCN: dumpmem_rx_callback
[   22.089226] WCN: dumpmem_rx_callback
[   22.091205] WCN: dumpmem_rx_callback
[   22.093261] WCN: dumpmem_rx_callback
[   22.095173] WCN: dumpmem_rx_callback
[   22.095199] WCN: mdbg dump ram 947200 ok!
[   22.095278] WCN: dumpmem_rx_callback
[   22.095281] WCN: mdbg dump aon ahb 84 ok!
[   22.095419] WCN: dumpmem_rx_callback
[   22.095422] WCN: mdbg dump aon_apb 852 ok!
[   22.095535] WCN: dumpmem_rx_callback
[   22.095539] WCN: mdbg dump btwfahb 1024 ok!
[   22.095661] WCN: dumpmem_rx_callback
[   22.095664] WCN: mdbg dump btwfapb 652 ok!
[   22.095746] WCN: dumpmem_rx_callback
[   22.095750] WCN: mdbg dump aonclk 324 ok!
[   22.095812] WCN: dumpmem_rx_callback
[   22.095815] WCN: mdbg dump predivclk 72 ok!
[   22.098176] WCN: dumpmem_rx_callback
[   22.100305] WCN: dumpmem_rx_callback
[   22.100327] WCN: mdbg dump sdio 65536 ok!
[   22.100403] WCN: enable_cp_pll rd CLK_CTRL0 reg val:0x2fff
[   22.100665] WCN: enable_cp_pll enable CLK_CTRL0 val:0x2fff
[   22.100986] WCN: check_wifi_power_domain_ison CHIP_SLP reg val:0xc430
[   22.100991] WCN: WIFI MAC have power down
[   22.101671] WCN: check_wifi_power_domain_ison WIFI_ENABLE reg val:0xa023
[   22.101685] WCN: WIFI_en and wifi_mac_en is disable
[   22.101877] WCN: dumpmem_rx_callback
[   22.104389] WCN: dumpmem_rx_callback
[   22.106053] WCN: dumpmem_rx_callback
[   22.107991] WCN: dumpmem_rx_callback
[   22.110144] WCN: dumpmem_rx_callback
[   22.112198] WCN: dumpmem_rx_callback
[   22.114350] WCN: dumpmem_rx_callback
[   22.116269] WCN: dumpmem_rx_callback
[   22.118337] WCN: dumpmem_rx_callback
[   22.120250] WCN: dumpmem_rx_callback
[   22.122315] WCN: dumpmem_rx_callback
[   22.124339] WCN: dumpmem_rx_callback
[   22.126433] WCN: dumpmem_rx_callback
[   22.128675] WCN: dumpmem_rx_callback
[   22.128695] WCN: mdbg dump wifi 360448 ok!
[   22.128780] WCN: dumpmem_rx_callback
[   22.128784] WCN: dump cp reg section[11] ok!
[   22.128926] WCN: dumpmem_rx_callback
[   22.128930] WCN: dump cp reg section[12] ok!
[   22.129022] WCN: dumpmem_rx_callback
[   22.129025] WCN: dump cp reg section[13] ok!
[   22.129348] WCN: dumpmem_rx_callback
[   22.129353] WCN: dump cp reg section[14] ok!
[   22.129423] WCN: dumpmem_rx_callback
[   22.129426] WCN: dump cp reg section[15] ok!
[   22.129833] WCN: dumpmem_rx_callback
[   22.129846] WCN: dump cp reg section[16] ok!
[   22.130108] WCN: dumpmem_rx_callback
[   22.130121] WCN: dump cp reg section[17] ok!
[   22.130435] WCN: dumpmem_rx_callback
[   22.130440] WCN: mdbg dump fm 2748 ok!
[   22.130635] WCN: dumpmem_rx_callback
[   22.130638] WCN: mdbg dump btacc 2292 ok!
[   22.130800] WCN: dumpmem_rx_callback
[   22.130803] WCN: mdbg dump btjal 1848 ok!
[   22.130867] WCN: dumpmem_rx_callback
[   22.130870] WCN: mdbg dump bthab 160 ok!
[   22.130963] WCN: dumpmem_rx_callback
[   22.130966] WCN: mdbg dump btlejal 540 ok!
[   22.466593] sunxi-mmc 4021000.mmc: data error, sending stop command
[   22.472935] sdiohal err:dt read fail ret:-110, system_addr=0x4024f000
[   22.479395] sdiohal:sdio dump_aon_reg entry
[   22.479434] sdiohal:pmu sdio status:[0x140]:0x6b
[   22.479451] sdiohal:pmu sdio status:[0x141]:0x3c
[   22.479466] sdiohal:pmu sdio status:[0x142]:0xe1
[   22.479480] sdiohal:pmu sdio status:[0x143]:0x0
[   22.479494] sdiohal:pmu sdio status:[0x144]:0x0
[   22.479508] sdiohal:pmu sdio status:[0x145]:0x0
[   22.479522] sdiohal:pmu sdio status:[0x146]:0x0
[   22.479536] sdiohal:pmu sdio status:[0x147]:0x0
[   22.479549] sdiohal:pmu sdio status:[0x148]:0x60
[   22.479563] sdiohal:pmu sdio status:[0x149]:0x0
[   22.479577] sdiohal:pmu sdio status:[0x14a]:0x0
[   22.479591] sdiohal:pmu sdio status:[0x14b]:0x0
[   22.479605] sdiohal:pmu sdio status:[0x14c]:0x0
[   22.479619] sdiohal:pmu sdio status:[0x14d]:0x0
[   22.479633] sdiohal:pmu sdio status:[0x14e]:0x0
[   22.479646] sdiohal:pmu sdio status:[0x14f]:0x0
[   22.479702] sdiohal:cm4d haddr 0:[0x144]:0x0
[   22.479718] sdiohal:cm4d haddr 0:[0x145]:0x20
[   22.479733] sdiohal:cm4d haddr 0:[0x146]:0x12
[   22.479748] sdiohal:cm4d haddr 0:[0x147]:0x0
[   22.479803] sdiohal:cm4i haddr 1:[0x144]:0xe0
[   22.479818] sdiohal:cm4i haddr 1:[0x145]:0x40
[   22.479833] sdiohal:cm4i haddr 1:[0x146]:0x10
[   22.479848] sdiohal:cm4i haddr 1:[0x147]:0x0
[   22.479904] sdiohal:cm4s haddr 2:[0x144]:0x7c
[   22.479919] sdiohal:cm4s haddr 2:[0x145]:0x6
[   22.479933] sdiohal:cm4s haddr 2:[0x146]:0x14
[   22.479948] sdiohal:cm4s haddr 2:[0x147]:0x40
[   22.480004] sdiohal:dmaw haddr 3:[0x144]:0x0
[   22.480019] sdiohal:dmaw haddr 3:[0x145]:0x0
[   22.480034] sdiohal:dmaw haddr 3:[0x146]:0x0
[   22.480048] sdiohal:dmaw haddr 3:[0x147]:0x0
[   22.480104] sdiohal:dmar haddr 4:[0x144]:0x0
[   22.480119] sdiohal:dmar haddr 4:[0x145]:0x0
[   22.480133] sdiohal:dmar haddr 4:[0x146]:0x0
[   22.480148] sdiohal:dmar haddr 4:[0x147]:0x0
[   22.480204] sdiohal:aon_to_ahb haddr 5:[0x144]:0x0
[   22.480219] sdiohal:aon_to_ahb haddr 5:[0x145]:0x0
[   22.480233] sdiohal:aon_to_ahb haddr 5:[0x146]:0x0
[   22.480248] sdiohal:aon_to_ahb haddr 5:[0x147]:0x0
[   22.480304] sdiohal:axi_to_ahb haddr 6:[0x144]:0x4
[   22.480319] sdiohal:axi_to_ahb haddr 6:[0x145]:0xf0
[   22.480333] sdiohal:axi_to_ahb haddr 6:[0x146]:0x24
[   22.480348] sdiohal:axi_to_ahb haddr 6:[0x147]:0x40
[   22.480404] sdiohal:hready_status haddr 7:[0x144]:0xcf
[   22.480419] sdiohal:hready_status haddr 7:[0x145]:0xff
[   22.480434] sdiohal:hready_status haddr 7:[0x146]:0xf9
[   22.480448] sdiohal:hready_status haddr 7:[0x147]:0x70
[   22.480452] sdiohal:val:0xc
[   22.480486] sdiohal:after reset hready status:[0x144]:0xcf
[   22.480500] sdiohal:after reset hready status:[0x145]:0xff
[   22.480514] sdiohal:after reset hready status:[0x146]:0xf9
[   22.480528] sdiohal:after reset hready status:[0x147]:0x70
[   22.480531] sdiohal:sdio dump_aon_reg end
[   22.480533] sdiohal:sdiohal_abort
[   22.480536] sdiohal:carddump flag set[1]
[   22.480559] sdiohal:disable rx int for dump
[   22.480562] sdiohal:chn8 tx push old, cmdid=25, mstime=21982, record_time=21982
[   22.480571] chn8 tx push old: 00 00 00 00 10 19 a8 00 de 55 00 00 00 00 00 00  .........U......
[   22.480575] sdiohal:chn8 tx denq old, cmdid=25, mstime=21982, record_time=21982
[   22.480580] chn8 tx denq old: 00 54 00 08 10 19 a8 00 de 55 00 00 00 00 00 00  .T.......U......
[   22.480584] sdiohal:chn22 rx dispatch old, cmdid=25, mstime=21982, record_time=21987
[   22.480589] chn22 rx dispatch old: 3f 06 00 0a 00 19 0c 00 de 55 00 00 00 3a 00 00  ?........U...:..
[   22.480592] sdiohal:chn8 tx push new, cmdid=11, mstime=21987, record_time=21987
[   22.480597] chn8 tx push new: 00 00 00 00 10 0b 18 00 e3 55 00 00 00 00 00 00  .........U......
[   22.480601] sdiohal:chn8 tx denq new, cmdid=11, mstime=21987, record_time=21987
[   22.480606] chn8 tx denq new: 00 0c 00 08 10 0b 18 00 e3 55 00 00 00 00 00 00  .........U......
[   22.480609] sdiohal:chn22 rx dispatch new, cmdid=11, mstime=21987, record_time=21990
[   22.480615] chn22 rx dispatch new: 3f 06 00 0a 00 0b 0c 00 e3 55 00 00 00 3b 00 00  ?........U...;..
[   22.480619] WCN_ERR: mdbg_dump_data dump memory error:-110
[   22.486125] WCN: mdbg dump bt modem 0 ok!
[   22.486130] WCN_ERR: read HCI_ARM_WR_RD_MODE reg error:-1
[   22.491547] WCN_ERR: mdbg_dump_data dump memory error:-1
[   22.496880] WCN: mdbg dump bt_cmd buf 0 ok!
[   22.496885] WCN_ERR: mdbg_dump_data dump memory error:-1
[   22.502207] WCN: mdbg dump btevent buf 0 ok!
[   22.502215] WCN_ERR: mdbg_dump_data dump memory error:-1
[   22.507529] WCN: mdbg dump bt_lmp_tx_buf 0 ok!
[   22.507533] WCN_ERR: mdbg_dump_data dump memory error:-1
[   22.512861] WCN: mdbg dump bt_lmp_rx_buf 0 ok!
[   22.512874] WCN_ERR: mdbg_dump_data dump memory error:-1
[   22.518194] WCN: mdbg dump bt_acl_tx_buf0 ok!
[   22.518200] WCN_ERR: mdbg_dump_data dump memory error:-1
[   22.523515] WCN: mdbg dump bt_acl_rx_buf 0 ok!
[   22.523520] WCN_ERR: mdbg_dump_data dump memory error:-1
[   22.528836] WCN: mdbg dump bt_sco_tx_buf 0 ok!
[   22.528842] WCN_ERR: mdbg_dump_data dump memory error:-1
[   22.534157] WCN: mdbg dump bt_sco_rx_buf 0 ok!
[   22.534162] WCN_ERR: mdbg_dump_data dump memory error:-1
[   22.539479] WCN: mdbg dump bt_bb_tx_buf 0 ok!
[   22.539484] WCN_ERR: mdbg_dump_data dump memory error:-1
[   22.544798] WCN: mdbg dump bt_bb_rx_buf 0 ok!
[   22.589463] WCN: dumpmem_rx_callback
[   22.589480] WCN: dump str finish!
[   22.589482] WCN: mdbg dump memory finish
[   29.511909] WCN: stop_loopcheck
[   32.586633] sprdwl:sprdwl_tx_cmd err:-19
[   35.935180] sprdwl:[WIFI_CMD_SET_IE]timeout
[   35.939404] sprdwl:ctx_id:0 cmd: WIFI_CMD_SET_IE[25] rsp timeout (mstime = 32226), num=19
[   35.947686] unisoc_wifi unisoc_wifi wlan0: sprdwl_cfg80211_connect failed
[   35.954588] sprdwl:sprdwl_atcmd_assert ctx_id:0, cmd_id:25, reason:3, cp_asserted:0
[   35.962307] WCN: mdbg_assert_interface:[CMD] WIFI_CMD_SET_IE, [REASON] CMD_RSP_TIMEOUT_ERROR
[   35.962320] sdiohal:carddump flag set[1]
[   35.962384] sdiohal:disable rx int for dump
[   35.962391] sdiohal:chn8 tx push old, cmdid=25, mstime=21982, record_time=21982
[   35.962401] chn8 tx push old: 00 00 00 00 10 19 a8 00 de 55 00 00 00 00 00 00  .........U......
[   35.962405] sdiohal:chn8 tx denq old, cmdid=25, mstime=21982, record_time=21982
[   35.962411] chn8 tx denq old: 00 54 00 08 10 19 a8 00 de 55 00 00 00 00 00 00  .T.......U......
[   35.962414] sdiohal:chn22 rx dispatch old, cmdid=25, mstime=21982, record_time=21987
[   35.962420] chn22 rx dispatch old: 3f 06 00 0a 00 19 0c 00 de 55 00 00 00 3a 00 00  ?........U...:..
[   35.962423] sdiohal:chn8 tx push new, cmdid=11, mstime=21987, record_time=21987
[   35.962428] chn8 tx push new: 00 00 00 00 10 0b 18 00 e3 55 00 00 00 00 00 00  .........U......
[   35.962431] sdiohal:chn8 tx denq new, cmdid=11, mstime=21987, record_time=21987
[   35.962436] chn8 tx denq new: 00 0c 00 08 10 0b 18 00 e3 55 00 00 00 00 00 00  .........U......
[   35.962439] sdiohal:chn22 rx dispatch new, cmdid=11, mstime=21987, record_time=21990
[   35.962445] chn22 rx dispatch new: 3f 06 00 0a 00 0b 0c 00 e3 55 00 00 00 3b 00 00  ?........U...;..
[   35.962449] WCN_ERR: Not dump again!
https://paste.armbian.com/axuxawesiy
The same is true if an Ethernet cable is plugged in when turned on. then wifi networks are looking for. If there is no Ethernet cable, then there is no network at all.
