The board are not load after update firmware
yamah
Hello!
My problem is with paying for OrangePi Plus 2 (not E), but I haven't found a suitable section. Dear administrators, please fix the split if I made a big mistake.
I was installed image orangepiplus/Bullseye_current (Nov 30, 2022) in eMMC. All works is normal. In armbian-config I was run Firmware (Update all packages and firmware). Afeter this the board are not loading from eMMC or external CD with current image Armbian. The Ubuntu from site orangepi.org the loading is normal.
In debug-uart I see a cyclical reboot with:
<0xdd>!␊
<0xea><0xfc>q<0xb9><0xf6>Core: 65 devices, 18 uclasses, devicetree: separate␍␊
WDT: Not starting watchdog@1c20ca0␍␊
MMC: mmc@1c0f000: 0, mmc@1c10000: 2, mmc@1c11000: 1␍␊
Loading Environment from FAT... Unable to use mmc 1:1...␍␊
In: serial@1c28000␍␊
Out: serial@1c28000␍␊
Err: serial@1c28000␍␊
Net: phy interface9␍␊
eth0: ethernet@1c30000␍␊
starting USB...␍␊
Bus usb@1c1b000: USB EHCI 1.00␍␊
Bus usb@1c1d000: USB EHCI 1.00␍␊
scanning bus usb@1c1b000 for devices... 2 USB Device(s) found␍␊
scanning bus usb@1c1d000 for devices... Device NOT ready␍␊
Request Sense returned 02 3A 00␍␊
prefetch abort␍␊
pc : [<fffffffa>]⇥ lr : [<bffaa4b3>]␍␊
reloc pc : [<8a077ffa>]⇥ lr : [<4a0224b3>]␍␊
sp : b8a99728 ip : bbf6c038⇥ fp : bffdec47␍␊
r10: ffffffff r9 : bbf67ec0⇥ r8 : b8a99780␍␊
r7 : 00000000 r6 : 00000001⇥ r5 : e59ff014 r4 : 00000000␍␊
r3 : b8a99780 r2 : 00000001⇥ r1 : 00000000 r0 : e59ff014␍␊
Flags: nzcv IRQs off FIQs off Mode SVC_32 (T)␍␊
Code: 0000 0000 0000 0000 (0000) 0000 ␍␊
Resetting CPU ...␍␊
resetting ...␍␊
The problem is that the board no longer wants to load with EXT4, and now it loads only with FAT32.
Please tell me how to teach the board to boot from EXT4 again.
Link to comment
Share on other sites
Hi!
The problem was a wrong package u-boot.
I was install linux-u-boot-orangepiplus-current,
maked
dd if=/usr/lib/linux-u-boot-current-orangepiplus_23.02.2_armhf/u-boot-sunxi-with-spl.bin of=/dev/mmcblk1 bs=1024 seek=8
and I can load the installed OS.
But now USB-ports are not work. I use ssh connection.
Link to comment
Hi!
The package linux-u-boot-orangepiplus-current has some problem on OPI+2
1. linux-u-boot-current-orangepiplus_22.11.4_armhf.deb - has not boot the OS
2. linux-u-boot-current-orangepiplus_23.02.2_armhf.deb - has not work cooler and all usb. Network is work.
Device is work normaly with wersion linux-u-boot-current-orangepiplus_22.05.3_armhf.deb.
Link to comment
