martivo Posted February 20, 2023 Share Posted February 20, 2023 Here is a video of my Orange Pi 5 setup. Hopefully someone finds it helpful! 0 Quote Link to comment Share on other sites More sharing options...
WarHawk_AVG Posted February 21, 2023 Share Posted February 21, 2023 Cool...how is the thruput on the drives? 0 Quote Link to comment Share on other sites More sharing options...
martivo Posted February 21, 2023 Author Share Posted February 21, 2023 @WarHawk_AVG The onboard nvme drive KingSpec M.2 2242 NVMe 512GB (theoretical max speed 600 MB/s in specs) Here the PCI 2.0 lane of the OPi 5 is defenetly not helping and its a cheap e-bay drive... root@:~# dd if=/dev/nvme0n1 bs=1M count=10000 of=/dev/null 10485760000 bytes (10 GB, 9.8 GiB) copied, 50.3259 s, 208 MB/s The Samsung 850 EVO SSD over USB in the enclosure (theoretical max speed 540 MB/s in specs): root@:~# dd if=/dev/sda bs=1M count=10000 of=/dev/null 10485760000 bytes (10 GB, 9.8 GiB) copied, 27.1413 s, 386 MB/s The Software Raid in on the 6TB WD Red HDD (max theoretical should be 2x speed of WD Red) root@:~# dd if=/dev/md0 bs=1M count=10000 seek=100000 of=/dev/null 10485760000 bytes (10 GB, 9.8 GiB) copied, 53.1439 s, 197 MB/s Single WD Red HDD (theoretical max by spec 180 MB/s) root@:~# dd if=/dev/sdd bs=1M count=10000 of=/dev/null 10485760000 bytes (10 GB, 9.8 GiB) copied, 57.9577 s, 181 MB/s So in case of the Spinning hard drives the harddrive itself will be the bottleneck. In case of SSD the enclosure is the limiting factor. I am happy with it, more than Ill need for my purposes. 0 Quote Link to comment Share on other sites More sharing options...
