Im pretty new to linux in general mostly used windows before.
Is there a way to get waydroid work on armbian? I installed it but waydroid sais that the binder kernels are missing (1). When I follow the instruction to install the kernel modules using dkms I also get a failure (2).
(1) ERROR: Binder node "binder" for waydroid not found
(2) Error! Bad return status for module build on kernel: linux-headers-5.10.110-rockchip-rk3588
Anyone can help me with this?
Thanks in advance! :)
I guess you need these kernel modules:
CONFIG_ANDROID_LOW_MEMORY_KILLER=n
CONFIG_ANDROID_BINDER_IPC=y
CONFIG_ANDROID_BINDERFS=y
CONFIG_ANDROID_BINDER_DEVICES="binder,hwbinder,vndbinder,anbox-binder,anbox-hwbinder,anbox-vndbinder"
These are in the config on github, probably you'll need to update the kernel
Is there a guide anywhere how to update the kernel?
I have found a guide on how to build a new kernel, but how do I update the existing one afterwards?
Thanks!
If it matters I read some logs and got the following error when installing the kernel module: Your kernel does not support KProbes
sudo apt install linux-image-legacy-rockchip-rk3588
If you build one yourself the debs will be in ./output/debs/
To install sudo apt install ./*image*.deb
or sudo dpkg -i *image*.deb
Edited by royk
You could check the config of the installed kernel, if these modules were already enabled, then it won't help if you rebuild with that same config
nano /boot/config-5.10.110-rockchip-rk3588
ahsmem and binder are not set. Should be a good chance then to get it working if I rebuild the kernel.
Gonna try that tomorrow. Thanks a lot!
Edit: Can I just copy this config, set the needed values and rebuild the kernel with it?
Edited by Prax
I would say that the deb have the kernel modules inside or built-in
You could try this first:
sudo apt update && sudo apt reinstall linux-image-legacy-rockchip-rk3588
Otherwise the default config on github has these already enabled.
Tried that. Getting the following error:"Reinstallation of linux-image-legacy-rockchip-rk3588 is not possible, it cannot be downloaded"
Also tried updating the dependecies and to reinstall using aptitude. Error there is:"Cant find source to download version '23.02.0-trunk.0184' of 'linux-image-legacy-rockchip-rk3588'
Any idea on how to reinstall?
Switched to nightly build. Binder and Ashmem are now activated in the config (/boot/config-5.10.110-rockchip-rk3588) but while kernel installation and at every reinstall I still get these errors:
Building module:
cleaning build area...
make -j8 KERNELRELEASE=5.10.110-rockchip-rk3588 all KERNEL_SRC=/lib/modules/5.10.110-rockchip-rk3588/build....(bad exit status: 2)
Error! Bad return status for module build on kernel: 5.10.110-rockchip-rk3588 (aarch64)
Consult /var/lib/dkms/anbox-ashmem/1/build/make.log for more information.
Kernel preparation unnecessary for this kernel. Skipping...
Building module:
make -j8 KERNELRELEASE=5.10.110-rockchip-rk3588 all KERNEL_SRC=/lib/modules/5.10.110-rockchip-rk3588/build.....(bad exit status: 2)
Consult /var/lib/dkms/anbox-binder/1/build/make.log for more information.
So I not only get them when I try to install the modules using dkms. I also get them when I reinstall the kernel.
/var/lib/dkms/anbox-binder/1/build/make.log gives following error: "Your kernel does not support KProbes, but this is required to compile ashmem as a kernel module on kernel 5.7 and later"
Edited by Prax
wget http://imola.armbian.com/beta/pool/main/l/linux-5.10.110-rockchip-rk3588/linux-image-legacy-rockchip-rk3588_23.02.2_arm64.deb
sudo dpkg -i linux-image-legacy-rockchip-rk3588_23.02.2_arm64.deb
wget http://imola.armbian.com/beta/pool/main/l/linux-5.10.110-rockchip-rk3588/linux-headers-legacy-rockchip-rk3588_23.02.2_arm64.deb
sudo dpkg -i linux-headers-legacy-rockchip-rk3588_23.02.2_arm64.deb
What is the output of cat  /var/lib/dkms/anbox-binder/1/build/make.log
Edited by royk
While installing the first .deb I still get the same errors as mentioned above when reinstalling.
While installing the second .deb I get a ton of warning and errors that used functions are deprecated.
Thanks for your help, can't say it often enough!
Here are the cat of anbox-binder and anbox-ashmen.
Cat of /var/lib/dkms/anbox-binder/1/build/make.log is following:
DKMS make.log for anbox-binder-1 for kernel 5.10.110-rockchip-rk3588 (aarch64)
Mi 22. Feb 22:22:42 CET 2023
make -C /lib/modules/5.10.110-rockchip-rk3588/build V=0 M=$PWD
make[1]: Entering directory '/usr/src/linux-headers-5.10.110-rockchip-rk3588'
  CC [M]  /var/lib/dkms/anbox-binder/1/build/deps.o
  CC [M]  /var/lib/dkms/anbox-binder/1/build/binder.o
  CC [M]  /var/lib/dkms/anbox-binder/1/build/binder_alloc.o
  CC [M]  /var/lib/dkms/anbox-binder/1/build/binderfs.o
In file included from ././include/linux/kconfig.h:7,
                 from <command-line>:
./include/generated/autoconf.h:1720: warning: "CONFIG_ANDROID_BINDER_DEVICES" redefined
error, forbidden warning:autoconf.h:1720
 1720 | #define CONFIG_ANDROID_BINDER_DEVICES "binder,hwbinder,vndbinder,anbox-binder,anbox-hwbinder,anbox-vndbinder"
<command-line>: note: this is the location of the previous definition
./include/generated/autoconf.h:2246: warning: "CONFIG_ANDROID_BINDERFS" redefined
error, forbidden warning:autoconf.h:2246
 2246 | #define CONFIG_ANDROID_BINDERFS 1
/var/lib/dkms/anbox-binder/1/build/deps.c:20:3: error: #error "Your kernel does not support KProbes, but this is required to compile binder as a kernel module on kernel 5.7 and later"
   20 | # error "Your kernel does not support KProbes, but this is required to compile binder as a kernel module on kernel 5.7 and later"
make[2]: *** [scripts/Makefile.build:273: /var/lib/dkms/anbox-binder/1/build/deps.o] Error 1
make[2]: *** Waiting for unfinished jobs....
/var/lib/dkms/anbox-binder/1/build/binder.c: In function 'binder_translate_binder':
/var/lib/dkms/anbox-binder/1/build/binder.c:2456:49: error: passing argument 1 of 'security_binder_transfer_binder' from incompatible pointer type [-Werror=incompatible-pointer-types]
 2456 |         if (security_binder_transfer_binder(proc->tsk, target_proc->tsk)) {
      |                                                 struct task_struct *
In file included from /var/lib/dkms/anbox-binder/1/build/binder.c:63:
./include/linux/security.h:258:56: note: expected 'const struct cred *' but argument is of type 'struct task_struct *'
  258 | int security_binder_transfer_binder(const struct cred *from,
/var/lib/dkms/anbox-binder/1/build/binder.c:2456:67: error: passing argument 2 of 'security_binder_transfer_binder' from incompatible pointer type [-Werror=incompatible-pointer-types]
./include/linux/security.h:259:56: note: expected 'const struct cred *' but argument is of type 'struct task_struct *'
  259 |                                     const struct cred *to);
/var/lib/dkms/anbox-binder/1/build/binder.c: In function 'binder_translate_handle':
/var/lib/dkms/anbox-binder/1/build/binder.c:2506:49: error: passing argument 1 of 'security_binder_transfer_binder' from incompatible pointer type [-Werror=incompatible-pointer-types]
 2506 |         if (security_binder_transfer_binder(proc->tsk, target_proc->tsk)) {
/var/lib/dkms/anbox-binder/1/build/binder.c:2506:67: error: passing argument 2 of 'security_binder_transfer_binder' from incompatible pointer type [-Werror=incompatible-pointer-types]
/var/lib/dkms/anbox-binder/1/build/binder.c: In function 'binder_translate_fd':
/var/lib/dkms/anbox-binder/1/build/binder.c:2598:49: error: passing argument 1 of 'security_binder_transfer_file' from incompatible pointer type [-Werror=incompatible-pointer-types]
 2598 |         ret = security_binder_transfer_file(proc->tsk, target_proc->tsk, file);
./include/linux/security.h:260:54: note: expected 'const struct cred *' but argument is of type 'struct task_struct *'
  260 | int security_binder_transfer_file(const struct cred *from,
/var/lib/dkms/anbox-binder/1/build/binder.c:2598:67: error: passing argument 2 of 'security_binder_transfer_file' from incompatible pointer type [-Werror=incompatible-pointer-types]
./include/linux/security.h:261:54: note: expected 'const struct cred *' but argument is of type 'struct task_struct *'
  261 |                                   const struct cred *to, struct file *file);
/var/lib/dkms/anbox-binder/1/build/binder.c: In function 'binder_transaction':
/var/lib/dkms/anbox-binder/1/build/binder.c:3001:53: error: passing argument 1 of 'security_binder_transaction' from incompatible pointer type [-Werror=incompatible-pointer-types]
 3001 |                 if (security_binder_transaction(proc->tsk,
./include/linux/security.h:256:52: note: expected 'const struct cred *' but argument is of type 'struct task_struct *'
  256 | int security_binder_transaction(const struct cred *from,
/var/lib/dkms/anbox-binder/1/build/binder.c:3002:60: error: passing argument 2 of 'security_binder_transaction' from incompatible pointer type [-Werror=incompatible-pointer-types]
 3002 |                                                 target_proc->tsk) < 0) {
./include/linux/security.h:257:52: note: expected 'const struct cred *' but argument is of type 'struct task_struct *'
  257 |                                 const struct cred *to);
/var/lib/dkms/anbox-binder/1/build/binder.c: In function 'binder_ioctl_set_ctx_mgr':
/var/lib/dkms/anbox-binder/1/build/binder.c:4956:51: error: passing argument 1 of 'security_binder_set_context_mgr' from incompatible pointer type [-Werror=incompatible-pointer-types]
 4956 |         ret = security_binder_set_context_mgr(proc->tsk);
make[2]: *** [scripts/Makefile.build:273: /var/lib/dkms/anbox-binder/1/build/binderfs.o] Error 1
make[2]: *** Deleting file '/var/lib/dkms/anbox-binder/1/build/binderfs.o'
make[2]: *** [scripts/Makefile.build:273: /var/lib/dkms/anbox-binder/1/build/binder_alloc.o] Error 1
make[2]: *** Deleting file '/var/lib/dkms/anbox-binder/1/build/binder_alloc.o'
./include/linux/security.h:255:56: note: expected 'const struct cred *' but argument is of type 'struct task_struct *'
  255 | int security_binder_set_context_mgr(const struct cred *mgr);
cc1: some warnings being treated as errors
make[2]: *** [scripts/Makefile.build:273: /var/lib/dkms/anbox-binder/1/build/binder.o] Error 1
make[1]: *** [Makefile:1920: /var/lib/dkms/anbox-binder/1/build] Error 2
make[1]: Leaving directory '/usr/src/linux-headers-5.10.110-rockchip-rk3588'
make: *** [Makefile:8: all] Error 2
Cat of /var/lib/dkms/anbox-ashmem/1/build/make.log is following:
DKMS make.log for anbox-ashmem-1 for kernel 5.10.110-rockchip-rk3588 (aarch64)
Mi 22. Feb 22:22:37 CET 2023
  CC [M]  /var/lib/dkms/anbox-ashmem/1/build/deps.o
  CC [M]  /var/lib/dkms/anbox-ashmem/1/build/ashmem.o
/var/lib/dkms/anbox-ashmem/1/build/deps.c:9:3: error: #error "Your kernel does not support KProbes, but this is required to compile ashmem as a kernel module on kernel 5.7 and later"
    9 | # error "Your kernel does not support KProbes, but this is required to compile ashmem as a kernel module on kernel 5.7 and later"
make[2]: *** [scripts/Makefile.build:273: /var/lib/dkms/anbox-ashmem/1/build/deps.o] Error 1
make[1]: *** [Makefile:1920: /var/lib/dkms/anbox-ashmem/1/build] Error 2
make: *** [Makefile:12: all] Error 2
Edited by Prax
sudo apt remove dkms
sudo dpkg --force-all -i linux-image-legacy-rockchip-rk3588_23.02.2_arm64.deb
sudo reboot
sudo apt install waydroid
sudo waydroid init
Edited by royk
That fixed the problem. Thanks a lot! :)
Now I only have to find a option to remote connect using wayland instead of x11.
I don't know with what you try to connect it to, if you try to connect with vnc then "Enable legacy vnc protocol".
It could be that the notification to accept the client was not visible, you could set "Require password" (3 dots after legacy vnc protocol) as workaround.
Tried with mstsc and with vnc can't connect. When I check grdctl status there isn't any credentials set while they are set in the ui. I also can't set credentials using grdctl, getting the error: "Cannot create an item in a locked collection"
If I try to connect:
VNC literally nothing happens client hangs trying to connect
RDP I get asked for credentials, afterwards I have to confirm the cert and then it closes suddenly without a error.
Edited by Prax
I activated it by gui but I can't connect. Do I have to log off with the user before I can login remote?
Edit: When I log off localy I can connect but I get a black screen and get disconnected after like 10 seconds
Edited by Prax
xrdp was still enabled from armbian-config. I disabled and remove xrdp.
Now I just cant login... getting an error from gnome-remote-desktop on the orangepi5
Feb 23 20:32:29 orangepi5 gnome-remote-desktop-daemon[6118]: Cannot load libcuda.so.1
Feb 23 20:32:29 orangepi5 gnome-remote-desktop-daemon[6118]: Cannot load libnvidia-encode.so.1
Did you set:
Enable legacy vnc protocol with "require password"
filled in a username and password
Updated the package
Try to connect with ip address instead of hostname
Maybe there is a firewall in between or another service on the OPI running on the same port?
Perhaps you've installed something  for nvidia?
Check:  apt list --installed *nvidia*   if you find something from nvidia and remove with sudo apt remove ....
Im just an idiot ... tried to connect while no display was connected. If I just connect a display there is no problem.
Is there any option to use rdp or vnc without a attached display?
