I've been trying to get my DS1820 temp sensor working but cant seem to get the device to show up om my orange pi zero 2 running Orange Pi 3.0.6 Bullseye
Most info i find starts our with run armbian-config but orangpi doesnt have it. All i got is the orangepi-config but it doesnt have the "Go to the “system” section and select “Hardware” then activate w1-gpio."
so i was looking arround and found you need to enable overlays in  /boot/armbianEnv.txt  but dont have it aswell but the alternative  /boot/orangepiEnv.txt
there i add the
overlay_prefix=sun50i-h616
overlays=w1-gpio
param_w1_pin=PC8                          <<<<< not sure about the pin numers
param_w1_pin_int_pullup=1
looking at the output i would say PC8 is correct pin name.
root@orangepizero2:~# gpio readall
 +------+-----+----------+------+---+   H616   +---+------+----------+-----+------+
 | GPIO | wPi |   Name   | Mode | V | Physical | V | Mode | Name     | wPi | GPIO |
 |      |     |     3.3V |      |   |  1 || 2  |   |      | 5V       |     |      |
 |  229 |   0 |    SDA.3 |  OFF | 0 |  3 || 4  |   |      | 5V       |     |      |
 |  228 |   1 |    SCL.3 |  OFF | 0 |  5 || 6  |   |      | GND      |     |      |
 |   73 |   2 |      PC9 |  OFF | 0 |  7 || 8  | 0 | OFF  | TXD.5    | 3   | 226  |
 |      |     |      GND |      |   |  9 || 10 | 0 | OFF  | RXD.5    | 4   | 227  |
 |   70 |   5 |      PC6 | ALT5 | 0 | 11 || 12 | 0 | OFF  | PC11     | 6   | 75   |
 |   69 |   7 |      PC5 | ALT5 | 0 | 13 || 14 |   |      | GND      |     |      |
 |   72 |   8 |      PC8 |  OFF | 0 | 15 || 16 | 0 | OFF  | PC15     | 9   | 79   |
 |      |     |     3.3V |      |   | 17 || 18 | 0 | OFF  | PC14     | 10  | 78   |
 |  231 |  11 |   MOSI.1 |  OFF | 0 | 19 || 20 |   |      | GND      |     |      |
 |  232 |  12 |   MISO.1 |  OFF | 0 | 21 || 22 | 0 | OFF  | PC7      | 13  | 71   |
 |  230 |  14 |   SCLK.1 |  OFF | 0 | 23 || 24 | 0 | OFF  | CE.1     | 15  | 233  |
 |      |     |      GND |      |   | 25 || 26 | 0 | OFF  | PC10     | 16  | 74   |
 |   65 |  17 |      PC1 |  OFF | 0 | 27 || 28 |   |      |          |     |      |
 |  272 |  18 |     PI16 | ALT2 | 0 | 29 || 30 |   |      |          |     |      |
 |  262 |  19 |      PI6 |  OFF | 0 | 31 || 32 |   |      |          |     |      |
 |  234 |  20 |     PH10 | ALT3 | 0 | 33 || 34 |   |      |          |     |      |
if i understaand correct i need to add the kernel moduels by doing:
modprobe w1-therm
modprobe w1-gpio
after reboot i should see the device show up? using:
ls /sys/bus/w1/devices
but go nothing.
so i check :
root@orangepizero2:~# cat /sys/kernel/debug/gpio
gpiochip0: GPIOs 0-287, parent: platform/300b000.pinctrl, 300b000.pinctrl:
 gpio-76  (                    |red:power           ) out lo
 gpio-77  (                    |green:status        ) out hi
 gpio-80  (                    |usb1-vbus           ) out hi
 gpio-166 (                    |cd                  ) in  lo IRQ ACTIVE LOW
 gpio-210 (                    |reset               ) out hi ACTIVE LOW
gpiochip1: GPIOs 352-383, parent: platform/7022000.pinctrl, 7022000.pinctrl:
it seems like im missing something fundamentally? can some one point me in the write direction?
First off, you aren't using Armbian.  So posting questions in the Armbian forum isn't the the correct place to ask your questions.  Since you are using the orangepi provided software, that is the appropriate place to ask your questions on that software.
However feel free to download the Armbian build for your board and try it if you would like: https://www.armbian.com/orange-pi-zero-2
lol guess it was bed time when i posted it. just swapped to the correct sd card. but is it still correct that armbian-config  doesnt have the option "Go to the “system” section and select “Hardware” then activate w1-gpio." any more?
