Hi, I have two meson64 SBCs where one is Khadas VIM 3 and the other is Odroid N2. They have been running almost the same setup and there has been minor differences with time.
For the past months, I have had issues with the error Illegal instruction for my Odroid N2 server. I did a clean install earlier today (Armbian_23.02.2_Odroidn2_jammy_current_6.1.11) without success. For instance, I often face the error when running cryptsetup benchmark. Most of the time I have to reboot multiple times, reinstall cryptsetup packages, try the armhf packages and more. I have never had the same issue with Khadas VIM 3.
The issue seems to be related to argon2i and the question is what and where should I look further regarding how to solve this. I've tried switching supported kernel versions, 6.1.*, 5.19.*, 5.10.*, without success. Trying legacy kernel 4.9.* had some issues resulting in the board not booting.
Output when everything is fine
| => sudo cryptsetup benchmark
  Reveal hidden contents
Output when facing the issue. It's always after trying to open with cryptsetup prior and I think it's in general
Edited by Z11ntal33r
@Z11ntal33r - do you maybe run your odroid n2 with cpu overclocking? this can sometimes result in such random errors - otherwise maybe try to lower the max cpu freq via /sys/devices/system/cpu/cpufreq to check if it runs more stable in such a case.
Thanks for reaching out :) I've default settings and I did a clean install yesterday. The few steps I did was to run cryptstetup benchmark which was fine, ran a script to install and setup packages and so on, tried to mount the drive, but Illegal instruction showed. After that, all cryptsetup benchmarks failed.
I can try a new clean build later today, lower the cpu freq and see if that's better. I am also thinking about switching from Jammy to Bullseye in order to apt-pin newer packages of cryptsetup to see if that solves the issue. I that doesn't help, I will think about buying a new SBC, unless I switch to something else than Armbian, which I would like to avoid
@hexdump it seems that you were absolutely right regarding the issue here! After lowering the max CPU speed from 1900 to 1800, I've done more than 100 benchmarks without facing Illegal instruction
Thank you very, very much!:)
