Christos Posted October 26, 2016 Share Posted October 26, 2016 As I reported yesterday, after an upgrade, wifi was lost. Although wlan devices were visible via ifconfig, no connection to AP was possible. (8192cu driver) Today I tried to have fresh Armbian build , got a 5.23 jessie login as: root root@192.168.1.15's password: _ _ ____ _ _ _ | \ | | __ _ _ __ ___ | _ \(_) | \ | | ___ ___ | \| |/ _` | '_ \ / _ \| |_) | | | \| |/ _ \/ _ \ | |\ | (_| | | | | (_) | __/| | | |\ | __/ (_) | |_| \_|\__,_|_| |_|\___/|_| |_| |_| \_|\___|\___/ Welcome to ARMBIAN Debian GNU/Linux 8 (jessie) 3.4.112-rt143-sun8i System load: 1.31 Up time: 3 min Memory usage: 15 % of 490Mb IP: 192.168.10.2,192.168.1.15 CPU temp: 34°C Usage of /: 8% of 15G [ 2 updates to install: apt-get upgrade ] Last login: Wed Oct 26 16:48:52 2016 from 192.168.1.6 root@nanopineo:~# As you see got the RT also build in 3.4.112-rt143-sun8i WiFi 8192cu driver was up and running just fine, As there were updates indicated, did the apt-get update and upgrade.. After that, AGAIN WiFi (8192cu) got lost and no connection was possible any more. Tried the armbian-firmware-full, but obviously the firmware there has some difference, the driver is no longer able to connect although shows up in ifconfig. ALSO, the kernel got a different name.. instead of "3.4.112-rt143-sun8i" now the RT was missing from title, dont know if that means anything deeper like RT mods gone for real, but I do report it. And thats the new banner login as: root root@192.168.1.11's password: _ _ ____ _ _ _ | \ | | __ _ _ __ ___ | _ \(_) | \ | | ___ ___ | \| |/ _` | '_ \ / _ \| |_) | | | \| |/ _ \/ _ \ | |\ | (_| | | | | (_) | __/| | | |\ | __/ (_) | |_| \_|\__,_|_| |_|\___/|_| |_| |_| \_|\___|\___/ Welcome to ARMBIAN Debian GNU/Linux 8 (jessie) 3.4.112-sun8i System load: 0.36 Up time: 1 min Memory usage: 8 % of 494Mb IP: 192.168.1.11 CPU temp: 36°C Usage of /: 8% of 15G Last login: Wed Oct 26 16:51:18 2016 from 192.168.1.6 root@nanopineo:~# So far the experience on upgrade shows that its untrusted at least.. One question, guys, is there any chance that my 8192cu driver wifi dongles work again in Armbian as they were a couple of days before? or should I forget about that?.. Link to comment Share on other sites More sharing options...
gnasch Posted October 27, 2016 Share Posted October 27, 2016 If my OpiPc is any indication, for 8192CU first try depmod -a as root, or else build your module locally as per the documentation. maybe blacklist the rtl8192 module from the kernel. best, gnasch Link to comment Share on other sites More sharing options...
