Contributing on armbian-bsp-cli-bananapim5
Go to solution Solved by SteeMan,
Hello all,
I discovered today (using Banapi-M5) with apt-file search 01-armbian-defaults.conf that this file is part of
the deb https://imola.armbian.com/beta/pool/main/a/armbian-bsp-cli-bananapim5/
I tried to fetch the sources on bsp-cli on https://github.com/armbian/build/tree/main/packages/
It is indicated bsp-cli folder in the README but neither the directory exists
nor bsp/bananapim5 folder that may provide the sources for the debian packages.
I am a bit confuse how to contribute to add the headless support for example.
It there an other git repository? Thanks.
        SoSie
Link to comment
Share on other sites
Armbian & Khadas are rewarding contributors
