s905x TV box stucked with network configuration at first boot
Posted (edited)
Hi all,
My s905x TV box worked well with Armbian_23.02.0 (03.17.0615/Armbian_23.02.0_amlogic_s905x_bullseye_5.15.100_server_2023.03.17.img.gz).
Today I tried Armbian_23.05.0 (03.19.0453/Armbian_23.05.0_amlogic_s905x_bullseye_5.15.100_server_2023.03.19.img.gz)
Debian is stucked  at first boot with network configuration. Same issue ethernet plugged or unplugged
I cannot find anymore Armbian_23.02.0 prebuilt image
Edit: Armbian_23.02.0 found in 03.19.0427
Many thanks!
Edited by joula
What exact builds are you downloading and from where?  The file names you mention above don't correspond to builds I am familiar with.
@joula  You are not using Armbian.  The location you are downloading from is a fork of armbian.  They use the Armbian name without permission.  We can't help you in these forums because we don't know what code you are using, you need to direct your questions to the location you downloaded your code from.  Those developers do not participate in these forums, nor support armbian development.
