robertoj Posted Monday at 07:27 AM Share Posted Monday at 07:27 AM I tried all weekend to add the touch function of the LCD's XPT2046 With this DTS: Spoiler /dts-v1/; /plugin/; / { compatible = "allwinner,sun8i-h3"; fragment@0 { target = <&pio>; __overlay__ { display_pins: display_pins { pins = "PC4", "PA2"; /*reset,dc*/ function = "gpio_out", "gpio_out"; }; ads7846_pins: ads7846_pins { pins = "PA19"; /*irq*/ function = "irq"; }; spi0_cs0: spi0_cs0 { pins = "PC3"; function = "gpio_out"; output-high; }; spi0_cs1: spi0_cs1 { pins = "PC7"; function = "gpio_out"; output-high; }; }; }; /*closing of fragment@0*/ fragment@1 { target = <&spi0>; __overlay__ { pinctrl-names = "default", "default"; pinctrl-1 = <&spi0_cs1>; cs-gpios = <0>, <&pio 2 7 0>; /* PC7 */ }; }; /*closing of fragment@1*/ fragment@2 { target = <&spi0>; __overlay__ { /* needed to avoid dtc warning */ #address-cells = <1>; #size-cells = <0>; status="okay"; pinctrl-names = "default", "default"; /*added by ryjelsum*/ cs-gpios = <&pio 2 3 0>, <&pio 2 7 0>; /* cs0=C3,cs1=C7 */ #num-chipselects = <2>; /*deleted by ryjelsum*/ display: display@0 { /*compatible = "ilitek,ili9341";*/ compatible = "adafruit,yx240qv29", "ilitek,ili9341"; reg = <0>; pinctrl-names = "default"; pinctrl-0 = <&display_pins>; pinctrl-1 = <&spi1_cs0>; /*added by ryjelsum*/ spi-max-frequency = <24000000>; status="okay"; /*added by ryjelsum*/ rotation= <90>; bgr = <0>; fps = <15>; buswidth = <8>; height = <320>; width = <240>; reset-gpios = <&pio 2 4 0>; /* C4,GPIO 24 polarity 0 for adafruit */ dc-gpios = <&pio 0 2 0>; /* A2,GPIO 25 */ debug = <3>; }; ads7846: ads7846@1 { /*this whole block added by ryjelsum*/ reg = <1>; /* Chip Select 1 */ compatible = "ti,ads7846"; spi-max-frequency = <1000000>; status = "okay"; pinctrl-2=<&spi0_cs1 &spi0_cs1>; pinctrl-names = "default"; pinctrl-3 = <&ads7846_pins>; interrupt-parent = <&pio>; interrupts = <0 19 2>; /* PA19 IRQ_TYPE_EDGE_FALLING */ pendown-gpio = <&pio 0 19 0>; /* PA19 */ /* driver defaults, optional */ ti,x-min = /bits/ 16 <0>; ti,y-min = /bits/ 16 <0>; ti,x-max = /bits/ 16 <0x0FFF>; ti,y-max = /bits/ 16 <0x0FFF>; ti,pressure-min = /bits/ 16 <0>; ti,pressure-max = /bits/ 16 <0xFFFF>; ti,x-plate-ohms = /bits/ 16 <400>; }; }; }; /*closing of fragment@2*/ __overrides__ { rotation = <&display>, "rotation:0"; fps = <&display>, "fps:0"; debug = <&display>, "debug:0"; }; /* closing of overrides */ }; It gets compiled, but the bootloader rejects it: Applying user provided DT overlay ili9341-touch-sp0.dtbo failed on fdt_overlay_apply(): FDT_ERR_NOT_FOUND Error applying DT overlays, restoring original DT (i included the spi-add-cs1.dtbo as suggested in https://ryjelsum.me/homelab/xpt2046-ili9341-opi-zero/ ) 0 Quote Link to comment Share on other sites More sharing options...
Ryzer Posted Monday at 01:21 PM Share Posted Monday at 01:21 PM Hi robertoj, I can see some lines that look problematic. Firstly you are defining cs-gpio twice. Once here: 5 hours ago, robertoj said: fragment@1 { target = <&spi0>; __overlay__ { pinctrl-names = "default", "default"; pinctrl-1 = <&spi0_cs1>; cs-gpios = <0>, <&pio 2 7 0>; /* PC7 */ }; Note - Remember that 0 refers to the native cs line (PC3) 5 hours ago, robertoj said: fragment@2 { target = <&spi0>; __overlay__ { /* needed to avoid dtc warning */ #address-cells = <1>; #size-cells = <0>; status="okay"; pinctrl-names = "default", "default"; /*added by ryjelsum*/ cs-gpios = <&pio 2 3 0>, <&pio 2 7 0>; /* cs0=C3,cs1=C7 */ Here the pinctrl references are wrong. I am not sure how strictly the ordering matters but for clarity 'pinctrl-names' should be before the actual pin control nodes. 5 hours ago, robertoj said: pinctrl-2=<&spi0_cs1 &spi0_cs1>; pinctrl-names = "default"; pinctrl-3 = <&ads7846_pins>; Adding spi-add-cs1.dtbo is not needed as all it does it defined the pins to use as cs lines which you have already done above anyway. My other suggestion would be to look into what the latest bindings should for the ads7846 touch controller. Let me know how you get on with following overlay: Spoiler /dts-v1/; /plugin/; / { compatible = "allwinner,sun8i-h3"; fragment@0 { target = <&pio>; __overlay__ { display_pins: display_pins { pins = "PC4", "PA2"; /*reset,dc*/ function = "gpio_out", "gpio_out"; }; ads7846_pins: ads7846_pins { pins = "PA19"; /*irq*/ function = "irq"; }; spi0_cs0: spi0_cs0 { pins = "PC3"; function = "gpio_out"; output-high; }; spi0_cs1: spi0_cs1 { pins = "PC7"; function = "gpio_out"; output-high; }; }; }; /*closing of fragment@0*/ fragment@1 { target = <&spi0>; __overlay__ { /* needed to avoid dtc warning */ #address-cells = <1>; #size-cells = <0>; status="okay"; pinctrl-names = "default", "default"; /*added by ryjelsum*/ pinctrl-1 = <&spi0_cs1>; /* pinctrl-0 is already declared in the primary dts */ cs-gpios = <0>, <&pio 2 7 0>; /* cs0=C3,cs1=C7 */ num-chipselects = <2>; display: display@0 { /*compatible = "ilitek,ili9341";*/ compatible = "adafruit,yx240qv29", "ilitek,ili9341"; reg = <0>; pinctrl-names ="default"; pinctrl-0 = <&display_pins>; spi-max-frequency = <24000000>; status="okay"; rotation= <90>; bgr = <0>; fps = <15>; buswidth = <8>; height = <320>; width = <240>; reset-gpios = <&pio 2 4 0>; /* C4,GPIO 24 polarity 0 for adafruit */ dc-gpios = <&pio 0 2 0>; /* A2,GPIO 25 */ debug = <3>; }; ads7846: ads7846@1 { reg = <1>; /* Chip Select 1 */ compatible = "ti,ads7846"; spi-max-frequency = <1000000>; status = "okay"; pinctrl-names ="default"; pinctrl-0 = <&ads7846_pins>; interrupt-parent = <&pio>; interrupts = <0 19 2>; /* PA19 IRQ_TYPE_EDGE_FALLING */ pendown-gpio = <&pio 0 19 0>; /* PA19 */ /* driver defaults, optional */ ti,x-min = /bits/ 16 <0>; ti,y-min = /bits/ 16 <0>; ti,x-max = /bits/ 16 <0x0FFF>; ti,y-max = /bits/ 16 <0x0FFF>; ti,pressure-min = /bits/ 16 <0>; ti,pressure-max = /bits/ 16 <0xFFFF>; ti,x-plate-ohms = /bits/ 16 <400>; }; }; }; /*closing of fragment@2*/ __overrides__ { rotation = <&display>, "rotation:0"; fps = <&display>, "fps:0"; debug = <&display>, "debug:0"; }; /* closing of overrides */ }; best of luck Ryzer 0 Quote Link to comment Share on other sites More sharing options...
robertoj Posted Monday at 03:26 PM Share Posted Monday at 03:26 PM I went with your corrected DTS ... so far it looks great Spoiler roberto@bananapim2zero:~$ lsmod |grep ads ads7846 20480 0 roberto@bananapim2zero:~$ lsmod |grep spi roberto@bananapim2zero:~$ sudo cat /proc/interrupts | grep ads [sudo] password for roberto: 59: 574 0 0 0 sunxi_pio_edge 19 Edge ads7846 roberto@bananapim2zero:~$ dmesg | grep spi [ 7.139676] ads7846 spi0.1: supply vcc not found, using dummy regulator [ 7.140801] ads7846 spi0.1: touchscreen, irq 59 [ 7.153779] input: ADS7846 Touchscreen as /devices/platform/soc/1c68000.spi/spi_master/spi0/spi0.1/input/input1 [ 7.195022] panel-ilitek-ili9341 spi0.0: get optional vcc failed [ 7.196412] [drm] Initialized ili9341 1.0.0 20210716 for spi0.0 on minor 1 [ 7.702554] panel-ilitek-ili9341 spi0.0: [drm] Initialized display serial interface [ 7.762184] panel-ilitek-ili9341 spi0.0: [drm] fb0: ili9341drmfb frame buffer device (Did NOT use the spi-add-cs1.dtbo, as advised) I went out running to work, and I will continue tests when I go back home Day 2 of testing: Spoiler roberto@bananapim2zero:~$ dmesg | grep ads [ 1.702669] ads7846@1 enforce active low on GPIO handle [ 7.139676] ads7846 spi0.1: supply vcc not found, using dummy regulator [ 7.140801] ads7846 spi0.1: touchscreen, irq 59 roberto@bananapim2zero:~$ sudo cat /sys/kernel/debug/gpio gpiochip0: GPIOs 0-223, parent: platform/1c20800.pinctrl, 1c20800.pinctrl: gpio-0 (CON2-P13 ) gpio-1 (CON2-P11 ) gpio-2 (CON2-P22 |dc ) out hi gpio-3 (CON2-P15 ) gpio-4 (CON3-P03 ) gpio-5 (CON3-P02 ) gpio-6 (CON2-P07 ) gpio-7 (CON2-P29 ) gpio-8 (CON2-P31 ) gpio-9 (CON2-P33 ) gpio-10 (CON2-P35 ) gpio-11 (CON2-P05 ) gpio-12 (CON2-P03 ) gpio-13 (CON2-P08 ) gpio-14 (CON2-P10 ) gpio-15 (CON2-P16 ) gpio-16 (CON2-P12 ) gpio-17 (CON2-P37 ) gpio-18 (CON2-P28 ) gpio-19 (CON2-P27 |pendown ) in hi IRQ gpio-20 (CON2-P40 ) gpio-21 (CON2-P38 ) gpio-64 (CON2-P19 ) gpio-65 (CON2-P21 ) gpio-66 (CON2-P23 ) gpio-67 (CON2-P24 ) gpio-68 (CON2-P18 |reset ) out hi gpio-71 (CON2-P26 |spi0 CS1 ) out hi ACTIVE LOW gpio-110 (CSI-PWR-EN ) gpio-128 (CN3-P17 ) gpio-129 (CN3-P13 ) gpio-130 (CN3-P09 ) gpio-131 (CN3-P07 ) gpio-132 (CN3-P19 ) gpio-133 (CN3-P21 ) gpio-134 (CN3-P22 ) gpio-135 (CN3-P20 ) gpio-136 (CN3-P18 ) gpio-137 (CN3-P16 ) gpio-138 (CN3-P14 ) gpio-139 (CN3-P12 ) gpio-140 (CN3-P05 ) gpio-141 (CN3-P03 ) gpio-142 (CN3-P06 ) gpio-143 (CN3-P08 ) gpio-160 (SDC0-D1 ) gpio-161 (SDC0-D0 ) gpio-162 (SDC0-CLK ) gpio-163 (SDC0-CMD ) gpio-164 (SDC0-D3 ) gpio-165 (SDC0-D2 ) gpio-166 (SDC0-DET |cd ) in hi gpio-192 (WL-SDIO-CLK ) gpio-193 (WL-SDIO-CMD ) gpio-194 (WL-SDIO-D0 ) gpio-195 (WL-SDIO-D1 ) gpio-196 (WL-SDIO-D2 ) gpio-197 (WL-SDIO-D3 ) gpio-198 (BT-UART-TX ) gpio-199 (BT-UART-RX ) gpio-200 (BT-UART-RTS ) gpio-201 (BT-UART-CTS ) gpio-202 (WL-WAKE-AP ) gpio-203 (BT-WAKE-AP |host-wakeup ) in lo gpio-204 (BT-RST-N |shutdown ) out hi gpio-205 (AP-WAKE-BT |device-wakeup ) out hi gpiochip1: GPIOs 352-383, parent: platform/1f02c00.pinctrl, 1f02c00.pinctrl: gpio-353 (CPUX-SET |vdd-cpux ) out hi gpio-354 (CON2-P32 ) gpio-355 (POWER-KEY |power ) in hi IRQ ACTIVE LOW gpio-356 (CON2-P36 ) gpio-357 (VCC-IO-EN ) gpio-358 (USB0-ID |usb0_id_det ) in hi IRQ gpio-359 (WL-PWR-EN |reset ) out hi ACTIVE LOW gpio-360 (PWR-STB |vcc1v2 ) out hi gpio-361 (PWR-DRAM |vcc-dram ) out hi gpio-362 (PWR-LED |bananapi-m2-zero:red) out lo ACTIVE LOW gpio-363 (IR-RX ) roberto@bananapim2zero:~$ sudo apt install evtest ...done roberto@bananapim2zero:~$ sudo evtest No device specified, trying to scan all of /dev/input/event* Available devices: /dev/input/event0: gpio-keys /dev/input/event1: ADS7846 Touchscreen Select the device event number [0-1]: 1 Input driver version is 1.0.1 Input device ID: bus 0x1c vendor 0x0 product 0x1ea6 version 0x0 Input device name: "ADS7846 Touchscreen" Supported events: Event type 0 (EV_SYN) Event type 1 (EV_KEY) Event code 330 (BTN_TOUCH) Event type 3 (EV_ABS) Event code 0 (ABS_X) Value 3303 Min 0 Max 4095 Event code 1 (ABS_Y) Value 2584 Min 0 Max 4095 Event code 24 (ABS_PRESSURE) Value 62397 Min 0 Max 65535 Properties: Testing ... (interrupt to exit) Event: time 1726556440.417809, type 3 (EV_ABS), code 0 (ABS_X), value 3294 Event: time 1726556440.417809, type 3 (EV_ABS), code 1 (ABS_Y), value 2585 Event: time 1726556440.417809, type 3 (EV_ABS), code 24 (ABS_PRESSURE), value 64811 Event: time 1726556440.417809, -------------- SYN_REPORT ------------ Event: time 1726556440.477739, type 3 (EV_ABS), code 0 (ABS_X), value 3303 Event: time 1726556440.477739, type 3 (EV_ABS), code 1 (ABS_Y), value 2584 Event: time 1726556440.477739, type 3 (EV_ABS), code 24 (ABS_PRESSURE), value 63498 ... evtest shows a random stream of events, then stops... then lcd touches dont get reactions. I will check my wiring and order a new LCD, because mine has a cracked glass Is there any way to tell that the SPI, IRQ, CS inputs/outputs to the XPT2046 (ADS 7846) is working correctly, and blame everything on a bad resistive panel? 0 Quote Link to comment Share on other sites More sharing options...
robertoj Posted 19 hours ago Share Posted 19 hours ago When doing sudo evtest, I get random events. It may be related to https://forum.armbian.com/topic/15271-spi0-cs1-held-low-when-ads7846-is-loaded/ 0 Quote Link to comment Share on other sites More sharing options...
