David Markey Posted March 22, 2023 Posted March 22, 2023 Anyone have any success getting this module for new MediaTek WIFI 6 adapters? I've tried this backport of the mainline driver but get this compilation error. https://github.com/astsam/mt7921/issues/1 Anyone any ideas? 0 Quote
amazingfate Posted March 29, 2023 Posted March 29, 2023 You need to backport the driver of mt7921 from mainline to kernel 5.10. I've already made a patch: https://github.com/amazingfate/armbian-h68k-images/blob/master/backport-v6.0.16.patch 0 Quote
Darwin wu Posted July 11, 2023 Posted July 11, 2023 Hi @David Markeydid you have any lead for this driver? I have mediatek wifi 6 as well, and now i am struggling to find a way to make this work for my orangepi5 Also @amazingfate can you explain on how to use your backport patch? sorry for the newbie question 0 Quote
amazingfate Posted July 12, 2023 Posted July 12, 2023 @Darwin wuyou can download and install this kernel deb: https://github.com/amazingfate/armbian-h68k-images/releases/download/20230703-1113/linux-image-legacy-rk35xx_23.08.0-trunk--5.10.160-Se8c8-Df1ec-Pa9b2-C6e1cHfe66-HK01ba-Vc222-Be693_arm64.deb https://github.com/amazingfate/armbian-h68k-images/releases/download/20230703-1113/linux-dtb-legacy-rk35xx_23.08.0-trunk--5.10.160-Se8c8-Df1ec-Pa9b2-C6e1cHfe66-HK01ba-Vc222-Be693_arm64.deb 0 Quote
Darwin wu Posted July 13, 2023 Posted July 13, 2023 hi @amazingfate thanks for sharing your linux-image-kernel and dtb, I did try it, but it cant boot at all after install on my orangepi 5, i tried to flash your image in the repository as well, and face the same issue, it seems it is not compatible with orange pi 5, also i didnt mention, I use mediatek wifi 6 usb, so I need MT7921U enabled on kernel. did you perhaps have any idea on how to enable this modules? 0 Quote
amazingfate Posted July 14, 2023 Posted July 14, 2023 @Darwin wuusb wifi modules are not supported in my backported kernel. 0 Quote
