Adan Posted April 9, 2023 Author Share Posted April 9, 2023 I cannot flash the SD card with the latest ARMBIAN build image because the TV BOX wont recognize the SD card. Now Im using "Armbian_20.10_Arm-64_focal_current_5.9.0_desktop.img.xz" 0 Quote Link to comment Share on other sites More sharing options...
Adan Posted April 9, 2023 Author Share Posted April 9, 2023 I have another question. Maybe it the Kernel? My Kernel is 4.9.113 is because is an older kernel its incompatible? 0 Quote Link to comment Share on other sites More sharing options...
SteeMan Posted April 9, 2023 Share Posted April 9, 2023 59 minutes ago, Adan said: 128 GB SD card That could be the problem. These old boxes generally were designed in an era when 16 to 32GB was the common/max. I personally wouldn't use a 128GB card. 0 Quote Link to comment Share on other sites More sharing options...
Adan Posted April 9, 2023 Author Share Posted April 9, 2023 Nothing, I tried with a 64 GB SD Card and the result is; the TV box detects the storage, but it asks me to format it to use it. I tried with Balena Etcher and Rufus but the result is the same. I guess its not possible to install Armbian in a GIGA TV BOX 890 HD. Ill try another attempt with an 32 GB SD Card, but I think the TV BOX has some kind of anti software protection or something like that. 0 Quote Link to comment Share on other sites More sharing options...
Adan Posted April 10, 2023 Author Share Posted April 10, 2023 Tried with a 16 GB SD card, as I said before, It wont read the SD card. This only happens with any Armbian 23 build. Armbian 20 allows me to read the sd card but i get "Map file error" 0 Quote Link to comment Share on other sites More sharing options...
Adan Posted June 12, 2023 Author Share Posted June 12, 2023 @SteeMan Thank you so much for your help!! I finally succeded installing Armbian for my TV box. I just open ADB and used "shell" command Then I used "reboot update" and it started armbian. The only problem I have now is the resolution, everything seems too small because im using a TV instead of a monitor. Can I change the resolution? 0 Quote Link to comment Share on other sites More sharing options...
Adan Posted June 12, 2023 Author Share Posted June 12, 2023 (edited) Anyways *If you are reading this and have the same problem I had* Dont use the update application, use shell command in ADB And then, "reboot update" Edited June 12, 2023 by Adan 0 Quote Link to comment Share on other sites More sharing options...
Toan Tran Posted February 1 Share Posted February 1 Hi @Adan I got the same isssue like you. Could you please tell me which armian version you used successfull with adb boot? 0 Quote Link to comment Share on other sites More sharing options...
Adan Posted February 28 Author Share Posted February 28 @toan tran Just download ADB wifi apk from the Play Store. Download ADB debug tools and then open a command box and connect trough Wi-Fi adb. 0 Quote Link to comment Share on other sites More sharing options...
