Hi Everyone,
I'm trying to get audio out of my N2+ via SPDIF on the 7 pin header, or any gpio pin if necessary.
So far I have confined my SPDIF output works with the official Odroid MATE image, and also that I can get audio out via the 3.5mm jack on armbian after flowing this post .
I have tried to understand the amixer wizardry but no luck achieving anything so am a bit stuck as I would really like to use armbian over the Odroid image.
Thanks for any help!
aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: ODROIDN2 [ODROID-N2], device 0: fe.dai-link-0 (*) []
  Subdevices: 1/1
  Subdevice #0: subdevice #0
card 0: ODROIDN2 [ODROID-N2], device 1: fe.dai-link-1 (*) []
  Subdevices: 1/1
card 0: ODROIDN2 [ODROID-N2], device 2: fe.dai-link-2 (*) []
  Subdevices: 1/1
aplay -L
null
    Discard all samples (playback) or generate zero samples (capture)
samplerate
    Rate Converter Plugin Using Samplerate Library
speexrate
    Rate Converter Plugin Using Speex Resampler
jack
    JACK Audio Connection Kit
oss
    Open Sound System
pulse
    PulseAudio Sound Server
upmix
    Plugin for channel upmix (4,6,8)
vdownmix
    Plugin for channel downmix (stereo) with a simple spacialization
default
    Playback/recording through the PulseAudio sound server
sysdefault:CARD=ODROIDN2
    ODROID-N2,
    Default Audio Device
dmix:CARD=ODROIDN2,DEV=0
    ODROID-N2,
    Direct sample mixing device
dmix:CARD=ODROIDN2,DEV=1
    ODROID-N2,
dmix:CARD=ODROIDN2,DEV=2
    ODROID-N2,
dsnoop:CARD=ODROIDN2,DEV=0
    ODROID-N2,
    Direct sample snooping device
dsnoop:CARD=ODROIDN2,DEV=1
    ODROID-N2,
dsnoop:CARD=ODROIDN2,DEV=2
    ODROID-N2,
hw:CARD=ODROIDN2,DEV=0
    ODROID-N2,
    Direct hardware device without any conversions
hw:CARD=ODROIDN2,DEV=1
    ODROID-N2,
hw:CARD=ODROIDN2,DEV=2
    ODROID-N2,
plughw:CARD=ODROIDN2,DEV=0
    ODROID-N2,
    Hardware device with all software conversions
plughw:CARD=ODROIDN2,DEV=1
    ODROID-N2,
plughw:CARD=ODROIDN2,DEV=2
    ODROID-N2,
usbstream:CARD=ODROIDN2
    ODROID-N2
    USB Stream Output
