I tested the latest available Armbian image (minimal installation) on my odroid C2 via SD card.
have available an 16gb hardkernel emmc card on which I had ubuntu 20.04 installed and running.
But by burning the image with etcher (the same procedure as with the SD image) the odroid is unable to boot. Black screen, solid red led, and nothing else. I waited more than 30 seconds, I tried to disconnect keyboard....I waited more than 30 seconds, I tried to disconnect keyboard
I have repeated the procedure through the SD and it works correctly. When I do it through the emmc, the system does not boot. When I use the SD card, the Emmc card is obviously disconnected, and when I use the emmc, the sd card is disconnected.
I think u-boot has something to do with it
https://redirect.armbian.com/region/EU/odroidc2/Jammy_current_minimal
I apologize to the people mentioned above. I've read the forum a lot and thought they were the right people to respond to. @Igor
Edited by pirsen
Apologize
