The latest edge version fail to boot with Renegade board(RK3328)
DavidJS
I cloned the quite latest version of Armbian:
commit 369e69a55390f59c2299c98c09bf3d805ac59335 (HEAD -> main, origin/main, origin/HEAD)
Author: Ricardo Pardini <ricardo@pardini.net>
Date:   Mon Apr 3 13:15:54 2023 +0200
    artifact-armbian-bsp-cli: hash more variables included in `/etc/armbian-release`
Using the edge branch to compile for my renegade board, which has the rk3328 chip:
./compile.sh BOARD=renegade BRANCH=edge RELEASE=bullseye BUILD_MINIMAL=no BUILD_DESKTOP=no KERNEL_CONFIGURE=no COMPRESS_OUTPUTIMAGE=sha,img
It blocks when start to boot the kernel:
U-Boot 2022.07-armbian (Apr 17 2023 - 23:29:15 +0800)
Model: Firefly roc-rk3328-cc
DRAM:  1022 MiB
PMIC:  RK8050 (on=0x50, off=0x01)
Core:  227 devices, 23 uclasses, devicetree: separate
MMC:   mmc@ff500000: 1, mmc@ff520000: 0
Loading Environment from MMC... Card did not respond to voltage select! : -110
*** Warning - No block device, using default environment
In:    serial@ff130000
Out:   serial@ff130000
Err:   serial@ff130000
Net:   eth0: ethernet@ff540000
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:1...
3252 bytes read in 3 ms (1 MiB/s)
## Executing script at 00500000
Boot script loaded from mmc 0
117 bytes read in 2 ms (56.6 KiB/s)
20639437 bytes read in 468 ms (42.1 MiB/s)
29397504 bytes read in 666 ms (42.1 MiB/s)
63592 bytes read in 7 ms (8.7 MiB/s)
2698 bytes read in 6 ms (438.5 KiB/s)
Applying kernel provided DT fixup script (rockchip-fixup.scr)
## Executing script at 09000000
Unknown command 'kaslrseed' - try 'help'
Moving Image from 0x2080000 to 0x2200000, end=3ea0000
## Loading init Ramdisk from Legacy Image at 06000000 ...
   Image Name:   uInitrd
   Data Size:    20639373 Bytes = 19.7 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 01f00000
   Booting using the fdt blob at 0x1f00000
   Loading Ramdisk to 3cb6f000, end 3df1de8d ... OK
   Loading Device Tree to 000000003caf7000, end 000000003cb6efff ... OK
Starting kernel ...
efi_free_pool: illegal free 0x000000003cf20040
efi_free_pool: illegal free 0x000000003cf1d040
I don't know what happen, the boad is ok using the old version.
Link to comment
Share on other sites
Armbian & Khadas are rewarding contributors
