dee0987 Posted November 2, 2016 Share Posted November 2, 2016 I've tried to connect 5" TFT monitor to OPI with no luck.Cable pinout :T (Left audio)R (right audio)R (video)S (Ground) boot image: Armbian_5.20 scripr.bin section [boot_disp] advert_disp = 0 auto_hpd = 1 output_type = 4 hdmi_channel = 0 hdmi_mode = 4 cvbs_channel = 1 cvbs_mode = 11 output_full = 1 hdmi_mode_check = 1 [disp_init] disp_init_enable = 1 disp_mode = 0 screen0_output_type = 2 screen0_output_mode = 14 screen1_output_type = 2 screen1_output_mode = 14 fb0_format = 0 fb0_width = 0 fb0_height = 0 fb1_format = 0 fb1_width = 0 fb1_height = 0 [hdmi_para] hdmi_used = 1 hdmi_power = "vcc-hdmi-18" [tv_para] tv_used = 0 tv_dac_used = 1 tv_dac_src0 = 0 and i also triedscreen0_output_type = 2screen0_output_mode = 11 Link to comment Share on other sites More sharing options...
dee0987 Posted November 5, 2016 Author Share Posted November 5, 2016 On Android(Orange OS) updated:2016-05-18 image 5" TFT monitor works normally so it's not a hardware problem. P.S. zero replies Seriously no one has a clue about why it's not working on armbian ? Link to comment Share on other sites More sharing options...
tkaiser Posted November 5, 2016 Share Posted November 5, 2016 Seriously no one has a clue about why it's not working on armbian ? tv_used = 1 Link to comment Share on other sites More sharing options...
dee0987 Posted November 5, 2016 Author Share Posted November 5, 2016 tv_used = 1 Not working also. thx for reply! Link to comment Share on other sites More sharing options...
jernej Posted November 5, 2016 Share Posted November 5, 2016 [disp_init] disp_mode = 1 screen1_output_type = 2 screen1_output_mode = 11 [tv_para] tv_used = 1 Mode 11 means PAL and 14 means NTSC Link to comment Share on other sites More sharing options...
jernej Posted November 5, 2016 Share Posted November 5, 2016 BTW, OrangePi boards have inverted Left and Right audio channels. Link to comment Share on other sites More sharing options...
dee0987 Posted November 7, 2016 Author Share Posted November 7, 2016 [disp_init] disp_mode = 1 screen1_output_type = 2 screen1_output_mode = 11 [tv_para] tv_used = 1 Mode 11 means PAL and 14 means NTSC still not working Link to comment Share on other sites More sharing options...
jernej Posted November 7, 2016 Share Posted November 7, 2016 still not working Ahm, did you modprobe tv.ko? Be aware that tv out driver is compiled as a module. So you must at least add it to a list of modules to load at boot. I forgot which file that is. Link to comment Share on other sites More sharing options...
iwalpola Posted November 20, 2016 Share Posted November 20, 2016 I checked it too, and [disp_init] disp_mode = 1 screen1_output_type = 2 screen1_output_mode = 14 [tv_para] tv_used = 1 the resulting script.bin works with the Debian, Ubuntu mate and ubuntu core images provided by friendlyARM, but the same script.bin doesn't work with armbian.It may be because of a module not being loaded. Does anyone have more info on this "tv.ko" thing? I have no HDMI monitor so can't interact with a running instance of armbian. Link to comment Share on other sites More sharing options...
jernej Posted November 20, 2016 Share Posted November 20, 2016 You could also interact with serial console or recompile image for yourself with kernel config "CONFIG_TV_DISP2_SUNXI=y" Link to comment Share on other sites More sharing options...
Camilo Martin Posted January 8, 2017 Share Posted January 8, 2017 I know it's a relatively old post, but unless you dumbed up on the fex file or forgot to load the tv module, one likely problem is the cable plug. You see, these don't follow a very rigid standard (at least not always), and I've even seen TRRS cables where the pins would be slightly off the correct contacts when plugged all the way. Take some TRRS jack apart, put the pins on a breadboard, and see which ones are video and ground. Then test with these. Link to comment Share on other sites More sharing options...
dee0987 Posted January 8, 2017 Author Share Posted January 8, 2017 I know it's a relatively old post, but unless you dumbed up on the fex file or forgot to load the tv module, one likely problem is the cable plug. You see, these don't follow a very rigid standard (at least not always), and I've even seen TRRS cables where the pins would be slightly off the correct contacts when plugged all the way. Take some TRRS jack apart, put the pins on a breadboard, and see which ones are video and ground. Then test with these. On Android(Orange OS) updated:2016-05-18 image 5" TFT monitor works normally so it's not a hardware problem. Link to comment Share on other sites More sharing options...
iwalpola Posted February 5, 2017 Share Posted February 5, 2017 (Update) The problem was the tv module. Enabled by adding "tv" in a new line, to /etc/modules on the sd image file system. In Armbian 5.23, the tv module is loaded by default, and you only need to enable the tv in fex. Details can be found in this github repo I made. You want to look at the [disp_init] and [tv_para] in the nanopim1.fex.tvmod file Link to comment Share on other sites More sharing options...
