armbian-install needs some fine tuning, when booting from sd/emmc
Go to solution Solved by SteeMan,
Currently we get 'sduuid' in form of
[[ -z $sdblkid ]] && sdblkid=$(blkid -o full /dev/mmcblk*p1)
# 3 - Extract the UUID from $sdblkid via regex:
sduuid=$(echo "$sdblkid" | sed -nE 's/^.*[[:space:]]UUID="([0-9a-zA-Z-]*)".*/\1/p')
which outputs only UUID
78cdc7b8-0f2e-4444-ba7c-38aa26198de1
This is fine, as long as we use it correctly afterwards, but everytime we modifify fstab,
echo "${sduuid}	/media/mmcboot	ext4    ${mountopts[ext4]}" >> "${TempDir}"/rootfs/etc/fstab
echo "/media/mmcboot/boot  				/boot		none	bind								0       0" >> "${TempDir}"/rootfs/etc/fstab
which results in
# <file system>					<mount point>	<type>	<options>							<dump>	<pass>
tmpfs						/tmp		tmpfs	defaults,nosuid							0	0
78cdc7b8-0f2e-4444-ba7c-38aa26198de1	/media/mmcboot	ext4    defaults,noatime,commit=600,errors=remount-ro,x-gvfs-hide	0	1
UUID=52f9b8a6-b6ab-4e81-a362-5c4ca041d539	/		ext4	defaults,noatime,commit=600,errors=remount-ro,x-gvfs-hide	0	1
Missing "UUID=" and prevents booting correctly.
But we cannot simply change sduuid, because on other steps it is used correctly. Maybe make clear which variable has the form of "UUID=XXXXX-XXX-XXXX" in their name, for better understanding, like
sduuid for only UUID ("blabla-bla") and sdwuuid für "UUID=blabla-bla".
Or use the lazy mode with a check before we modify fstab and add "UUID" as simple string.
Example log
 cat /var/log/nand-sata-install.log
Sun May 14 11:31:23 PM CEST 2023: Start armbian-install.
Old UUID:  UUID=78cdc7b8-0f2e-4444-ba7c-38aa26198de1
SD UUID:   78cdc7b8-0f2e-4444-ba7c-38aa26198de1
SATA UUID: UUID=52f9b8a6-b6ab-4e81-a362-5c4ca041d539
eMMC UUID:
Boot: $1
Root: $2 /dev/nvme0n1p1 ext4
Usage: 4895
Dest: 44227
/etc/fstab:
UUID=78cdc7b8-0f2e-4444-ba7c-38aa26198de1 / ext4 defaults,noatime,commit=600,errors=remount-ro 0 1
/etc/mtab:
/dev/mmcblk1p1 / ext4 rw,noatime,errors=remount-ro,commit=600 0 0
/dev/mmcblk1p1 /var/log.hdd ext4 rw,noatime,errors=remount-ro,commit=600 0 0
/dev/nvme0n1p1 /mnt/armbian-install.CyDgPN/rootfs ext4 rw,relatime,stripe=32 0 0
/dev/zram1 /var/log ext4 rw,relatime,discard 0 0
Files currently open for writing:
packageki 2313            root   10u   REG  179,1    32768 135722 /var/lib/PackageKit/transactions.db
colord    2634          colord    5u   REG  179,1    16384 135743 /var/lib/colord/mapping.db
colord    2634          colord    6u   REG  179,1    28672 135744 /var/lib/colord/storage.db
colord    2634          colord    7u   REG  179,1    28672 135744 /var/lib/colord/storage.db
pulseaudi 3063            rock   10u   REG  179,1    12288 259682 /home/rock/.config/pulse/9e37a4772d8740b5bb96b8e39212a59e-device-volumes.tdb
pulseaudi 3063            rock   11u   REG  179,1    16384 259683 /home/rock/.config/pulse/9e37a4772d8740b5bb96b8e39212a59e-stream-volumes.tdb
pulseaudi 3063            rock   12u   REG  179,1    12288 259684 /home/rock/.config/pulse/9e37a4772d8740b5bb96b8e39212a59e-card-database.tdb
evolution 3600            rock   12u   REG  179,1    86016 259771 /home/rock/.local/share/evolution/addressbook/system/contacts.db
tracker-m 3937            rock    9ur  REG  179,1  2809856 259696 /home/rock/.cache/tracker3/files/meta.db
tracker-m 3937            rock   10u   REG  179,1    41112 266876 /home/rock/.cache/tracker3/files/meta.db-wal
tracker-m 3937            rock   11ur  REG  179,1    32768 266877 /home/rock/.cache/tracker3/files/meta.db-shm
tracker-m 3937            rock   13ur  REG  179,1  1294336 259709 /home/rock/.cache/tracker3/files/http%3A%2F%2Ftracker.api.gnome.org%2Fontology%2Fv3%2Ftracker%23Documents.db
tracker-m 3937            rock   14u   REG  179,1    98912 259981 /home/rock/.cache/tracker3/files/http%3A%2F%2Ftracker.api.gnome.org%2Fontology%2Fv3%2Ftracker%23Documents.db-wal
tracker-m 3937            rock   15ur  REG  179,1    32768 266879 /home/rock/.cache/tracker3/files/http%3A%2F%2Ftracker.api.gnome.org%2Fontology%2Fv3%2Ftracker%23Documents.db-shm
tracker-m 3937            rock   16ur  REG  179,1  1425408 259706 /home/rock/.cache/tracker3/files/http%3A%2F%2Ftracker.api.gnome.org%2Fontology%2Fv3%2Ftracker%23Software.db
tracker-m 3937            rock   17u   REG  179,1   280192 266880 /home/rock/.cache/tracker3/files/http%3A%2F%2Ftracker.api.gnome.org%2Fontology%2Fv3%2Ftracker%23Software.db-wal
tracker-m 3937            rock   18ur  REG  179,1    32768 266881 /home/rock/.cache/tracker3/files/http%3A%2F%2Ftracker.api.gnome.org%2Fontology%2Fv3%2Ftracker%23Software.db-shm
tracker-m 3937            rock   19ur  REG  179,1  1294336 259712 /home/rock/.cache/tracker3/files/http%3A%2F%2Ftracker.api.gnome.org%2Fontology%2Fv3%2Ftracker%23Pictures.db
tracker-m 3937            rock   20u   REG  179,1    98912 266882 /home/rock/.cache/tracker3/files/http%3A%2F%2Ftracker.api.gnome.org%2Fontology%2Fv3%2Ftracker%23Pictures.db-wal
tracker-m 3937            rock   21ur  REG  179,1    32768 266883 /home/rock/.cache/tracker3/files/http%3A%2F%2Ftracker.api.gnome.org%2Fontology%2Fv3%2Ftracker%23Pictures.db-shm
tracker-m 3937            rock   22ur  REG  179,1  1294336 259715 /home/rock/.cache/tracker3/files/http%3A%2F%2Ftracker.api.gnome.org%2Fontology%2Fv3%2Ftracker%23Audio.db
tracker-m 3937            rock   23u   REG  179,1    98912 266885 /home/rock/.cache/tracker3/files/http%3A%2F%2Ftracker.api.gnome.org%2Fontology%2Fv3%2Ftracker%23Audio.db-wal
tracker-m 3937            rock   24ur  REG  179,1    32768 266886 /home/rock/.cache/tracker3/files/http%3A%2F%2Ftracker.api.gnome.org%2Fontology%2Fv3%2Ftracker%23Audio.db-shm
tracker-m 3937            rock   25ur  REG  179,1  1372160 259701 /home/rock/.cache/tracker3/files/http%3A%2F%2Ftracker.api.gnome.org%2Fontology%2Fv3%2Ftracker%23FileSystem.db
tracker-m 3937            rock   26u   REG  179,1   189552 266887 /home/rock/.cache/tracker3/files/http%3A%2F%2Ftracker.api.gnome.org%2Fontology%2Fv3%2Ftracker%23FileSystem.db-wal
tracker-m 3937            rock   27ur  REG  179,1    32768 266888 /home/rock/.cache/tracker3/files/http%3A%2F%2Ftracker.api.gnome.org%2Fontology%2Fv3%2Ftracker%23FileSystem.db-shm
tracker-m 3937            rock   28ur  REG  179,1  1294336 259718 /home/rock/.cache/tracker3/files/http%3A%2F%2Ftracker.api.gnome.org%2Fontology%2Fv3%2Ftracker%23Video.db
tracker-m 3937            rock   29u   REG  179,1    98912 266889 /home/rock/.cache/tracker3/files/http%3A%2F%2Ftracker.api.gnome.org%2Fontology%2Fv3%2Ftracker%23Video.db-wal
tracker-m 3937            rock   30ur  REG  179,1    32768 266890 /home/rock/.cache/tracker3/files/http%3A%2F%2Ftracker.api.gnome.org%2Fontology%2Fv3%2Ftracker%23Video.db-shm
gvfsd-met 3984            rock    9u   REG  179,1    32768 259692 /home/rock/.local/share/gvfs-metadata/root-ee3d16b7.log
Trying to stop running services to minimize open files:
Stopping cron.service
Checking again for open files:
Copying 149044 files to /dev/nvme0n1p1. Finishing transfer to disk, boot from SD/eMMC
Sun May 14 11:34:21 PM CEST 2023: Finished
Okay, somehow i got lost between the repos, next-gen and 150balbes (.
Thanks, let's find out out where I went wrong and what else I might pulled 🙂
