ARMBIAN 5.41 user-built Debian GNU/Linux 9 (stretch) 4.14.34-sunxi, Orange Pi Zero board. Very limited Debian installed, wifi doesn't work. I found lines install xradio_wlan /bin/false install 8189es /bin/false in /etc/modprobe.d/blacklist.conf and removed it. In /etc/modules-load.d/modules.conf I added the lines 8189es xradio_wlan. No help, wi-fi didn't work, nothing about xradio or wifi in dmesg. I figured out that there was no drivers (modules) for wifi. Found this article https://linux-sunxi.org/Wifi
I execute the commands from the article, section
RTL8189ES / RTL8189ETV
The driver has its own repository:
git clone https://github.com/jwrdegoede/rtl8189ES_linux.git
cd rtl8189ES_linux
make -j4 ARCH=arm CROSS_COMPILE=arm-linux-gnu- KSRC=../linux
This is what it says
root@its-02-o:~# git clone https://github.com/jwrdegoede/rtl8189ES_linux.git
Cloning into 'rtl8189ES_linux'...
remote: Enumerating objects: 2565, done.
remote: Counting objects: 100% (807/807), done.
remote: Compressing objects: 100% (413/413), done.
remote: Total 2565 (delta 432), reused 670 (delta 385), pack-reused 1758.
Receiving objects: 100% (2565/2565), 7.29 MiB | 2.32 MiB/s, done.
Resolving deltas: 100% (1476/1476), done.
root@its-02-o:~# cd rtl8189ES_linux
root@its-02-o:~/rtl8189ES_linux# make -j4 ARCH=arm CROSS_COMPILE=arm-linux-gnu- KSRC=../linux
make ARCH=arm CROSS_COMPILE=arm-linux-gnu- -C ../linux M=/root/rtl8189ES_linux modules
make[1]: *** ../linux: No such file or directory.  Stop.
Makefile:2292: recipe for target 'modules' failed
make: *** [modules] Error 2
What am I doing wrong? How do I install WiFi modules (drivers)?
And the following is in the dmesg
vcc-wifi: disabling
What is this wifi power disabling? How do I turn it on? Googling didn't help, I couldn't find anything clear about vcc-wifi: disabling
Don't suggest installing a new/other Debian. Important software works on it (everything works over LAN), you just need to enable wi-fi.
Translated with www.DeepL.com/Translator (free version)
ARMBIAN 5.41 user-built Debian GNU/Linux 9 (stretch) 4.14.34-sunxi, плата Orange Pi Zero. Очень какой-то урезаный Debian установлен, не работает Wi-Fi. Нашел в файле /etc/modprobe.d/blacklist.conf строки install xradio_wlan /bin/false install 8189es /bin/false, удалил. В файле /etc/modules-load.d/modules.conf добавил строки 8189es xradio_wlan. Не помогло, wi-fi не заработал, в dmesg ничего про  xradio или wifi нет. Понял что нет драйверов (модулей) Wi-Fi. Нашел такую статью https://linux-sunxi.org/Wifi
Выполняю комманды из статьи, раздел
Driver has its own repository:
cd rtl8189ES_linux
Вот что пишет
Что не так делаю? Как установить модули (драйвера) WiFi?
А вот такое в dmesg есть
vcc-wifi: disabling
Что это питание wifi отключено? Как включить? Гугление не помогло, не нашел ничего внятного про vcc-wifi: disabling
Не предлагайте установить новый/другой Debian. На нем работает работает важный софт (по LAN все работает), нужно просто включить wi-fi.
Если можно на русском. Английский только с переводчиком :-(
