I've a tv box marked MXQ PRO 4K quick play (S905 soc).
toothpick recovery no longer works after installing not correct android rom
Anyway I installed Armbian choosing random zip file in "update" app in android.
Armbian works ok, but if I remove sd card android stays forewer in boot splash screen.
Also I tried flash chip short, worked once, but now I can't repeat (is quite dangerous shortin random pins, no documentation for this board)
Is it possible to trigger "reboot update" from armbian? Or to start recovery from Armbian.
I have android IMG with dtg.img and recovery.img if needed-
Thanks for help
Have you tried using the amlogic usb_burning_tool (that is the common way to install/restore amlogic firmware)?  Note you will need a usb-a to usb-a cable to do this.
