Sargador Posted May 24, 2023 Posted May 24, 2023 Hello. Is it possible to enable OV13855 camera on OPi5 with the latest armbian image? If yes, how do it? Thanks! 0 Quote
Efe Çetin Posted June 2, 2023 Posted June 2, 2023 @Sargador drivers seem to be enabled on kernel. can you try this overlays to enable cams? https://github.com/orangepi-xunlong/linux-orangepi/tree/orange-pi-5.10-rk3588/arch/arm64/boot/dts/rockchip/overlay You can download needed overlay and enable it using armbian-add-overlay 0 Quote
Sargador Posted June 4, 2023 Author Posted June 4, 2023 (edited) Hi, thanks for the response, I was able to use armbian-add-overlay. Now i will follow the guide from Orange Pi and will report back later Thanks! Edited June 4, 2023 by Sargador 0 Quote
Sargador Posted June 5, 2023 Author Posted June 5, 2023 I was able to get the image but it was too dark compared with the one using Orange Pi Ubuntu OS. I will try to figure out the reason for this. 0 Quote
Roman Aliev Posted June 6, 2025 Posted June 6, 2025 Did you figured out what is the reason for this problem with dark pictures? 0 Quote
