NanoPi NEO3 on ARMbian 23.02.2 not using physical MAC address
TonyB.ca
Greetings,
I have multiple NanoPi NEO3s on the same subnet. When booting with Ubuntu 20.04.6 LTS they use the physical MAC address when posting to DHCP, but ARMbian seems to create a default (fake) MAC address and uses that instead. Judging by the "armbianmonitor -U" output, ARMbian knows about the physical MAC address, it just doesn't use it. The NEO3 board is listed as supported, but there is another posting dated 2020 that still seems to be unresolved.
MAC address c2:1f:b3:b0:d2:41 seems to be a generic (fake) address that is being used.
Is there a remedy to allow it to use the actual hardware address with this kernel ?
bracka@NanoPi-neo3:~$ hostnamectl
   Static hostname: NanoPi-neo3
         Icon name: computer
        Machine ID: 7a8f8d11a2be4919bc15a3b60d4bb717
           Boot ID: af467481c9054525b978b6a316e61c94
  Operating System: Debian GNU/Linux 11 (bullseye)
            Kernel: Linux 6.1.11-rockchip64
      Architecture: arm64
bracka@NanoPi-neo3:~$ sudo ifconfig eth0
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.1.196  netmask 255.255.255.0  broadcast 192.168.1.255
        inet6 fe80::6cf0:52e7:7e44:23f8  prefixlen 64  scopeid 0x20<link>
        ether c2:1f:b3:b0:d2:41  txqueuelen 1000  (Ethernet)
        RX packets 1032591  bytes 1165880161 (1.0 GiB)
        RX errors 0  dropped 471  overruns 0  frame 0
        TX packets 303323  bytes 43670515 (41.6 MiB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
        device interrupt 51
$ armbianmonitor -U
     8  Thu 25 May 2023 09:48:33 PM UTC | NanoPi Neo 3 | 23.02.2 | arm64 | aarch64 | 6.1.11-rockchip64
   730  ### ip addr:
   731
   732  1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
   733      link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
   734      inet XXX.XXX.0.1/8 scope host lo
   735         valid_lft forever preferred_lft forever
   736      inet6 ::1/128 scope host
   737         valid_lft forever preferred_lft forever
   738  2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
   739      link/ether 9a:84:df:28:e1:3e brd ff:ff:ff:ff:ff:ff
  1316  ### armbian-release:
  1317
  1318  # PLEASE DO NOT EDIT THIS FILE
  1319  BOARD=nanopineo3
  1320  BOARD_NAME="NanoPi Neo 3"
  1321  BOARDFAMILY=rockchip64
  1322  BUILD_REPOSITORY_URL=https://github.com/armbian/build
  1323  BUILD_REPOSITORY_COMMIT=1a8daf0
  1324  VERSION=23.02.2
  1325  LINUXFAMILY=rockchip64
  1326  ARCH=arm64
  1327  IMAGE_TYPE=stable
  1328  BOARD_TYPE=conf
  1329  INITRD_ARCH=arm64
  1330  KERNEL_IMAGE_TYPE=stable
  1331  BRANCH=edge
  1525  ### ip addr:
  1526
  1527  1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
  1528      link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
  1529      inet XXX.XXX.0.1/8 scope host lo
  1530         valid_lft forever preferred_lft forever
  1531      inet6 ::1/128 scope host
  1532         valid_lft forever preferred_lft forever
  1533  2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
  1534      link/ether c2:1f:b3:b0:d2:41 brd ff:ff:ff:ff:ff:ff
* I am willing to research this if somebody can provide build & submission guidelines.
Edited by TonyB.ca
grammar fixes
Link to comment
Share on other sites
Further comment:
I built the latest "bookworm/edge" image and it has the same problem. Can anybody point me at which modules set this or give me ideas as to how to locate it and I'll try my hand at correcting it? (... or try finding what Ubuntu did to fix it)
bracka@nanopi-neo3:~$ hostnamectl
 Static hostname: nanopi-neo3
       Icon name: computer
      Machine ID: e0dd9ba08bec458e97d14aa2a8797a5e
         Boot ID: 04b5eb118e9b4fb8a876b4ed81342106
Operating System: Armbian 23.08.0-trunk bookworm
          Kernel: Linux 6.3.4-rockchip64
    Architecture: arm64
bracka@nanopi-neo3:~$ sudo ifconfig -a
end0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet6 fe80::dc32:47a9:6da5:4074  prefixlen 64  scopeid 0x20<link>
        RX packets 645931  bytes 759294079 (724.1 MiB)
        RX errors 0  dropped 148  overruns 0  frame 0
        TX packets 144665  bytes 89492195 (85.3 MiB)
        device interrupt 51
I have also built the latest "jammy" release and it has the same issue:
Welcome to Armbian 23.02.2 Jammy with bleeding edge Linux 6.1.11-rockchip64
       Icon name: computer
      Machine ID: 419c0895553e4efe9795e6f0899a794e
         Boot ID: 89aff8b2899c43d0aa16b0c245556b4d
Operating System: Ubuntu 22.04.2 LTS
    Architecture: arm64
bracka@nanopi-neo3:~$ ifconfig -a
        inet6 fe80::350b:a860:b0a1:80b9  prefixlen 64  scopeid 0x20<link>
        RX packets 109  bytes 11465 (11.4 KB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 91  bytes 11480 (11.4 KB)
        device interrupt 51
So far, this release from the "Friendly" site does pick up the hardware MAC and use it.
Welcome to Ubuntu 20.04.6 LTS (GNU/Linux 5.15.78 aarch64)
bracka@NanoPi-NEO3-2:~$ hostnamectl
   Static hostname: NanoPi-NEO3-2
         Icon name: computer
        Machine ID: 493a472b58ef4baeaa0a4962766bd9a6
           Boot ID: cf237517e7ad4aa7a89a18a30972b560
  Operating System: Ubuntu 20.04.6 LTS
            Kernel: Linux 5.15.78
      Architecture: arm64
bracka@NanoPi-NEO3-2:~$ ifconfig -a
        inet 192.168.1.197  netmask 255.255.255.0  broadcast 192.168.1.255
        inet6 fe80::8234:28ff:fe79:2031  prefixlen 64  scopeid 0x20<link>
        ether 80:34:28:79:20:31  txqueuelen 1000  (Ethernet)
        RX packets 1137985  bytes 1275043076 (1.2 GB)
        TX packets 118723  bytes 22628010 (22.6 MB)
        device interrupt 37
Regards,
Tony
Edited by TonyB.ca
added a few more builds/tests
Link to comment
Hi @TonyB.ca, I have another NanoPi Neo3 and I'm experiencing the same you are, I wonder what could be happening.
Right now, I have a stable build on Jammy, but I have another microSD with which I'm making tests to try to see how come the actual MAC from the device isn't picked up. Just now I finished building a current Bookworm based Armbian, but with u-boot being that of 2023.04 instead, same outcome. I know the board was released with u-boot 2017.sth, but I thought, what the hell, perhaps it's a bug in the 2022 versions.
In any case, I'm at a loss, I'll try to find other boards that ship with real MACs and see if there's any difference on how they're defined in configuration files or kernel builds. For example, the NanoPi R4S used to ship with a unique MAC, but due to shortage of parts or something they can't guarantee that now unless you place a considerable order; that doesn't happen with the Neo3, even if ordered just one they do come with a unique address.
If anyone comes across this thread and knows at least where we should look into, we'd appreciate it! I'm new to this kind of low level stuff.
Link to comment
Hi KaoDome,
I downloaded the minimal release from FriendlyElec and it picks up the physical MAC address just fine. I have built a few minimal release images, but have not had a chance yet to test them out since some morons hacked by test lab and decided to encrypt/ransom my NAS and a bunch of dev VMware servers. So much for easy passwords in a test lab (lesson learned) ... no big deal as all the data is either trash or replaceable, and it was due for a redesign anyway.
The FriendlyElec build is older, but uses the correct MAC address. I will post details once my network is fully back on line. If you look at my post, I explain what I am seeing. If we can determine where to look, I am certain that the change is obvious as these are both Debian/Ubuntu releases.
Link to comment
I am allright with you and i find my MAC Address here
sudo i2cdump 0 0x51
i have a Neo3 with i2c eeprom and the mac is writing inside
and when i go to
/etc/NetworkManager/system-connections# sudo nano Wired\ connection\ 1.nmconnection
i can see that the MAC is fixed
How can we patch this problem?
Link to comment
Hi All,
Again, the running operating system even reports back the physical MAC address. Something is overriding it, but finding out what and where is the challenge. My guess is that it is common code that is shared with the NEOs and possibly NEO2s which do not have a hard MAC address. These are line numbers from the same output. The FriendlyElec build of the same kernel does not have this problem.
Maybe we need to look into armbianmonitor to find out the difference between the 2 sections of output as a potential starting point? This is a single output produced by running this program, and seems to be reporting the same interface, so SOMETHING already knows the physical MAC address.
From my initial post:
$ armbianmonitor -U
   730  ### ip addr:
   731
  1525  ### ip addr:
  1526
Link to comment
si it can help you for a nanopi neo3
you can write a script like
sudo nano extract_mac.sh
#!/bin/bash
# Extraire l'adresse MAC de l'EEPROM
mac_address=""
mac_address+="$(sudo i2cget -y -f 0 0x51 0xfa c):$(sudo i2cget -y -f 0 0x51 0xfb c)"
mac_address+=:"$(sudo i2cget -y -f 0 0x51 0xfc c):$(sudo i2cget -y -f 0 0x51 0xfd c)"
mac_address+=:"$(sudo i2cget -y -f 0 0x51 0xfe c):$(sudo i2cget -y -f 0 0x51 0xff c)"
# Supprimer les préfixes "0x"
mac_address="${mac_address//0x/}"
mac_address=$(echo $mac_address | tr '[:lower:]' '[:upper:]')
echo "MAC address: $mac_address"
# Extraire l'adresse MAC du fichier de configuration NetworkManager
configured_mac_address="$(sudo grep "mac-address=" /etc/NetworkManager/system-connections/Wired\ connection\ 1.nmconnection | cut -d "=" -f 2)"
# configured_mac_address="${configured_mac_address//:/}"
echo "configured mac address: $configured_mac_address"
# Comparer les adresses MAC
if [[ "$mac_address" != "$configured_mac_address" ]]; then
  echo "Les adresses MAC sont différentes. Mise à jour nécessaire."
  # Mettre à jour le fichier de configuration NetworkManager avec la nouvelle adresse MAC
  sudo sed -i "s/mac-address=.*/mac-address=$mac_address/" /etc/NetworkManager/system-connections/Wired\ connection\ 1.nmconnection
  # Redémarrer NetworkManager pour prendre en compte les modifications
  sudo service NetworkManager restart
  echo "Adresse MAC mise à jour et redémarrage du systeme."
  # Redémarrer complètement le système pour prendre en compte les modifications
  sudo reboot
else
  echo "Les adresses MAC sont identiques."
fi
 and
sudo chmod +x extract_mac.sh
and to start script
./extract_mac.sh
it's working well for me
best regards
Link to comment
Greetings All,
If I run one of the Friendly distributions, they use the correct (physical) MAC address. My 3 are as follows:
80:34:28:79:4e:5c
80:34:28:79:2e:07
80:34:28:79:20:31
From this we can tell that FriendlyElec uses "80:34:28" as their vendor code. The remaining 3 digits compose the individual NIC address. Thanks for providing the script to work around the issue. It does what it needs to do, but it still raises the question as to why this is necessary. The FriendlyElec build does not require that we do this, so it would be great to have a base code fix. At some point I will try simply deleting the directory containing the script to see what happens ( - unless somebody else gets there first🙂 - ). For now, this script does what is needed ...
bracka@NanoPi-NEO3b:/etc/NetworkManager/system-connections$ hostnamectl
   Static hostname: NanoPi-NEO3b
         Icon name: computer
        Machine ID: f86b967515a04b7aa4ee086b7ee8f50b
           Boot ID: 7d724c0ff2a544f7959641728cacfe16
      Architecture: arm64
bracka@NanoPi-NEO3b:/etc/NetworkManager/system-connections$ ls -al
total 8
drwxr-xr-x 2 root root 4096 Nov 26  2021 .
drwxr-xr-x 7 root root 4096 Jun 13 20:55 ..
Regards & Thank You,
Tony
Link to comment
You forgot something that i test, you can launch it directly.
You just need to add this in the repository /etc/rc.local before the line "exit 0"
/bin/bash /etc/init.d/extract_mac.sh
If you do this, the script will launch automatically if the MAC didn't correspond, and if they correspond then he will don't reboot so you don't have to launch it manually if you had these line.
Link to comment
so on the last revision i use another methode
Create file in /etc/systemd/network
sudo nano 99-default.link
[Match]
OriginalName=*
[Link]
NamePolicy=
Name=end0
MACAddressPolicy=none
MACAddress=00:42:c4:9e:de:90
 and reboot
so the script change as
#!/bin/bash
mac_address=""
configured_mac_address="$(sudo grep "MACAddress=" /etc/systemd/network/99-default.link | cut -d "=" -f 2)"
  sudo sed -i "s/MACAddress=.*/MACAddress=$mac_address/" /etc/systemd/network/99-default.link
  #sudo reboot
else
fi
Edited by Kazymir
add informations
Link to comment
step by step
I am on Arbian 23.8.1 BookWorm linux 6.1.50 on my nanopi neo3
Create file with sudo nano /etc/systemd/network/99-default.link
[Match]
OriginalName=*
[Link]
NamePolicy=
Name=end0
i know it' a fake mac address for the start
if you write
sudo i2cdump 0 0x51
you have your real mac address
so we need to write a script
sudo nano /etc/init.d/extract_mac.sh
#!/bin/bash
# Extract MACAdress from i2c EEPROM
mac_address=""
# remove "0x"
  echo "WRONG Mac Address, rewrite good one"
  echo "MAC Adress allright. Reboot"
  sudo reboot
else
  echo "Mac Adress is already OK"
fi
If you want to test
go in folder cd /etc/init.d
./extract_mac.sh
to run automatic at boot
open rc.local : sudo nano /etc/rc.local
inside add
before "exit 0"
and reboot
the good mac adress will be writting and use
Link to comment
