Orange PI5 - WiringOP - Interrupt NOT WORKING, How can it be activated ?
elsabz
Hello Armbian forum, I need to have a GPIO interrupt on Orange PI5. I have successfully installed WiringOP and I am using it with C code. The problem is that the interrupt is not working, and I am receiving the following error. How can I proceed? Does anyone know how to enable the WiringOP interrupt on the GPIO PIN?
Code C :
#define AUX 13
wiringPiISR(AUX, INT_EDGE_FALLING, &MyFunction);
Error:
wiringPiISR: unable to open /sys/class/gpio/gpio92/value: No such file or directory
PS. I have just successfully installed this version: Armbian 23.02 Jammy Gnome
Edited by elsabz
Link to comment
Share on other sites
Hi @royk thanks for the answer, I had already looked in the library but I can't find anything different from the code I use, if you look at the isr.c example the call is the same as the one I use, except for the number of PINs that goes from 0 to 7, I tried to put PIN 0 but nothing changes, always the same error.
Link to comment
