Hi igor
Can you build and add libcsptr to your repo?
https://github.com/Snaipe/libcsptr )
it is required by libvdpau.
i tried to build it via the build environment but it doesn't work ;-) :-(
vdr_sunxi-vdpau (){
	git clone https://github.com/Snaipe/libcsptr.git $DEST/cache/sdcard/usr/local/src/libcsptr
	chroot $DEST/cache/sdcard /bin/bash -c "cd /usr/local/src/libcsptr && mkdir build && cd build && cmake -DCMAKE_INSTALL_PREFIX=/usr/local .. && make && make install"
	chroot $DEST/cache/sdcard /bin/bash -c "cd /usr/local/src/libcsptr && make"
	chroot $DEST/cache/sdcard /bin/bash -c "cd /usr/local/src/libcsptr && make install"
	echo -e "[\e[0;34m git cloning \x1B[0m] libvdpau-sunxi ..."
	git clone -b staging https://github.com/rellla/libvdpau-sunxi.git $DEST/cache/sdcard/usr/local/src/libvdpau-sunxi
	echo -e "[\e[0;32m finished \x1B[0m]  cloning libvdpausunxi ..."
  	chroot $DEST/cache/sdcard /bin/bash -c "cd /usr/local/src/libvdpau-sunxi && make clean && make $CTHREADS ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- && make install"
  	#	export Variable
  	echo "export VDPAU_DRIVER=sunxi" >> $DEST/cache/sdcard/etc/profile
greeting
daniel
I don't quite understand.
What is not working? You can build it native but fails within chroot?
Now it work i forgot to install gcc :facepalm
[ ok ] Installing xf86 fbturbo driver ...
[ ok ] copy the pakage ...
Selecting previously unselected package libump:armhf.
(Reading database ... 43843 files and directories currently installed.)
Preparing to unpack /libump_3.0-0sunxi1-armhf.deb ...
Unpacking libump:armhf (3.0-0sunxi1~koodur1) ...
Setting up libump:armhf (3.0-0sunxi1~koodur1) ...
Selecting previously unselected package libump-dev.
(Reading database ... 43849 files and directories currently installed.)
Preparing to unpack .../libump-dev_3.0-0sunxi1-armhf.deb ...
Unpacking libump-dev (3.0-0sunxi1~koodur1) ...
Setting up libump-dev (3.0-0sunxi1~koodur1) ...
Selecting previously unselected package xf86-video-fbturbo.
(Reading database ... 43859 files and directories currently installed.)
Preparing to unpack /xf86-video-fbturbo-armhf.deb ...
Unpacking xf86-video-fbturbo (0.4.0-1~koodur2) ...
Setting up xf86-video-fbturbo (0.4.0-1~koodur2) ...
Processing triggers for man-db (2.7.0.2-5) ...
[ ok ] installing the package ...
[ ok ] Linking libxcb-xv for vdr-plugin-softhd-device ...
[ failed ] lib's not found
Klone nach '/home/build/Schreibtisch/vdrtest/output/cache/sdcard/usr/local/src/libcsptr'...
remote: Counting objects: 595, done.
remote: Total 595 (delta 0), reused 0 (delta 0), pack-reused 595
Empfange Objekte: 100% (595/595), 99.59 KiB | 0 bytes/s, Fertig.
Löse Unterschiede auf: 100% (341/341), Fertig.
Prüfe Konnektivität... Fertig.
-- The C compiler identification is GNU 4.9.2
-- Check for working C compiler: /usr/bin/cc
-- Check for working C compiler: /usr/bin/cc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Found PkgConfig: /usr/bin/pkg-config (found version "0.28")
-- checking for one of the modules 'check'
-- Configuring done
-- Generating done
-- Build files have been written to: /usr/local/src/libcsptr/build
Scanning dependencies of target csptr
[100%] Building C object CMakeFiles/csptr.dir/src/mman.c.o
Linking C static library libcsptr.a
[100%] Built target csptr
Install the project...
-- Install configuration: ""
-- Installing: /usr/local/include/csptr/config.h
-- Installing: /usr/local/include/csptr/smalloc.h
-- Installing: /usr/local/include/csptr/array.h
-- Installing: /usr/local/include/csptr/smart_ptr.h
-- Installing: /usr/local/share/man/man3/csptr.3
-- Installing: /usr/local/lib/libcsptr.a
[ git cloning ] libvdpau-sunxi ...
Klone nach '/home/build/Schreibtisch/vdrtest/output/cache/sdcard/usr/local/src/libvdpau-sunxi'...
remote: Counting objects: 1074, done.
remote: Total 1074 (delta 0), reused 0 (delta 0), pack-reused 1074
Empfange Objekte: 100% (1074/1074), 393.55 KiB | 222.00 KiB/s, Fertig.
Löse Unterschiede auf: 100% (746/746), Fertig.
[ finished ]  cloning libvdpausunxi ...
Package vdpau was not found in the pkg-config search path.
Perhaps you should add the directory containing `vdpau.pc'
to the PKG_CONFIG_PATH environment variable
No package 'vdpau' found
rm -f device.o presentation_queue.o surface_output.o surface_video.o surface_bitmap.o video_mixer.o decoder.o handles.o queue.o ve.o h264.o mpeg12.o mpeg4.o rgba.o tiled_yuv.o
rm -f device.d presentation_queue.d surface_output.d surface_video.d surface_bitmap.d video_mixer.d decoder.d handles.d queue.d ve.d h264.d mpeg12.d mpeg4.d rgba.d tiled_yuv.d
rm -f libvdpau_sunxi.so.1
cc -MD -MP -MQ device.o -fpic -fvisibility=hidden -Wall -O3 -std=gnu99 -c device.c -o device.o
cc -MD -MP -MQ presentation_queue.o -fpic -fvisibility=hidden -Wall -O3 -std=gnu99 -c presentation_queue.c -o presentation_queue.o
cc -MD -MP -MQ surface_output.o -fpic -fvisibility=hidden -Wall -O3 -std=gnu99 -c surface_output.c -o surface_output.o
cc -MD -MP -MQ surface_video.o -fpic -fvisibility=hidden -Wall -O3 -std=gnu99 -c surface_video.c -o surface_video.o
cc -MD -MP -MQ surface_bitmap.o -fpic -fvisibility=hidden -Wall -O3 -std=gnu99 -c surface_bitmap.c -o surface_bitmap.o
cc -MD -MP -MQ video_mixer.o -fpic -fvisibility=hidden -Wall -O3 -std=gnu99 -c video_mixer.c -o video_mixer.o
cc -MD -MP -MQ decoder.o -fpic -fvisibility=hidden -Wall -O3 -std=gnu99 -c decoder.c -o decoder.o
cc -MD -MP -MQ handles.o -fpic -fvisibility=hidden -Wall -O3 -std=gnu99 -c handles.c -o handles.o
cc -MD -MP -MQ queue.o -fpic -fvisibility=hidden -Wall -O3 -std=gnu99 -c queue.c -o queue.o
cc -MD -MP -MQ ve.o -fpic -fvisibility=hidden -Wall -O3 -std=gnu99 -c ve.c -o ve.o
cc -MD -MP -MQ h264.o -fpic -fvisibility=hidden -Wall -O3 -std=gnu99 -c h264.c -o h264.o
cc -MD -MP -MQ mpeg12.o -fpic -fvisibility=hidden -Wall -O3 -std=gnu99 -c mpeg12.c -o mpeg12.o
In file included from vdpau_private.h:58:0,
                 from surface_output.c:20:
/usr/local/include/csptr/smart_ptr.h:29:21: fatal error: common.h: No such file or directory
 # include "common.h"
compilation terminated.
                 from presentation_queue.c:20:
                 from handles.c:23:
                 from surface_video.c:21:
                 from decoder.c:22:
                 from h264.c:23:
                 from surface_bitmap.c:20:
                 from device.c:23:
                 from mpeg12.c:21:
                 from ve.c:28:
                 from video_mixer.c:22:
Makefile:43: recipe for target 'surface_video.o' failed
make: *** [surface_video.o] Error 1
make: *** Waiting for unfinished jobs....
Makefile:43: recipe for target 'presentation_queue.o' failed
make: *** [presentation_queue.o] Error 1
Makefile:43: recipe for target 'surface_output.o' failed
make: *** [surface_output.o] Error 1
Makefile:43: recipe for target 'decoder.o' failed
make: *** [decoder.o] Error 1
Makefile:43: recipe for target 'handles.o' failed
make: *** [handles.o] Error 1
Makefile:43: recipe for target 'h264.o' failed
make: *** [h264.o] Error 1
Makefile:43: recipe for target 'mpeg12.o' failed
make: *** [mpeg12.o] Error 1
Makefile:43: recipe for target 'surface_bitmap.o' failed
make: *** [surface_bitmap.o] Error 1
Makefile:43: recipe for target 'device.o' failed
make: *** [device.o] Error 1
Makefile:43: recipe for target 've.o' failed
make: *** [ve.o] Error 1
Makefile:43: recipe for target 'video_mixer.o' failed
make: *** [video_mixer.o] Error 1
[ running ] Downloading VDR ...
[ finished ]  Downloading VDR ...
[ finished ]  unpacking VDR ...
[ finished ]  Link VDR Sources ...
[ finished ]  Cleaning VDR removing Plugins: dvbhddevice, dvbsddevice, hello, pictures, rcu, skincurses ...
[ o.k. ] Possible after install.
[ o.k. ] Writing boot loader [ /dev/loop0 ]
439+1 Datensätze ein
439+1 Datensätze aus
[ o.k. ] Shrink partition and image to real size [ 15 % free space ]
resize2fs 1.42.12 (29-Aug-2014)
1: unknown command
Re-reading the partition table failed.: Das Argument ist ungültig
[ ok ] Create and sign download ready ZIP archive
updating: Armbian_4.3_Cubieboard2_Debian_jessie_3.4.108.raw (deflated 68%)
updating: armbian.txt (deflated 62%)
updating: imagewriter.exe (deflated 36%)
[ o.k. ] Uploading to server [ Armbian_4.3_Cubieboard2_Debian_jessie_3.4.108.zip ]
[ ok ] Runtime 5 min
build with this code:
vdr_sunxi-vdpau (){
  	chroot $DEST/cache/sdcard /bin/bash -c "cd /usr/local/src/libvdpau-sunxi && make clean && make $CTHREADS && make install"
  	#	export Variable
something is still wrong but it is getting better ;-)
I am stuck here too:
                 from device.c:23:
I will try a older commit
root@cubieboard2:~/vdpau-devel/libvdpau-sunxi# git branch
* staging
root@cubieboard2:~/vdpau-devel/libvdpau-sunxi# git log
commit 80cda1eb12965d9230ca10fa32b9c0873cfde066
Author: rellla <ichgeh@imkreisrum.de>
Date:   Mon Aug 10 07:40:57 2015 -0400
    Add some logging.
    Change default logging level.
make clean
root@cubieboard2:~/vdpau-devel/libvdpau-sunxi# make -j2
h264.c: In function ‘ref_pic_list_modification’:
h264.c:263:19: warning: unused variable ‘long_term_pic_num’ [-Wunused-variable]
      unsigned int long_term_pic_num = get_ue(c->regs);
h264.c:281:19: warning: unused variable ‘abs_diff_pic_num_minus1’ [-Wunused-variable]
      unsigned int abs_diff_pic_num_minus1 = get_ue(c->regs);
h264.c:285:19: warning: unused variable ‘long_term_pic_num’ [-Wunused-variable]
cc -MD -MP -MQ mpeg4.o -fpic -fvisibility=hidden -Wall -O3 -std=gnu99 -c mpeg4.c -o mpeg4.o
cc -MD -MP -MQ rgba.o -fpic -fvisibility=hidden -Wall -O3 -std=gnu99 -c rgba.c -o rgba.o
cc -c tiled_yuv.S -o tiled_yuv.o
cc -shared -Wl,-soname,libvdpau_sunxi.so.1  device.o presentation_queue.o surface_output.o surface_video.o surface_bitmap.o video_mixer.o decoder.o handles.o queue.o ve.o h264.o mpeg12.o mpeg4.o rgba.o tiled_yuv.o -lrt -lm -lX11 -lpthread -lcsptr -o libvdpau_sunxi.so.1
this commit worked on my second cubieboard2 when doing it manually
maybe rellla killed something ^^
:edit
nothing changed
libvdpau-sunxi ...
Empfange Objekte: 100% (1074/1074), 393.55 KiB | 138.00 KiB/s, Fertig.
Note: checking out '80cda1eb12965d9230ca10fa32b9c0873cfde066'.
You are in 'detached HEAD' state. You can look around, make experimental
changes and commit them, and you can discard any commits you make in this
state without impacting any branches by performing another checkout.
If you want to create a new branch to retain commits you create, you may
do so (now or later) by using -b with the checkout command again. Example:
  git checkout -b new_branch_name
HEAD is now at 80cda1e... Add some logging. Change default logging level.
In file included from vdpau_private.h:40:0,
                 from handles.c:23:
                 from mpeg12.c:21:
                 from decoder.c:22:
                 from device.c:23:
                 from h264.c:23:
                 from ve.c:28:
i created a packages.list on the second Cubieboard and use it now for the build
and now it downloads 480MB before 78MB ;-)
now i have to wait 40 minutes to see if it works :-/
