Efforts to develop firmware for HK1 RBOX R2 4G/64G
Hqnicolas
hmm, I tested with 6.2 before, but I will change to 6.2 as your advice
Quote
maybe your problem could be just the usb port
currently, yes.
in kernel 4.19 dts, I see:
usbdrd30 = "/usbdrd";
usbdrd_dwc3 = "/usbdrd/dwc3@fcc00000";
usbhost30 = "/usbhost";
usbhost_dwc3 = "/usbhost/dwc3@fd000000";
usb_host0_ehci = "/usb@fd800000";
usb_host0_ohci = "/usb@fd840000";
usb_host1_ehci = "/usb@fd880000";
usb_host1_ohci = "/usb@fd8c0000";
I'm trying to understand the parts usbdrd and dwc3, I think these are responsible for usb3.
Edited by ewww
@maka awesome bro!!
Plugged in usb3 port
Quote
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x412fd050]
[    0.000000] Linux version 6.1.34-media (armbian@next) (aarch64-linux-gnu-gcc (Ubuntu 11.3.0-1ubuntu1~22.04.1) 11.3.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #1 SMP PREEMPT_DYNAMIC Wed Jun 14 09:15:34 UTC 2023
[    0.000000] Machine model: Rockchip RK3566 BOX DEMO Board
[    0.000000] efi: UEFI not found.
[    0.000000] NUMA: No NUMA configuration found
[    0.000000] NUMA: Faking a node at [mem 0x0000000000200000-0x00000000efffffff]
[    0.000000] NUMA: NODE_DATA [mem 0xef7ec100-0xef7f1fff]
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000000200000-0x00000000efffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000200000-0x00000000083fffff]
[    0.000000]   node   0: [mem 0x0000000009400000-0x00000000efffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000200000-0x00000000efffffff]
[    0.000000] On node 0, zone DMA: 512 pages in unavailable ranges
[    0.000000] On node 0, zone DMA: 4096 pages in unavailable ranges
[    0.000000] cma: Reserved 256 MiB at 0x00000000dba00000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 30 pages/cpu s83112 r8192 d31576 u122880
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: Virtualization Host Extensions
[    0.000000] CPU features: detected: Qualcomm erratum 1009, or ARM erratum 1286807, 2441009
[    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[    0.000000] alternatives: applying boot alternatives
[    0.000000] Fallback order for Node 0: 0
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 963080
[    0.000000] Policy zone: DMA
[    0.000000] Kernel command line: root=UUID=a657b566-b886-45b2-9c35-b27754119297 rootflags=data=writeback rw rootwait console=ttyS02,1500000 console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 loglevel=7
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] Memory: 3515188K/3913728K available (14528K kernel code, 3388K rwdata, 4740K rodata, 3520K init, 1028K bss, 136396K reserved, 262144K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] trace event string verifier disabled
[    0.000000] Dynamic Preempt: none
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[    0.000000]     Trampoline variant of Tasks RCU enabled.
[    0.000000]     Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 320 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: MBI range [296:319]
[    0.000000] GICv3: Using MBI frame 0x00000000fd410000
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GICv3: GICv3 features: 16 PPIs
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x00000000fd460000
[    0.000000] ITS: No ITS available, not enabling LPIs
[    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000000] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.001515] Console: colour dummy device 80x25
[    0.002179] printk: console [tty0] enabled
[    0.002344] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.002386] pid_max: default: 32768 minimum: 301
[    0.002678] LSM: Security Framework initializing
[    0.002778] Yama: becoming mindful.
[    0.002871] LSM support for eBPF active
[    0.003083] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.003135] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.005056] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    0.006281] cblist_init_generic: Setting adjustable number of callback queues.
[    0.006320] cblist_init_generic: Setting shift to 2 and lim to 1.
[    0.006493] cblist_init_generic: Setting shift to 2 and lim to 1.
[    0.006884] rcu: Hierarchical SRCU implementation.
[    0.006909] rcu:     Max phase no-delay instances is 1000.
[    0.013456] EFI services will not be available.
[    0.014159] smp: Bringing up secondary CPUs ...
[    0.015249] Detected VIPT I-cache on CPU1
[    0.015370] cacheinfo: Unable to detect cache hierarchy for CPU 1
[    0.015394] GICv3: CPU1: found redistributor 100 region 0:0x00000000fd480000
[    0.015452] CPU1: Booted secondary processor 0x0000000100 [0x412fd050]
[    0.016646] Detected VIPT I-cache on CPU2
[    0.016760] cacheinfo: Unable to detect cache hierarchy for CPU 2
[    0.016780] GICv3: CPU2: found redistributor 200 region 0:0x00000000fd4a0000
[    0.016828] CPU2: Booted secondary processor 0x0000000200 [0x412fd050]
[    0.017908] Detected VIPT I-cache on CPU3
[    0.018015] cacheinfo: Unable to detect cache hierarchy for CPU 3
[    0.018036] GICv3: CPU3: found redistributor 300 region 0:0x00000000fd4c0000
[    0.018079] CPU3: Booted secondary processor 0x0000000300 [0x412fd050]
[    0.018219] smp: Brought up 1 node, 4 CPUs
[    0.018383] SMP: Total of 4 processors activated.
[    0.018402] CPU features: detected: 32-bit EL0 Support
[    0.018418] CPU features: detected: 32-bit EL1 Support
[    0.018438] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[    0.018460] CPU features: detected: Common not Private translations
[    0.018476] CPU features: detected: CRC32 instructions
[    0.018492] CPU features: detected: Data cache clean to Point of Persistence
[    0.018513] CPU features: detected: RCpc load-acquire (LDAPR)
[    0.018529] CPU features: detected: LSE atomic instructions
[    0.018545] CPU features: detected: Privileged Access Never
[    0.018560] CPU features: detected: RAS Extension Support
[    0.018580] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[    0.018712] CPU: All CPU(s) started at EL2
[    0.018734] alternatives: applying system-wide alternatives
[    0.025590] devtmpfs: initialized
[    0.055228] Registered cp15_barrier emulation handler
[    0.055282] Registered setend emulation handler
[    0.055584] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.055632] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.063620] pinctrl core: initialized pinctrl subsystem
[    0.064645] DMI not present or invalid.
[    0.065655] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.067556] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[    0.068301] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.068914] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.069018] audit: initializing netlink subsys (disabled)
[    0.069303] audit: type=2000 audit(0.064:1): state=initialized audit_enabled=0 res=1
[    0.070636] thermal_sys: Registered thermal governor 'fair_share'
[    0.070648] thermal_sys: Registered thermal governor 'bang_bang'
[    0.070675] thermal_sys: Registered thermal governor 'step_wise'
[    0.070693] thermal_sys: Registered thermal governor 'user_space'
[    0.070786] cpuidle: using governor ladder
[    0.070860] cpuidle: using governor menu
[    0.071234] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.071443] ASID allocator initialised with 65536 entries
[    0.073499] Serial: AMBA PL011 UART driver
[    0.087148] platform fe040000.vop: Fixed dependency cycle(s) with /hdmi@fe0a0000
[    0.114076] rockchip-gpio fdd60000.gpio: probed /pinctrl/gpio@fdd60000
[    0.114868] rockchip-gpio fe740000.gpio: probed /pinctrl/gpio@fe740000
[    0.115710] rockchip-gpio fe750000.gpio: probed /pinctrl/gpio@fe750000
[    0.116450] rockchip-gpio fe760000.gpio: probed /pinctrl/gpio@fe760000
[    0.117292] rockchip-gpio fe770000.gpio: probed /pinctrl/gpio@fe770000
[    0.118489] platform fe0a0000.hdmi: Fixed dependency cycle(s) with /hdmi-con
[    0.125719] KASLR disabled due to lack of seed
[    0.138480] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    0.138525] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[    0.138547] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[    0.138566] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[    0.138586] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.138604] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[    0.138622] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[    0.138638] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[    0.206062] raid6: neonx8   gen()  1415 MB/s
[    0.274153] raid6: neonx4   gen()  1443 MB/s
[    0.342258] raid6: neonx2   gen()  1337 MB/s
[    0.410362] raid6: neonx1   gen()  1097 MB/s
[    0.478459] raid6: int64x8  gen()   909 MB/s
[    0.546549] raid6: int64x4  gen()  1046 MB/s
[    0.614633] raid6: int64x2  gen()   936 MB/s
[    0.682730] raid6: int64x1  gen()   680 MB/s
[    0.682753] raid6: using algorithm neonx4 gen() 1443 MB/s
[    0.750826] raid6: .... xor() 1099 MB/s, rmw enabled
[    0.750850] raid6: using neon recovery algorithm
[    0.752065] fbcon: Taking over console
[    0.752149] ACPI: Interpreter disabled.
[    0.757391] iommu: Default domain type: Translated
[    0.757422] iommu: DMA domain TLB invalidation policy: lazy mode
[    0.758272] usbcore: registered new interface driver usbfs
[    0.758376] usbcore: registered new interface driver hub
[    0.758443] usbcore: registered new device driver usb
[    0.758860] pps_core: LinuxPPS API ver. 1 registered
[    0.758884] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.758925] PTP clock support registered
[    0.759462] EDAC MC: Ver: 3.0.0
[    0.760094] arm-scmi firmware:scmi: Enabled polling mode TX channel - prot_id:16
[    0.760352] arm-scmi firmware:scmi: SCMI Notifications - Core Enabled.
[    0.760440] arm-scmi firmware:scmi: Malformed reply - real_sz:8  calc_sz:4  (loop_num_ret:1)
[    0.760473] arm-scmi firmware:scmi: SCMI Protocol v2.0 'rockchip:' Firmware version 0x0
[    0.762229] NetLabel: Initializing
[    0.762259] NetLabel:  domain hash size = 128
[    0.762276] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    0.762365] NetLabel:  unlabeled traffic allowed by default
[    0.762656] vgaarb: loaded
[    0.763359] clocksource: Switched to clocksource arch_sys_counter
[    0.764088] VFS: Disk quotas dquot_6.6.0
[    0.764198] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.764653] pnp: PnP ACPI: disabled
[    0.779505] NET: Registered PF_INET protocol family
[    0.779912] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.784276] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[    0.784375] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.784422] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.784712] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[    0.785761] TCP: Hash tables configured (established 32768 bind 32768)
[    0.786185] MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear)
[    0.786385] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.786493] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.786867] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.786935] NET: Registered PF_XDP protocol family
[    0.786971] PCI: CLS 0 bytes, default 64
[    0.788305] Trying to unpack rootfs image as initramfs...
[    0.811250] hw perfevents: enabled with armv8_cortex_a55 PMU driver, 7 counters available
[    0.812366] kvm [1]: IPA Size Limit: 40 bits
[    0.812446] kvm [1]: GICv3: no GICV resource entry
[    0.812470] kvm [1]: disabling GICv2 emulation
[    0.812506] kvm [1]: GIC system register CPU interface enabled
[    0.812747] kvm [1]: vgic interrupt IRQ9
[    0.813441] kvm [1]: VHE mode initialized successfully
[    0.815944] Initialise system trusted keyrings
[    0.816396] workingset: timestamp_bits=39 max_order=20 bucket_order=0
[    0.825529] zbud: loaded
[    0.828819] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.829098] fuse: init (API version 7.37)
[    0.885403] xor: measuring software checksum speed
[    0.891195]    8regs           :  1722 MB/sec
[    0.897499]    32regs          :  1577 MB/sec
[    0.903383]    arm64_neon      :  1692 MB/sec
[    0.903416] xor: using function: 8regs (1722 MB/sec)
[    0.903446] Key type asymmetric registered
[    0.903465] Asymmetric key parser 'x509' registered
[    2.796125] Freeing initrd memory: 32552K
[    2.825537] alg: self-tests for CTR-KDF (hmac(sha256)) passed
[    2.825720] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[    2.825968] io scheduler mq-deadline registered
[    2.826325] io scheduler bfq registered
[    2.843273] arm-scmi firmware:scmi: Failed. SCMI protocol 22 not active.
[    2.849400] Serial: 8250/16550 driver, 8 ports, IRQ sharing enabled
[    2.854062] fe650000.serial: ttyS1 at MMIO 0xfe650000 (irq = 23, base_baud = 1500000) is a 16550A
[    2.854297] serial serial0: tty port ttyS1 registered
[    2.855463] fe660000.serial: ttyS2 at MMIO 0xfe660000 (irq = 24, base_baud = 1500000) is a 16550A
[    2.968468] printk: console [ttyS2] enabled
[    2.970526] Serial: AMBA driver
[    2.974050] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    2.987688] brd: module loaded
[    2.997886] loop: module loaded
[    3.003313] thunder_xcv, ver 1.0
[    3.003733] thunder_bgx, ver 1.0
[    3.004087] nicpf, ver 1.0
[    3.006640] rk_gmac-dwmac fe010000.ethernet: IRQ eth_lpi not found
[    3.007497] rk_gmac-dwmac fe010000.ethernet: supply phy not found, using dummy regulator
[    3.008472] rk_gmac-dwmac fe010000.ethernet: clock input or output? (input).
[    3.009120] rk_gmac-dwmac fe010000.ethernet: TX delay(0x4b).
[    3.009640] rk_gmac-dwmac fe010000.ethernet: RX delay(0x2b).
[    3.010170] rk_gmac-dwmac fe010000.ethernet: integrated PHY? (no).
[    3.010774] rk_gmac-dwmac fe010000.ethernet: clock input from PHY
[    3.016370] rk_gmac-dwmac fe010000.ethernet: init for RGMII
[    3.017226] rk_gmac-dwmac fe010000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[    3.017887] rk_gmac-dwmac fe010000.ethernet:     DWMAC4/5
[    3.018361] rk_gmac-dwmac fe010000.ethernet: DMA HW capability register supported
[    3.019038] rk_gmac-dwmac fe010000.ethernet: RX Checksum Offload Engine supported
[    3.019741] rk_gmac-dwmac fe010000.ethernet: TX Checksum insertion supported
[    3.020381] rk_gmac-dwmac fe010000.ethernet: Wake-Up On Lan supported
[    3.021043] rk_gmac-dwmac fe010000.ethernet: TSO supported
[    3.021547] rk_gmac-dwmac fe010000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[    3.022273] rk_gmac-dwmac fe010000.ethernet: Enabled RFS Flow TC (entries=10)
[    3.022919] rk_gmac-dwmac fe010000.ethernet: TSO feature enabled
[    3.023488] rk_gmac-dwmac fe010000.ethernet: Using 32/32 bits DMA host/device width
[    3.159641] mdio_bus stmmac-0: MDIO device at address 1 is missing.
[    3.162679] usbcore: registered new interface driver usbserial_generic
[    3.163312] usbserial: USB Serial support registered for generic
[    3.163945] usbcore: registered new interface driver ch341
[    3.164498] usbserial: USB Serial support registered for ch341-uart
[    3.165113] usbcore: registered new interface driver cp210x
[    3.165647] usbserial: USB Serial support registered for cp210x
[    3.166223] usbcore: registered new interface driver ftdi_sio
[    3.166771] usbserial: USB Serial support registered for FTDI USB Serial Device
[    3.167503] usbcore: registered new interface driver pl2303
[    3.168041] usbserial: USB Serial support registered for pl2303
[    3.169290] mousedev: PS/2 mouse device common for all mice
[    3.175220] ledtrig-cpu: registered to indicate activity on CPUs
[    3.176559] arm-scmi firmware:scmi: Failed. SCMI protocol 17 not active.
[    3.177253] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    3.183078] NET: Registered PF_INET6 protocol family
[    3.212197] Segment Routing with IPv6
[    3.212642] In-situ OAM (IOAM) with IPv6
[    3.214620] registered taskstats version 1
[    3.215041] Loading compiled-in X.509 certificates
[    3.219406] zswap: loaded using pool zstd/z3fold
[    3.220740] Key type .fscrypt registered
[    3.221114] Key type fscrypt-provisioning registered
[    3.223499] Btrfs loaded, crc32c=crc32c-generic, assert=on, integrity-checker=on, zoned=yes, fsverity=yes
[    3.250981] Key type encrypted registered
[    3.251474] ima: No TPM chip found, activating TPM-bypass!
[    3.252014] ima: Allocated hash algorithm: sha1
[    3.252490] ima: No architecture policies found
[    3.252978] evm: Initialising EVM extended attributes:
[    3.253449] evm: security.selinux
[    3.253757] evm: security.SMACK64
[    3.254062] evm: security.SMACK64EXEC
[    3.254398] evm: security.SMACK64TRANSMUTE
[    3.254771] evm: security.SMACK64MMAP
[    3.255106] evm: security.apparmor
[    3.255447] evm: security.ima
[    3.255727] evm: security.capability
[    3.256056] evm: HMAC attrs: 0x1
[    3.311764] psci_checker: PSCI checker started using 4 CPUs
[    3.312305] psci_checker: Starting hotplug tests
[    3.312734] psci_checker: Trying to turn off and on again all CPUs
[    3.315116] psci: CPU0 killed (polled 0 ms)
[    3.319381] psci: CPU1 killed (polled 4 ms)
[    3.323070] psci: CPU2 killed (polled 0 ms)
[    3.326138] Detected VIPT I-cache on CPU0
[    3.326568] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    3.327123] GICv3: CPU0: found redistributor 0 region 0:0x00000000fd460000
[    3.327802] CPU0: Booted secondary processor 0x0000000000 [0x412fd050]
[    3.330207] Detected VIPT I-cache on CPU1
[    3.330628] cacheinfo: Unable to detect cache hierarchy for CPU 1
[    3.331181] GICv3: CPU1: found redistributor 100 region 0:0x00000000fd480000
[    3.331870] CPU1: Booted secondary processor 0x0000000100 [0x412fd050]
[    3.334718] Detected VIPT I-cache on CPU2
[    3.335176] cacheinfo: Unable to detect cache hierarchy for CPU 2
[    3.335732] GICv3: CPU2: found redistributor 200 region 0:0x00000000fd4a0000
[    3.336418] CPU2: Booted secondary processor 0x0000000200 [0x412fd050]
[    3.338502] psci_checker: Trying to turn off and on again group 0 (CPUs 0-3)
[    3.339650] psci: CPU0 killed (polled 0 ms)
[    3.343066] psci: CPU1 killed (polled 0 ms)
[    3.345555] psci: CPU2 killed (polled 0 ms)
[    3.348247] Detected VIPT I-cache on CPU0
[    3.348679] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    3.349236] GICv3: CPU0: found redistributor 0 region 0:0x00000000fd460000
[    3.349914] CPU0: Booted secondary processor 0x0000000000 [0x412fd050]
[    3.352462] Detected VIPT I-cache on CPU1
[    3.352884] cacheinfo: Unable to detect cache hierarchy for CPU 1
[    3.353437] GICv3: CPU1: found redistributor 100 region 0:0x00000000fd480000
[    3.354124] CPU1: Booted secondary processor 0x0000000100 [0x412fd050]
[    3.356820] Detected VIPT I-cache on CPU2
[    3.357286] cacheinfo: Unable to detect cache hierarchy for CPU 2
[    3.357842] GICv3: CPU2: found redistributor 200 region 0:0x00000000fd4a0000
[    3.358531] CPU2: Booted secondary processor 0x0000000200 [0x412fd050]
[    3.360599] psci_checker: Hotplug tests passed OK
[    3.361042] psci_checker: Starting suspend tests (10 cycles per state)
[    3.361692] psci_checker: cpuidle not available on CPU 0, ignoring
[    3.362258] psci_checker: cpuidle not available on CPU 1, ignoring
[    3.362815] psci_checker: cpuidle not available on CPU 2, ignoring
[    3.363408] psci_checker: cpuidle not available on CPU 3, ignoring
[    3.363973] psci_checker: Could not start suspend tests on any CPU
[    3.364531] psci_checker: PSCI checker completed
[    3.367804] Freeing unused kernel memory: 3520K
[    3.383473] Run /init as init process
[    4.414315] panfrost fde60000.gpu: clock rate = 594000000
[    4.414874] panfrost fde60000.gpu: bus_clock rate = 500000000
[    4.415530] panfrost fde60000.gpu: error -ENODEV: _opp_set_regulators: no regulator (mali) found
[    4.418184] panfrost fde60000.gpu: mali-g52 id 0x7402 major 0x1 minor 0x0 status 0x0
[    4.418925] panfrost fde60000.gpu: features: 00000000,00000cf7, issues: 00000000,00000400
[    4.419737] panfrost fde60000.gpu: Features: L2:0x07110206 Shader:0x00000002 Tiler:0x00000209 Mem:0x1 MMU:0x00002823 AS:0xff JS:0x7
[    4.420815] panfrost fde60000.gpu: shader_present=0x1 l2_present=0x1
[    4.423983] [drm] Initialized panfrost 1.2.0 20180908 for fde60000.gpu on minor 0
[    4.498117] rockchip-vop2 fe040000.vop: Adding to iommu group 2
[    4.498741] iommu: Failed to allocate default IOMMU domain of type 11 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[    4.510695] rockchip-drm display-subsystem: bound fe040000.vop (ops vop2_component_ops [rockchipdrm])
[    4.512486] sdhci: Secure Digital Host Controller Interface driver
[    4.513233] sdhci: Copyright(c) Pierre Ossman
[    4.513451] dwhdmi-rockchip fe0a0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[    4.521918] Synopsys Designware Multimedia Card Interface Driver
[    4.526242] dwhdmi-rockchip fe0a0000.hdmi: registered DesignWare HDMI I2C bus driver
[    4.528794] rockchip-drm display-subsystem: bound fe0a0000.hdmi (ops dw_hdmi_rockchip_ops [rockchipdrm])
[    4.531965] dma-pl330 fe530000.dma-controller: Loaded driver for PL330 DMAC-241330
[    4.532688] dma-pl330 fe530000.dma-controller:     DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[    4.539070] [drm] Initialized rockchip 1.0.0 20140818 for display-subsystem on minor 1
[    4.545780] dma-pl330 fe550000.dma-controller: Loaded driver for PL330 DMAC-241330
[    4.546504] dma-pl330 fe550000.dma-controller:     DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[    4.548148] sdhci-pltfm: SDHCI platform and OF driver helper
[    4.555744] dwmmc_rockchip fe2b0000.mmc: IDMAC supports 32-bit address mode.
[    4.556451] dwmmc_rockchip fe2b0000.mmc: Using internal DMA controller.
[    4.557067] dwmmc_rockchip fe2b0000.mmc: Version ID is 270a
[    4.557633] dwmmc_rockchip fe2b0000.mmc: DW MMC controller at irq 40,32 bit host data width,256 deep fifo
[    4.559858] dwmmc_rockchip fe2b0000.mmc: Got CD GPIO
[    4.560399] dwmmc_rockchip fe2c0000.mmc: IDMAC supports 32-bit address mode.
[    4.561118] dwmmc_rockchip fe2c0000.mmc: Using internal DMA controller.
[    4.561766] dwmmc_rockchip fe2c0000.mmc: Version ID is 270a
[    4.562351] dwmmc_rockchip fe2c0000.mmc: DW MMC controller at irq 41,32 bit host data width,256 deep fifo
[    4.572127] mmc_host mmc0: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[    4.586569] dwc3 fd000000.usbhost: can't request region for resource [mem 0xfd00c100-0xfd3fffff]
[    4.587420] mmc2: SDHCI controller on fe310000.mmc [fe310000.mmc] using ADMA
[    4.588114] dwc3: probe of fd000000.usbhost failed with error -16
[    4.588894] ------------[ cut here ]------------
[    4.589334] WARNING: CPU: 3 PID: 57 at drivers/reset/core.c:766 __reset_control_get_internal+0x68/0x17c
[    4.590206] Modules linked in: display_connector phy_rockchip_inno_usb2 sdhci_of_dwcmshc sdhci_pltfm dw_mmc_rockchip dw_mmc_pltfm pl330 dw_mmc sdhci mmc_core rockchipdrm(+) dw_mipi_dsi dw_hdmi analogix_dp drm_display_helper cec rc_core panfrost gpu_sched drm_shmem_helper drm_dma_helper drm_kms_helper dwc3_of_simple dwc3 roles drm udc_core drm_panel_orientation_quirks
[    4.593210] CPU: 3 PID: 57 Comm: kworker/u8:3 Not tainted 6.1.34-media #1
[    4.593830] Hardware name: Rockchip RK3566 BOX DEMO Board (DT)
[    4.594363] Workqueue: events_unbound deferred_probe_work_func
[    4.594914] pstate: 60400009 (nZCv daif +PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[    4.595547] pc : __reset_control_get_internal+0x68/0x17c
[    4.596046] lr : __of_reset_control_get+0x170/0x1d4
[    4.596501] sp : ffff80000a3dba30
[    4.596807] x29: ffff80000a3dba30 x28: 0000000000000000 x27: ffff00000db8cdb8
[    4.597465] x26: 0000000000000001 x25: 0000000000000000 x24: 0000000000000001
[    4.598120] x23: 0000000000000000 x22: ffff000002127180 x21: 0000000000000095
[    4.598774] x20: ffff0000021271a0 x19: ffff00000dbbf680 x18: ffffffffffffffff
[    4.599430] x17: 7830206d656d5b20 x16: 656372756f736572 x15: ffff00000db8ce0a
[    4.600084] x14: ffffffffffffffff x13: 0074736f68627375 x12: 2e30303030303064
[    4.600739] x11: 0000000000000000 x10: ffff84000b4f5ef9 x9 : 0000000000000018
[    4.601394] x8 : 0101010101010101 x7 : 00000000736c6c65 x6 : 00000080e1f3f369
[    4.602049] x5 : fffffbfffdd01a50 x4 : ffff80000a3dba28 x3 : 0000000000000001
[    4.602703] x2 : 0000000000000095 x1 : 0000000000000095 x0 : 0000000000000001
[    4.603358] Call trace:
[    4.603592]  __reset_control_get_internal+0x68/0x17c
[    4.604061]  __of_reset_control_get+0x170/0x1d4
[    4.604487]  of_reset_control_array_get+0xa8/0x220
[    4.604931]  dwc3_of_simple_probe+0x64/0x1b0 [dwc3_of_simple]
[    4.605472]  platform_probe+0x68/0xe0
[    4.605820]  really_probe+0xbc/0x2dc
[    4.606162]  __driver_probe_device+0x78/0x114
[    4.606570]  driver_probe_device+0x3c/0x15c
[    4.606963]  __device_attach_driver+0xb8/0x134
[    4.607374]  bus_for_each_drv+0x78/0xd0
[    4.607735]  __device_attach+0xa8/0x1c0
[    4.608097]  device_initial_probe+0x14/0x20
[    4.608485]  bus_probe_device+0x9c/0xa4
[    4.608846]  deferred_probe_work_func+0x88/0xc0
[    4.609268]  process_one_work+0x1fc/0x480
[    4.609645]  worker_thread+0x14c/0x444
[    4.609997]  kthread+0x10c/0x110
[    4.610303]  ret_from_fork+0x10/0x20
[    4.610643] ---[ end trace 0000000000000000 ]---
[    4.611179] dwc3-of-simple fd000000.usbhost: failed to get device resets, err=-16
[    4.611923] dwc3-of-simple: probe of fd000000.usbhost failed with error -16
[    4.615537] dwmmc_rockchip fe2c0000.mmc: IDMAC supports 32-bit address mode.
[    4.616243] dwmmc_rockchip fe2c0000.mmc: Using internal DMA controller.
[    4.616856] dwmmc_rockchip fe2c0000.mmc: Version ID is 270a
[    4.617409] dwmmc_rockchip fe2c0000.mmc: DW MMC controller at irq 41,32 bit host data width,256 deep fifo
[    4.624401] dwmmc_rockchip fe2c0000.mmc: IDMAC supports 32-bit address mode.
[    4.625113] dwmmc_rockchip fe2c0000.mmc: Using internal DMA controller.
[    4.625767] dwmmc_rockchip fe2c0000.mmc: Version ID is 270a
[    4.626326] dwmmc_rockchip fe2c0000.mmc: DW MMC controller at irq 41,32 bit host data width,256 deep fifo
[    4.651902] mmc2: new HS200 MMC card at address 0001
[    4.654592] dwmmc_rockchip fe2c0000.mmc: IDMAC supports 32-bit address mode.
[    4.655305] dwmmc_rockchip fe2c0000.mmc: Using internal DMA controller.
[    4.655971] dwmmc_rockchip fe2c0000.mmc: Version ID is 270a
[    4.656558] dwmmc_rockchip fe2c0000.mmc: DW MMC controller at irq 41,32 bit host data width,256 deep fifo
[    4.658143] dwmmc_rockchip fe2c0000.mmc: allocated mmc-pwrseq
[    4.658699] mmc_host mmc1: card is non-removable.
[    4.668870] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[    4.669930] mmc0: new high speed SDHC card at address 0001
[    4.671492] mmc_host mmc1: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[    4.785773] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[    4.791953] mmc1: new high speed SDIO card at address 0001
[    4.866457] Console: switching to colour frame buffer device 240x67
[    4.903252] rockchip-drm display-subsystem: [drm] fb0: rockchipdrmfb frame buffer device
[    4.969062] Registered IR keymap rc-cec
[    4.970702] rc rc0: dw_hdmi as /devices/platform/fe0a0000.hdmi/rc/rc0
[    4.971968] input: dw_hdmi as /devices/platform/fe0a0000.hdmi/rc/rc0/input0
[    5.033406] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[    5.034085] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 1
[    5.035113] xhci-hcd xhci-hcd.2.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000000002010010
[    5.036239] xhci-hcd xhci-hcd.2.auto: irq 43, io mem 0xfd000000
[    5.037129] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[    5.037755] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 2
[    5.038591] xhci-hcd xhci-hcd.2.auto: Host supports USB 3.0 SuperSpeed
[    5.041805] mmcblk2: mmc2:0001 CJNB4R 58.2 GiB
[    5.041969] hub 1-0:1.0: USB hub found
[    5.043192] hub 1-0:1.0: 1 port detected
[    5.049149] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    5.052654] hub 2-0:1.0: USB hub found
[    5.053223] hub 2-0:1.0: 1 port detected
[    5.055859]  mmcblk2: p2 p4
[    5.057273] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
[    5.057945] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 3
[    5.058285] mmcblk2boot0: mmc2:0001 CJNB4R 4.00 MiB
[    5.058992] xhci-hcd xhci-hcd.3.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x8000000002010010
[    5.060410] xhci-hcd xhci-hcd.3.auto: irq 44, io mem 0xfcc00000
[    5.061329] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
[    5.061958] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 4
[    5.062784] xhci-hcd xhci-hcd.3.auto: Host supports USB 3.0 SuperSpeed
[    5.064180] mmcblk2boot1: mmc2:0001 CJNB4R 4.00 MiB
[    5.065723] hub 3-0:1.0: USB hub found
[    5.066268] hub 3-0:1.0: 1 port detected
[    5.067813] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[    5.069898] mmcblk2rpmb: mmc2:0001 CJNB4R 4.00 MiB, chardev (240:0)
[    5.070333] hub 4-0:1.0: USB hub found
[    5.071099] hub 4-0:1.0: 1 port detected
[    5.074651] mmcblk0: mmc0:0001 SD 3.72 GiB
[    5.101177] GPT:Primary header thinks Alt. header is not at the end of the disk.
[    5.102018] GPT:7744511 != 7802879
[    5.102392] GPT:Alternate GPT header not at the end of the disk.
[    5.103017] GPT:7744511 != 7802879
[    5.103444] GPT: Use GNU Parted to correct GPT errors.
[    5.104039]  mmcblk0: p1 p2
[    5.307396] usb 1-1: new high-speed USB device number 2 using xhci-hcd
[    5.489702] SCSI subsystem initialized
[    5.494874] usb-storage 1-1:1.0: USB Mass Storage device detected
[    5.495896] scsi host0: usb-storage 1-1:1.0
[    5.497926] usbcore: registered new interface driver usb-storage
[    5.503976] usbcore: registered new interface driver uas
[    7.158977] scsi 0:0:0:0: Direct-Access     JetFlash Transcend 16GB   1100 PQ: 0 ANSI: 4
[    7.175910] sd 0:0:0:0: [sda] 31703040 512-byte logical blocks: (16.2 GB/15.1 GiB)
[    7.182328] sd 0:0:0:0: [sda] Write Protect is off
[    7.188397] sd 0:0:0:0: [sda] No Caching mode page found
[    7.194455] sd 0:0:0:0: [sda] Assuming drive cache: write through
[    7.211765] GPT:Primary header thinks Alt. header is not at the end of the disk.
[    7.217583] GPT:4866047 != 31703039
[    7.222964] GPT:Alternate GPT header not at the end of the disk.
[    7.228496] GPT:4866047 != 31703039
[    7.233780] GPT: Use GNU Parted to correct GPT errors.
[    7.239691]  sda: sda1
[    7.245571] sd 0:0:0:0: [sda] Attached SCSI removable disk
[    7.789703] EXT4-fs (sda1): mounted filesystem with writeback data mode. Quota mode: none.
[    8.767390] systemd[1]: System time before build time, advancing clock.
[    8.802707] systemd[1]: Inserted module 'autofs4'
[    8.888830] systemd[1]: systemd 249.11-0ubuntu3.9 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY -P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[    8.906271] systemd[1]: Detected architecture arm64.
[    8.913381] systemd[1]: Detected first boot.
[    8.940747] systemd[1]: Hostname set to <station-m2>.
[   11.603355] random: crng init done
[   11.611795] systemd[1]: Initializing machine ID from random generator.
[   12.541505] dw-apb-uart fe660000.serial: forbid DMA for kernel console
[   15.272794] systemd[1]: Populated /etc with preset unit settings.
[   15.777780] systemd[1]: Queued start job for default target Graphical Interface.
[   15.811307] systemd[1]: Created slice Slice /system/modprobe.
[   15.830261] systemd[1]: Created slice Slice /system/serial-getty.
[   15.845177] systemd[1]: Created slice User and Session Slice.
[   15.858667] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   15.873489] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[   15.887892] systemd[1]: Reached target Slice Units.
[   15.901087] systemd[1]: Reached target Swaps.
[   15.913871] systemd[1]: Reached target System Time Set.
[   15.927194] systemd[1]: Reached target Local Verity Protected Volumes.
[   15.986412] systemd[1]: Listening on RPCbind Server Activation Socket.
[   16.005049] systemd[1]: Listening on Syslog Socket.
[   16.019994] systemd[1]: Listening on fsck to fsckd communication Socket.
[   16.034020] systemd[1]: Listening on initctl Compatibility Named Pipe.
[   16.049143] systemd[1]: Listening on Journal Audit Socket.
[   16.063599] systemd[1]: Listening on Journal Socket (/dev/log).
[   16.078476] systemd[1]: Listening on Journal Socket.
[   16.092667] systemd[1]: systemd-networkd.socket: Socket service systemd-networkd.service not loaded, refusing.
[   16.099480] systemd[1]: Failed to listen on Network Service Netlink Socket.
[   16.128699] systemd[1]: Listening on udev Control Socket.
[   16.143485] systemd[1]: Listening on udev Kernel Socket.
[   16.183992] systemd[1]: Mounting Huge Pages File System...
[   16.208358] systemd[1]: Mounting POSIX Message Queue File System...
[   16.229281] systemd[1]: Mounting Kernel Debug File System...
[   16.249799] systemd[1]: Mounting Kernel Trace File System...
[   16.264632] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
[   16.280559] systemd[1]: Starting Restore / save the current clock...
[   16.304666] systemd[1]: Starting Wait for network to be configured by ifupdown...
[   16.328801] systemd[1]: Starting Set the console keyboard layout...
[   16.350658] systemd[1]: Starting Create List of Static Device Nodes...
[   16.376604] systemd[1]: Starting Load Kernel Module chromeos_pstore...
[   16.400131] systemd[1]: Starting Load Kernel Module configfs...
[   16.424321] systemd[1]: Starting Load Kernel Module drm...
[   16.447807] systemd[1]: Starting Load Kernel Module efi_pstore...
[   16.470703] systemd[1]: Starting Load Kernel Module fuse...
[   16.494022] systemd[1]: Starting Load Kernel Module pstore_blk...
[   16.515075] systemd[1]: Starting Load Kernel Module pstore_zone...
[   16.539111] systemd[1]: Starting Load Kernel Module ramoops...
[   16.553659] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[   16.574256] systemd[1]: Starting Load Kernel Modules...
[   16.595176] systemd[1]: Starting Generate network units from Kernel command line...
[   16.616250] systemd[1]: Starting Remount Root and Kernel File Systems...
[   16.639872] systemd[1]: Starting Coldplug All udev Devices...
[   16.674187] systemd[1]: Mounted Huge Pages File System.
[   16.689373] systemd[1]: Mounted POSIX Message Queue File System.
[   16.693831] EXT4-fs (sda1): re-mounted. Quota mode: none.
[   16.714963] systemd[1]: Mounted Kernel Debug File System.
[   16.729353] systemd[1]: Mounted Kernel Trace File System.
[   16.746356] systemd[1]: Finished Restore / save the current clock.
[   16.762863] systemd[1]: Finished Wait for network to be configured by ifupdown.
[   16.781550] systemd[1]: Finished Set the console keyboard layout.
[   16.797941] systemd[1]: Finished Create List of Static Device Nodes.
[   16.813946] systemd[1]: modprobe@chromeos_pstore.service: Deactivated successfully.
[   16.824398] systemd[1]: Finished Load Kernel Module chromeos_pstore.
[   16.841037] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[   16.850252] systemd[1]: Finished Load Kernel Module configfs.
[   16.866470] systemd[1]: modprobe@drm.service: Deactivated successfully.
[   16.875744] systemd[1]: Finished Load Kernel Module drm.
[   16.892071] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
[   16.901212] systemd[1]: Finished Load Kernel Module efi_pstore.
[   16.917075] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[   16.926044] systemd[1]: Finished Load Kernel Module fuse.
[   16.942505] systemd[1]: modprobe@pstore_blk.service: Deactivated successfully.
[   16.951943] systemd[1]: Finished Load Kernel Module pstore_blk.
[   16.968690] systemd[1]: modprobe@pstore_zone.service: Deactivated successfully.
[   16.977834] systemd[1]: Finished Load Kernel Module pstore_zone.
[   16.994208] systemd[1]: modprobe@ramoops.service: Deactivated successfully.
[   17.004302] systemd[1]: Finished Load Kernel Module ramoops.
[   17.022554] systemd[1]: Finished Load Kernel Modules.
[   17.038348] systemd[1]: Finished Generate network units from Kernel command line.
[   17.054732] systemd[1]: Finished Remount Root and Kernel File Systems.
[   17.107601] systemd[1]: Reached target Preparation for Network.
[   17.129473] systemd[1]: Mounting FUSE Control File System...
[   17.149766] systemd[1]: Mounting Kernel Configuration File System...
[   17.163891] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[   17.192297] systemd[1]: Starting Load/Save Random Seed...
[   17.213409] systemd[1]: Starting Apply Kernel Variables...
[   17.235403] systemd[1]: Starting Create System Users...
[   17.266776] systemd[1]: Mounted FUSE Control File System.
[   17.280654] systemd[1]: Mounted Kernel Configuration File System.
[   17.706649] systemd[1]: Finished Coldplug All udev Devices.
[   17.744387] systemd[1]: Starting Helper to synchronize boot up for ifupdown...
[   17.761048] systemd[1]: Finished Helper to synchronize boot up for ifupdown.
[   18.048439] systemd[1]: Finished Load/Save Random Seed.
[   18.063782] systemd[1]: Reached target First Boot Complete.
station-m2 login: root (automatic login)
Plugged in usb2 port
Quote
 kernel ...
[    0.001565] Console: colour dummy device 80x25
[    0.002231] printk: console [tty0] enabled
[    0.002392] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.002435] pid_max: default: 32768 minimum: 301
[    0.002728] LSM: Security Framework initializing
[    0.002827] Yama: becoming mindful.
[    0.002914] LSM support for eBPF active
[    0.003129] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.003184] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.005137] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    0.006365] cblist_init_generic: Setting adjustable number of callback queues.
[    0.006402] cblist_init_generic: Setting shift to 2 and lim to 1.
[    0.006575] cblist_init_generic: Setting shift to 2 and lim to 1.
[    0.006967] rcu: Hierarchical SRCU implementation.
[    0.006992] rcu:     Max phase no-delay instances is 1000.
[    0.013567] EFI services will not be available.
[    0.014276] smp: Bringing up secondary CPUs ...
[    0.015367] Detected VIPT I-cache on CPU1
[    0.015487] cacheinfo: Unable to detect cache hierarchy for CPU 1
[    0.015510] GICv3: CPU1: found redistributor 100 region 0:0x00000000fd480000
[    0.015569] CPU1: Booted secondary processor 0x0000000100 [0x412fd050]
[    0.016757] Detected VIPT I-cache on CPU2
[    0.016870] cacheinfo: Unable to detect cache hierarchy for CPU 2
[    0.016890] GICv3: CPU2: found redistributor 200 region 0:0x00000000fd4a0000
[    0.016941] CPU2: Booted secondary processor 0x0000000200 [0x412fd050]
[    0.018023] Detected VIPT I-cache on CPU3
[    0.018132] cacheinfo: Unable to detect cache hierarchy for CPU 3
[    0.018152] GICv3: CPU3: found redistributor 300 region 0:0x00000000fd4c0000
[    0.018196] CPU3: Boves
[    0.025682] devtmpfs: initialized
[    0.055342] Registered cp15_barrier emulation handered cp15_barrier emulation handered cp15_barrier emulation handered cp15_barrier emulation handered cp15_barrier emulation handered cp15_barrier emulation hd setend emulation handler
[    0.055701] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.055748] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.063721] pinctrl core: initialized pinctrl subsystem
[    0.064740] DMI not present or invalid.
[    0.065746] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.067632] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[    0.068364] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.068987] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.069094] audit: initializing netlink subsys (disabled)
[    0.069386] audit: type=2000 audit(0.064:1): state=initialized audit_enabled=0 res=1
[    0.070717] thermal_sys: Registered thermal governor 'fair_share'
[    0.070730] thermal_sys: Registered thermal governor 'bang_bang'
[    0.070757] thermal_sys: Registered thermal governor 'step_wise'
[    0.070775] thermal_sys: Registered thermal governor 'user_space'
[    0.070874] cpuidle: using governor ladder
[    0.070946] cpuidle: using governor menu
[    0.071321] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.071529] ASID allocator initialised with 65536 entries
[    0.073618] Serial: AMBA PL011 UART driver
[    0.087258] platform fe040000.vop: Fixed dependency cycle(s) with /hdmi@fe0a0000
[    0.114154] rockchip-gpio fdd60000.gpio: probed /pinctrl/gpio@fdd60000
[    0.114944] rockchip-gpio fe740000.gpio: probed /pinctrl/gpio@fe740000
[    0.115787] rockchip-gpio fe750000.gpio: probed /pinctrl/gpio@fe750000
[    0.116530] rockchip-gpio fe760000.gpio: probed /pinctrl/gpio@fe760000
[    0.117370] rockchip-gpio fe770000.gpio: probed /pinctrl/gpio@fe770000
[    0.118587] platform fe0a0000.hdmi: Fixed dependency cycle(s) with /hdmi-con
[    0.125861] KASLR disabled due to lack of seed
[    0.138599] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    0.138642] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[    0.138665] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[    0.138683] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[    0.138701] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.138719] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[    0.138737] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[    0.138755] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[    0.206177] raid6: neonx8   gen()  1415 MB/s
[    0.274269] raid6: neonx4   gen()  1443 MB/s
[    0.342378] raid6: neonx2   gen()  1337 MB/s
[    0.410464] raid6: neonx1   gen()  1096 MB/s
[    0.478572] raid6: int64x8  gen()   909 MB/s
[    0.546649] raid6: int64x4  gen()  1045 MB/s
[    0.614761] raid6: int64x2  gen()   935 MB/s
[    0.682836] raid6: int64x1  gen()   673 MB/s
[    0.682859] raid6: using algorithm neonx4 gen() 1443 MB/s
[    0.750931] raid6: .... xor() 1097 MB/s, rmw enabled
[    0.750954] raid6: using neon recovery algorithm
[    0.752163] fbcon: Taking over console
[    0.752248] ACPI: Interpreter disabled.
[    0.757440] iommu: Default domain type: Translated
[    0.757471] iommu: DMA domain TLB invalidation policy: lazy mode
[    0.758325] usbcore: registered new interface driver usbfs
[    0.758426] usbcore: registered new interface driver hub
[    0.758494] usbcore: registered new device driver usb
[    0.758903] pps_core: LinuxPPS API ver. 1 registered
[    0.758927] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.758969] PTP clock support registered
[    0.759499] EDAC MC: Ver: 3.0.0
[    0.760126] arm-scmi firmware:scmi: Enabled polling mode TX channel - prot_id:16
[    0.760383] arm-scmi firmware:scmi: SCMI Notifications - Core Enabled.
[    0.760470] arm-scmi firmware:scmi: Malformed reply - real_sz:8  calc_sz:4  (loop_num_ret:1)
[    0.760503] arm-scmi firmware:scmi: SCMI Protocol v2.0 'rockchip:' Firmware version 0x0
[    0.762267] NetLabel: Initializing
[    0.762295] NetLabel:  domain hash size = 128
[    0.762312] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    0.762404] NetLabel:  unlabeled traffic allowed by default
[    0.762695] vgaarb: loaded
[    0.763395] clocksource: Switched to clocksource arch_sys_counter
[    0.764126] VFS: Disk quotas dquot_6.6.0
[    0.764233] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.764690] pnp: PnP ACPI: disabled
[    0.779166] NET: Registered PF_INET protocol family
[    0.779641] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.784075] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[    0.784175] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.784225] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.784514] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[    0.785563] TCP: Hash tables configured (established 32768 bind 32768)
[    0.785994] MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear)
[    0.786213] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.786320] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.786732] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.786800] NET: Registered PF_XDP protocol family
[    0.786836] PCI: CLS 0 bytes, default 64
[    0.788023] Trying to unpack rootfs image as initramfs...
[    0.810869] hw perfevents: enabled with armv8_cortex_a55 PMU driver, 7 counters available
[    0.811962] kvm [1]: IPA Size Limit: 40 bits
[    0.812018] kvm [1]: GICv3: no GICV resource entry
[    0.812039] kvm [1]: disabling GICv2 emulation
[    0.812074] kvm [1]: GIC system register CPU interface enabled
[    0.812417] kvm [1]: vgic interrupt IRQ9
[    0.813158] kvm [1]: VHE mode initialized successfully
[    0.815640] Initialise system trusted keyrings
[    0.816070] workingset: timestamp_bits=39 max_order=20 bucket_order=0
[    0.825183] zbud: loaded
[    0.828473] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.828766] fuse: init (API version 7.37)
[    0.884023] xor: measuring software checksum speed
[    0.889822]    8regs           :  1721 MB/sec
[    0.896114]    32regs          :  1577 MB/sec
[    0.901973]    arm64_neon      :  1692 MB/sec
[    0.902000] xor: using function: 8regs (1721 MB/sec)
[    0.902029] Key type asymmetric registered
[    0.902047] Asymmetric key parser 'x509' registered
[    2.800073] Freeing initrd memory: 32552K
[    2.829609] alg: self-tests for CTR-KDF (hmac(sha256)) passed
[    2.829793] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[    2.830012] io scheduler mq-deadline registered
[    2.830372] io scheduler bfq registered
[    2.847427] arm-scmi firmware:scmi: Failed. SCMI protocol 22 not active.
[    2.853338] Serial: 8250/16550 driver, 8 ports, IRQ sharing enabled
[    2.858117] fe650000.serial: ttyS1 at MMIO 0xfe650000 (irq = 23, base_baud = 1500000) is a 16550A
[    2.858353] serial serial0: tty port ttyS1 registered
[    2.859494] fe660000.serial: ttyS2 at MMIO 0xfe660000 (irq = 24, base_baud = 1500000) is a 16550A
[    2.972383] printk: console [ttyS2] enabled
[    2.974542] Serial: AMBA driver
[    2.978189] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    2.991825] brd: module loaded
[    3.001976] loop: module loaded
[    3.007428] thunder_xcv, ver 1.0
[    3.007841] thunder_bgx, ver 1.0
[    3.008223] nicpf, ver 1.0
[    3.010735] rk_gmac-dwmac fe010000.ethernet: IRQ eth_lpi not found
[    3.011578] rk_gmac-dwmac fe010000.ethernet: supply phy not found, using dummy regulator
[    3.012534] rk_gmac-dwmac fe010000.ethernet: clock input or output? (input).
[    3.013183] rk_gmac-dwmac fe010000.ethernet: TX delay(0x4b).
[    3.013703] rk_gmac-dwmac fe010000.ethernet: RX delay(0x2b).
[    3.014232] rk_gmac-dwmac fe010000.ethernet: integrated PHY? (no).
[    3.014838] rk_gmac-dwmac fe010000.ethernet: clock input from PHY
[    3.020436] rk_gmac-dwmac fe010000.ethernet: init for RGMII
[    3.021247] rk_gmac-dwmac fe010000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[    3.021932] rk_gmac-dwmac fe010000.ethernet:     DWMAC4/5
[    3.022410] rk_gmac-dwmac fe010000.ethernet: DMA HW capability register supported
[    3.023088] rk_gmac-dwmac fe010000.ethernet: RX Checksum Offload Engine supported
[    3.023794] rk_gmac-dwmac fe010000.ethernet: TX Checksum insertion supported
[    3.024435] rk_gmac-dwmac fe010000.ethernet: Wake-Up On Lan supported
[    3.025098] rk_gmac-dwmac fe010000.ethernet: TSO supported
[    3.025601] rk_gmac-dwmac fe010000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[    3.026325] rk_gmac-dwmac fe010000.ethernet: Enabled RFS Flow TC (entries=10)
[    3.026971] rk_gmac-dwmac fe010000.ethernet: TSO feature enabled
[    3.027541] rk_gmac-dwmac fe010000.ethernet: Using 32/32 bits DMA host/device width
[    3.163682] mdio_bus stmmac-0: MDIO device at address 1 is missing.
[    3.166788] usbcore: registered new interface driver usbserial_generic
[    3.167455] usbserial: USB Serial support registered for generic
[    3.168049] usbcore: registered new interface driver ch341
[    3.168575] usbserial: USB Serial support registered for ch341-uart
[    3.169208] usbcore: registered new interface driver cp210x
[    3.169745] usbserial: USB Serial support registered for cp210x
[    3.170326] usbcore: registered new interface driver ftdi_sio
[    3.170897] usbserial: USB Serial support registered for FTDI USB Serial Device
[    3.171642] usbcore: registered new interface driver pl2303
[    3.172180] usbserial: USB Serial support registered for pl2303
[    3.173393] mousedev: PS/2 mouse device common for all mice
[    3.179593] ledtrig-cpu: registered to indicate activity on CPUs
[    3.180863] arm-scmi firmware:scmi: Failed. SCMI protocol 17 not active.
[    3.181583] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    3.187457] NET: Registered PF_INET6 protocol family
[    3.216920] Segment Routing with IPv6
[    3.217364] In-situ OAM (IOAM) with IPv6
[    3.219512] registered taskstats version 1
[    3.219956] Loading compiled-in X.509 certificates
[    3.224293] zswap: loaded using pool zstd/z3fold
[    3.225682] Key type .fscrypt registered
[    3.226054] Key type fscrypt-provisioning registered
[    3.228444] Btrfs loaded, crc32c=crc32c-generic, assert=on, integrity-checker=on, zoned=yes, fsverity=yes
[    3.255982] Key type encrypted registered
[    3.256431] ima: No TPM chip found, activating TPM-bypass!
[    3.256947] ima: Allocated hash algorithm: sha1
[    3.257398] ima: No architecture policies found
[    3.257881] evm: Initialising EVM extended attributes:
[    3.258351] evm: security.selinux
[    3.258658] evm: security.SMACK64
[    3.258963] evm: security.SMACK64EXEC
[    3.259300] evm: security.SMACK64TRANSMUTE
[    3.259697] evm: security.SMACK64MMAP
[    3.260039] evm: security.apparmor
[    3.260352] evm: security.ima
[    3.260626] evm: security.capability
[    3.260954] evm: HMAC attrs: 0x1
[    3.316439] psci_checker: PSCI checker started using 4 CPUs
[    3.316979] psci_checker: Starting hotplug tests
[    3.317407] psci_checker: Trying to turn off and on again all CPUs
[    3.319401] psci: CPU0 killed (polled 4 ms)
[    3.323258] psci: CPU1 killed (polled 0 ms)
[    3.326152] psci: CPU2 killed (polled 0 ms)
[    3.329148] Detected VIPT I-cache on CPU0
[    3.329596] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    3.330155] GICv3: CPU0: found redistributor 0 region 0:0x00000000fd460000
[    3.330839] CPU0: Booted secondary processor 0x0000000000 [0x412fd050]
[    3.333675] Detected VIPT I-cache on CPU1
[    3.334125] cacheinfo: Unable to detect cache hierarchy for CPU 1
[    3.334684] GICv3: CPU1: found redistributor 100 region 0:0x00000000fd480000
[    3.335392] CPU1: Booted secondary processor 0x0000000100 [0x412fd050]
[    3.338425] Detected VIPT I-cache on CPU2
[    3.338890] cacheinfo: Unable to detect cache hierarchy for CPU 2
[    3.339449] GICv3: CPU2: found redistributor 200 region 0:0x00000000fd4a0000
[    3.340136] CPU2: Booted secondary processor 0x0000000200 [0x412fd050]
[    3.342224] psci_checker: Trying to turn off and on again group 0 (CPUs 0-3)
[    3.343345] psci: CPU0 killed (polled 0 ms)
[    3.346746] psci: CPU1 killed (polled 0 ms)
[    3.350250] psci: CPU2 killed (polled 0 ms)
[    3.352929] Detected VIPT I-cache on CPU0
[    3.353360] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    3.353914] GICv3: CPU0: found redistributor 0 region 0:0x00000000fd460000
[    3.354593] CPU0: Booted secondary processor 0x0000000000 [0x412fd050]
[    3.357071] Detected VIPT I-cache on CPU1
[    3.357494] cacheinfo: Unable to detect cache hierarchy for CPU 1
[    3.358049] GICv3: CPU1: found redistributor 100 region 0:0x00000000fd480000
[    3.358736] CPU1: Booted secondary processor 0x0000000100 [0x412fd050]
[    3.361579] Detected VIPT I-cache on CPU2
[    3.362041] cacheinfo: Unable to detect cache hierarchy for CPU 2
[    3.362600] GICv3: CPU2: found redistributor 200 region 0:0x00000000fd4a0000
[    3.363286] CPU2: Booted secondary processor 0x0000000200 [0x412fd050]
[    3.365342] psci_checker: Hotplug tests passed OK
[    3.365785] psci_checker: Starting suspend tests (10 cycles per state)
[    3.366437] psci_checker: cpuidle not available on CPU 0, ignoring
[    3.367002] psci_checker: cpuidle not available on CPU 1, ignoring
[    3.367648] psci_checker: cpuidle not available on CPU 2, ignoring
[    3.368210] psci_checker: cpuidle not available on CPU 3, ignoring
[    3.368770] psci_checker: Could not start suspend tests on any CPU
[    3.369326] psci_checker: PSCI checker completed
[    3.372946] Freeing unused kernel memory: 3520K
[    3.395511] Run /init as init process
[    4.449829] panfrost fde60000.gpu: clock rate = 594000000
[    4.450411] panfrost fde60000.gpu: bus_clock rate = 500000000
[    4.451089] panfrost fde60000.gpu: error -ENODEV: _opp_set_regulators: no regulator (mali) found
[    4.455813] panfrost fde60000.gpu: mali-g52 id 0x7402 major 0x1 minor 0x0 status 0x0
[    4.456553] panfrost fde60000.gpu: features: 00000000,00000cf7, issues: 00000000,00000400
[    4.457296] panfrost fde60000.gpu: Features: L2:0x07110206 Shader:0x00000002 Tiler:0x00000209 Mem:0x1 MMU:0x00002823 AS:0xff JS:0x7
[    4.458360] panfrost fde60000.gpu: shader_present=0x1 l2_present=0x1
[    4.466951] rockchip-vop2 fe040000.vop: Adding to iommu group 2
[    4.467630] iommu: Failed to allocate default IOMMU domain of type 11 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[    4.470203] [drm] Initialized panfrost 1.2.0 20180908 for fde60000.gpu on minor 0
[    4.476960] rockchip-drm display-subsystem: bound fe040000.vop (ops vop2_component_ops [rockchipdrm])
[    4.478662] dwhdmi-rockchip fe0a0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[    4.481672] dwhdmi-rockchip fe0a0000.hdmi: registered DesignWare HDMI I2C bus driver
[    4.482998] rockchip-drm display-subsystem: bound fe0a0000.hdmi (ops dw_hdmi_rockchip_ops [rockchipdrm])
[    4.487127] [drm] Initialized rockchip 1.0.0 20140818 for display-subsystem on minor 1
[    4.525677] Synopsys Designware Multimedia Card Interface Driver
[    4.527037] sdhci: Secure Digital Host Controller Interface driver
[    4.527685] sdhci: Copyright(c) Pierre Ossman
[    4.529837] sdhci-pltfm: SDHCI platform and OF driver helper
[    4.532195] dwmmc_rockchip fe2c0000.mmc: IDMAC supports 32-bit address mode.
[    4.532555] dwmmc_rockchip fe2b0000.mmc: IDMAC supports 32-bit address mode.
[    4.532901] dwmmc_rockchip fe2c0000.mmc: Using internal DMA controller.
[    4.533552] dwmmc_rockchip fe2b0000.mmc: Using internal DMA controller.
[    4.534130] dwmmc_rockchip fe2c0000.mmc: Version ID is 270a
[    4.534150] dwmmc_rockchip fe2b0000.mmc: Version ID is 270a
[    4.534241] dwmmc_rockchip fe2b0000.mmc: DW MMC controller at irq 36,32 bit host data width,256 deep fifo
[    4.534775] dwmmc_rockchip fe2c0000.mmc: DW MMC controller at irq 35,32 bit host data width,256 deep fifo
[    4.535864] dwmmc_rockchip fe2b0000.mmc: Got CD GPIO
[    4.545373] dma-pl330 fe530000.dma-controller: Loaded driver for PL330 DMAC-241330
[    4.546102] dma-pl330 fe530000.dma-controller:     DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[    4.550876] mmc_host mmc0: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[    4.551150] dma-pl330 fe550000.dma-controller: Loaded driver for PL330 DMAC-241330
[    4.552495] dma-pl330 fe550000.dma-controller:     DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[    4.559220] dwmmc_rockchip fe2c0000.mmc: IDMAC supports 32-bit address mode.
[    4.559961] dwmmc_rockchip fe2c0000.mmc: Using internal DMA controller.
[    4.560613] dwmmc_rockchip fe2c0000.mmc: Version ID is 270a
[    4.561193] dwmmc_rockchip fe2c0000.mmc: DW MMC controller at irq 35,32 bit host data width,256 deep fifo
[    4.568071] dwmmc_rockchip fe2c0000.mmc: IDMAC supports 32-bit address mode.
[    4.568799] dwmmc_rockchip fe2c0000.mmc: Using internal DMA controller.
[    4.569420] dwmmc_rockchip fe2c0000.mmc: Version ID is 270a
[    4.569973] dwmmc_rockchip fe2c0000.mmc: DW MMC controller at irq 35,32 bit host data width,256 deep fifo
[    4.592798] dwc3 fd000000.usbhost: can't request region for resource [mem 0xfd00c100-0xfd3fffff]
[    4.593641] dwc3: probe of fd000000.usbhost failed with error -16
[    4.594375] ------------[ cut here ]------------
[    4.594806] WARNING: CPU: 1 PID: 9 at drivers/reset/core.c:766 __reset_control_get_internal+0x68/0x17c
[    4.595669] Modules linked in: phy_rockchip_inno_usb2 display_connector sdhci_of_dwcmshc pl330 dw_mmc_rockchip sdhci_pltfm dw_mmc_pltfm sdhci dw_mmc mmc_core rockchipdrm(+) dw_mipi_dsi panfrost dw_hdmi analogix_dp gpu_sched drm_shmem_helper drm_display_helper cec rc_core drm_dma_helper drm_kms_helper dwc3_of_simple dwc3 roles drm udc_core drm_panel_orientation_quirks
[    4.598668] CPU: 1 PID: 9 Comm: kworker/u8:0 Not tainted 6.1.34-media #1
[    4.599283] Hardware name: Rockchip RK3566 BOX DEMO Board (DT)
[    4.599813] Workqueue: events_unbound deferred_probe_work_func
[    4.600362] pstate: 60400009 (nZCv daif +PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[    4.600995] pc : __reset_control_get_internal+0x68/0x17c
[    4.601490] lr : __of_reset_control_get+0x170/0x1d4
[    4.601942] sp : ffff800009bdba30
[    4.602247] x29: ffff800009bdba30 x28: 0000000000000000 x27: ffff00000d940b38
[    4.602902] x26: 0000000000000001 x25: 0000000000000000 x24: 0000000000000001
[    4.603556] x23: 0000000000000000 x22: ffff000002127100 x21: 0000000000000095
[    4.604211] x20: ffff000002127120 x19: ffff00000d943c80 x18: ffffffffffffffff
[    4.604864] x17: 7830206d656d5b20 x16: 656372756f736572 x15: ffff00000d955f8a
[    4.605517] x14: ffffffffffffffff x13: 0074736f68627375 x12: 2e30303030303064
[    4.606170] x11: 0000000000000000 x10: ffff84000b4f5ef9 x9 : 0000000000000018
[    4.606823] x8 : 0101010101010101 x7 : 00000000736c6c65 x6 : 00000080e1f3f369
[    4.607477] x5 : fffffbfffdd01a50 x4 : ffff800009bdba28 x3 : 0000000000000001
[    4.608129] x2 : 0000000000000095 x1 : 0000000000000095 x0 : 0000000000000001
[    4.608782] Call trace:
[    4.609012]  __reset_control_get_internal+0x68/0x17c
[    4.609482]  __of_reset_control_get+0x170/0x1d4
[    4.609906]  of_reset_control_array_get+0xa8/0x220
[    4.610350]  dwc3_of_simple_probe+0x64/0x1b0 [dwc3_of_simple]
[    4.610892]  platform_probe+0x68/0xe0
[    4.611240]  really_probe+0xbc/0x2dc
[    4.611581]  __driver_probe_device+0x78/0x114
[    4.611988]  driver_probe_device+0x3c/0x15c
[    4.612382]  __device_attach_driver+0xb8/0x134
[    4.612794]  bus_for_each_drv+0x78/0xd0
[    4.613155]  __device_attach+0xa8/0x1c0
[    4.613514]  device_initial_probe+0x14/0x20
[    4.613901]  bus_probe_device+0x9c/0xa4
[    4.614264]  deferred_probe_work_func+0x88/0xc0
[    4.614686]  process_one_work+0x1fc/0x480
[    4.615066]  worker_thread+0x14c/0x444
[    4.615419]  kthread+0x10c/0x110
[    4.615727]  ret_from_fork+0x10/0x20
[    4.616069] ---[ end trace 0000000000000000 ]---
[    4.616598] dwc3-of-simple fd000000.usbhost: failed to get device resets, err=-16
[    4.617328] dwc3-of-simple: probe of fd000000.usbhost failed with error -16
[    4.622316] dwmmc_rockchip fe2c0000.mmc: IDMAC supports 32-bit address mode.
[    4.623037] dwmmc_rockchip fe2c0000.mmc: Using internal DMA controller.
[    4.623691] dwmmc_rockchip fe2c0000.mmc: Version ID is 270a
[    4.624251] dwmmc_rockchip fe2c0000.mmc: DW MMC controller at irq 35,32 bit host data width,256 deep fifo
[    4.631452] mmc2: SDHCI controller on fe310000.mmc [fe310000.mmc] using ADMA
[    4.634804] dwmmc_rockchip fe2c0000.mmc: IDMAC supports 32-bit address mode.
[    4.635534] dwmmc_rockchip fe2c0000.mmc: Using internal DMA controller.
[    4.636143] dwmmc_rockchip fe2c0000.mmc: Version ID is 270a
[    4.636690] dwmmc_rockchip fe2c0000.mmc: DW MMC controller at irq 35,32 bit host data width,256 deep fifo
[    4.638423] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[    4.639523] mmc0: new high speed SDHC card at address 0001
[    4.666683] dwmmc_rockchip fe2c0000.mmc: IDMAC supports 32-bit address mode.
[    4.667484] dwmmc_rockchip fe2c0000.mmc: Using internal DMA controller.
[    4.668115] dwmmc_rockchip fe2c0000.mmc: Version ID is 270a
[    4.668722] dwmmc_rockchip fe2c0000.mmc: DW MMC controller at irq 35,32 bit host data width,256 deep fifo
[    4.670258] dwmmc_rockchip fe2c0000.mmc: allocated mmc-pwrseq
[    4.670800] mmc_host mmc1: card is non-removable.
[    4.683535] mmc_host mmc1: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[    4.703769] mmc2: new HS200 MMC card at address 0001
[    4.796766] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[    4.802111] mmc1: new high speed SDIO card at address 0001
[    4.843213] Console: switching to colour frame buffer device 240x67
[    4.887436] rockchip-drm display-subsystem: [drm] fb0: rockchipdrmfb frame buffer device
[    4.945921] Registered IR keymap rc-cec
[    4.946615] rc rc0: dw_hdmi as /devices/platform/fe0a0000.hdmi/rc/rc0
[    4.949835] input: dw_hdmi as /devices/platform/fe0a0000.hdmi/rc/rc0/input0
[    5.037553] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[    5.038246] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 1
[    5.039283] xhci-hcd xhci-hcd.2.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000000002010010
[    5.040480] xhci-hcd xhci-hcd.2.auto: irq 44, io mem 0xfd000000
[    5.041407] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[    5.042059] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 2
[    5.042925] xhci-hcd xhci-hcd.2.auto: Host supports USB 3.0 SuperSpeed
[    5.045903] mmcblk0: mmc0:0001 SD 3.72 GiB
[    5.052382] hub 1-0:1.0: USB hub found
[    5.052942] hub 1-0:1.0: 1 port detected
[    5.054263] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    5.057584] hub 2-0:1.0: USB hub found
[    5.058452] hub 2-0:1.0: 1 port detected
[    5.060605] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
[    5.061340] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 3
[    5.062373] xhci-hcd xhci-hcd.3.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x8000000002010010
[    5.063528] xhci-hcd xhci-hcd.3.auto: irq 45, io mem 0xfcc00000
[    5.064422] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
[    5.065063] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 4
[    5.065886] xhci-hcd xhci-hcd.3.auto: Host supports USB 3.0 SuperSpeed
[    5.068429] hub 3-0:1.0: USB hub found
[    5.068966] hub 3-0:1.0: 1 port detected
[    5.070364] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[    5.072076] GPT:Primary header thinks Alt. header is not at the end of the disk.
[    5.072657] hub 4-0:1.0: USB hub found
[    5.072883] GPT:7744511 != 7802879
[    5.073052] hub 4-0:1.0: 1 port detected
[    5.073350] GPT:Alternate GPT header not at the end of the disk.
[    5.074692] GPT:7744511 != 7802879
[    5.075068] GPT: Use GNU Parted to correct GPT errors.
[    5.075695]  mmcblk0: p1 p2
[    5.079919] mmcblk2: mmc2:0001 CJNB4R 58.2 GiB
[    5.097326]  mmcblk2: p2 p4
[    5.099324] mmcblk2boot0: mmc2:0001 CJNB4R 4.00 MiB
[    5.109724] mmcblk2boot1: mmc2:0001 CJNB4R 4.00 MiB
[    5.118643] mmcblk2rpmb: mmc2:0001 CJNB4R 4.00 MiB, chardev (240:0)
[    5.327434] usb 3-1: new high-speed USB device number 2 using xhci-hcd
[    5.508707] SCSI subsystem initialized
[    5.518165] usb-storage 3-1:1.0: USB Mass Storage device detected
[    5.524735] scsi host0: usb-storage 3-1:1.0
[    5.532542] usbcore: registered new interface driver usb-storage
[    5.540695] usbcore: registered new interface driver uas
[    7.213009] scsi 0:0:0:0: Direct-Access     JetFlash Transcend 16GB   1100 PQ: 0 ANSI: 4
[    7.229321] sd 0:0:0:0: [sda] 31703040 512-byte logical blocks: (16.2 GB/15.1 GiB)
[    7.235646] sd 0:0:0:0: [sda] Write Protect is off
[    7.242095] sd 0:0:0:0: [sda] No Caching mode page found
[    7.247593] sd 0:0:0:0: [sda] Assuming drive cache: write through
[    7.267961]  sda: sda1
[    7.273751] sd 0:0:0:0: [sda] Attached SCSI removable disk
[    7.765051] EXT4-fs (sda1): mounted filesystem with writeback data mode. Quota mode: none.
[    8.744767] systemd[1]: System time before build time, advancing clock.
[    8.778884] systemd[1]: Inserted module 'autofs4'
[    8.865107] systemd[1]: systemd 249.11-0ubuntu3.9 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY -P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[    8.882346] systemd[1]: Detected architecture arm64.
[    8.909283] systemd[1]: Hostname set to <station-m2>.
[    9.157366] dw-apb-uart fe660000.serial: forbid DMA for kernel console
[   10.088878] systemd[1]: Queued start job for default target Graphical Interface.
[   11.923392] random: crng init done
[   11.959520] systemd[1]: Created slice Slice /system/modprobe.
[   11.978390] systemd[1]: Created slice Slice /system/serial-getty.
[   11.992898] systemd[1]: Created slice User and Session Slice.
[   12.006111] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   12.020569] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[   12.034730] systemd[1]: Reached target Slice Units.
[   12.047857] systemd[1]: Reached target Swaps.
[   12.060953] systemd[1]: Reached target System Time Set.
[   12.073995] systemd[1]: Reached target Local Verity Protected Volumes.
[   12.134851] systemd[1]: Listening on RPCbind Server Activation Socket.
[   12.151994] systemd[1]: Listening on Syslog Socket.
[   12.166664] systemd[1]: Listening on fsck to fsckd communication Socket.
[   12.181089] systemd[1]: Listening on initctl Compatibility Named Pipe.
[   12.198014] systemd[1]: Listening on Journal Audit Socket.
[   12.213076] systemd[1]: Listening on Journal Socket (/dev/log).
[   12.228477] systemd[1]: Listening on Journal Socket.
[   12.242496] systemd[1]: systemd-networkd.socket: Socket service systemd-networkd.service not loaded, refusing.
[   12.249796] systemd[1]: Failed to listen on Network Service Netlink Socket.
[   12.280052] systemd[1]: Listening on udev Control Socket.
[   12.295220] systemd[1]: Listening on udev Kernel Socket.
[   12.331928] systemd[1]: Mounting Huge Pages File System...
[   12.353608] systemd[1]: Mounting POSIX Message Queue File System...
[   12.374317] systemd[1]: Mounting Kernel Debug File System...
[   12.396012] systemd[1]: Mounting Kernel Trace File System...
[   12.410708] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
[   12.426853] systemd[1]: Starting Restore / save the current clock...
[   12.451024] systemd[1]: Starting Wait for network to be configured by ifupdown...
[   12.474236] systemd[1]: Starting Set the console keyboard layout...
[   12.520498] systemd[1]: Starting Create List of Static Device Nodes...
[   12.544925] systemd[1]: Starting Load Kernel Module chromeos_pstore...
[   12.567445] systemd[1]: Starting Load Kernel Module configfs...
[   12.589992] systemd[1]: Starting Load Kernel Module drm...
[   12.612557] systemd[1]: Starting Load Kernel Module efi_pstore...
[   12.636233] systemd[1]: Starting Load Kernel Module fuse...
[   12.658370] systemd[1]: Starting Load Kernel Module pstore_blk...
[   12.680996] systemd[1]: Starting Load Kernel Module pstore_zone...
[   12.704914] systemd[1]: Starting Load Kernel Module ramoops...
[   12.719174] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[   12.760368] systemd[1]: Starting Load Kernel Modules...
[   12.784474] systemd[1]: Starting Generate network units from Kernel command line...
[   12.815010] systemd[1]: Starting Remount Root and Kernel File Systems...
[   12.838309] systemd[1]: Starting Coldplug All udev Devices...
[   12.870651] systemd[1]: Mounted Huge Pages File System.
[   12.883314] EXT4-fs (sda1): re-mounted. Quota mode: none.
[   12.898458] systemd[1]: Mounted POSIX Message Queue File System.
[   12.913877] systemd[1]: Mounted Kernel Debug File System.
[   12.928257] systemd[1]: Mounted Kernel Trace File System.
[   12.944083] systemd[1]: Finished Restore / save the current clock.
[   12.961538] systemd[1]: Finished Wait for network to be configured by ifupdown.
[   12.978404] systemd[1]: Finished Set the console keyboard layout.
[   12.994883] systemd[1]: Finished Create List of Static Device Nodes.
[   13.010570] systemd[1]: modprobe@chromeos_pstore.service: Deactivated successfully.
[   13.019979] systemd[1]: Finished Load Kernel Module chromeos_pstore.
[   13.036358] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[   13.045668] systemd[1]: Finished Load Kernel Module configfs.
[   13.062272] systemd[1]: modprobe@drm.service: Deactivated successfully.
[   13.071313] systemd[1]: Finished Load Kernel Module drm.
[   13.087215] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
[   13.097577] systemd[1]: Finished Load Kernel Module efi_pstore.
[   13.113448] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[   13.126267] systemd[1]: Finished Load Kernel Module fuse.
[   13.142109] systemd[1]: modprobe@pstore_blk.service: Deactivated successfully.
[   13.153465] systemd[1]: Finished Load Kernel Module pstore_blk.
[   13.170102] systemd[1]: modprobe@pstore_zone.service: Deactivated successfully.
[   13.179942] systemd[1]: Finished Load Kernel Module pstore_zone.
[   13.197514] systemd[1]: modprobe@ramoops.service: Deactivated successfully.
[   13.206399] systemd[1]: Finished Load Kernel Module ramoops.
[   13.222633] systemd[1]: Finished Load Kernel Modules.
[   13.239200] systemd[1]: Finished Generate network units from Kernel command line.
[   13.256081] systemd[1]: Finished Remount Root and Kernel File Systems.
[   13.303680] systemd[1]: Reached target Preparation for Network.
[   13.325494] systemd[1]: Mounting FUSE Control File System...
[   13.346491] systemd[1]: Mounting Kernel Configuration File System...
[   13.360182] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[   13.396352] systemd[1]: Starting Load/Save Random Seed...
[   13.418156] systemd[1]: Starting Apply Kernel Variables...
[   13.440048] systemd[1]: Starting Create System Users...
[   13.467964] systemd[1]: Mounted FUSE Control File System.
[   13.482867] systemd[1]: Mounted Kernel Configuration File System.
[   13.905880] systemd[1]: Finished Coldplug All udev Devices.
[   13.952416] systemd[1]: Starting Helper to synchronize boot up for ifupdown...
[   13.970715] systemd[1]: Finished Helper to synchronize boot up for ifupdown.
[   14.242029] systemd[1]: Finished Load/Save Random Seed.
[   14.257338] systemd[1]: Condition check resulted in First Boot Complete being skipped.
[   14.268330] systemd[1]: Finished Create System Users.
Armbian 23.08.0-trunk Jammy ttyS2
station-m2 login:
There are things left
Quote
but I can say both USB port works, HDMI works too
Edited by ewww
@maka ethernet can not connect, still need your help,  dmesg shows me:
Quote
[   31.467015] rk_gmac-dwmac fe010000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0
[   31.467519] rk_gmac-dwmac fe010000.ethernet eth0: __stmmac_open: Cannot attach to PHY (error: -19)
[   31.561666] rk_gmac-dwmac fe010000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0
[   31.562158] rk_gmac-dwmac fe010000.ethernet eth0: __stmmac_open: Cannot attach to PHY (error: -19)
[   31.574426] rk_gmac-dwmac fe010000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0
[   31.574992] rk_gmac-dwmac fe010000.ethernet eth0: __stmmac_open: Cannot attach to PHY (error: -19)
[   31.586589] rk_gmac-dwmac fe010000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0
[   31.587108] rk_gmac-dwmac fe010000.ethernet eth0: __stmmac_open: Cannot attach to PHY (error: -19)
[   31.599582] rk_gmac-dwmac fe010000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0
[   31.600191] rk_gmac-dwmac fe010000.ethernet eth0: __stmmac_open: Cannot attach to PHY (error: -19)
Edited by ewww
@maka rk3566-box-demo_rboxr2_5.dtb
ethernet: no more  __stmmac_open: Cannot attach to PHY (error: -19), it appeared to be probed correctly but can not connect, not get ip from dhcp, even manually set static ip
Quote
 kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x412fd050]
[    0.000000] Linux version 6.1.34-media (armbian@next) (aarch64-linux-gnu-gcc (Ubuntu 11.3.0-1ubuntu1~22.04.1) 11.3.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #1 SMP PREEMPT_DYNAMIC Wed Jun 14 09:15:34 UTC 2023
[    0.000000] Machine model: Rockchip RK3566 BOX DEMO Board
[    0.000000] efi: UEFI not found.
[    0.000000] NUMA: No NUMA configuration found
[    0.000000] NUMA: Faking a node at [mem 0x0000000000200000-0x00000000efffffff]
[    0.000000] NUMA: NODE_DATA [mem 0xef7ec100-0xef7f1fff]
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000000200000-0x00000000efffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000200000-0x00000000083fffff]
[    0.000000]   node   0: [mem 0x0000000009400000-0x00000000efffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000200000-0x00000000efffffff]
[    0.000000] On node 0, zone DMA: 512 pages in unavailable ranges
[    0.000000] On node 0, zone DMA: 4096 pages in unavailable ranges
[    0.000000] cma: Reserved 256 MiB at 0x00000000dba00000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 30 pages/cpu s83112 r8192 d31576 u122880
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: Virtualization Host Extensions
[    0.000000] CPU features: detected: Qualcomm erratum 1009, or ARM erratum 1286807, 2441009
[    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[    0.000000] alternatives: applying boot alternatives
[    0.000000] Fallback order for Node 0: 0
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 963080
[    0.000000] Policy zone: DMA
[    0.000000] Kernel command line: root=UUID=a657b566-b886-45b2-9c35-b27754119297 rootflags=data=writeback rw rootwait console=ttyS02,1500000 console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 loglevel=7
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] Memory: 3515188K/3913728K available (14528K kernel code, 3388K rwdata, 4740K rodata, 3520K init, 1028K bss, 136396K reserved, 262144K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] trace event string verifier disabled
[    0.000000] Dynamic Preempt: none
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[    0.000000]     Trampoline variant of Tasks RCU enabled.
[    0.000000]     Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 320 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: MBI range [296:319]
[    0.000000] GICv3: Using MBI frame 0x00000000fd410000
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GICv3: GICv3 features: 16 PPIs
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x00000000fd460000
[    0.000000] ITS: No ITS available, not enabling LPIs
[    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000001] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.001544] Console: colour dummy device 80x25
[    0.002211] printk: console [tty0] enabled
[    0.002377] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.002420] pid_max: default: 32768 minimum: 301
[    0.002717] LSM: Security Framework initializing
[    0.002817] Yama: becoming mindful.
[    0.002905] LSM support for eBPF active
[    0.003115] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.003167] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.005076] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    0.006306] cblist_init_generic: Setting adjustable number of callback queues.
[    0.006345] cblist_init_generic: Setting shift to 2 and lim to 1.
[    0.006515] cblist_init_generic: Setting shift to 2 and lim to 1.
[    0.006907] rcu: Hierarchical SRCU implementation.
[    0.006932] rcu:     Max phase no-delay instances is 1000.
[    0.013473] EFI services will not be available.
[    0.014179] smp: Bringing up secondary CPUs ...
[    0.015266] Detected VIPT I-cache on CPU1
[    0.015388] cacheinfo: Unable to detect cache hierarchy for CPU 1
[    0.015411] GICv3: CPU1: found redistributor 100 region 0:0x00000000fd480000
[    0.015470] CPU1: Booted secondary processor 0x0000000100 [0x412fd050]
[    0.016667] Detected VIPT I-cache on CPU2
[    0.016779] cacheinfo: Unable to detect cache hierarchy for CPU 2
[    0.016801] GICv3: CPU2: found redistributor 200 region 0:0x00000000fd4a0000
[    0.016850] CPU2: Booted secondary processor 0x0000000200 [0x412fd050]
[    0.017931] Detected VIPT I-cache on CPU3
[    0.018042] cacheinfo: Unable to detect cache hierarchy for CPU 3
[    0.018064] GICv3: CPU3: found redistributor 300 region 0:0x00000000fd4c0000
[    0.018107] CPU3: Booted secondary processor 0x0000000300 [0x412fd050]
[    0.018249] smp: Brought up 1 node, 4 CPUs
[    0.018413] SMP: Total of 4 processors activated.
[    0.018433] CPU features: detected: 32-bit EL0 Support
[    0.018449] CPU features: detected: 32-bit EL1 Support
[    0.018467] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[    0.018489] CPU features: detected: Common not Private translations
[    0.018505] CPU features: detected: CRC32 instructions
[    0.018521] CPU features: detected: Data cache clean to Point of Persistence
[    0.018543] CPU features: detected: RCpc load-acquire (LDAPR)
[    0.018559] CPU features: detected: LSE atomic instructions
[    0.018575] CPU features: detected: Privileged Access Never
[    0.018590] CPU features: detected: RAS Extension Support
[    0.018609] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[    0.018740] CPU: All CPU(s) started at EL2
[    0.018763] alternatives: applying system-wide alternatives
[    0.025609] devtmpfs: initialized
[    0.055299] Registered cp15_barrier emulation handler
[    0.055354] Registered setend emulation handler
[    0.055655] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.055703] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.063700] pinctrl core: initialized pinctrl subsystem
[    0.064719] DMI not present or invalid.
[    0.065731] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.067641] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[    0.068385] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.068997] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.069105] audit: initializing netlink subsys (disabled)
[    0.069387] audit: type=2000 audit(0.064:1): state=initialized audit_enabled=0 res=1
[    0.070713] thermal_sys: Registered thermal governor 'fair_share'
[    0.070725] thermal_sys: Registered thermal governor 'bang_bang'
[    0.070752] thermal_sys: Registered thermal governor 'step_wise'
[    0.070771] thermal_sys: Registered thermal governor 'user_space'
[    0.070863] cpuidle: using governor ladder
[    0.070934] cpuidle: using governor menu
[    0.071307] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.071516] ASID allocator initialised with 65536 entries
[    0.073539] Serial: AMBA PL011 UART driver
[    0.087186] platform fe040000.vop: Fixed dependency cycle(s) with /hdmi@fe0a0000
[    0.114046] rockchip-gpio fdd60000.gpio: probed /pinctrl/gpio@fdd60000
[    0.114838] rockchip-gpio fe740000.gpio: probed /pinctrl/gpio@fe740000
[    0.115668] rockchip-gpio fe750000.gpio: probed /pinctrl/gpio@fe750000
[    0.116413] rockchip-gpio fe760000.gpio: probed /pinctrl/gpio@fe760000
[    0.117251] rockchip-gpio fe770000.gpio: probed /pinctrl/gpio@fe770000
[    0.118454] platform fe0a0000.hdmi: Fixed dependency cycle(s) with /hdmi-con
[    0.125708] KASLR disabled due to lack of seed
[    0.136913] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    0.136957] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[    0.136980] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[    0.136999] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[    0.137017] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.137034] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[    0.137052] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[    0.137070] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[    0.206173] raid6: neonx8   gen()  1415 MB/s
[    0.274303] raid6: neonx4   gen()  1443 MB/s
[    0.342398] raid6: neonx2   gen()  1335 MB/s
[    0.410509] raid6: neonx1   gen()  1098 MB/s
[    0.478591] raid6: int64x8  gen()   910 MB/s
[    0.546703] raid6: int64x4  gen()  1046 MB/s
[    0.614800] raid6: int64x2  gen()   937 MB/s
[    0.682890] raid6: int64x1  gen()   671 MB/s
[    0.682912] raid6: using algorithm neonx4 gen() 1443 MB/s
[    0.750982] raid6: .... xor() 1098 MB/s, rmw enabled
[    0.751006] raid6: using neon recovery algorithm
[    0.752189] fbcon: Taking over console
[    0.752271] ACPI: Interpreter disabled.
[    0.757586] iommu: Default domain type: Translated
[    0.757617] iommu: DMA domain TLB invalidation policy: lazy mode
[    0.758406] usbcore: registered new interface driver usbfs
[    0.758489] usbcore: registered new interface driver hub
[    0.758551] usbcore: registered new device driver usb
[    0.758967] pps_core: LinuxPPS API ver. 1 registered
[    0.758991] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.759058] PTP clock support registered
[    0.759628] EDAC MC: Ver: 3.0.0
[    0.760249] arm-scmi firmware:scmi: Enabled polling mode TX channel - prot_id:16
[    0.760470] arm-scmi firmware:scmi: SCMI Notifications - Core Enabled.
[    0.760558] arm-scmi firmware:scmi: Malformed reply - real_sz:8  calc_sz:4  (loop_num_ret:1)
[    0.760590] arm-scmi firmware:scmi: SCMI Protocol v2.0 'rockchip:' Firmware version 0x0
[    0.762327] NetLabel: Initializing
[    0.762355] NetLabel:  domain hash size = 128
[    0.762372] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    0.762484] NetLabel:  unlabeled traffic allowed by default
[    0.762797] vgaarb: loaded
[    0.763500] clocksource: Switched to clocksource arch_sys_counter
[    0.764229] VFS: Disk quotas dquot_6.6.0
[    0.764340] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.764797] pnp: PnP ACPI: disabled
[    0.779844] NET: Registered PF_INET protocol family
[    0.780287] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.784722] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[    0.784824] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.784888] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.785180] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[    0.786229] TCP: Hash tables configured (established 32768 bind 32768)
[    0.786715] MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear)
[    0.786895] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.787001] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.787367] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.787455] NET: Registered PF_XDP protocol family
[    0.787545] PCI: CLS 0 bytes, default 64
[    0.788513] Trying to unpack rootfs image as initramfs...
[    0.810907] hw perfevents: enabled with armv8_cortex_a55 PMU driver, 7 counters available
[    0.811991] kvm [1]: IPA Size Limit: 40 bits
[    0.812047] kvm [1]: GICv3: no GICV resource entry
[    0.812069] kvm [1]: disabling GICv2 emulation
[    0.812108] kvm [1]: GIC system register CPU interface enabled
[    0.812484] kvm [1]: vgic interrupt IRQ9
[    0.813174] kvm [1]: VHE mode initialized successfully
[    0.815706] Initialise system trusted keyrings
[    0.816103] workingset: timestamp_bits=39 max_order=20 bucket_order=0
[    0.825219] zbud: loaded
[    0.828586] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.828862] fuse: init (API version 7.37)
[    0.884757] xor: measuring software checksum speed
[    0.890563]    8regs           :  1721 MB/sec
[    0.896864]    32regs          :  1577 MB/sec
[    0.902728]    arm64_neon      :  1692 MB/sec
[    0.902755] xor: using function: 8regs (1721 MB/sec)
[    0.902784] Key type asymmetric registered
[    0.902804] Asymmetric key parser 'x509' registered
[    2.797507] Freeing initrd memory: 32552K
[    2.827014] alg: self-tests for CTR-KDF (hmac(sha256)) passed
[    2.827208] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[    2.827423] io scheduler mq-deadline registered
[    2.827839] io scheduler bfq registered
[    2.844857] arm-scmi firmware:scmi: Failed. SCMI protocol 22 not active.
[    2.850920] Serial: 8250/16550 driver, 8 ports, IRQ sharing enabled
[    2.855747] fe650000.serial: ttyS1 at MMIO 0xfe650000 (irq = 23, base_baud = 1500000) is a 16550A
[    2.855991] serial serial0: tty port ttyS1 registered
[    2.857153] fe660000.serial: ttyS2 at MMIO 0xfe660000 (irq = 24, base_baud = 1500000) is a 16550A
[    2.970036] printk: console [ttyS2] enabled
[    2.972196] Serial: AMBA driver
[    2.975793] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    2.989343] brd: module loaded
[    2.999655] loop: module loaded
[    3.005038] thunder_xcv, ver 1.0
[    3.005416] thunder_bgx, ver 1.0
[    3.005770] nicpf, ver 1.0
[    3.008344] rk_gmac-dwmac fe010000.ethernet: IRQ eth_lpi not found
[    3.009175] rk_gmac-dwmac fe010000.ethernet: supply phy not found, using dummy regulator
[    3.010131] rk_gmac-dwmac fe010000.ethernet: clock input or output? (input).
[    3.010781] rk_gmac-dwmac fe010000.ethernet: TX delay(0x4b).
[    3.011300] rk_gmac-dwmac fe010000.ethernet: RX delay(0x2b).
[    3.011858] rk_gmac-dwmac fe010000.ethernet: integrated PHY? (no).
[    3.012466] rk_gmac-dwmac fe010000.ethernet: clock input from PHY
[    3.018037] rk_gmac-dwmac fe010000.ethernet: init for RGMII
[    3.018892] rk_gmac-dwmac fe010000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[    3.019582] rk_gmac-dwmac fe010000.ethernet:     DWMAC4/5
[    3.020058] rk_gmac-dwmac fe010000.ethernet: DMA HW capability register supported
[    3.020735] rk_gmac-dwmac fe010000.ethernet: RX Checksum Offload Engine supported
[    3.021410] rk_gmac-dwmac fe010000.ethernet: TX Checksum insertion supported
[    3.022045] rk_gmac-dwmac fe010000.ethernet: Wake-Up On Lan supported
[    3.022707] rk_gmac-dwmac fe010000.ethernet: TSO supported
[    3.023209] rk_gmac-dwmac fe010000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[    3.023955] rk_gmac-dwmac fe010000.ethernet: Enabled RFS Flow TC (entries=10)
[    3.024607] rk_gmac-dwmac fe010000.ethernet: TSO feature enabled
[    3.025153] rk_gmac-dwmac fe010000.ethernet: Using 32/32 bits DMA host/device width
[    3.179329] usbcore: registered new interface driver usbserial_generic
[    3.180025] usbserial: USB Serial support registered for generic
[    3.180615] usbcore: registered new interface driver ch341
[    3.181141] usbserial: USB Serial support registered for ch341-uart
[    3.181775] usbcore: registered new interface driver cp210x
[    3.182309] usbserial: USB Serial support registered for cp210x
[    3.182911] usbcore: registered new interface driver ftdi_sio
[    3.183462] usbserial: USB Serial support registered for FTDI USB Serial Device
[    3.184196] usbcore: registered new interface driver pl2303
[    3.184733] usbserial: USB Serial support registered for pl2303
[    3.185963] mousedev: PS/2 mouse device common for all mice
[    3.191992] ledtrig-cpu: registered to indicate activity on CPUs
[    3.193278] arm-scmi firmware:scmi: Failed. SCMI protocol 17 not active.
[    3.193972] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    3.199901] NET: Registered PF_INET6 protocol family
[    3.228920] Segment Routing with IPv6
[    3.229367] In-situ OAM (IOAM) with IPv6
[    3.231353] registered taskstats version 1
[    3.231846] Loading compiled-in X.509 certificates
[    3.236276] zswap: loaded using pool zstd/z3fold
[    3.237643] Key type .fscrypt registered
[    3.238015] Key type fscrypt-provisioning registered
[    3.240447] Btrfs loaded, crc32c=crc32c-generic, assert=on, integrity-checker=on, zoned=yes, fsverity=yes
[    3.267816] Key type encrypted registered
[    3.268267] ima: No TPM chip found, activating TPM-bypass!
[    3.268779] ima: Allocated hash algorithm: sha1
[    3.269230] ima: No architecture policies found
[    3.269750] evm: Initialising EVM extended attributes:
[    3.270224] evm: security.selinux
[    3.270533] evm: security.SMACK64
[    3.270840] evm: security.SMACK64EXEC
[    3.271174] evm: security.SMACK64TRANSMUTE
[    3.271593] evm: security.SMACK64MMAP
[    3.271936] evm: security.apparmor
[    3.272250] evm: security.ima
[    3.272525] evm: security.capability
[    3.272852] evm: HMAC attrs: 0x1
[    3.328254] psci_checker: PSCI checker started using 4 CPUs
[    3.328795] psci_checker: Starting hotplug tests
[    3.329225] psci_checker: Trying to turn off and on again all CPUs
[    3.331520] psci: CPU0 killed (polled 4 ms)
[    3.335470] psci: CPU1 killed (polled 0 ms)
[    3.338600] psci: CPU2 killed (polled 0 ms)
[    3.341939] Detected VIPT I-cache on CPU0
[    3.342390] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    3.342949] GICv3: CPU0: found redistributor 0 region 0:0x00000000fd460000
[    3.343636] CPU0: Booted secondary processor 0x0000000000 [0x412fd050]
[    3.346161] Detected VIPT I-cache on CPU1
[    3.346583] cacheinfo: Unable to detect cache hierarchy for CPU 1
[    3.347137] GICv3: CPU1: found redistributor 100 region 0:0x00000000fd480000
[    3.347824] CPU1: Booted secondary processor 0x0000000100 [0x412fd050]
[    3.350692] Detected VIPT I-cache on CPU2
[    3.351161] cacheinfo: Unable to detect cache hierarchy for CPU 2
[    3.351720] GICv3: CPU2: found redistributor 200 region 0:0x00000000fd4a0000
[    3.352411] CPU2: Booted secondary processor 0x0000000200 [0x412fd050]
[    3.354482] psci_checker: Trying to turn off and on again group 0 (CPUs 0-3)
[    3.355639] psci: CPU0 killed (polled 0 ms)
[    3.358089] psci: CPU1 killed (polled 0 ms)
[    3.361454] psci: CPU2 killed (polled 0 ms)
[    3.364150] Detected VIPT I-cache on CPU0
[    3.364578] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    3.365134] GICv3: CPU0: found redistributor 0 region 0:0x00000000fd460000
[    3.365812] CPU0: Booted secondary processor 0x0000000000 [0x412fd050]
[    3.368320] Detected VIPT I-cache on CPU1
[    3.368745] cacheinfo: Unable to detect cache hierarchy for CPU 1
[    3.369300] GICv3: CPU1: found redistributor 100 region 0:0x00000000fd480000
[    3.369988] CPU1: Booted secondary processor 0x0000000100 [0x412fd050]
[    3.372927] Detected VIPT I-cache on CPU2
[    3.373396] cacheinfo: Unable to detect cache hierarchy for CPU 2
[    3.373954] GICv3: CPU2: found redistributor 200 region 0:0x00000000fd4a0000
[    3.374644] CPU2: Booted secondary processor 0x0000000200 [0x412fd050]
[    3.376702] psci_checker: Hotplug tests passed OK
[    3.377146] psci_checker: Starting suspend tests (10 cycles per state)
[    3.377794] psci_checker: cpuidle not available on CPU 0, ignoring
[    3.378359] psci_checker: cpuidle not available on CPU 1, ignoring
[    3.378917] psci_checker: cpuidle not available on CPU 2, ignoring
[    3.379473] psci_checker: cpuidle not available on CPU 3, ignoring
[    3.380073] psci_checker: Could not start suspend tests on any CPU
[    3.380629] psci_checker: PSCI checker completed
[    3.383938] Freeing unused kernel memory: 3520K
[    3.411628] Run /init as init process
[    4.525971] panfrost fde60000.gpu: clock rate = 594000000
[    4.526527] panfrost fde60000.gpu: bus_clock rate = 500000000
[    4.527132] panfrost fde60000.gpu: error -ENODEV: _opp_set_regulators: no regulator (mali) found
[    4.542453] panfrost fde60000.gpu: mali-g52 id 0x7402 major 0x1 minor 0x0 status 0x0
[    4.543195] panfrost fde60000.gpu: features: 00000000,00000cf7, issues: 00000000,00000400
[    4.543984] panfrost fde60000.gpu: Features: L2:0x07110206 Shader:0x00000002 Tiler:0x00000209 Mem:0x1 MMU:0x00002823 AS:0xff JS:0x7
[    4.545061] panfrost fde60000.gpu: shader_present=0x1 l2_present=0x1
[    4.552787] rockchip-vop2 fe040000.vop: Adding to iommu group 2
[    4.553450] iommu: Failed to allocate default IOMMU domain of type 11 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[    4.558997] Synopsys Designware Multimedia Card Interface Driver
[    4.563180] rockchip-drm display-subsystem: bound fe040000.vop (ops vop2_component_ops [rockchipdrm])
[    4.564953] dwhdmi-rockchip fe0a0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[    4.571846] dwhdmi-rockchip fe0a0000.hdmi: registered DesignWare HDMI I2C bus driver
[    4.573410] rockchip-drm display-subsystem: bound fe0a0000.hdmi (ops dw_hdmi_rockchip_ops [rockchipdrm])
[    4.573671] dwmmc_rockchip fe2c0000.mmc: IDMAC supports 32-bit address mode.
[    4.574699] sdhci: Secure Digital Host Controller Interface driver
[    4.575070] dwmmc_rockchip fe2c0000.mmc: Using internal DMA controller.
[    4.575684] sdhci: Copyright(c) Pierre Ossman
[    4.576266] dwmmc_rockchip fe2c0000.mmc: Version ID is 270a
[    4.576389] dwmmc_rockchip fe2c0000.mmc: DW MMC controller at irq 38,32 bit host data width,256 deep fifo
[    4.579313] dwmmc_rockchip fe2b0000.mmc: IDMAC supports 32-bit address mode.
[    4.580066] dwmmc_rockchip fe2b0000.mmc: Using internal DMA controller.
[    4.580681] dwmmc_rockchip fe2b0000.mmc: Version ID is 270a
[    4.581256] dwmmc_rockchip fe2b0000.mmc: DW MMC controller at irq 37,32 bit host data width,256 deep fifo
[    4.582714] dwmmc_rockchip fe2b0000.mmc: Got CD GPIO
[    4.584441] [drm] Initialized panfrost 1.2.0 20180908 for fde60000.gpu on minor 0
[    4.586993] [drm] Initialized rockchip 1.0.0 20140818 for display-subsystem on minor 1
[    4.587885] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
[    4.589312] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
[    4.590022] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
[    4.595664] mmc_host mmc0: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[    4.601642] dwmmc_rockchip fe2c0000.mmc: IDMAC supports 32-bit address mode.
[    4.602359] dwmmc_rockchip fe2c0000.mmc: Using internal DMA controller.
[    4.602979] dwmmc_rockchip fe2c0000.mmc: Version ID is 270a
[    4.603611] dwmmc_rockchip fe2c0000.mmc: DW MMC controller at irq 38,32 bit host data width,256 deep fifo
[    4.614689] sdhci-pltfm: SDHCI platform and OF driver helper
[    4.616093] dwmmc_rockchip fe2c0000.mmc: IDMAC supports 32-bit address mode.
[    4.616795] dwmmc_rockchip fe2c0000.mmc: Using internal DMA controller.
[    4.617413] dwmmc_rockchip fe2c0000.mmc: Version ID is 270a
[    4.617967] dwmmc_rockchip fe2c0000.mmc: DW MMC controller at irq 38,32 bit host data width,256 deep fifo
[    4.629010] dma-pl330 fe530000.dma-controller: Loaded driver for PL330 DMAC-241330
[    4.629752] dma-pl330 fe530000.dma-controller:     DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[    4.632624] dwmmc_rockchip fe2c0000.mmc: IDMAC supports 32-bit address mode.
[    4.633330] dwmmc_rockchip fe2c0000.mmc: Using internal DMA controller.
[    4.633945] dwmmc_rockchip fe2c0000.mmc: Version ID is 270a
[    4.634515] dwmmc_rockchip fe2c0000.mmc: DW MMC controller at irq 38,32 bit host data width,256 deep fifo
[    4.634910] dma-pl330 fe550000.dma-controller: Loaded driver for PL330 DMAC-241330
[    4.636118] dma-pl330 fe550000.dma-controller:     DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[    4.645429] dwc3 fd000000.usb: can't request region for resource [mem 0xfd00c100-0xfd3fffff]
[    4.646241] dwc3: probe of fd000000.usb failed with error -16
[    4.648958] dwmmc_rockchip fe2c0000.mmc: IDMAC supports 32-bit address mode.
[    4.649661] dwmmc_rockchip fe2c0000.mmc: Using internal DMA controller.
[    4.650274] dwmmc_rockchip fe2c0000.mmc: Version ID is 270a
[    4.650826] dwmmc_rockchip fe2c0000.mmc: DW MMC controller at irq 38,32 bit host data width,256 deep fifo
[    4.659588] mmc2: SDHCI controller on fe310000.mmc [fe310000.mmc] using ADMA
[    4.662967] dwmmc_rockchip fe2c0000.mmc: IDMAC supports 32-bit address mode.
[    4.663723] dwmmc_rockchip fe2c0000.mmc: Using internal DMA controller.
[    4.664343] dwmmc_rockchip fe2c0000.mmc: Version ID is 270a
[    4.664900] dwmmc_rockchip fe2c0000.mmc: DW MMC controller at irq 38,32 bit host data width,256 deep fifo
[    4.665413] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[    4.666779] mmc0: new high speed SDHC card at address 0001
[    4.710612] dwmmc_rockchip fe2c0000.mmc: IDMAC supports 32-bit address mode.
[    4.711319] dwmmc_rockchip fe2c0000.mmc: Using internal DMA controller.
[    4.711985] dwmmc_rockchip fe2c0000.mmc: Version ID is 270a
[    4.712546] dwmmc_rockchip fe2c0000.mmc: DW MMC controller at irq 38,32 bit host data width,256 deep fifo
[    4.714015] dwmmc_rockchip fe2c0000.mmc: allocated mmc-pwrseq
[    4.714571] mmc_host mmc1: card is non-removable.
[    4.723097] mmc2: new HS200 MMC card at address 0001
[    4.727678] mmc_host mmc1: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[    4.840784] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[    4.845493] mmc1: new high speed SDIO card at address 0001
[    4.970049] Registered IR keymap rc-cec
[    4.970590] rc rc0: dw_hdmi as /devices/platform/fe0a0000.hdmi/rc/rc0
[    4.971446] input: dw_hdmi as /devices/platform/fe0a0000.hdmi/rc/rc0/input0
[    5.047430] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[    5.048100] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 1
[    5.048995] xhci-hcd xhci-hcd.2.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x8000000002010010
[    5.049957] xhci-hcd xhci-hcd.2.auto: irq 44, io mem 0xfcc00000
[    5.050770] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[    5.051304] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 2
[    5.052097] xhci-hcd xhci-hcd.2.auto: Host supports USB 3.0 SuperSpeed
[    5.054305] hub 1-0:1.0: USB hub found
[    5.055616] hub 1-0:1.0: 1 port detected
[    5.057994] mmcblk0: mmc0:0001 SD 3.72 GiB
[    5.061559] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    5.064240] hub 2-0:1.0: USB hub found
[    5.064825] hub 2-0:1.0: 1 port detected
[    5.069920] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
[    5.070491] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 3
[    5.071439] xhci-hcd xhci-hcd.3.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000000002010010
[    5.072437] xhci-hcd xhci-hcd.3.auto: irq 45, io mem 0xfd000000
[    5.073242] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
[    5.073783] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 4
[    5.074505] xhci-hcd xhci-hcd.3.auto: Host supports USB 3.0 SuperSpeed
[    5.076630] hub 3-0:1.0: USB hub found
[    5.077089] hub 3-0:1.0: 1 port detected
[    5.078317] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[    5.080468] hub 4-0:1.0: USB hub found
[    5.080931] hub 4-0:1.0: 1 port detected
[    5.081520] GPT:Primary header thinks Alt. header is not at the end of the disk.
[    5.082205] GPT:7744511 != 7802879
[    5.082526] GPT:Alternate GPT header not at the end of the disk.
[    5.083066] GPT:7744511 != 7802879
[    5.083380] GPT: Use GNU Parted to correct GPT errors.
[    5.083933]  mmcblk0: p1 p2
[    5.088082] mmcblk2: mmc2:0001 CJNB4R 58.2 GiB
[    5.125103]  mmcblk2: p2 p4
[    5.127125] mmcblk2boot0: mmc2:0001 CJNB4R 4.00 MiB
[    5.130650] mmcblk2boot1: mmc2:0001 CJNB4R 4.00 MiB
[    5.133545] mmcblk2rpmb: mmc2:0001 CJNB4R 4.00 MiB, chardev (240:0)
[    5.335546] usb 3-1: new high-speed USB device number 2 using xhci-hcd
[    5.511337] SCSI subsystem initialized
[    5.516457] usb-storage 3-1:1.0: USB Mass Storage device detected
[    5.517882] scsi host0: usb-storage 3-1:1.0
[    5.519077] usbcore: registered new interface driver usb-storage
[    5.522069] usbcore: registered new interface driver uas
[    7.192415] scsi 0:0:0:0: Direct-Access     JetFlash Transcend 16GB   1100 PQ: 0 ANSI: 4
[    7.201872] sd 0:0:0:0: [sda] 31703040 512-byte logical blocks: (16.2 GB/15.1 GiB)
[    7.203639] sd 0:0:0:0: [sda] Write Protect is off
[    7.204726] sd 0:0:0:0: [sda] No Caching mode page found
[    7.205242] sd 0:0:0:0: [sda] Assuming drive cache: write through
[    7.218688]  sda: sda1
[    7.219683] sd 0:0:0:0: [sda] Attached SCSI removable disk
[    7.701067] EXT4-fs (sda1): mounted filesystem with writeback data mode. Quota mode: none.
[    8.655303] systemd[1]: System time before build time, advancing clock.
[    8.681844] systemd[1]: Inserted module 'autofs4'
[    8.759663] systemd[1]: systemd 249.11-0ubuntu3.9 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY -P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[    8.764332] systemd[1]: Detected architecture arm64.
[    8.768836] systemd[1]: Hostname set to <station-m2>.
[    8.971429] dw-apb-uart fe660000.serial: forbid DMA for kernel console
[    9.976798] systemd[1]: Queued start job for default target Graphical Interface.
[   12.239511] random: crng init done
[   12.259378] systemd[1]: Created slice Slice /system/modprobe.
[   12.263602] systemd[1]: Created slice Slice /system/serial-getty.
[   12.266500] systemd[1]: Created slice User and Session Slice.
[   12.268027] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   12.270476] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[   12.272455] systemd[1]: Reached target Slice Units.
[   12.273346] systemd[1]: Reached target Swaps.
[   12.274119] systemd[1]: Reached target System Time Set.
[   12.275220] systemd[1]: Reached target Local Verity Protected Volumes.
[   12.301913] systemd[1]: Listening on RPCbind Server Activation Socket.
[   12.304263] systemd[1]: Listening on Syslog Socket.
[   12.306022] systemd[1]: Listening on fsck to fsckd communication Socket.
[   12.307474] systemd[1]: Listening on initctl Compatibility Named Pipe.
[   12.310179] systemd[1]: Listening on Journal Audit Socket.
[   12.311955] systemd[1]: Listening on Journal Socket (/dev/log).
[   12.314005] systemd[1]: Listening on Journal Socket.
[   12.315438] systemd[1]: systemd-networkd.socket: Socket service systemd-networkd.service not loaded, refusing.
[   12.316481] systemd[1]: Failed to listen on Network Service Netlink Socket.
[   12.326333] systemd[1]: Listening on udev Control Socket.
[   12.328250] systemd[1]: Listening on udev Kernel Socket.
[   12.352117] systemd[1]: Mounting Huge Pages File System...
[   12.359985] systemd[1]: Mounting POSIX Message Queue File System...
[   12.368326] systemd[1]: Mounting Kernel Debug File System...
[   12.376338] systemd[1]: Mounting Kernel Trace File System...
[   12.378339] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
[   12.388236] systemd[1]: Starting Restore / save the current clock...
[   12.396980] systemd[1]: Starting Wait for network to be configured by ifupdown...
[   12.405734] systemd[1]: Starting Set the console keyboard layout...
[   12.415080] systemd[1]: Starting Create List of Static Device Nodes...
[   12.425052] systemd[1]: Starting Load Kernel Module chromeos_pstore...
[   12.434778] systemd[1]: Starting Load Kernel Module configfs...
[   12.444627] systemd[1]: Starting Load Kernel Module drm...
[   12.454145] systemd[1]: Starting Load Kernel Module efi_pstore...
[   12.463632] systemd[1]: Starting Load Kernel Module fuse...
[   12.473088] systemd[1]: Starting Load Kernel Module pstore_blk...
[   12.485049] systemd[1]: Starting Load Kernel Module pstore_zone...
[   12.500170] systemd[1]: Starting Load Kernel Module ramoops...
[   12.502623] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[   12.519141] systemd[1]: Starting Load Kernel Modules...
[   12.527945] systemd[1]: Starting Generate network units from Kernel command line...
[   12.537074] systemd[1]: Starting Remount Root and Kernel File Systems...
[   12.546677] systemd[1]: Starting Coldplug All udev Devices...
[   12.569428] systemd[1]: Mounted Huge Pages File System.
[   12.572211] systemd[1]: Mounted POSIX Message Queue File System.
[   12.574210] systemd[1]: Mounted Kernel Debug File System.
[   12.576945] systemd[1]: Mounted Kernel Trace File System.
[   12.580887] systemd[1]: Finished Restore / save the current clock.
[   12.585727] systemd[1]: Finished Wait for network to be configured by ifupdown.
[   12.590685] systemd[1]: Finished Create List of Static Device Nodes.
[   12.593428] EXT4-fs (sda1): re-mounted. Quota mode: none.
[   12.594533] systemd[1]: modprobe@chromeos_pstore.service: Deactivated successfully.
[   12.597999] systemd[1]: Finished Load Kernel Module chromeos_pstore.
[   12.608007] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[   12.610862] systemd[1]: Finished Load Kernel Module configfs.
[   12.615320] systemd[1]: modprobe@drm.service: Deactivated successfully.
[   12.618096] systemd[1]: Finished Load Kernel Module drm.
[   12.621405] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
[   12.624516] systemd[1]: Finished Load Kernel Module efi_pstore.
[   12.627885] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[   12.630526] systemd[1]: Finished Load Kernel Module fuse.
[   12.634276] systemd[1]: modprobe@pstore_blk.service: Deactivated successfully.
[   12.637085] systemd[1]: Finished Load Kernel Module pstore_blk.
[   12.640416] systemd[1]: modprobe@pstore_zone.service: Deactivated successfully.
[   12.643118] systemd[1]: Finished Load Kernel Module pstore_zone.
[   12.647210] systemd[1]: modprobe@ramoops.service: Deactivated successfully.
[   12.650013] systemd[1]: Finished Load Kernel Module ramoops.
[   12.653876] systemd[1]: Finished Load Kernel Modules.
[   12.657745] systemd[1]: Finished Generate network units from Kernel command line.
[   12.661628] systemd[1]: Finished Remount Root and Kernel File Systems.
[   12.664504] systemd[1]: Reached target Preparation for Network.
[   12.688689] systemd[1]: Mounting FUSE Control File System...
[   12.696594] systemd[1]: Mounting Kernel Configuration File System...
[   12.698144] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[   12.706519] systemd[1]: Starting Load/Save Random Seed...
[   12.715063] systemd[1]: Starting Apply Kernel Variables...
[   12.725330] systemd[1]: Starting Create System Users...
[   12.734309] systemd[1]: Mounted FUSE Control File System.
[   12.736199] systemd[1]: Mounted Kernel Configuration File System.
[   12.871895] systemd[1]: Finished Set the console keyboard layout.
[   13.426509] systemd[1]: Finished Coldplug All udev Devices.
[   13.464721] systemd[1]: Starting Helper to synchronize boot up for ifupdown...
[   13.478727] systemd[1]: Finished Helper to synchronize boot up for ifupdown.
[   13.583373] systemd[1]: Finished Load/Save Random Seed.
dmesg
Quote
station-m2:~:# dmesg|grep ethernet
[   33.211836] rk_gmac-dwmac fe010000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0
[   33.307581] rk_gmac-dwmac fe010000.ethernet eth0: PHY [stmmac-0:01] driver [RTL8211F Gigabit Ethernet] (irq=POLL)
[   33.315612] rk_gmac-dwmac fe010000.ethernet eth0: No Safety Features support found
[   33.315640] rk_gmac-dwmac fe010000.ethernet eth0: IEEE 1588-2008 Advanced Timestamp supported
[   33.315897] rk_gmac-dwmac fe010000.ethernet eth0: registered PTP clock
[   33.316210] rk_gmac-dwmac fe010000.ethernet eth0: configuring for phy/rgmii link mode
[   36.422552] rk_gmac-dwmac fe010000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
Quote
#dhclient hangs
station-m2:~:# dhclient eth0
^C
station-m2:~:# ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
    link/ether 6e:87:63:6f:82:b5 brd ff:ff:ff:ff:ff:ff
Edited by ewww
@maka rk3566-box-demo_rboxr2_6.dtb
Quote
Starting kernel ...
[    0.000000] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.001606] Console: colour dummy device 80x25
[    0.002268] printk: console [tty0] enabled
[    0.002428] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.002470] pid_max: default: 32768 minimum: 301
[    0.002761] LSM: Security Framework initializing
[    0.002861] Yama: becoming mindful.
[    0.002950] LSM support for eBPF active
[    0.003164] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.003221] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.005166] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    0.006397] cblist_init_generic: Setting adjustable number of callback queues.
[    0.006436] cblist_init_generic: Setting shift to 2 and lim to 1.
[    0.006608] cblist_init_generic: Setting shift to 2 and lim to 1.
[    0.007004] rcu: Hierarchical SRCU implementation.
[    0.007028] rcu:     Max phase no-delay instances is 1000.
[    0.013650] EFI services will not be available.
[    0.014361] smp: Bringing up secondary CPUs ...
[    0.015450] Detected VIPT I-cache on CPU1
[    0.015572] cacheinfo: Unable to detect cache hierarchy for CPU 1
[    0.015596] GICv3: CPU1: found redistributor 100 region 0:0x00000000fd480000
[    0.015655] CPU1: Booted secondary processor 0x0000000100 [0x412fd050]
[    0.016849] Detected VIPT I-cache on CPU2
[    0.016962] cacheinfo: Unable to detect cache hierarchy for CPU 2
[    0.016984] GICv3: CPU2: found redistributor 200 region 0:0x00000000fd4a0000
[    0.017032] CPU2: Booted secondary processor 0x0000000200 [0x412fd050]
[    0.018108] Detected VIPT I-cache on CPU3
[    0.018220] cacheinfo: Unable to detect cache hierarchy for CPU 3
[    0.018240] GICv3: CPU3: found redistributor 300 region 0:0x00000000fd4c0000
[    0.018283] CPU3: Booted secondary processor 0x0000000300 [0x412fd050]
[    0.018421] smp: Brought up 1 node, 4 CPUs
[    0.018587] SMP: Total of 4 processors activated.
[    0.018606] CPU features: detected: 32-bit EL0 Support
[    0.018622] CPU features: detected: 32-bit EL1 Support
[    0.018639] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[    0.018661] CPU features: detected: Common not Private translations
[    0.018677] CPU features: detected: CRC32 instructions
[    0.018692] CPU features: detected: Data cache clean to Point of Persistence
[    0.018712] CPU features: detected: RCpc load-acquire (LDAPR)
[    0.018728] CPU features: detected: LSE atomic instructions
[    0.018745] CPU features: detected: Privileged Access Never
[    0.018759] CPU features: detected: RAS Extension Support
[    0.018779] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[    0.018903] CPU: All CPU(s) started at EL2
[    0.018926] alternatives: applying system-wide alternatives
[    0.025696] devtmpfs: initialized
[    0.055363] Registered cp15_barrier emulation handler
[    0.055417] Registered setend emulation handler
[    0.055714] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.055765] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.063763] pinctrl core: initialized pinctrl subsystem
[    0.064789] DMI not present or invalid.
[    0.065812] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.067714] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[    0.068459] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.069081] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.069185] audit: initializing netlink subsys (disabled)
[    0.069468] audit: type=2000 audit(0.064:1): state=initialized audit_enabled=0 res=1
[    0.070798] thermal_sys: Registered thermal governor 'fair_share'
[    0.070809] thermal_sys: Registered thermal governor 'bang_bang'
[    0.070837] thermal_sys: Registered thermal governor 'step_wise'
[    0.070855] thermal_sys: Registered thermal governor 'user_space'
[    0.070948] cpuidle: using governor ladder
[    0.071020] cpuidle: using governor menu
[    0.071390] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.071594] ASID allocator initialised with 65536 entries
[    0.073603] Serial: AMBA PL011 UART driver
[    0.087324] platform fe040000.vop: Fixed dependency cycle(s) with /hdmi@fe0a0000
[    0.114285] rockchip-gpio fdd60000.gpio: probed /pinctrl/gpio@fdd60000
[    0.115105] rockchip-gpio fe740000.gpio: probed /pinctrl/gpio@fe740000
[    0.115951] rockchip-gpio fe750000.gpio: probed /pinctrl/gpio@fe750000
[    0.116704] rockchip-gpio fe760000.gpio: probed /pinctrl/gpio@fe760000
[    0.117546] rockchip-gpio fe770000.gpio: probed /pinctrl/gpio@fe770000
[    0.118762] platform fe0a0000.hdmi: Fixed dependency cycle(s) with /hdmi-con
[    0.126047] KASLR disabled due to lack of seed
[    0.137215] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    0.137260] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[    0.137283] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[    0.137301] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[    0.137320] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.137337] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[    0.137356] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[    0.137373] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[    0.206254] raid6: neonx8   gen()  1413 MB/s
[    0.274422] raid6: neonx4   gen()  1439 MB/s
[    0.342598] raid6: neonx2   gen()  1331 MB/s
[    0.410792] raid6: neonx1   gen()  1091 MB/s
[    0.478954] raid6: int64x8  gen()   910 MB/s
[    0.547127] raid6: int64x4  gen()  1046 MB/s
[    0.615293] raid6: int64x2  gen()   934 MB/s
[    0.683456] raid6: int64x1  gen()   693 MB/s
[    0.683480] raid6: using algorithm neonx4 gen() 1439 MB/s
[    0.751570] raid6: .... xor() 1097 MB/s, rmw enabled
[    0.751595] raid6: using neon recovery algorithm
[    0.752742] fbcon: Taking over console
[    0.752821] ACPI: Interpreter disabled.
[    0.758119] iommu: Default domain type: Translated
[    0.758152] iommu: DMA domain TLB invalidation policy: lazy mode
[    0.758981] usbcore: registered new interface driver usbfs
[    0.759061] usbcore: registered new interface driver hub
[    0.759149] usbcore: registered new device driver usb
[    0.759562] pps_core: LinuxPPS API ver. 1 registered
[    0.759586] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.759735] PTP clock support registered
[    0.760290] EDAC MC: Ver: 3.0.0
[    0.760917] arm-scmi firmware:scmi: Enabled polling mode TX channel - prot_id:16
[    0.761144] arm-scmi firmware:scmi: SCMI Notifications - Core Enabled.
[    0.761231] arm-scmi firmware:scmi: Malformed reply - real_sz:8  calc_sz:4  (loop_num_ret:1)
[    0.761265] arm-scmi firmware:scmi: SCMI Protocol v2.0 'rockchip:' Firmware version 0x0
[    0.762966] NetLabel: Initializing
[    0.762995] NetLabel:  domain hash size = 128
[    0.763011] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    0.763105] NetLabel:  unlabeled traffic allowed by default
[    0.763382] vgaarb: loaded
[    0.764082] clocksource: Switched to clocksource arch_sys_counter
[    0.764737] VFS: Disk quotas dquot_6.6.0
[    0.764844] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.765332] pnp: PnP ACPI: disabled
[    0.779859] NET: Registered PF_INET protocol family
[    0.780350] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.784767] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[    0.784863] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.784929] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.785222] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[    0.786268] TCP: Hash tables configured (established 32768 bind 32768)
[    0.786678] MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear)
[    0.786859] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.786967] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.787320] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.787410] NET: Registered PF_XDP protocol family
[    0.787443] PCI: CLS 0 bytes, default 64
[    0.788329] Trying to unpack rootfs image as initramfs...
[    0.811372] hw perfevents: enabled with armv8_cortex_a55 PMU driver, 7 counters available
[    0.812472] kvm [1]: IPA Size Limit: 40 bits
[    0.812529] kvm [1]: GICv3: no GICV resource entry
[    0.812549] kvm [1]: disabling GICv2 emulation
[    0.812585] kvm [1]: GIC system register CPU interface enabled
[    0.813170] kvm [1]: vgic interrupt IRQ9
[    0.813810] kvm [1]: VHE mode initialized successfully
[    0.816261] Initialise system trusted keyrings
[    0.816715] workingset: timestamp_bits=39 max_order=20 bucket_order=0
[    0.825865] zbud: loaded
[    0.829190] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.829496] fuse: init (API version 7.37)
[    0.885043] xor: measuring software checksum speed
[    0.890854]    8regs           :  1721 MB/sec
[    0.897154]    32regs          :  1577 MB/sec
[    0.903020]    arm64_neon      :  1692 MB/sec
[    0.903053] xor: using function: 8regs (1721 MB/sec)
[    0.903083] Key type asymmetric registered
[    0.903102] Asymmetric key parser 'x509' registered
[    2.801630] Freeing initrd memory: 32552K
[    2.831153] alg: self-tests for CTR-KDF (hmac(sha256)) passed
[    2.831377] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[    2.831600] io scheduler mq-deadline registered
[    2.831985] io scheduler bfq registered
[    2.848407] arm-scmi firmware:scmi: Failed. SCMI protocol 22 not active.
[    2.854394] Serial: 8250/16550 driver, 8 ports, IRQ sharing enabled
[    2.859067] fe650000.serial: ttyS1 at MMIO 0xfe650000 (irq = 23, base_baud = 1500000) is a 16550A
[    2.859334] serial serial0: tty port ttyS1 registered
[    2.860485] fe660000.serial: ttyS2 at MMIO 0xfe660000 (irq = 24, base_baud = 1500000) is a 16550A
[    2.973354] printk: console [ttyS2] enabled
[    2.975529] Serial: AMBA driver
[    2.979142] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    2.992744] brd: module loaded
[    3.002932] loop: module loaded
[    3.008204] thunder_xcv, ver 1.0
[    3.008614] thunder_bgx, ver 1.0
[    3.008968] nicpf, ver 1.0
[    3.011442] rk_gmac-dwmac fe010000.ethernet: IRQ eth_lpi not found
[    3.012287] rk_gmac-dwmac fe010000.ethernet: supply phy not found, using dummy regulator
[    3.013220] rk_gmac-dwmac fe010000.ethernet: clock input or output? (input).
[    3.013868] rk_gmac-dwmac fe010000.ethernet: TX delay(0x4b).
[    3.014388] rk_gmac-dwmac fe010000.ethernet: RX delay(0x2b).
[    3.014917] rk_gmac-dwmac fe010000.ethernet: integrated PHY? (no).
[    3.015520] rk_gmac-dwmac fe010000.ethernet: clock input from PHY
[    3.021111] rk_gmac-dwmac fe010000.ethernet: init for RGMII
[    3.021976] rk_gmac-dwmac fe010000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[    3.022636] rk_gmac-dwmac fe010000.ethernet:     DWMAC4/5
[    3.023111] rk_gmac-dwmac fe010000.ethernet: DMA HW capability register supported
[    3.023788] rk_gmac-dwmac fe010000.ethernet: RX Checksum Offload Engine supported
[    3.024492] rk_gmac-dwmac fe010000.ethernet: TX Checksum insertion supported
[    3.025134] rk_gmac-dwmac fe010000.ethernet: Wake-Up On Lan supported
[    3.025794] rk_gmac-dwmac fe010000.ethernet: TSO supported
[    3.026298] rk_gmac-dwmac fe010000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[    3.027022] rk_gmac-dwmac fe010000.ethernet: Enabled RFS Flow TC (entries=10)
[    3.027669] rk_gmac-dwmac fe010000.ethernet: TSO feature enabled
[    3.028237] rk_gmac-dwmac fe010000.ethernet: Using 32/32 bits DMA host/device width
[    3.164361] mdio_bus stmmac-0: MDIO device at address 0 is missing.
[    3.167413] usbcore: registered new interface driver usbserial_generic
[    3.168080] usbserial: USB Serial support registered for generic
[    3.168675] usbcore: registered new interface driver ch341
[    3.169202] usbserial: USB Serial support registered for ch341-uart
[    3.169830] usbcore: registered new interface driver cp210x
[    3.170365] usbserial: USB Serial support registered for cp210x
[    3.170943] usbcore: registered new interface driver ftdi_sio
[    3.171492] usbserial: USB Serial support registered for FTDI USB Serial Device
[    3.172224] usbcore: registered new interface driver pl2303
[    3.172783] usbserial: USB Serial support registered for pl2303
[    3.173990] mousedev: PS/2 mouse device common for all mice
[    3.179975] ledtrig-cpu: registered to indicate activity on CPUs
[    3.181299] arm-scmi firmware:scmi: Failed. SCMI protocol 17 not active.
[    3.181992] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    3.187728] NET: Registered PF_INET6 protocol family
[    3.216549] Segment Routing with IPv6
[    3.216996] In-situ OAM (IOAM) with IPv6
[    3.218990] registered taskstats version 1
[    3.219416] Loading compiled-in X.509 certificates
[    3.223754] zswap: loaded using pool zstd/z3fold
[    3.225213] Key type .fscrypt registered
[    3.225588] Key type fscrypt-provisioning registered
[    3.227923] Btrfs loaded, crc32c=crc32c-generic, assert=on, integrity-checker=on, zoned=yes, fsverity=yes
[    3.255624] Key type encrypted registered
[    3.256108] ima: No TPM chip found, activating TPM-bypass!
[    3.256624] ima: Allocated hash algorithm: sha1
[    3.257074] ima: No architecture policies found
[    3.257620] evm: Initialising EVM extended attributes:
[    3.258093] evm: security.selinux
[    3.258403] evm: security.SMACK64
[    3.258707] evm: security.SMACK64EXEC
[    3.259042] evm: security.SMACK64TRANSMUTE
[    3.259417] evm: security.SMACK64MMAP
[    3.259751] evm: security.apparmor
[    3.260088] evm: security.ima
[    3.260368] evm: security.capability
[    3.260695] evm: HMAC attrs: 0x1
[    3.316552] psci_checker: PSCI checker started using 4 CPUs
[    3.317094] psci_checker: Starting hotplug tests
[    3.317523] psci_checker: Trying to turn off and on again all CPUs
[    3.318881] psci: CPU0 killed (polled 0 ms)
[    3.322894] psci: CPU1 killed (polled 0 ms)
[    3.326711] psci: CPU2 killed (polled 0 ms)
[    3.330159] Detected VIPT I-cache on CPU0
[    3.330593] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    3.331149] GICv3: CPU0: found redistributor 0 region 0:0x00000000fd460000
[    3.331829] CPU0: Booted secondary processor 0x0000000000 [0x412fd050]
[    3.334332] Detected VIPT I-cache on CPU1
[    3.334754] cacheinfo: Unable to detect cache hierarchy for CPU 1
[    3.335310] GICv3: CPU1: found redistributor 100 region 0:0x00000000fd480000
[    3.335997] CPU1: Booted secondary processor 0x0000000100 [0x412fd050]
[    3.338825] Detected VIPT I-cache on CPU2
[    3.339291] cacheinfo: Unable to detect cache hierarchy for CPU 2
[    3.339848] GICv3: CPU2: found redistributor 200 region 0:0x00000000fd4a0000
[    3.340538] CPU2: Booted secondary processor 0x0000000200 [0x412fd050]
[    3.342645] psci_checker: Trying to turn off and on again group 0 (CPUs 0-3)
[    3.343768] psci: CPU0 killed (polled 0 ms)
[    3.347262] psci: CPU1 killed (polled 0 ms)
[    3.350576] psci: CPU2 killed (polled 0 ms)
[    3.353228] Detected VIPT I-cache on CPU0
[    3.353658] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    3.354215] GICv3: CPU0: found redistributor 0 region 0:0x00000000fd460000
[    3.354893] CPU0: Booted secondary processor 0x0000000000 [0x412fd050]
[    3.357280] Detected VIPT I-cache on CPU1
[    3.357706] cacheinfo: Unable to detect cache hierarchy for CPU 1
[    3.358261] GICv3: CPU1: found redistributor 100 region 0:0x00000000fd480000
[    3.358949] CPU1: Booted secondary processor 0x0000000100 [0x412fd050]
[    3.361741] Detected VIPT I-cache on CPU2
[    3.362206] cacheinfo: Unable to detect cache hierarchy for CPU 2
[    3.362765] GICv3: CPU2: found redistributor 200 region 0:0x00000000fd4a0000
[    3.363457] CPU2: Booted secondary processor 0x0000000200 [0x412fd050]
[    3.365577] psci_checker: Hotplug tests passed OK
[    3.366020] psci_checker: Starting suspend tests (10 cycles per state)
[    3.366668] psci_checker: cpuidle not available on CPU 0, ignoring
[    3.367233] psci_checker: cpuidle not available on CPU 1, ignoring
[    3.367791] psci_checker: cpuidle not available on CPU 2, ignoring
[    3.368483] psci_checker: cpuidle not available on CPU 3, ignoring
[    3.369049] psci_checker: Could not start suspend tests on any CPU
[    3.369604] psci_checker: PSCI checker completed
[    3.373174] Freeing unused kernel memory: 3520K
[    3.396189] Run /init as init process
[    4.493571] rockchip-vop2 fe040000.vop: Adding to iommu group 2
[    4.494172] iommu: Failed to allocate default IOMMU domain of type 11 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[    4.497744] panfrost fde60000.gpu: clock rate = 594000000
[    4.499274] panfrost fde60000.gpu: bus_clock rate = 500000000
[    4.499911] panfrost fde60000.gpu: error -ENODEV: _opp_set_regulators: no regulator (mali) found
[    4.502180] panfrost fde60000.gpu: mali-g52 id 0x7402 major 0x1 minor 0x0 status 0x0
[    4.502910] panfrost fde60000.gpu: features: 00000000,00000cf7, issues: 00000000,00000400
[    4.503663] panfrost fde60000.gpu: Features: L2:0x07110206 Shader:0x00000002 Tiler:0x00000209 Mem:0x1 MMU:0x00002823 AS:0xff JS:0x7
[    4.504757] panfrost fde60000.gpu: shader_present=0x1 l2_present=0x1
[    4.524252] Synopsys Designware Multimedia Card Interface Driver
[    4.528007] [drm] Initialized panfrost 1.2.0 20180908 for fde60000.gpu on minor 0
[    4.531534] dwmmc_rockchip fe2c0000.mmc: IDMAC supports 32-bit address mode.
[    4.531835] dwmmc_rockchip fe2b0000.mmc: IDMAC supports 32-bit address mode.
[    4.532341] dwmmc_rockchip fe2c0000.mmc: Using internal DMA controller.
[    4.532894] dwmmc_rockchip fe2b0000.mmc: Using internal DMA controller.
[    4.533472] dwmmc_rockchip fe2c0000.mmc: Version ID is 270a
[    4.533492] dwmmc_rockchip fe2b0000.mmc: Version ID is 270a
[    4.533587] dwmmc_rockchip fe2b0000.mmc: DW MMC controller at irq 37,32 bit host data width,256 deep fifo
[    4.533881] rockchip-drm display-subsystem: bound fe040000.vop (ops vop2_component_ops [rockchipdrm])
[    4.534150] dwmmc_rockchip fe2c0000.mmc: DW MMC controller at irq 36,32 bit host data width,256 deep fifo
[    4.537971] sdhci: Secure Digital Host Controller Interface driver
[    4.538557] sdhci: Copyright(c) Pierre Ossman
[    4.542293] dwhdmi-rockchip fe0a0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[    4.543947] dwmmc_rockchip fe2b0000.mmc: Got CD GPIO
[    4.556213] mmc_host mmc0: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[    4.557933] dwhdmi-rockchip fe0a0000.hdmi: registered DesignWare HDMI I2C bus driver
[    4.559425] rockchip-drm display-subsystem: bound fe0a0000.hdmi (ops dw_hdmi_rockchip_ops [rockchipdrm])
[    4.561855] [drm] Initialized rockchip 1.0.0 20140818 for display-subsystem on minor 1
[    4.562694] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
[    4.564284] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
[    4.565024] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
[    4.568561] dwmmc_rockchip fe2c0000.mmc: IDMAC supports 32-bit address mode.
[    4.569270] dwmmc_rockchip fe2c0000.mmc: Using internal DMA controller.
[    4.569886] dwmmc_rockchip fe2c0000.mmc: Version ID is 270a
[    4.570443] dwmmc_rockchip fe2c0000.mmc: DW MMC controller at irq 36,32 bit host data width,256 deep fifo
[    4.581646] dwmmc_rockchip fe2c0000.mmc: IDMAC supports 32-bit address mode.
[    4.582352] dwmmc_rockchip fe2c0000.mmc: Using internal DMA controller.
[    4.582960] dwmmc_rockchip fe2c0000.mmc: Version ID is 270a
[    4.583513] dwmmc_rockchip fe2c0000.mmc: DW MMC controller at irq 36,32 bit host data width,256 deep fifo
[    4.587070] dma-pl330 fe530000.dma-controller: Loaded driver for PL330 DMAC-241330
[    4.587796] dma-pl330 fe530000.dma-controller:     DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[    4.592524] sdhci-pltfm: SDHCI platform and OF driver helper
[    4.596169] dwc3 fd000000.usbhost: can't request region for resource [mem 0xfd00c100-0xfd3fffff]
[    4.597021] dwc3: probe of fd000000.usbhost failed with error -16
[    4.597803] ------------[ cut here ]------------
[    4.598239] WARNING: CPU: 1 PID: 9 at drivers/reset/core.c:766 __reset_control_get_internal+0x68/0x17c
[    4.599101] Modules linked in: display_connector(+) sdhci_of_dwcmshc sdhci_pltfm phy_rockchip_inno_usb2 sdhci dw_mmc_rockchip dw_mmc_pltfm pl330(+) dw_mmc mmc_core rockchipdrm dw_mipi_dsi dw_hdmi analogix_dp panfrost gpu_sched drm_shmem_helper dwc3_of_simple drm_display_helper cec rc_core drm_dma_helper dwc3 drm_kms_helper roles drm udc_core drm_panel_orientation_quirks
[    4.602121] CPU: 1 PID: 9 Comm: kworker/u8:0 Not tainted 6.1.34-media #1
[    4.602733] Hardware name: Rockchip RK3566 BOX DEMO Board (DT)
[    4.603129] dma-pl330 fe550000.dma-controller: Loaded driver for PL330 DMAC-241330
[    4.603264] Workqueue: events_unbound deferred_probe_work_func
[    4.603296] dma-pl330 fe550000.dma-controller:     DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[    4.603954]
[    4.605449] pstate: 60400009 (nZCv daif +PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[    4.606083] pc : __reset_control_get_internal+0x68/0x17c
[    4.606577] lr : __of_reset_control_get+0x170/0x1d4
[    4.607028] sp : ffff800009bdba30
[    4.607334] x29: ffff800009bdba30 x28: 0000000000000000 x27: ffff00000a542838
[    4.607991] x26: 0000000000000001 x25: 0000000000000000 x24: 0000000000000001
[    4.608643] x23: 0000000000000000 x22: ffff000002127180 x21: 0000000000000095
[    4.609297] x20: ffff0000021271a0 x19: ffff00000a705580 x18: ffffffffffffffff
[    4.609950] x17: 7830206d656d5b20 x16: 656372756f736572 x15: ffff00000a4ef90a
[    4.610603] x14: ffffffffffffffff x13: 0074736f68627375 x12: 2e30303030303064
[    4.611256] x11: 0000000000000000 x10: ffff84000b4f5ef9 x9 : 0000000000000018
[    4.611907] x8 : 0101010101010101 x7 : 00000000736c6c65 x6 : 00000080e1f3f369
[    4.612559] x5 : fffffbfffdd01a50 x4 : ffff800009bdba28 x3 : 0000000000000001
[    4.613212] x2 : 0000000000000095 x1 : 0000000000000095 x0 : 0000000000000001
[    4.613866] Call trace:
[    4.614097]  __reset_control_get_internal+0x68/0x17c
[    4.614563]  __of_reset_control_get+0x170/0x1d4
[    4.614985]  of_reset_control_array_get+0xa8/0x220
[    4.615428]  dwc3_of_simple_probe+0x64/0x1b0 [dwc3_of_simple]
[    4.615970]  platform_probe+0x68/0xe0
[    4.616316]  really_probe+0xbc/0x2dc
[    4.616656]  __driver_probe_device+0x78/0x114
[    4.617064]  driver_probe_device+0x3c/0x15c
[    4.617454]  __device_attach_driver+0xb8/0x134
[    4.617865]  bus_for_each_drv+0x78/0xd0
[    4.618225]  __device_attach+0xa8/0x1c0
[    4.618583]  device_initial_probe+0x14/0x20
[    4.618969]  bus_probe_device+0x9c/0xa4
[    4.619328]  deferred_probe_work_func+0x88/0xc0
[    4.619748]  process_one_work+0x1fc/0x480
[    4.620128]  worker_thread+0x14c/0x444
[    4.620481]  kthread+0x10c/0x110
[    4.620788]  ret_from_fork+0x10/0x20
[    4.621128] ---[ end trace 0000000000000000 ]---
[    4.621679] dwc3-of-simple fd000000.usbhost: failed to get device resets, err=-16
[    4.622400] dwc3-of-simple: probe of fd000000.usbhost failed with error -16
[    4.625705] dwmmc_rockchip fe2c0000.mmc: IDMAC supports 32-bit address mode.
[    4.626498] dwmmc_rockchip fe2c0000.mmc: Using internal DMA controller.
[    4.627146] dwmmc_rockchip fe2c0000.mmc: Version ID is 270a
[    4.627729] dwmmc_rockchip fe2c0000.mmc: DW MMC controller at irq 36,32 bit host data width,256 deep fifo
[    4.635838] mmc2: SDHCI controller on fe310000.mmc [fe310000.mmc] using ADMA
[    4.639156] dwmmc_rockchip fe2c0000.mmc: IDMAC supports 32-bit address mode.
[    4.639887] dwmmc_rockchip fe2c0000.mmc: Using internal DMA controller.
[    4.640529] dwmmc_rockchip fe2c0000.mmc: Version ID is 270a
[    4.641085] dwmmc_rockchip fe2c0000.mmc: DW MMC controller at irq 36,32 bit host data width,256 deep fifo
[    4.655247] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[    4.656378] mmc0: new high speed SDHC card at address 0001
[    4.688603] dwmmc_rockchip fe2c0000.mmc: IDMAC supports 32-bit address mode.
[    4.689345] dwmmc_rockchip fe2c0000.mmc: Using internal DMA controller.
[    4.689960] dwmmc_rockchip fe2c0000.mmc: Version ID is 270a
[    4.690516] dwmmc_rockchip fe2c0000.mmc: DW MMC controller at irq 36,32 bit host data width,256 deep fifo
[    4.693750] dwmmc_rockchip fe2c0000.mmc: allocated mmc-pwrseq
[    4.694313] mmc_host mmc1: card is non-removable.
[    4.707673] mmc_host mmc1: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[    4.709716] mmc2: new HS200 MMC card at address 0001
[    4.820960] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[    4.825386] mmc1: new high speed SDIO card at address 0001
[    4.952239] Registered IR keymap rc-cec
[    4.953058] rc rc0: dw_hdmi as /devices/platform/fe0a0000.hdmi/rc/rc0
[    4.953949] input: dw_hdmi as /devices/platform/fe0a0000.hdmi/rc/rc0/input0
[    5.005340] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[    5.005902] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 1
[    5.006825] xhci-hcd xhci-hcd.2.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000000002010010
[    5.007763] xhci-hcd xhci-hcd.2.auto: irq 43, io mem 0xfd000000
[    5.008653] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[    5.009214] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 2
[    5.009965] xhci-hcd xhci-hcd.2.auto: Host supports USB 3.0 SuperSpeed
[    5.012545] hub 1-0:1.0: USB hub found
[    5.012993] hub 1-0:1.0: 1 port detected
[    5.015009] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    5.018609] hub 2-0:1.0: USB hub found
[    5.019066] hub 2-0:1.0: 1 port detected
[    5.021129] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
[    5.021706] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 3
[    5.022600] xhci-hcd xhci-hcd.3.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x8000000002010010
[    5.023537] xhci-hcd xhci-hcd.3.auto: irq 44, io mem 0xfcc00000
[    5.024438] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
[    5.024977] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 4
[    5.025697] xhci-hcd xhci-hcd.3.auto: Host supports USB 3.0 SuperSpeed
[    5.028319] hub 3-0:1.0: USB hub found
[    5.029476] hub 3-0:1.0: 1 port detected
[    5.030786] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[    5.032956] hub 4-0:1.0: USB hub found
[    5.033401] hub 4-0:1.0: 1 port detected
[    5.041451] mmcblk0: mmc0:0001 SD 3.72 GiB
[    5.058789] GPT:Primary header thinks Alt. header is not at the end of the disk.
[    5.059487] GPT:7744511 != 7802879
[    5.059806] GPT:Alternate GPT header not at the end of the disk.
[    5.060402] GPT:7744511 != 7802879
[    5.060727] GPT: Use GNU Parted to correct GPT errors.
[    5.061226]  mmcblk0: p1 p2
[    5.063561] mmcblk2: mmc2:0001 CJNB4R 58.2 GiB
[    5.088696]  mmcblk2: p2 p4
[    5.090519] mmcblk2boot0: mmc2:0001 CJNB4R 4.00 MiB
[    5.094044] mmcblk2boot1: mmc2:0001 CJNB4R 4.00 MiB
[    5.096892] mmcblk2rpmb: mmc2:0001 CJNB4R 4.00 MiB, chardev (240:0)
[    5.268161] usb 1-1: new high-speed USB device number 2 using xhci-hcd
[    5.440369] SCSI subsystem initialized
[    5.445513] usb-storage 1-1:1.0: USB Mass Storage device detected
[    5.446961] scsi host0: usb-storage 1-1:1.0
[    5.448170] usbcore: registered new interface driver usb-storage
[    5.450998] usbcore: registered new interface driver uas
[    7.125831] scsi 0:0:0:0: Direct-Access     JetFlash Transcend 16GB   1100 PQ: 0 ANSI: 4
[    7.135322] sd 0:0:0:0: [sda] 31703040 512-byte logical blocks: (16.2 GB/15.1 GiB)
[    7.136644] sd 0:0:0:0: [sda] Write Protect is off
[    7.137711] sd 0:0:0:0: [sda] No Caching mode page found
[    7.138251] sd 0:0:0:0: [sda] Assuming drive cache: write through
[    7.151421]  sda: sda1
[    7.152433] sd 0:0:0:0: [sda] Attached SCSI removable disk
[    7.629298] EXT4-fs (sda1): mounted filesystem with writeback data mode. Quota mode: none.
[    8.576109] systemd[1]: System time before build time, advancing clock.
[    8.602113] systemd[1]: Inserted module 'autofs4'
[    8.679180] systemd[1]: systemd 249.11-0ubuntu3.9 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY -P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[    8.683848] systemd[1]: Detected architecture arm64.
[    8.688349] systemd[1]: Hostname set to <station-m2>.
[    8.914518] dw-apb-uart fe660000.serial: forbid DMA for kernel console
[    9.929430] systemd[1]: Queued start job for default target Graphical Interface.
[   12.332077] random: crng init done
[   12.351906] systemd[1]: Created slice Slice /system/modprobe.
[   12.356160] systemd[1]: Created slice Slice /system/serial-getty.
[   12.359015] systemd[1]: Created slice User and Session Slice.
[   12.360538] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   12.362993] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[   12.365000] systemd[1]: Reached target Slice Units.
[   12.365886] systemd[1]: Reached target Swaps.
[   12.366668] systemd[1]: Reached target System Time Set.
[   12.367785] systemd[1]: Reached target Local Verity Protected Volumes.
[   12.394238] systemd[1]: Listening on RPCbind Server Activation Socket.
[   12.396605] systemd[1]: Listening on Syslog Socket.
[   12.398308] systemd[1]: Listening on fsck to fsckd communication Socket.
[   12.399768] systemd[1]: Listening on initctl Compatibility Named Pipe.
[   12.402419] systemd[1]: Listening on Journal Audit Socket.
[   12.404231] systemd[1]: Listening on Journal Socket (/dev/log).
[   12.406236] systemd[1]: Listening on Journal Socket.
[   12.407659] systemd[1]: systemd-networkd.socket: Socket service systemd-networkd.service not loaded, refusing.
[   12.408696] systemd[1]: Failed to listen on Network Service Netlink Socket.
[   12.418272] systemd[1]: Listening on udev Control Socket.
[   12.420300] systemd[1]: Listening on udev Kernel Socket.
[   12.427613] systemd[1]: Mounting Huge Pages File System...
[   12.435827] systemd[1]: Mounting POSIX Message Queue File System...
[   12.444440] systemd[1]: Mounting Kernel Debug File System...
[   12.452393] systemd[1]: Mounting Kernel Trace File System...
[   12.454411] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
[   12.464226] systemd[1]: Starting Restore / save the current clock...
[   12.472889] systemd[1]: Starting Wait for network to be configured by ifupdown...
[   12.482488] systemd[1]: Starting Set the console keyboard layout...
[   12.492624] systemd[1]: Starting Create List of Static Device Nodes...
[   12.504878] systemd[1]: Starting Load Kernel Module chromeos_pstore...
[   12.515031] systemd[1]: Starting Load Kernel Module configfs...
[   12.525356] systemd[1]: Starting Load Kernel Module drm...
[   12.534941] systemd[1]: Starting Load Kernel Module efi_pstore...
[   12.545166] systemd[1]: Starting Load Kernel Module fuse...
[   12.555461] systemd[1]: Starting Load Kernel Module pstore_blk...
[   12.566300] systemd[1]: Starting Load Kernel Module pstore_zone...
[   12.575970] systemd[1]: Starting Load Kernel Module ramoops...
[   12.578441] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[   12.598548] systemd[1]: Starting Load Kernel Modules...
[   12.609542] systemd[1]: Starting Generate network units from Kernel command line...
[   12.619439] systemd[1]: Starting Remount Root and Kernel File Systems...
[   12.629440] systemd[1]: Starting Coldplug All udev Devices...
[   12.651384] systemd[1]: Mounted Huge Pages File System.
[   12.654248] systemd[1]: Mounted POSIX Message Queue File System.
[   12.656284] systemd[1]: Mounted Kernel Debug File System.
[   12.659783] systemd[1]: Mounted Kernel Trace File System.
[   12.664633] systemd[1]: Finished Restore / save the current clock.
[   12.670084] EXT4-fs (sda1): re-mounted. Quota mode: none.
[   12.670106] systemd[1]: Finished Wait for network to be configured by ifupdown.
[   12.681778] systemd[1]: Finished Create List of Static Device Nodes.
[   12.685397] systemd[1]: modprobe@chromeos_pstore.service: Deactivated successfully.
[   12.688898] systemd[1]: Finished Load Kernel Module chromeos_pstore.
[   12.692504] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[   12.695510] systemd[1]: Finished Load Kernel Module configfs.
[   12.699492] systemd[1]: modprobe@drm.service: Deactivated successfully.
[   12.702249] systemd[1]: Finished Load Kernel Module drm.
[   12.705599] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
[   12.708549] systemd[1]: Finished Load Kernel Module efi_pstore.
[   12.711874] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[   12.714680] systemd[1]: Finished Load Kernel Module fuse.
[   12.718093] systemd[1]: modprobe@pstore_blk.service: Deactivated successfully.
[   12.722119] systemd[1]: Finished Load Kernel Module pstore_blk.
[   12.725575] systemd[1]: modprobe@pstore_zone.service: Deactivated successfully.
[   12.728390] systemd[1]: Finished Load Kernel Module pstore_zone.
[   12.731725] systemd[1]: modprobe@ramoops.service: Deactivated successfully.
[   12.734426] systemd[1]: Finished Load Kernel Module ramoops.
[   12.738236] systemd[1]: Finished Load Kernel Modules.
[   12.741889] systemd[1]: Finished Generate network units from Kernel command line.
[   12.745797] systemd[1]: Finished Remount Root and Kernel File Systems.
[   12.749556] systemd[1]: Reached target Preparation for Network.
[   12.772802] systemd[1]: Mounting FUSE Control File System...
[   12.780700] systemd[1]: Mounting Kernel Configuration File System...
[   12.782419] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[   12.790855] systemd[1]: Starting Load/Save Random Seed...
[   12.799563] systemd[1]: Starting Apply Kernel Variables...
[   12.810134] systemd[1]: Starting Create System Users...
[   12.818793] systemd[1]: Mounted FUSE Control File System.
[   12.820686] systemd[1]: Mounted Kernel Configuration File System.
[   12.929262] systemd[1]: Finished Set the console keyboard layout.
[   12.933470] systemd[1]: Finished Create System Users.
[   12.942505] systemd[1]: Starting Create Static Device Nodes in /dev...
[   13.482394] systemd[1]: Finished Coldplug All udev Devices.
[   13.509243] systemd[1]: Starting Helper to synchronize boot up for ifupdown...
[   13.523344] systemd[1]: Finished Helper to synchronize boot up for ifupdown.
dmesg
Quote
station-m2:~:# dmesg | grep ethernet
[   33.093308] rk_gmac-dwmac fe010000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0
[   33.093895] rk_gmac-dwmac fe010000.ethernet eth0: __stmmac_open: Cannot attach to PHY (error: -19)
[   33.156502] rk_gmac-dwmac fe010000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0
[   33.157018] rk_gmac-dwmac fe010000.ethernet eth0: __stmmac_open: Cannot attach to PHY (error: -19)
[   33.171935] rk_gmac-dwmac fe010000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0
[   33.172559] rk_gmac-dwmac fe010000.ethernet eth0: __stmmac_open: Cannot attach to PHY (error: -19)
[   33.191602] rk_gmac-dwmac fe010000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0
[   33.192260] rk_gmac-dwmac fe010000.ethernet eth0: __stmmac_open: Cannot attach to PHY (error: -19)
[   33.216785] rk_gmac-dwmac fe010000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0
[   33.217345] rk_gmac-dwmac fe010000.ethernet eth0: __stmmac_open: Cannot attach to PHY (error: -19)
[  101.292632] rk_gmac-dwmac fe010000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0
[  101.293085] rk_gmac-dwmac fe010000.ethernet eth0: __stmmac_open: Cannot attach to PHY (error: -19)
[  114.716221] rk_gmac-dwmac fe010000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0
[  114.717913] rk_gmac-dwmac fe010000.ethernet eth0: __stmmac_open: Cannot attach to PHY (error: -19)
Quote
station-m2:~:# ip a
2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
station-m2:~:# ip l set eth0 up
RTNETLINK answers: No such device
Edited by ewww
@ewww Seems that you want to take the nightmare of playing with dts files. So this is your first exercise.
rk3566-box-demo_rboxr2_5.dtb reports that your ethernet is based in RTL8211F but doesnt work. Because we can guess that kernel identification is good, maybe the timing is wrong in 4.19 dts file.  Apply the corect timing ( TX delay RX delay) to the board.
Edited by maka
@maka I'm trying to learn things, correct me if wrong:
my kernel 4.19 dts has:
tx_delay = <0x4f>;
rx_delay = <0x2d>;
I decompile your rk3566-box-demo_rboxr2_5.dtb to dts, it has
tx_delay = <0x4b>;
rx_delay = <0x2b>;
so I change tx rx to 0x4f and 0x2d in rk3566-box-demo_rboxr2_5.dts then recompile withdtc -I dts -O dtb -f rk3566-box-demo_rboxr2_5.dts -o test.dtb
loaded the test.dtb but still can not connect
Quote
[    3.009878] rk_gmac-dwmac fe010000.ethernet: IRQ eth_lpi not found
[    3.010686] rk_gmac-dwmac fe010000.ethernet: supply phy not found, using dummy regulator
[    3.011742] rk_gmac-dwmac fe010000.ethernet: clock input or output? (input).
[    3.012391] rk_gmac-dwmac fe010000.ethernet: TX delay(0x4f).
[    3.012910] rk_gmac-dwmac fe010000.ethernet: RX delay(0x2d).
[    3.013439] rk_gmac-dwmac fe010000.ethernet: integrated PHY? (no).
[    3.014044] rk_gmac-dwmac fe010000.ethernet: clock input from PHY
[    3.019614] rk_gmac-dwmac fe010000.ethernet: init for RGMII
[    3.020495] rk_gmac-dwmac fe010000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[    3.021156] rk_gmac-dwmac fe010000.ethernet:         DWMAC4/5
[    3.021631] rk_gmac-dwmac fe010000.ethernet: DMA HW capability register supported
[    3.022309] rk_gmac-dwmac fe010000.ethernet: RX Checksum Offload Engine supported
[    3.022984] rk_gmac-dwmac fe010000.ethernet: TX Checksum insertion supported
[    3.023618] rk_gmac-dwmac fe010000.ethernet: Wake-Up On Lan supported
[    3.024312] rk_gmac-dwmac fe010000.ethernet: TSO supported
[    3.024819] rk_gmac-dwmac fe010000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[    3.025544] rk_gmac-dwmac fe010000.ethernet: Enabled RFS Flow TC (entries=10)
[    3.026190] rk_gmac-dwmac fe010000.ethernet: TSO feature enabled
[    3.026735] rk_gmac-dwmac fe010000.ethernet: Using 32/32 bits DMA host/device width
[   29.880761] rk_gmac-dwmac fe010000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0
[   29.975796] rk_gmac-dwmac fe010000.ethernet eth0: PHY [stmmac-0:01] driver [RTL8211F Gigabit Ethernet] (irq=POLL)
[   29.983800] rk_gmac-dwmac fe010000.ethernet eth0: No Safety Features support found
[   29.983829] rk_gmac-dwmac fe010000.ethernet eth0: IEEE 1588-2008 Advanced Timestamp supported
[   29.984105] rk_gmac-dwmac fe010000.ethernet eth0: registered PTP clock
[   29.984562] rk_gmac-dwmac fe010000.ethernet eth0: configuring for phy/rgmii link mode
[   33.094767] rk_gmac-dwmac fe010000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
I forgot to mention, in https://git.kernel.org/pub/scm/linux/kernel/git/stable/linux.git/tree/arch/arm64/boot/dts/rockchip/rk3566-box-demo.dts?h=v6.3.8
the tx rx value is the same on my kernel 4.19 dts
Edited by ewww
tx_delay = <0x4f>;
rx_delay = <0x2d>;
Be carefull, This value coud be a phandle.
the phandle is an redirect pointer.
# when you sent
redirect = <0x4f>;
# the device redirect it to something like
			usb2phy2@483e8000 {
				compatible = "ti,am437x-usb2";
				reg = <0x483e8000 0x8000>;
				ctrl-module = <0x4c>;
				clocks = <0x1a 0x4d>;
				clock-names = "wkupclk", "refclk";
				#phy-cells = <0x0>;
				linux,phandle = <0x4f>;
				phandle = <0x4f>;
Edited by hotnikq
I have realized that was using an rboxr2 dts that is diferent from yours because I had a previous file and was opening the wrong one. Because of this there is a voltage error that have mended.  The usb nodes are different as well but havent changed anything because is causing fatal error. You can play with usb nodes if you want to.
I think this file should work with the right voltage but the "final" word is just a hope.
PD 4f-2d is the right timing.
rk3566-box-demo_rboxr2_final.dtb
@maka usb2 port stopped working, I can boot from usb3 port. ethernet issue is the same as before, probed but can not connect, I don't understand 😅 so the root cause is USB nodes voltage? thanks
Quote
[    4.308527] dwc3 fd000000.usbhost: can't request region for resource [mem 0xfd00c100-0xfd3fffff]
[    4.309380] dwc3: probe of fd000000.usbhost failed with error -16
[    4.310252] ------------[ cut here ]------------
[    4.310700] WARNING: CPU: 2 PID: 52 at drivers/reset/core.c:766 __reset_control_get_internal+0x68/0x17c
[    4.311568] Modules linked in: sdhci_pltfm(+) rockchipdrm(+) display_connector phy_rockchip_inno_usb2 dw_mipi_dsi dw_hdmi analogix_dp dw_mmc_rockchip drm_display_helper pl330 dw_mmc_pltfm cec sdhci dw_mmc mmc_core panfrost gpu_sched rc_core drm_dma_helper drm_kms_helper drm_shmem_helper dwc3_of_simple drm dwc3 roles drm_panel_orientation_quirks udc_core realtek
[    4.314532] CPU: 2 PID: 52 Comm: kworker/u8:2 Not tainted 6.2.16-media #5
[    4.315156] Hardware name: Rockchip RK3566 BOX DEMO Board (DT)
[    4.315687] Workqueue: events_unbound deferred_probe_work_func
[    4.315739] sdhci-pltfm: SDHCI platform and OF driver helper
[    4.316240] pstate: 60400009 (nZCv daif +PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[    4.316252] pc : __reset_control_get_internal+0x68/0x17c
[    4.316266] lr : __of_reset_control_get+0x170/0x1d4
[    4.316276] sp : ffff80000a493a30
[    4.316280] x29: ffff80000a493a30 x28: 0000000000000000 x27: ffff00000da660b8
[    4.316297] x26: 0000000000000001 x25: 0000000000000000 x24: 0000000000000001
[    4.316311] x23: 0000000000000000 x22: ffff000002132a00 x21: 0000000000000095
[    4.320576] x20: ffff000002132a20 x19: ffff00000da2e980 x18: ffffffffffffffff
[    4.321239] x17: 7830206d656d5b20 x16: 656372756f736572 x15: ffff00000da6648a
[    4.321896] x14: ffffffffffffffff x13: 0074736f68627375 x12: 2e30303030303064
[    4.322552] x11: 0000000000000000 x10: ffff84000b58e127 x9 : 0000000000000028
[    4.323208] x8 : 0101010101010101 x7 : 00000000736c6c65 x6 : 000000000080e1f3
[    4.323863] x5 : fffffbfffdd01a4c x4 : ffff80000a493a28 x3 : 0000000000000001
[    4.324520] x2 : 0000000000000095 x1 : 0000000000000095 x0 : 0000000000000001
[    4.325175] Call trace:
[    4.325407]  __reset_control_get_internal+0x68/0x17c
[    4.325876]  __of_reset_control_get+0x170/0x1d4
[    4.326298]  of_reset_control_array_get+0xa8/0x220
[    4.326742]  dwc3_of_simple_probe+0x64/0x1b0 [dwc3_of_simple]
[    4.327285]  platform_probe+0x68/0xe0
[    4.327634]  really_probe+0xbc/0x2dc
[    4.327971]  __driver_probe_device+0x78/0x114
[    4.328376]  driver_probe_device+0x3c/0x15c
[    4.328765]  __device_attach_driver+0xb8/0x134
[    4.329177]  bus_for_each_drv+0x78/0xd0
[    4.329537]  __device_attach+0xa8/0x1c0
[    4.329895]  device_initial_probe+0x14/0x20
[    4.330286]  bus_probe_device+0x9c/0xa4
[    4.330644]  deferred_probe_work_func+0x88/0xc0
[    4.331064]  process_one_work+0x1fc/0x480
[    4.331442]  worker_thread+0x14c/0x444
[    4.331795]  kthread+0x10c/0x110
[    4.332102]  ret_from_fork+0x10/0x20
[    4.332444] ---[ end trace 0000000000000000 ]---
[    4.332985] dwc3-of-simple fd000000.usbhost: failed to get device resets, err=-16
[    4.333716] dwc3-of-simple: probe of fd000000.usbhost failed with error -16
[    4.338957] dwmmc_rockchip fe2c0000.mmc: IDMAC supports 32-bit address mode.
[    4.339664] dwmmc_rockchip fe2c0000.mmc: Using internal DMA controller.
[    4.340326] dwmmc_rockchip fe2c0000.mmc: Version ID is 270a
[    4.340886] dwmmc_rockchip fe2c0000.mmc: DW MMC controller at irq 37,32 bit host data width,256 deep fifo
[    4.345861] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[    4.346880] mmc0: new high speed SDHC card at address 0001
[    4.351456] rockchip-drm display-subsystem: bound fe040000.vop (ops vop2_component_ops [rockchipdrm])
[    4.353550] dwhdmi-rockchip fe0a0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[    4.360186] dwhdmi-rockchip fe0a0000.hdmi: registered DesignWare HDMI I2C bus driver
[    4.361606] rockchip-drm display-subsystem: bound fe0a0000.hdmi (ops dw_hdmi_rockchip_ops [rockchipdrm])
[    4.364031] mmc2: SDHCI controller on fe310000.mmc [fe310000.mmc] using ADMA
[    4.366870] dwmmc_rockchip fe2c0000.mmc: IDMAC supports 32-bit address mode.
[    4.367583] dwmmc_rockchip fe2c0000.mmc: Using internal DMA controller.
[    4.368252] dwmmc_rockchip fe2c0000.mmc: Version ID is 270a
[    4.368808] [drm] Initialized rockchip 1.0.0 20140818 for display-subsystem on minor 1
[    4.368816] dwmmc_rockchip fe2c0000.mmc: DW MMC controller at irq 37,32 bit host data width,256 deep fifo
[    4.379118] dwmmc_rockchip fe2c0000.mmc: IDMAC supports 32-bit address mode.
[    4.379827] dwmmc_rockchip fe2c0000.mmc: Using internal DMA controller.
[    4.380479] dwmmc_rockchip fe2c0000.mmc: Version ID is 270a
[    4.381039] dwmmc_rockchip fe2c0000.mmc: DW MMC controller at irq 37,32 bit host data width,256 deep fifo
[    4.382504] dwmmc_rockchip fe2c0000.mmc: allocated mmc-pwrseq
[    4.383060] mmc_host mmc1: card is non-removable.
[    4.396133] mmc_host mmc1: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[    4.439974] mmc2: new HS200 MMC card at address 0001
[    4.511507] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[    4.518924] mmc1: new high speed SDIO card at address 0001
[    4.552929] Console: switching to colour frame buffer device 240x67
[    4.591837] rockchip-drm display-subsystem: [drm] fb0: rockchipdrmfb frame buffer device
[    4.725732] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    4.726464] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[    4.727463] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000000002010010
[    4.728580] xhci-hcd xhci-hcd.0.auto: irq 42, io mem 0xfd000000
[    4.729559] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    4.730180] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[    4.731002] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[    4.733322] hub 1-0:1.0: USB hub found
[    4.733871] hub 1-0:1.0: 1 port detected
[    4.736216] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    4.738374] hub 2-0:1.0: USB hub found
[    4.738920] hub 2-0:1.0: 1 port detected
[    4.750558] mmcblk0: mmc0:0001 SD 3.72 GiB
[    4.754346] Registered IR keymap rc-cec
[    4.755067] rc rc0: dw_hdmi as /devices/platform/fe0a0000.hdmi/rc/rc0
[    4.756119] input: dw_hdmi as /devices/platform/fe0a0000.hdmi/rc/rc0/input0
[    4.769322] GPT:Primary header thinks Alt. header is not at the end of the disk.
[    4.770140] GPT:7744511 != 7802879
[    4.770533] GPT:Alternate GPT header not at the end of the disk.
[    4.771167] GPT:7744511 != 7802879
[    4.771537] GPT: Use GNU Parted to correct GPT errors.
[    4.772219]  mmcblk0: p1 p2
[    4.774692] mmcblk2: mmc2:0001 CJNB4R 58.2 GiB
[    4.780535]  mmcblk2: p2 p4
[    4.782485] mmcblk2boot0: mmc2:0001 CJNB4R 4.00 MiB
[    4.787575] mmcblk2boot1: mmc2:0001 CJNB4R 4.00 MiB
[    4.790993] mmcblk2rpmb: mmc2:0001 CJNB4R 4.00 MiB, chardev (240:0)
[    4.996018] usb 1-1: new high-speed USB device number 2 using xhci-hcd
[    5.173693] SCSI subsystem initialized
[    5.178828] usb-storage 1-1:1.0: USB Mass Storage device detected
[    5.179755] scsi host0: usb-storage 1-1:1.0
[    5.180620] usbcore: registered new interface driver usb-storage
[    5.183165] usbcore: registered new interface driver uas
[    6.214040] scsi 0:0:0:0: Direct-Access     Generic  Flash Disk       8.07 PQ: 0 ANSI: 4
[    6.224432] sd 0:0:0:0: [sda] 15601664 512-byte logical blocks: (7.99 GB/7.44 GiB)
[    6.231145] sd 0:0:0:0: [sda] Write Protect is off
[    6.237848] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[    6.278257]  sda: sda1
[    6.284362] sd 0:0:0:0: [sda] Attached SCSI removable disk
[    7.164949] EXT4-fs (sda1): mounted filesystem a363d768-2b93-4e9f-b134-0379c1426165 with writeback data mode. Quota mode: none.
[    8.581687] systemd[1]: System time before build time, advancing clock.
i made a change from "host" to "otg" in the first usb node, maybe fails because of that. Anyway, ethernet should be ok and have no more ideas. Can you check if rtl8211f is in the box?
Edited by maka
@maka
[    1.220060] mdio_bus stmmac-0: MDIO device at address 1 is missing.
 phy error here
Quote
[    4.239808] ------------[ cut here ]------------
[    4.240252] WARNING: CPU: 3 PID: 38 at drivers/reset/core.c:766 __reset_control_get_internal+0x68/0x17c
[    4.241117] Modules linked in: display_connector phy_rockchip_inno_usb2 dw_mmc sdhci_of_dwcmshc sdhci_pltfm sdhci pl330 mmc_core rockchipdrm(+) dw_mipi_dsi dw_hdmi panfrost dwc3_of_simple analogix_dp gpu_schs
[    4.243894] CPU: 3 PID: 38 Comm: kworker/u8:1 Not tainted 6.2.16-media #5
[    4.244162] mmc2: SDHCI controller on fe310000.mmc [fe310000.mmc] using ADMA
[    4.244510] Hardware name: Rockchip RK3566 BOX DEMO Board (DT)
[    4.244519] Workqueue: events_unbound deferred_probe_work_func
[    4.244542] pstate: 60400009 (nZCv daif +PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[    4.246846] pc : __reset_control_get_internal+0x68/0x17c
[    4.247346] lr : __of_reset_control_get+0x170/0x1d4
[    4.247800] sp : ffff80000a3e3a30
[    4.248106] x29: ffff80000a3e3a30 x28: 0000000000000000 x27: ffff00000d9878b8
[    4.248765] x26: 0000000000000001 x25: 0000000000000000 x24: 0000000000000001
[    4.249422] x23: 0000000000000000 x22: ffff000002132580 x21: 0000000000000095
[    4.250077] x20: ffff0000021325a0 x19: ffff00000a5c1780 x18: ffffffffffffffff
[    4.250732] x17: 7830206d656d5b20 x16: 656372756f736572 x15: ffff00000d98718a
[    4.251388] x14: ffffffffffffffff x13: 0074736f68627375 x12: 2e30303030303064
[    4.252042] x11: 0000000000000000 x10: ffff84000b58e117 x9 : 0000000000000028
[    4.252696] x8 : 0101010101010101 x7 : 00000000736c6c65 x6 : 000000000080e1f3
[    4.253349] x5 : fffffbfffdd01a50 x4 : ffff80000a3e3a28 x3 : 0000000000000001
[    4.254002] x2 : 0000000000000095 x1 : 0000000000000095 x0 : 0000000000000001
[    4.254656] Call trace:
[    4.254886]  __reset_control_get_internal+0x68/0x17c
[    4.255352]  __of_reset_control_get+0x170/0x1d4
[    4.255773]  of_reset_control_array_get+0xa8/0x220
[    4.256217]  dwc3_of_simple_probe+0x64/0x1b0 [dwc3_of_simple]
[    4.256760]  platform_probe+0x68/0xe0
[    4.257106]  really_probe+0xbc/0x2dc
[    4.257443]  __driver_probe_device+0x78/0x114
[    4.257848]  driver_probe_device+0x3c/0x15c
[    4.258236]  __device_attach_driver+0xb8/0x134
[    4.258648]  bus_for_each_drv+0x78/0xd0
[    4.259005]  __device_attach+0xa8/0x1c0
[    4.259364]  device_initial_probe+0x14/0x20
[    4.259754]  bus_probe_device+0x9c/0xa4
[    4.260113]  deferred_probe_work_func+0x88/0xc0
[    4.260532]  process_one_work+0x1fc/0x480
[    4.260911]  worker_thread+0x14c/0x444
[    4.261262]  kthread+0x10c/0x110
[    4.261570]  ret_from_fork+0x10/0x20
[    4.261912] ---[ end trace 0000000000000000 ]---
[    4.262458] dwc3-of-simple fd000000.usbhost: failed to get device resets, err=-16
[    4.263189] dwc3-of-simple: probe of fd000000.usbhost failed with error -16
@maka rk3566-box-demo_rboxr2_8.dtb still has the same issue, it can't connect although link up
Quote
[   38.122548] rk_gmac-dwmac fe010000.ethernet eth0: PHY [stmmac-0:01] driver [RTL8211F Gigabit Ethernet] (irq=POLL)
[   38.136413] dwmac4: Master AXI performs any burst length
[   38.139893] rk_gmac-dwmac fe010000.ethernet eth0: No Safety Features support found
[   38.143584] rk_gmac-dwmac fe010000.ethernet eth0: IEEE 1588-2008 Advanced Timestamp supported
[   38.147671] rk_gmac-dwmac fe010000.ethernet eth0: registered PTP clock
[   38.154098] rk_gmac-dwmac fe010000.ethernet eth0: configuring for phy/rgmii link mode
[   69.927235] rk_gmac-dwmac fe010000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[   69.939496] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   70.041230] NET: Registered PF_PACKET protocol family
well, I think I will have to get an ethernet usb 😶
I just found something, that looks similar here https://forum.openwrt.org/t/help-with-rtl8211f-rk3588-tx-issues/154818
Edited by ewww
the fix, their is a mismatch in
" mainline " vs  " downstream uboot "
that causes its clock "fix up" based on the kernels DTB
set the wrong clocks for (at least) GPLL and CPLL.
Fixing this the RGMII interface now works as intended.
You will need to create a mainline Uboot or fix the RGMII
Edited by hotnikq
Quote
But eth0 is working, isn't it?
it is working with async timmings. it's an know issue
To armbian, we use legacy uboot kernel.
in your case, the RTL8211F dont accept to start with legacy uboot and switch to mainline armbian
Edited by hotnikq
I don't know how to fix RGMII, still need others help. All dtbs from @maka
currently:
runs kernel 6 (and 5.15) ✔️
USB 2.0 port ✔️
USB 3.0 port ✔️
display video HDMI ✔️
detect internal MMC ✔️
ethernet gigabit ✖️
Edited by ewww
I'm using sdcard for storing /boot and emmc/usb for rootfs. here are steps for building rockchip uboot (refer to https://forum.pine64.org/showthread.php?tid=14507 )
git clone --depth=1 -b next-dev https://github.com/rockchip-linux/u-boot.git u-boot
git clone --depth=1 https://github.com/rockchip-linux/rkbin.git rkbin
cd u-boot
ln -sf ../rkbin/bin/rk35/rk3568_bl31_v1.42.elf bl31.elf
ln -sf ../rkbin/bin/rk35/rk3568_bl32_v2.09.bin tee.bin
make rk3568_defconfig
make -j4 && make -j4 u-boot.itb
tools/mkimage -n rk3568 -T rksd -d ../rkbin/bin/rk35/rk3566_ddr_1056MHz_v1.16.bin:spl/u-boot-spl.bin idblock.bin
# creating sdcard partitions:
echo -e "\ng\nn\n1\n16384\n+16M\nt\n11\nn\n2\n\n+256M\nt\n2\n1\nn\n\n\n\nw" | fdisk /dev/mmcblk0
echo -e "\nx\nn\n1\nuboot\nr\nw" | fdisk /dev/mmcblk0
It will look like
Quote
fdisk -l /dev/mmcblk0
Device          Start      End Sectors  Size Type
/dev/mmcblk0p1  16384    49151  32768  16M Microsoft basic data
/dev/mmcblk0p2  49152  573439  524288  256M EFI System
/dev/mmcblk0p3 573440 10557406 9983967  4.8G Linux filesystem
# we got u-boot.itb and idblock.bin now write sdcard
dd if=idblock.bin of=/dev/mmcblk0 seek=64
dd if=u-boot.itb of=/dev/mmcblk0p1
mount armbian image and /dev/mmcblk0p2 then copy (armbian) /boot to /dev/mmcblk0p2, edit extlinux.conf, change uuid of rootfs to emmc/usb rootfs partition, copy working dtb and edit its path respectively.
if you want to use sdcard only, so put armbian rootfs on /dev/mmcblk0p3, else delete /dev/mmcblk0p3 as you wish
these file names may change whenever rockchip pushes their new version
Boot log
Quote
U-Boot SPL board init
U-Boot SPL 2017.09-gbb96596-dirty #ubuntu (Jun 16 2023 - 03:20:14)
unknown raw ID phN
unrecognized JEDEC id bytes: 00, 00, 00
Trying to boot from MMC2
## Verified-boot: 0
## Checking atf-1 0x00040000 ... sha256+ OK
## Checking uboot 0x00a00000 ... sha256+ OK
## Checking fdt 0x00b3ece0 ... sha256+ OK
## Checking atf-2 0xfdcc1000 ... sha256+ OK
## Checking atf-3 0x0006c000 ... sha256+ OK
## Checking atf-4 0xfdcce000 ... sha256+ OK
## Checking atf-5 0xfdcd0000 ... sha256+ OK
## Checking atf-6 0x0006a000 ... sha256+ OK
## Checking optee 0x08400000 ... sha256+ OK
Jumping to U-Boot(0x00a00000) via ARM Trusted Firmware(0x00040000)
Total: 389.347 ms
INFO:    Preloader serial: 2
NOTICE:  BL31: v2.3():v2.3-594-g7f859117f:cl
NOTICE:  BL31: Built : 04:51:16, May 11 2023
INFO:    GICv3 without legacy support detected.
INFO:    ARM GICv3 driver initialized in EL3
INFO:    pmu v1 is valid 220114
INFO:    dfs DDR fsp_param[0].freq_mhz= 1056MHz
INFO:    dfs DDR fsp_param[1].freq_mhz= 324MHz
INFO:    dfs DDR fsp_param[2].freq_mhz= 528MHz
INFO:    dfs DDR fsp_param[3].freq_mhz= 780MHz
INFO:    BL31: Initialising Exception Handling Framework
INFO:    BL31: Initializing runtime services
INFO:    BL31: Initializing BL32
I/TC:
I/TC: OP-TEE version: 3.13.0-651-gd84087907 #hisping.lin (gcc version 10.2.1 20201103 (GNU Toolchain for the A-profile Architecture 10.2-2020.11 (arm-10.16))) #5 Fri Sep 16 15:39:33 CST 2022 aarch64
I/TC: Primary CPU initializing
I/TC: Primary CPU switching to normal world boot
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0xa00000
INFO:    SPSR = 0x3c9
U-Boot 2017.09-gcc781e0-230509 #ubuntu (Jun 23 2023 - 11:22:01 +0000)
Model: Rockchip RK3568 Evaluation Board
MPIDR: 0x81000000
PreSerial: 2, raw, 0xfe660000
DRAM:  3.7 GiB
Sysmem: init
Relocation Offset: ed220000
Relocation fdt: eb9f89c8 - eb9fece8
CR: M/C/I
Using default environment
DM: v1
no mmc device at slot 1
dwmmc@fe2b0000: 1 (SD), dwmmc@fe2c0000: 2, sdhci@fe310000: 0
Bootdev(atags): mmc 1
MMC1: Legacy, 52Mhz
PartType: EFI
No misc partition
boot mode: None
FIT: No boot partition
Failed to load DTB, ret=-19
No valid DTB, ret=-22
Failed to get kernel dtb, ret=-22
io-domain: OK
Failed to get scmi clk dev
dmc_fsp failed, ret=-19
MPIDR: 0x81000000
rockchip_set_serialno: could not find efuse/otp device
CLK: (sync kernel. arm: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
  apll 816000 KHz
  dpll 528000 KHz
  gpll 1188000 KHz
  cpll 1000000 KHz
  npll 24000 KHz
  vpll 24000 KHz
  hpll 24000 KHz
  ppll 200000 KHz
  armclk 816000 KHz
  aclk_bus 150000 KHz
  pclk_bus 50000 KHz
  aclk_top_high 300000 KHz
  aclk_top_low 200000 KHz
  hclk_top 150000 KHz
  pclk_top 50000 KHz
  aclk_perimid 300000 KHz
  hclk_perimid 150000 KHz
  pclk_pmu 100000 KHz
No misc partition
Net:   No ethernet found.
Hit key to stop autoboot('CTRL+C'):  0
Could not find misc partition
ANDROID: reboot reason: "(none)"
optee api revision: 2.0
TEEC: Waring: Could not find security partition
Not AVB images, AVB skip
android_image_load_by_partname: Can't find part: boot
Android image load failed
Android boot failed, error -1.
## Booting FIT Image FIT: No boot partition
FIT: No fit blob
FIT: No FIT image
Could not find  part
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:2...
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
Edited by ewww
