rm_ Posted June 18, 2023 Posted June 18, 2023 Hello, I'm trying the currently offered Armbian Bookworm images for the Orange Pi Prime, using kernels 6.1.30 and 6.2.16, and notice that there is no support for SoC temperature monitoring, neither in armbianmonitor, nor in /sys/devices/virtual/thermal/. Here is the debug info from 6.2.16: https://paste.armbian.com/cetovulubu Is that a known issue? An older Armbian image that I have downloaded previously, using the kernel 5.15.93, shows the temperature just fine. 0 Quote
rm_ Posted July 2, 2023 Author Posted July 2, 2023 Copying DTBs over from the older image into the new one (6.1) does not solve it. 0 Quote
c0rnelius Posted July 2, 2023 Posted July 2, 2023 (edited) This requires patching, I'm not sure if it has been submitted yet. You are more than welcome to test it. 001-arch-arm64-dts-sun50i-h5-thermal-support.patch A similar patch is also needed for the A64. Edited July 2, 2023 by c0rnelius 1 Quote
rm_ Posted July 13, 2023 Author Posted July 13, 2023 Sorry, somehow I didn't get a reply notification of your post. On A64 (Orange Pi Win) I do not have this issue. I did not try the patch, but got the 6.4.1 development image a few days ago, and tried that just now, and can confirm the temperature monitoring is working again in that kernel. Now the same image is no longer offered on the download page for some reason though. 0 Quote
Gunjan Gupta Posted July 19, 2023 Posted July 19, 2023 Created jira for the issue and raised pull request for the same 0 Quote
Solution Gunjan Gupta Posted July 20, 2023 Solution Posted July 20, 2023 Fix has been merged and will be included in next release. 0 Quote
