🏆 Become a sponsor, help to add other boards in armbian standart, you don't need to be a programmer to help the community,
just need a copy of the ARM BOARD and a x86 computer to compile new versions.
If you like what you see here and want to help: Donate Armbian the like button only costs a few dollars.
Armbian Needs you help!
This Armbian adventure was summarized in my Public Github Repository.
H96 MAX V56 RK3566 8gb Ram SD-Card unofficial images:
Tutorial SD-Card Version v0.5 ARMBIAN BETA unofficial
H96 MAX V56 RK3566 8gb EMMC Chainloader to mainline HotnikQ unofficial images:
Tutorial EMMC Version V0.7 ARMBIAN BETA unofficial
H96 MAX V56 RK3566 8gb EMMC Mainline Boot Hzdm unofficial images:
Tutorial EMMC Version v0.8 ARMBIAN unofficial
Tutorial EMMC Version v0.9 ARMBIAN BETA unofficial
Tutorial EMMC Version v1.0 ARMBIAN unofficial
H96 MAX V56 RK3566 8gb EMMC Hzdm Mainline Boot Custom unofficial images:
Tutorial Build Your own Armbian EMMC unofficial image
H96 MAX V56 RK3566 EMMC Raspiblitz HotnikQ unofficial images:
Tutorial Build Raspiblitz on EMMC Armbian Bullseye unofficial
H96 MAX V56 RK3566 8gb EMMC Hzdm Mainline Boot unofficial images:
Tutorial Build Your own V1.1 Armbian EMMC unofficial image
H96 MAX V56 RK3566 8gb Vendor Kernel 5.1.16
Tutorial Build Your own Armbian Rockchip Kernel vendor Kernel 5.1.16 Armbian
Joshua Riek Ubuntu Rockchip Images kernel 5.1
H96 MAX V56 RK3566 8gb Vendor Kernel 6.1.43
Tutorial Build Your own Armbian Rockchip Kernel vendor Kernel 6.1.43 Armbian
Joshua Riek Ubuntu Rockchip Images Kernel 6.1
Tutorial Flash H96 Max on Linux Desktop
Tutorial Build Your own Armbian with Maxios Lan Device Using Linux Power Shell
                                         :love:
H96 MAX V56 RK3566 8gb EMMC Ning Mainline Kernel:
                       Armbian EMMC official image
Armbian Desktop Gnome kernel The Latest official
Debian BookWorm Server Kernel Minimal The Latest official
Desktop Test Images:
Pre-Build Desktop 22.04 Armbian Test Image (PT-BR)
Community Official Images:
Armbian_community_25.2.0-trunk.410_H96-tvbox-3566_bookworm_current_6.12.11_minimal.img.xz
Armbian_community_25.2.0-trunk.410_H96-tvbox-3566_noble_current_6.12.11_gnome_desktop.img.xz
Bleding Edge images:
Armbian-unofficial_25.11.0-trunk_H96-tvbox-3566_bookworm_edge_6.16.10_gnome_desktop.tar.xz
Software description:
V0.5 = @armbian The Armbian SD card image "Compiled From Armbian Project"
V0.8 = @hzdm Project with Mainline Bootloader "Boot the 64gb Emmc Armbian with Mainline Rockchip"
V0.9 = @hzdm Release Mainline Bootloader "Boot the 32gb and 64gb Emmc Armbian with Mainline Rockchip"
V1.0 = @hotnikq The Armbian SD card inside the Android Legacy Rockchip Image "Two Original Glued Images: Android boot for Linux"
V1.2 = @ning Release Device Tree and Bootloader to longterm 6.6.27 Kernel "Boot with Mainline Rockchip"
V1.3 = @Hqnicolas Github PR Enable h96 Rk3566 TV-Box device for Kernel 6.8
V1.4 = @pocosparc Github PR Enable OpenVFD and IR controller
V1.5 = @dfahren Github PR Update U-boot 2025.01 for Kernel 6.12+
@fevangelou Linux Flash Tutorial
@WINEDS Build Armbian for Maxios Lan Chip Board
Video drivers:
https://developer.arm.com/downloads/-/mali-drivers/bifrost-kernel
https://docs.mesa3d.org/download.html
https://docs.mesa3d.org/drivers/panfrost.html
Wifi Driver:
https://drive.google.com/file/d/1B1LmAylalETcnBEWiPiJHL0MjK5xlIV4/view?usp=sharing
For Boards Newer than 2025:
Follow @WINEDS method to compile Armbian with the ethernet and wifi drivers
Front Panel Display: Tutorial
Repo: https://github.com/jefflessard/tm16xx-display
UEFI: https://github.com/hqnicolas/h96v56_uefi/releases/tag/v1.2.1
Or Just Live install Wifi Driver:
cd /lib/firmware/brcm/
sudo wget https://github.com/CoreELEC/brcmfmac_sdio-firmware-aml/raw/master/firmware/brcm/fw_bcm4335b0_ag.bin
sudo ln -s fw_bcm4335b0_ag.bin brcmfmac4335-sdio.h96-TVbox,rk3566.bin
sudo reboot now
nmcli dev wifi
sudo cat > /lib/firmware/brcm/brcmfmac4335-sdio.txt << "EOF"
# bcm94335wlcspMS_ES50_RC171p24p23_04052013_AM_mdfy_PAparam.txt -- 4/5/2013 by Murata, based on bcm94335wlcspMS_ES50_RC171p24p20_04022013_AM.txt, changed PA parameters and txidxcap parameters and ccode.
# bcm94335wlcspMS_ES50_RC171p24p20_04022013_AM.txt -- 4/2/2013 by Broadcom Corporation
# Use with AARDVARK_REL_6_30_171_24_23 -- Murata BCM4335 WLCSP 11AC Module
# Sample variables file for Murata Type-XJ ES5.0 (0x00 0x11) -- bcm94335wlcspMS_AM_P400.txt as original
sromrev=11
boardrev=0x1500
boardtype=0x064b
boardflags=0x10401001
boardflags2=0x0
#updated boardflags3 for forcing to enable external LPO
boardflags3=0x0800c08b
macaddr=00:90:4c:c5:12:38
#ccode modified by Murata
#ccode=0
ccode=XS
regrev=0
antswitch=0
pdgain5g=1
pdgain2g=1
tworangetssi2g=0
tworangetssi5g=0
femctrl=4
vendid=0x14e4
devid=0x43ae
manfid=0x2d0
#prodid=0x052e
nocrc=1
#otpimagesize=502
xtalfreq=37400
extpagain2g=1
extpagain5g=1
rxgains2gelnagaina0=2
rxgains2gtrisoa0=6
rxgains2gtrelnabypa0=1
rxgains5gelnagaina0=3
rxgains5gtrisoa0=5
rxgains5gtrelnabypa0=1
rxchain=1
txchain=1
aa2g=1
aa5g=1
ag0=0
ag1=0
tssipos5g=1
tssipos2g=1
#PA parameters (2G20M/2G40M/5G20M/5G40M/5G80M)
#PA parameters modified by Murata
#pa2ga0=-208,6208,-764
#pa2ga1=-203,6429,-793
#pa5ga0=-167,5736,-685,-157,5669,-670,-157,5548,-665,-141,5621,-664
#pa5ga1=-101,6543,-735,-99,6452,-731,-147,5743,-695,-75,6468,-723
#pa5ga2=-172,5903,-708,-160,5868,-698,-113,6264,-722,-125,5915,-684
pa2ga0=0xff31,0x1759,0xFD1D
pa2ga1=0xff35,0x18BB,0xFCEC
pa5ga0=0xff78,0x1715,0xFD49,0xff89,0x1714,0xFD57,0xff86,0x1652,0xFD62,0xffa9,0x1760,0xFD5E
pa5ga1=0xff56,0x1596,0xFD5F,0xff88,0x1764,0xFD45,0xff89,0x1632,0xFD65,0xff69,0x160E,0xFD49
pa5ga2=0xff5a,0x1667,0xFD4E,0xff5f,0x15F7,0xFD5E,0xff5a,0x1531,0xFD68,0xff6e,0x1587,0xFD6A
# Default Target Power for 2G -- 17dBm(11)/14dBm(54)/13dBm(MCS7,MCS8)/16dBm(6,MCS0)
maxp2ga0=74
cckbw202gpo=0
cckbw20ul2gpo=0
dot11agofdmhrbw202gpo=0x6666
ofdmlrbw202gpo=0x0022
mcsbw202gpo=0x88866662
# Default Target Power for 5G -- 14dBm(54)/13dBm(HT20-MCS7,VHT20-MCS8)/12dBm(HT40-MCS7,VHT40-MCS9)/11dBm(VHT80-MCS8/MCS9)/16dBm(6,20HT-MCS0)
maxp5ga0=74,74,74,74
# Low
mcslr5glpo=0
mcsbw205glpo=0x88866662
mcsbw405glpo=0xAAA88884
mcsbw805glpo=0xCCCAAAA6
# Mid
mcslr5gmpo=0
mcsbw205gmpo=0x88866662
mcsbw405gmpo=0xAAA88884
mcsbw805gmpo=0xCCCAAAA6
# High
mcslr5ghpo=0
mcsbw205ghpo=0x88866662
mcsbw405ghpo=0xAAA88884
mcsbw805ghpo=0xCCCAAAA6
#20MHz High Rate
sb20in40hrpo=0x0
sb20in80and160hr5glpo=0x0
sb20in80and160hr5gmpo=0x0
sb20in80and160hr5ghpo=0x0
#40MHz High Rate
sb40and80hr5glpo=0x0
sb40and80hr5gmpo=0x0
sb40and80hr5ghpo=0x0
#20MHz Low Rate
sb20in40lrpo=0x0
sb20in80and160lr5glpo=0x0
sb20in80and160lr5gmpo=0x0
sb20in80and160lr5ghpo=0x0
#40MHz Low Rate
sb40and80lr5glpo=0x0
sb40and80lr5gmpo=0x0
sb40and80lr5ghpo=0x0
dot11agduphrpo=0x0
dot11agduplrpo=0x0
tssifloor2g=80
tssifloor5g=160,190,240,260
#rpcal:use with 171.17 or later, compensates filter ripple
rpcal2g=0x0
rpcal5gb0=0x0
#cckdigfilttype[0-7] 0:default
cckdigfilttype=2
phycal_tempdelta=25
#GPIO 0 for SDIO HW OOB interruption
muxenab=0x10
#sd_gpout=0
#sd_oobonly=1
rssicorrnorm_c0=-3,-2
rssicorrnorm5g_c0=-1,0,-3,-1,0,-3,-3,-2,-4,-3,-2,-4
#txidxcap2g and txidxcap5g modified by Murata
#txidxcap2g=32
#txidxcap5g=44
txidxcap2g=36
txidxcap5g=36
paparambwver=1
EOF
sudo rmmod brcmfmac_wcc brcmfmac brcmutil
modprobe brcmfmac
Topic description:
This topic aims to demonstrate the path taken to the Armibian EMMC solution.
In our path we create a lot of ready-to-use ROM files, some users burn an use this images without learning with the Linux compilation process.
the name of the topic is efforts but that's no effort at all, you should try compile your own images.
Device Capability Test: Using Rockchip SoCs NPU.
Drivers: https://github.com/rockchip-linux/rknpu2
User Guide: https://github.com/rockchip-linux/rknpu2/blob/master/doc/Rockchip_RKNPU_User_Guide_RKNN_API_V1.4.0_EN.pdf
OpenCV: https://opencv.org/blog/2022/11/29/working-with-neural-processing-units-npus-using-opencv/
A discussion on Reddit: https://www.reddit.com/r/OrangePI/comments/12b3jmj/accessing_the_npu_on_the_orange_pi/
Transformers models: https://github.com/usefulsensors/useful-transformers
Usage: https://www.crowdsupply.com/useful-sensors/ai-in-a-box/
Usage: https://youtu.be/pN8mKZ5wpdQ
How i will did this image?
I simply applied everything that was already said in the other topic, I will repeat ....
The only difference is the loader.bin: Uboot Legacy, Parameter.txt to create the Rockchip image
On 6/8/2023 at 7:16 PM, hotnikq said:
if you wanna do all that creepy again with other devices and images, (please do it on other devices) and topic
this is all you need to create this image,
first step:
Compile armbian on linux desktop
dont forgot to do it with modified DTS file:
in this case DTB + DTS Files for you to edit because you want to help the community
any resemblance to this topic is mere adaptation
Mount that image virtual device like /media/armbian_boot
fdisk -l your-armbian-image-for-sd-card.img
mount -o loop your-armbian-image-for-sd-card.img /media/armbian_boot
if you can't "like WSL2"
sudo apt-get install kpartx
sudo kpartx -av your-armbian-image-for-sd-card.img
sudo mount -o loop /dev/mapper/loop0p1 /media/armbian_boot
Second Step:  prepare an sd card or usb flash dummy , can be anithing with 6gb
fdisk /dev/mmcblk1
N
default
default (lower this value to match the size of your root image)
T
1
W
third step: format that flash drive for ext4
mkfs.ext4 /dev/mmcblk1p1
fourth step: mount that clear partition and copy the entire virtual drive to the flash device
mount /dev/mmcblk1p1 /mnt
rsync -avx /media/armbian_boot/ /mnt
fifth Step: Edit your uuid From Armbian Boot config "uuid for /dev/mmcblk1p1"
blkid
nano -w /mnt/boot/extlinux/extlinux.conf
sync
umount /mnt
sixth step: make an hardware RAW.img from hardware flash drive with these parameters
sudo dd if=/dev/mmcblk1p1 of=~/root.img bs=4096 status=progress
PS: can be /dev/SDA" I do it on my h96max" so it's mmcblk1
now you have an ROOT IMAGE MADE BY YOURSELF!
Update.img
CREATE the Update Image on linux with the rockchip software.
Linux Pack Rockchip Firmware
/Downloads/Linux_Pack_Firmware/rockdev$ ./mkupdate.sh
start to make update.img...
Android Firmware Package Tool v1.66
------ PACKAGE ------
Add file: ./package-file
Add file: ./package-file done,offset=0x800,size=0x1ce,userspace=0x1
Add file: ./Image/MiniLoaderAll.bin
Add file: ./Image/MiniLoaderAll.bin done,offset=0x1000,size=0x729c0,userspace=0xe6
Add file: ./Image/parameter.txt
Add file: ./Image/parameter.txt done,offset=0x74000,size=0x1aa,userspace=0x1
Add file: ./Image/dtbo.img
Add file: ./Image/dtbo.img done,offset=0x74800,size=0x26f,userspace=0x1
Add file: ./Image/uboot.img
Add file: ./Image/uboot.img done,offset=0x75000,size=0x400000,userspace=0x800
Add file: ./Image/parameter.txt done,offset=0x475000,size=0x19e,userspace=0x1
Add file: ./Image/rootfs.img
Add file: ./Image/rootfs.img done,offset=0x475800,size=0x11f213e00,userspace=0x23e428
Add CRC...
Make firmware OK!
------ OK ------
********RKImageMaker ver 1.66********
Generating new image, please wait...
Writing head info...
Writing boot file...
Writing firmware...
Generating MD5 data...
MD5 data generated successfully!
New image generated successfully!
Making ./Image/update.img OK.
Expand
./mkupdate.sh
Probably you can create a solid single file.img
How?
Just changing the parameter.txt file seting it UP to stop Grow!
Stop grow: by setting it to a FIXED VALUE instead of -@0x00038000(root:grow)
I think Rockchip grow function is messing with armbian ext4 by the whrong way
open new topics when performing this procedure on a device other than the H96MAX
I will be happy to help
This topic is Closed until Kernel 7
i dont wanna talk about RK3566 for the rest of my short life
Edited by hotnikq
  • Hqnicolas changed the title to Efforts to develop firmware for H96 MAX V56 RK3566 8G/64G
@hotnikq
I have downloaded the firmware root.img and update.img
When I use RkDevTool v2.86 to select the Firmware update.img follow step1, there is a error "Loading firmware failed!" at the RkDevTool
Is the reason for the error due to the fact that the firmware is not FIT firmware?
How can I flash the two firmware, THX!
Edited by mvpwar
Thanks, @hotnikq!
@mvpwar
But I'm having the same issue!
I tried on RkDevTool v2.95 and v2.86.
Unfortunately, I still know nothing about how to build an image from scratch so I'm looking like crazy for one that will work on my Vontar KK Max (yeah, I know this is for H96 Max but, as I said, I'm desperately already because it was not so cheap). I really hated the Android 11 UI of this box (tried another launchers but none is better than the stock). So I think Armbian would be a much more useful for it.
Edited by gersones
incorrect parenthesis
finally an adventurer to test this shit I made,
now I'm going to redo it and publish it again
when it is recompiled I will ask you to test again
remembering that this is not my device it's just an adaptation for 8gb
New Link
11 hours ago, gersones said:
Vontar KK Max
Start from scratch!
Create a new topic, and name it:  "Efforts to develop firmware for Vontar KK Max 4gb/32gb"
put pictures from your device and links to the android ROM images that already works on device
apply this method to decompile android image
share the DTB files, the uBoot files, the miniloader.bin all on your topic
my case took more than 8 months to show any result
but now we are on kernel 6 and things got faster, look this example
Edited by hotnikq
Sorry @hotnikq
but you don't have to bother anymore (about Vontar KK Max).
I think I just bricked the device though I read somewhere Rockchip devices were unbrickable.
I was so close to make it because I finally was successful in booting into Armbian (bookworm - kernel 5.10.x) and I f**ked it when, in an attempt to write it to the eMMC, I accidentaly erased all the partitions instead of letting the bootloader partition alone. Now my box doesn't get out of Maskmode anymore, no matter what I do.
I tried different versions of RkDevTool but I think I have no idea of what I'm doing anymore.
But thank you anyway.
@hotnikq
Okay, now I understand absolutely nothing.
Excepted the fact that I was able to boot Armbian as I told, everything (PC, electronics) went wrong "today" (now is "tomorrow" already in here).
After solving my computer BIOS little problem, I tried to flash the stock firmware (Android 11) with the RkDevTool and it did (I tried about thirty times or more for real).
I'm coming to the conclusion that I'll never understand anything about "computers" (gadgets and related thing in TIC) and how it works nor how it doesn't work.
I'll try again (Armbian that had worked) and give an update.
Regards
Just flash the original Android firmware again.
If it doesn't work you will need to:
do the clk - gnd short on emmc
And connect the device at the same time
After connect, just release the short
Probably you will find a tutorial on 4pda forum
If you Post two side pictures from your board hardware here,
I will show the clk and gnd pins
It's unbreakable like a rock cheap
Edited by hotnikq
4 hours ago, mvpwar said:
My box has been damaged
With the firmware working very well, I mean....
Can I flag this firmware as "working"?
As I said, I don't have this 8gb cheap Chinese box
I just have the cheapest cheap 4gb chip
Edited by hotnikq
@hotnikq
Now the update flashes but when it's done it goes to Maskrom mode no matter how many times I disconnect/reconnect while pressing the back button with a toothpick.
But I think my male usb to male usb isn't reliable since it fails many times to connect into both loader or maskrom while pressing the back button (now I think this was the problem I faced earlier).
I have no idea why a reboots "fix" it but I'm able to flash only once then I start to get these issues.
Sorry.
I'll try to buy another cable asap.
This is the Vontar kk Max?
That's happens because incompatible loader.Bin
Your device uses different memory.
19 hours ago, hotnikq said:
Start from scratch!
Understood.
Lastly, do you know any method to extract the original .dtb (as Android systems "are" Linux, they also work with .dtb binaries?).
If so, I'd need to extract mine because the only .dtb that worked with my device so far only sees 4GB RAM instead of the 8GB.
But I don't really know if this limitation is the image limitation (kernel used) or if is a .dtb that specifies only 4GB RAM.
Anyway, I'll stop posting here about Vontar KK Max and will create a new topic.
Thanks @hotnikq
The link to the method
About the new topic:
Which tag do I put (required field) since there's no rk3566 available and the Armbian which worked for me is a "station-m3"?
About my attempts:
I was able to extract multiple .dtb files from the boot.img (unpacked from the original Vontar KK Max firmware) but I have no idea how can I join these 01-first.dtb 02-second.dtb 03-third.dtb files into a single .dtb that I'll try to put into the working Armbian and point it in extlinux.conf to see if the 8gb RAM are recognized or if it's the kernel's limitation.
Edited by gersones
just checked that theres "other" tag in the tag list for creating a new post
Click Here and do it.
you will need to publish all of them in your topic since every DTB correspound to a device type, 4gb, 8gb, differente lan card... etc
Edited by hotnikq
No, after 1step flashing your new update.img, Maskrom mode happen... Only the debian 10.10 image works @hotnikq+
cs1 chA ca0 min: 0x38, mid:0x7e max:0xc5, range:0x8d
cs1 chA ca1 min: 0x45, mid:0x7e max:0xb7, range:0x72
cs1 chA ca2 min: 0x31, mid:0x75 max:0xba, range:0x89
cs1 chA ca3 min: 0x3c, mid:0x76 max:0xb1, range:0x75
cs1 chA ca4 min: 0x33, mid:0x76 max:0xba, range:0x87
cs1 chA ca5 min: 0x3b, mid:0x75 max:0xb0, range:0x75
cs1 chA  CS min: 0x3b, mid:0x6f max:0xa4, range:0x69
cs1 chB ca0 min: 0x37, mid:0x7c max:0xc1, range:0x8a
cs1 chB ca1 min: 0x3e, mid:0x78 max:0xb3, range:0x75
cs1 chB ca2 min: 0x32, mid:0x75 max:0xb8, range:0x86
cs1 chB ca3 min: 0x39, mid:0x74 max:0xaf, range:0x76
cs1 chB ca4 min: 0x31, mid:0x74 max:0xb8, range:0x87
cs1 chB ca5 min: 0x37, mid:0x72 max:0xad, range:0x76
cs1 chB  CS min: 0x3a, mid:0x6b max:0x9d, range:0x63
RX DQS Train result:
cs0, DQS0:cyc:3,oph:5,dll:17
cs0, DQS1:cyc:3,oph:5,dll:23
cs0, DQS2:cyc:3,oph:5,dll:14
cs0, DQS3:cyc:3,oph:5,dll:26
cs1, DQS0:cyc:3,oph:5,dll:20
cs1, DQS1:cyc:3,oph:5,dll:26
cs1, DQS2:cyc:3,oph:5,dll:17
cs1, DQS3:cyc:3,oph:5,dll:28
out
U-Boot SPL board init
U-Boot SPL 2017.09-gc613b7ea04-210315 #zzz (Mar 15 2021 - 18:08:14)
unknown raw ID phN
unrecognized JEDEC id bytes: 00, 00, 00
Trying to boot from MMC2
MMC error: The cmd index is 1, ret is -110
Card did not respond to voltage select!
mmc_init: -95, time 10
spl: mmc init failed with error: -95
Trying to boot from MMC1
SPL: A/B-slot: _a, successful: 0, tries-remain: 7
Not fit magic
Trying fit image at 0x5000 sector
Not fit magic
SPL: failed to boot from all boot devices
### ERROR ### Please RESET the board ###
# Reset the board to bootrom #
Edited by mvpwar
when I unpack the old update.img (can not be chosen to upgrade Firmware by RKDevTool directly) to path "RockChip_FactoryTool_v5.3\Temp\Android\Image" by FactoryTool V5.3
and manual run the partion img by RKDevTool, it can run the Loader device now! after flashing the armbian root.img , ttl debug below
unknown raw ID phN
SPL: A/B-slot: _a, successful: 0, tries-remain: 6
## Verified-boot: 0
## Checking atf-1 0x00040000 ... sha256+ OK
## Checking uboot 0x00a00000 ... sha256+ OK
## Checking fdt 0x00b3bb50 ... sha256+ OK
## Checking atf-2 0xfdcc9000 ... sha256+ OK
## Checking atf-3 0xfdcd0000 ... sha256+ OK
## Checking optee 0x08400000 ... sha256+ OK
Jumping to U-Boot(0x00a00000) via ARM Trusted Firmware(0x00040000)
Total: 226.206 ms
INFO:    Preloader serial: 2
NOTICE:  BL31: v2.3():v2.3-152-g4e725b15f:cl
NOTICE:  BL31: Built : 10:51:13, Jul 15 2021
INFO:    GICv3 without legacy support detected.
INFO:    ARM GICv3 driver initialized in EL3
INFO:    pmu v1 is valid
INFO:    dfs DDR fsp_param[0].freq_mhz= 780MHz
INFO:    dfs DDR fsp_param[1].freq_mhz= 324MHz
INFO:    dfs DDR fsp_param[2].freq_mhz= 528MHz
INFO:    dfs DDR fsp_param[3].freq_mhz= 780MHz
INFO:    Using opteed sec cpu_context!
INFO:    boot cpu mask: 0
INFO:    BL31: Initializing runtime services
INFO:    BL31: Initializing BL32
I/TC:
I/TC: Start rockchip platform init
I/TC: Rockchip release version: 1.0
I/TC: OP-TEE version: 3.6.0-307-g0b06ae94 #1 Fri May  7 01:52:27 UTC 2021 aarch64
I/TC: Initialized
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0xa00000
INFO:    SPSR = 0x3c9
U-Boot 2017.09 #qmx_srv (Mar 20 2023 - 17:46:24 +0800)
Model: Rockchip RK3568 Evaluation Board
PreSerial: 2, raw, 0xfe660000
DRAM:  7.7 GiB
Sysmem: init
Relocation Offset: ed23d000
Relocation fdt: eb9f8820 - eb9fecd0
CR: M/C/I
Using default environment
Hotkey: ctrl+`
dwmmc@fe2b0000: 1, dwmmc@fe2c0000: 2, sdhci@fe310000: 0
Bootdev(atags): mmc 0
MMC0: HS200, 200Mhz
PartType: EFI
DM: v1
boot mode: normal
FIT: Failed to load resource
No resource partition
Failed to load DTB, ret=-19
No find valid DTB, ret=-22
Failed to get kernel dtb, ret=-22
io-domain: OK
Failed to get scmi clk dev
dmc_fsp failed, ret=-19
rockchip_set_serialno: could not find efuse/otp device
CLK: (sync kernel. arm: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
  apll 816000 KHz
  dpll 390000 KHz
  gpll 1188000 KHz
  cpll 1000000 KHz
  npll 24000 KHz
  vpll 24000 KHz
  hpll 24000 KHz
  ppll 200000 KHz
  armclk 816000 KHz
  aclk_bus 150000 KHz
  pclk_bus 50000 KHz
  aclk_top_high 300000 KHz
  aclk_top_low 200000 KHz
  hclk_top 150000 KHz
  pclk_top 50000 KHz
  aclk_perimid 300000 KHz
  hclk_perimid 150000 KHz
  pclk_pmu 100000 KHz
Net:   No ethernet found.
Hit key to stop autoboot('CTRL+C'):  0
ANDROID: reboot reason: "(none)"
optee api revision: 2.0
TEEC: Waring: Could not find security partition
Not AVB images, AVB skip
No valid android hdr
Android image load failed
Android boot failed, error -1.
## Booting FIT Image at 0xeb7f6e00 with size 0x00000a00
Fdt Ramdisk skip relocation
## Loading kernel from FIT Image at eb7f6e00 ...
   Using 'conf' configuration
## Verified-boot: 0
Could not find subimage node
ERROR: can't get kernel image!
## Booting Rockchip Format Image
Could not find kernel partition, ret=-1
mmc_init: -95, time 9
switch to partitions #0, OK
mmc0(part 0) is current device
Failed to mount ext2 filesystem...
## Error: "mtd_boot" not defined
starting USB...
Bus dwc3@fcc00000: usb maximum-speed not found
Register 2000140 NbrPorts 2
Starting the controller
USB XHCI 1.10
Bus dwc3@fd000000: usb maximum-speed not found
USB XHCI 1.10
scanning bus dwc3@fcc00000 for devices... 1 USB Device(s) found
scanning bus dwc3@fd000000 for devices... 1 USB Device(s) found
Device 0: unknown device
No ethernet found.
missing environment variable: bootfile
Retrieving file: pxelinux.cfg/00000000
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
Retrieving file: pxelinux.cfg/default-arm-rockchip
No ethernet found.
No ethernet found.
No ethernet found.
Config file not found
No ethernet found.
You need to flash the part 2 tutorial
Sent from my 22021211RC using Tapatalk
9 hours ago, mvpwar said:
you mean the part2 is below link?
I was on a trip, now that I could see all your posts.
now i can see, you did all steps on other post.
I see you have a debug TTL, and a board different from mine.
I see you can run this method using this new box and parse the results
@mvpwar publish the results of your board in this post here! since it's an 8gb/64gb
Edited by hotnikq
yes , but I also have done all steps on this post...  the same result
wish you have a pleasant journey !  very grateful for taking the time to read my post 🫰 @hotnikq
yes, you will need to work around the "update.img" file
this is how i create the update.img
https://drive.google.com/file/d/1k_VUDxwtc-ACayWx4PtAkef0jWk65-jK/view
you can try to combine all MiniLoaderAll.bin with uboot.img files....
starting USB...
looks like the bootloader dont find the "root.img" partition inside EMMC............
????did you try to flash both versions from root.img on  0x0000A000 ???
I have already tried
yes, I both try the root.img of debian12 and armbian by "0x0000A000", the result is the same...
I found the 0x0000A000 is the dtb partition start address of Android image , I want to know your GPT partition table of emmc
@hotnikq
Edited by mvpwar
