dfahren Posted January 21 Posted January 21 (edited) Zitat Great job man, it works, it's fast, can you show us the secret sauce? Did you find a way to include it on armbian? @Hqnicolas Thanks! Yes and yes. 😀 I'd like to have others test this u-boot, too, if you don't mind. In due time, you will get a PR for your repo and may include it in Armbian. However, I think it is too special for inclusion right into Armbian source code, but you can decide once you looked at the PR. Edited January 21 by dfahren 1 Quote
dfahren Posted January 24 Posted January 24 (edited) @Hqnicolas I submitted a PR for you to review. Notice that it is somewhat fragmented and may not be mergable right away. I hope you can integrate it with your repo. Feel free to get back to me if you have questions or want amendments or the like ... 🙂 Best wishes, Deetsh Edited January 24 by dfahren 0 Quote
Hqnicolas Posted January 24 Author Posted January 24 (edited) 22 hours ago, dfahren said: I hope you can integrate it with your repo. Ok, I made changes that will make possible add this uboot 2025.01 to armbian build mainline @dfahren https://github.com/hqnicolas/ArmBoardBringUp/tree/deetsh Some features that was allowed with this: https://wiki.t-firefly.com/en/iCore-3588MQ/usage_adc.html After some tests, it was pulled for main https://github.com/hqnicolas/ArmBoardBringUp working in a pull request for armbian community.... edit: pull request to armbian: https://github.com/armbian/build/pull/7746 Edited January 25 by Hqnicolas 0 Quote
Hqnicolas Posted January 25 Author Posted January 25 (edited) @dfahren I see that you have a lot to add here, I would like you to participate in the integration of this board in Joshua Riek's project to enable RKNPU, where the board already works but there is the problem of the maskrom button, micro stuttering and the memory clock. edit: the u-boot 2025.01 for h96max v56 was merged, also wifi works out of the box, no patch needed. @maka @mvpwar @hzdm @dfahren @Vincenzoernst1 @pessimism please keep a copy from next armbian release for this board. Edited January 30 by Hqnicolas 2 Quote
dfahren Posted January 27 Posted January 27 @Hqnicolas: Thanks for the invitation! I have the impression, you overestimate my capabilities to participate in this project. NPU, for example, I'm completely blank, have no idea what it is about. May be I'm able to integrate this particular OpenVFD driver in the kernel, but that is something for the (hopefully not so distant) future. Panfrost, rkvdec and so on is for the DEVs with high stakes and - without any doubt - boat loads of time, which, very unfortunately, have not ... 😞 I'll get back to this forum once I have good news to share (or questions to ask). Till then: all the best to everybody! 0 Quote
Hqnicolas Posted February 2 Author Posted February 2 (edited) @dfahren Your changes was made also for Joshua Riek project. https://github.com/Joshua-Riek/ubuntu-rockchip/pull/1179 I also generated some images: Joshua-Riek Vendor Images: 22.04-preinstalled-desktop-arm64-h96max-v56 22.04-preinstalled-server-arm64-h96max-v56 deal with wifi drivers for kernel 5.1 24.04-preinstalled-desktop-arm64-h96max-v56 24.04-preinstalled-server-arm64-h96max-v56 deal with wifi drivers and stutterings for Kernel 6.1 on mainline, the mainline images was deployed by the armbian community: Community Official Images: Armbian_community_25.2.0-trunk.410_H96-tvbox-3566_bookworm_current_6.12.11_minimal.img.xz Armbian_community_25.2.0-trunk.410_H96-tvbox-3566_noble_current_6.12.11_gnome_desktop.img.xz Now this board can Run RKNPU with frigate. Edited February 2 by Hqnicolas 0 Quote
fragpic Posted February 6 Posted February 6 Sorry for intruding guys but I have a T95 Plus which has an RK3566 with 4G/64G. Will this firmware be a drop in replacement for it? Thanks in advance. 0 Quote
Hqnicolas Posted February 6 Author Posted February 6 (edited) 4 hours ago, fragpic said: Sorry for intruding guys but I have a T95 Plus which has an RK3566 with 4G/64G. Will this firmware be a drop in replacement for it? Thanks in advance. We don't have this board, but you can find users with this model in this link you could also find people on https://www.t95plus.com/ use other topics as development path Edited February 6 by Hqnicolas 1 Quote
fragpic Posted February 6 Posted February 6 6 hours ago, Hqnicolas said: We don't have this board, but you can find users with this model in this link you could also find people on https://www.t95plus.com/ use other topics as development path Edited 6 hours ago by Hqnicolas Thanks for the response, I went through them already and it looks like the development on it went stale. I read that all RK3566 TV Boxes have the same internals so was hoping to use this build. 0 Quote
Deoptim Posted February 22 Posted February 22 14.01.2025 в 05:36, Deoptim сказал: The chip on Taobao ~15$ is 64gbit (8GByte) but has 2 ranks (2 CS) Dual-Rank must be supported in your hardware, e.g. there must be tracks and pads under LPDDR for both A and B channel: CS0_A, CS0_B and CS1_A, CS1_B same for data lines DQ_0-15_A and DQ_0-15_B etc.... I bought it for my Rock 3A (2GB), If I bought this SBC for 25$ (34$ on Taobao or 49$ on AliExpress), then plus this memory chip +15$(not including shipping) comes out to 40$ for my case. Also I have the skills of soldering and repairing with a soldering air station - this is also important, by the way I bought a stencil for bga200 + solder paste (or balls for bga rebolling) just in case I have to re-solder. Continuing on the topic of replacing the LPDDR4 memory chip. Here is a successful experience of replacement. 2 Quote
DreamDreams Posted 12 hours ago Posted 12 hours ago I'd like to netboot from u-boot, but found that there is no network driver enabled. I tried to compile u-boot by myself, attatched is my .config file. With this config u-boot still can't detect network card. Any idea which driver I should use? h96.config 0 Quote
Hqnicolas Posted 6 hours ago Author Posted 6 hours ago 5 hours ago, DreamDreams said: Any idea which driver I should use? I think you will need to create an u-boot DTS and CONFIG with this device enabled, the u-boot that I use is 2025.01 0 Quote
DreamDreams Posted 5 hours ago Posted 5 hours ago @Hqnicolas Thanks for the reminder. I patched the dts, now I can see network card in u-boot. 0 Quote
