Posted (edited)
Zitat
Great job man, it works, it's fast, can you show us the secret sauce?
Did you find a way to include it on armbian?
@Hqnicolas    Thanks! Yes and yes. 😀
I'd like to have others test this u-boot, too, if you don't mind. In due time, you will get a PR for your repo and may include it in Armbian. However, I think it is too special for inclusion right into Armbian source code, but you can decide once you looked at the PR.
Edited by dfahren
Posted (edited)
@Hqnicolas I submitted a PR for you to review. Notice that it is somewhat fragmented and may not be mergable right away. I hope you can integrate it with your repo. Feel free to get back to me if you have questions or want amendments or the like ... 🙂
Best wishes, Deetsh
Edited by dfahren
Posted (edited)
Ok, I made changes that will make possible add this uboot 2025.01 to armbian build mainline
@dfahren
https://github.com/hqnicolas/ArmBoardBringUp/tree/deetsh
Some features that was allowed with this:
https://wiki.t-firefly.com/en/iCore-3588MQ/usage_adc.html
After some tests, it was pulled for main
working in a pull request for armbian community....
edit:
pull request to armbian: https://github.com/armbian/build/pull/7746
Edited by Hqnicolas
Posted (edited)
@dfahren
I see that you have a lot to add here,
I would like you to participate in the integration of this board in Joshua Riek's project to enable RKNPU,
where the board already works but there is the problem of the maskrom button, micro stuttering and the memory clock.
edit: the u-boot 2025.01 for h96max v56 was merged, also wifi works out of the box, no patch needed.
@maka @mvpwar @hzdm @dfahren @Vincenzoernst1 @pessimism
please keep a copy from next armbian release for this board.
Edited by Hqnicolas
@Hqnicolas: Thanks for the invitation! I have the impression, you overestimate my capabilities to participate in this project. NPU, for example, I'm completely blank, have no idea what it is about. May be I'm able to integrate this particular OpenVFD driver in the kernel, but that is something for the (hopefully not so distant) future. Panfrost, rkvdec and so on is for the DEVs with high stakes and - without any doubt - boat loads of time, which, very unfortunately, have not ... 😞
I'll get back to this forum once I have good news to share (or questions to ask). Till then: all the best to everybody!
Sorry for intruding guys but I have a T95 Plus which has an RK3566 with 4G/64G. Will this firmware be a drop in replacement for it?
Thanks in advance.
14.01.2025 в 05:36, Deoptim сказал:
The chip on Taobao ~15$ is 64gbit (8GByte) but has 2 ranks (2 CS) Dual-Rank must be supported in your hardware, e.g. there must be tracks and pads under LPDDR for both A and B channel: CS0_A, CS0_B and CS1_A,  CS1_B same for data lines DQ_0-15_A and DQ_0-15_B etc....
I bought it for my Rock 3A (2GB), If I bought this SBC for 25$ (34$ on Taobao or 49$ on AliExpress), then plus this memory chip +15$(not including shipping) comes out to 40$ for my case. Also I have the skills of soldering and repairing with a soldering air station - this is also important, by the way I bought a stencil for bga200 + solder paste (or balls for bga rebolling) just in case I have to re-solder.
Continuing on the topic of replacing the LPDDR4 memory chip.
Here is a successful experience of replacement.
I'd like to netboot from u-boot, but found that there is no network driver enabled. I tried to compile u-boot by myself, attatched is my .config file. With this config u-boot still can't detect network card. Any idea which driver I should use?
h96.config
Posted (edited)
Maxio Tech kindly sent me some documentation and files.  I managed to get the MAE0621 driver compiled into kernel 6.12.24. I had to make some new patches.  But I am getting a DMA engine initialization failed message (see attached) in dmesg and Ethernet still doesn't work :
[  157.100705] rk_gmac-dwmac fe010000.ethernet end0: PHY [stmmac-0:00] driver [MAE0621A-Q2C Gigabit Ethernet] (irq=POLL)
[  158.104686] rk_gmac-dwmac fe010000.ethernet: Failed to reset the dma
[  158.105304] rk_gmac-dwmac fe010000.ethernet end0: stmmac_hw_setup: DMA engine initialization failed
[  158.106119] rk_gmac-dwmac fe010000.ethernet end0: __stmmac_open: Hw setup failed
Do I also need to update uboot for MAE0621?  The current uboot patches I have from the vendor apply to phy_init() which has been deprecated.  Or maybe this is a DTB issue?   Any hints or advice would be kindly appreciated.
dmesg_error.txt
Edited by WINEDS
Posted (edited)
Thanks maka for replying.  Issue is resolved and Ethernet is working now.  I did not read the first email from Maxio tech properly and I was sent files for MAE0621A-Q3C rather than the MAE0621A-Q2C which I have.  Maxio tech kindly sent me files for MAE0621A-Q2C yesterday and I managed to compile it into the current kernel 6.12.24
Edited by WINEDS
Posted (edited)
AIC8800 modules spam dmesg with debug messages.  To suppress add aic8800.conf to etc/modprobe.d/
see :  https://github.com/radxa-pkg/aic8800/issues/15
sudo nano /etc/modprobe.d/aic8800.conf
add:
options aic8800_fdrv_sdio aicwf_dbg_level=0
options aic_load_fw_sdio aicwf_dbg_level=0
Edit : WIFI speed still limited to about 100Mbps with H96 about 2m from access point.  Anybody else see this?
aic8800.conf
Edited by WINEDS
Posted (edited)
https://kanyi.gm/how-to-install-and-enable-aic8800-chipset-wi-fi-driver-for-linux/
Some people have problems with this device
There’s no denying that the AIC8800 is a terrible component for a linux desktop/server. Its manufacturer has not made any effort to upstream the drivers. Either you live with no WLAN/BT or you live with DKMS package.
Edited by Hqnicolas
Posted (edited)
Yes I guess at AUD3.15 dollar SDIO module on Aliexpress we can't expect much.  Although maybe SDIO bandwidth is the limiting factor?
alarm@h96-tvbox-3566:~/Desktop$ sudo iw dev wlan0 link
Connected to 48:b4:24:48:96:46 (on wlan0)
    SSID: wireless+
    freq: 5180.0
    RX: 1341373709 bytes (1032430 packets)
    TX: 525423972 bytes (535411 packets)
    signal: -38 dBm
    rx bitrate: 286.7 MBit/s 40MHz HE-MCS 11 HE-NSS 1 HE-GI 0 HE-DCM 0
    tx bitrate: 286.7 MBit/s 40MHz HE-MCS 11 HE-NSS 1 HE-GI 0 HE-DCM 0
My Ideapad sitting next to the H96 connects to the same AP and does much better :
paul@paul-IdeaPad-5-2-in-1-14AHP9:~$ sudo iw dev wlp2s0 link
Connected to 48:b4:24:48:96:46 (on wlp2s0)
    SSID: wireless+
    freq: 5180.0
    RX: 4168818505 bytes (5516108 packets)
    TX: 12131143 bytes (14907828 packets)
    signal: -41 dBm
    rx bitrate: 2401.9 MBit/s 160MHz HE-MCS 11 HE-NSS 2 HE-GI 0 HE-DCM 0
    tx bitrate: 2161.3 MBit/s 160MHz HE-MCS 10 HE-NSS 2 HE-GI 0 HE-DCM 0
    bss flags: short-slot-time
    dtim period: 2
    beacon int: 100
Edited by WINEDS
guys, any noob-friendly guide to make  JL2101 ethernet work by editing dtb ?
i did :
dtc -I dtb -O dts -o rk3556-h96-tvbox.dts rk3556-h96-tvbox.dtb
but that's all what i know, i dont know which string should i change in the dts file before converting back to dtb
or is it currently not possible to make it work without full armbian rebuild instead of just modifying the dtb file ?
