dfahren Posted January 21 Posted January 21 (edited) Zitat Great job man, it works, it's fast, can you show us the secret sauce? Did you find a way to include it on armbian? @Hqnicolas Thanks! Yes and yes. 😀 I'd like to have others test this u-boot, too, if you don't mind. In due time, you will get a PR for your repo and may include it in Armbian. However, I think it is too special for inclusion right into Armbian source code, but you can decide once you looked at the PR. Edited January 21 by dfahren 1 Quote
dfahren Posted January 24 Posted January 24 (edited) @Hqnicolas I submitted a PR for you to review. Notice that it is somewhat fragmented and may not be mergable right away. I hope you can integrate it with your repo. Feel free to get back to me if you have questions or want amendments or the like ... 🙂 Best wishes, Deetsh Edited January 24 by dfahren 0 Quote
Hqnicolas Posted January 24 Author Posted January 24 (edited) 22 hours ago, dfahren said: I hope you can integrate it with your repo. Ok, I made changes that will make possible add this uboot 2025.01 to armbian build mainline @dfahren https://github.com/hqnicolas/ArmBoardBringUp/tree/deetsh Some features that was allowed with this: https://wiki.t-firefly.com/en/iCore-3588MQ/usage_adc.html After some tests, it was pulled for main https://github.com/hqnicolas/ArmBoardBringUp working in a pull request for armbian community.... edit: pull request to armbian: https://github.com/armbian/build/pull/7746 Edited January 25 by Hqnicolas 0 Quote
Hqnicolas Posted January 25 Author Posted January 25 (edited) @dfahren I see that you have a lot to add here, I would like you to participate in the integration of this board in Joshua Riek's project to enable RKNPU, where the board already works but there is the problem of the maskrom button, micro stuttering and the memory clock. edit: the u-boot 2025.01 for h96max v56 was merged, also wifi works out of the box, no patch needed. @maka @mvpwar @hzdm @dfahren @Vincenzoernst1 @pessimism please keep a copy from next armbian release for this board. Edited January 30 by Hqnicolas 2 Quote
dfahren Posted January 27 Posted January 27 @Hqnicolas: Thanks for the invitation! I have the impression, you overestimate my capabilities to participate in this project. NPU, for example, I'm completely blank, have no idea what it is about. May be I'm able to integrate this particular OpenVFD driver in the kernel, but that is something for the (hopefully not so distant) future. Panfrost, rkvdec and so on is for the DEVs with high stakes and - without any doubt - boat loads of time, which, very unfortunately, have not ... 😞 I'll get back to this forum once I have good news to share (or questions to ask). Till then: all the best to everybody! 0 Quote
Hqnicolas Posted February 2 Author Posted February 2 (edited) @dfahren Your changes was made also for Joshua Riek project. https://github.com/Joshua-Riek/ubuntu-rockchip/pull/1179 I also generated some images: Joshua-Riek Vendor Images: 22.04-preinstalled-desktop-arm64-h96max-v56 22.04-preinstalled-server-arm64-h96max-v56 deal with wifi drivers for kernel 5.1 24.04-preinstalled-desktop-arm64-h96max-v56 24.04-preinstalled-server-arm64-h96max-v56 deal with wifi drivers and stutterings for Kernel 6.1 on mainline, the mainline images was deployed by the armbian community: Community Official Images: Armbian_community_25.2.0-trunk.410_H96-tvbox-3566_bookworm_current_6.12.11_minimal.img.xz Armbian_community_25.2.0-trunk.410_H96-tvbox-3566_noble_current_6.12.11_gnome_desktop.img.xz Now this board can Run RKNPU with frigate. Edited February 2 by Hqnicolas 0 Quote
fragpic Posted February 6 Posted February 6 Sorry for intruding guys but I have a T95 Plus which has an RK3566 with 4G/64G. Will this firmware be a drop in replacement for it? Thanks in advance. 0 Quote
Hqnicolas Posted February 6 Author Posted February 6 (edited) 4 hours ago, fragpic said: Sorry for intruding guys but I have a T95 Plus which has an RK3566 with 4G/64G. Will this firmware be a drop in replacement for it? Thanks in advance. We don't have this board, but you can find users with this model in this link you could also find people on https://www.t95plus.com/ use other topics as development path Edited February 6 by Hqnicolas 1 Quote
fragpic Posted February 6 Posted February 6 6 hours ago, Hqnicolas said: We don't have this board, but you can find users with this model in this link you could also find people on https://www.t95plus.com/ use other topics as development path Edited 6 hours ago by Hqnicolas Thanks for the response, I went through them already and it looks like the development on it went stale. I read that all RK3566 TV Boxes have the same internals so was hoping to use this build. 0 Quote
Deoptim Posted February 22 Posted February 22 14.01.2025 в 05:36, Deoptim сказал: The chip on Taobao ~15$ is 64gbit (8GByte) but has 2 ranks (2 CS) Dual-Rank must be supported in your hardware, e.g. there must be tracks and pads under LPDDR for both A and B channel: CS0_A, CS0_B and CS1_A, CS1_B same for data lines DQ_0-15_A and DQ_0-15_B etc.... I bought it for my Rock 3A (2GB), If I bought this SBC for 25$ (34$ on Taobao or 49$ on AliExpress), then plus this memory chip +15$(not including shipping) comes out to 40$ for my case. Also I have the skills of soldering and repairing with a soldering air station - this is also important, by the way I bought a stencil for bga200 + solder paste (or balls for bga rebolling) just in case I have to re-solder. Continuing on the topic of replacing the LPDDR4 memory chip. Here is a successful experience of replacement. 2 Quote
DreamDreams Posted March 13 Posted March 13 I'd like to netboot from u-boot, but found that there is no network driver enabled. I tried to compile u-boot by myself, attatched is my .config file. With this config u-boot still can't detect network card. Any idea which driver I should use? h96.config 0 Quote
Hqnicolas Posted March 13 Author Posted March 13 5 hours ago, DreamDreams said: Any idea which driver I should use? I think you will need to create an u-boot DTS and CONFIG with this device enabled, the u-boot that I use is 2025.01 0 Quote
DreamDreams Posted March 13 Posted March 13 @Hqnicolas Thanks for the reminder. I patched the dts, now I can see network card in u-boot. 0 Quote
WINEDS Posted April 9 Posted April 9 (edited) I've just got one of these boxes and ethernet does not work in armbian. It has a MAE0621A network chip. Also WIFI chip is https://www.aliexpress.com/item/1005007622558922.html which is think is similar to AIC8800DC. Edited April 9 by WINEDS 0 Quote
WINEDS Posted April 11 Posted April 11 (edited) I have a temp fix for the WIFI on newer hardware with AIC8800 SDIO WIFI module. Download or wget : https://github.com/radxa-pkg/aic8800/releases/download/3.0%2Bgit20240327.3561b08f-4/aic8800-firmware_3.0+git20240327.3561b08f-4_all.deb https://github.com/radxa-pkg/aic8800/releases/download/3.0%2Bgit20240327.3561b08f-4/aic8800-sdio-dkms_3.0+git20240327.3561b08f-4_all.deb Then : sudo dpkg -i aic8800-firmware_3.0+git20240327.3561b08f-4_all.deb sudo dpkg -i aic8800-sdio-dkms_3.0+git20240327.3561b08f-4_all.deb Edited April 11 by WINEDS 0 Quote
WINEDS Posted April 23 Posted April 23 (edited) Maxio Tech kindly sent me some documentation and files. I managed to get the MAE0621 driver compiled into kernel 6.12.24. I had to make some new patches. But I am getting a DMA engine initialization failed message (see attached) in dmesg and Ethernet still doesn't work : [ 157.100705] rk_gmac-dwmac fe010000.ethernet end0: PHY [stmmac-0:00] driver [MAE0621A-Q2C Gigabit Ethernet] (irq=POLL) [ 158.104686] rk_gmac-dwmac fe010000.ethernet: Failed to reset the dma [ 158.105304] rk_gmac-dwmac fe010000.ethernet end0: stmmac_hw_setup: DMA engine initialization failed [ 158.106119] rk_gmac-dwmac fe010000.ethernet end0: __stmmac_open: Hw setup failed Do I also need to update uboot for MAE0621? The current uboot patches I have from the vendor apply to phy_init() which has been deprecated. Or maybe this is a DTB issue? Any hints or advice would be kindly appreciated. dmesg_error.txt Edited April 23 by WINEDS 0 Quote
maka Posted April 23 Posted April 23 The driver is well so the problem seems you are in the wrong ethernet phy. Change from phy0 to phy1 in the ethernet node. 2 Quote
WINEDS Posted April 24 Posted April 24 (edited) Thanks maka for replying. Issue is resolved and Ethernet is working now. I did not read the first email from Maxio tech properly and I was sent files for MAE0621A-Q3C rather than the MAE0621A-Q2C which I have. Maxio tech kindly sent me files for MAE0621A-Q2C yesterday and I managed to compile it into the current kernel 6.12.24 Edited April 24 by WINEDS 1 Quote
guenter Posted April 24 Posted April 24 It was already mentioned that bluetooth is not working on boxes with AIC8800D40. Maybe is the bug describe here: https://github.com/radxa-pkg/aic8800/issues/14 responsible for that. 0 Quote
WINEDS Posted April 25 Posted April 25 (edited) AIC8800 modules spam dmesg with debug messages. To suppress add aic8800.conf to etc/modprobe.d/ see : https://github.com/radxa-pkg/aic8800/issues/15 sudo nano /etc/modprobe.d/aic8800.conf add: options aic8800_fdrv_sdio aicwf_dbg_level=0 options aic_load_fw_sdio aicwf_dbg_level=0 Edit : WIFI speed still limited to about 100Mbps with H96 about 2m from access point. Anybody else see this? aic8800.conf Edited April 25 by WINEDS 0 Quote
Hqnicolas Posted April 25 Author Posted April 25 (edited) 1 hour ago, WINEDS said: Edit : WIFI speed still limited to about 100Mbps with H96 about 2m from access point. Anybody else see this? https://kanyi.gm/how-to-install-and-enable-aic8800-chipset-wi-fi-driver-for-linux/ Some people have problems with this device There’s no denying that the AIC8800 is a terrible component for a linux desktop/server. Its manufacturer has not made any effort to upstream the drivers. Either you live with no WLAN/BT or you live with DKMS package. Edited April 25 by Hqnicolas 1 Quote
WINEDS Posted April 25 Posted April 25 (edited) Yes I guess at AUD3.15 dollar SDIO module on Aliexpress we can't expect much. Although maybe SDIO bandwidth is the limiting factor? alarm@h96-tvbox-3566:~/Desktop$ sudo iw dev wlan0 link Connected to 48:b4:24:48:96:46 (on wlan0) SSID: wireless+ freq: 5180.0 RX: 1341373709 bytes (1032430 packets) TX: 525423972 bytes (535411 packets) signal: -38 dBm rx bitrate: 286.7 MBit/s 40MHz HE-MCS 11 HE-NSS 1 HE-GI 0 HE-DCM 0 tx bitrate: 286.7 MBit/s 40MHz HE-MCS 11 HE-NSS 1 HE-GI 0 HE-DCM 0 My Ideapad sitting next to the H96 connects to the same AP and does much better : paul@paul-IdeaPad-5-2-in-1-14AHP9:~$ sudo iw dev wlp2s0 link Connected to 48:b4:24:48:96:46 (on wlp2s0) SSID: wireless+ freq: 5180.0 RX: 4168818505 bytes (5516108 packets) TX: 12131143 bytes (14907828 packets) signal: -41 dBm rx bitrate: 2401.9 MBit/s 160MHz HE-MCS 11 HE-NSS 2 HE-GI 0 HE-DCM 0 tx bitrate: 2161.3 MBit/s 160MHz HE-MCS 10 HE-NSS 2 HE-GI 0 HE-DCM 0 bss flags: short-slot-time dtim period: 2 beacon int: 100 Edited April 25 by WINEDS 0 Quote
Andre B Posted April 25 Posted April 25 guys, any noob-friendly guide to make JL2101 ethernet work by editing dtb ? i did : dtc -I dtb -O dts -o rk3556-h96-tvbox.dts rk3556-h96-tvbox.dtb but that's all what i know, i dont know which string should i change in the dts file before converting back to dtb or is it currently not possible to make it work without full armbian rebuild instead of just modifying the dtb file ? 0 Quote
Hqnicolas Posted April 26 Author Posted April 26 guys, any noob-friendly guide to make JL2101 ethernet work by editing dtb ? i did :dtc -I dtb -O dts -o rk3556-h96-tvbox.dts rk3556-h96-tvbox.dtb but that's all what i know, i dont know which string should i change in the dts file before converting back to dtb or is it currently not possible to make it work without full armbian rebuild instead of just modifying the dtb file ?That's the deal, you are the only one in earth that can make it, you have the device to test the changes.Just find the phy and Ethernet fields make you changes and send it back to device to testJust change the dtb inside the folder, in my opinion, the SD card board that other users make is always fast, because the SD card is easy to edit 0 Quote
WINEDS Posted April 28 Posted April 28 (edited) In case someone else needs MAX0621 support here are the original files sent to me from Maxio Tech and my modified patch file (my_v1_patch.patch) for kernel 6.12.24 Then : sudo modprobe -r dwmac_rk sudo modprobe -a maxio sudo modprobe -a dwmac_rk I made a startup script to do that but there must be a better way? maxio also needs to be selected (M) in kernel config phase of build script (Device Drivers -> Network Device Support -> PHY Deice Support and Infrastructure) Release Note.txt v1_patch.patch maxio.c README my_v1_patch.patch Edited Monday at 06:54 AM by WINEDS 0 Quote
maka Posted Monday at 08:24 AM Posted Monday at 08:24 AM I think your driver is already in armbian, but your chip is not identified. To get it working you can identify it in the ethernet node this way: mdio { compatible = "snps,dwmac-mdio"; #address-cells = < 0x01 >; #size-cells = < 0x00 >; ethernet-phy@1 { compatible = "ethernet-phy-ieee802.3-c22"; ====> compatible = "ethernet-phy-id7b74.4411", "ethernet-phy-ieee802.3-c22"; 2 Quote
WINEDS Posted Monday at 11:15 AM Posted Monday at 11:15 AM (edited) Many thanks Maka! Works like a charm. maxio loads automatically now. No need for modprobe Server listening on 5201 (test #2) ----------------------------------------------------------- Accepted connection from 192.168.0.25, port 45188 [ 5] local 192.168.0.26 port 5201 connected to 192.168.0.25 port 45192 [ ID] Interval Transfer Bitrate [ 5] 0.00-1.00 sec 111 MBytes 929 Mbits/sec [ 5] 1.00-2.00 sec 112 MBytes 942 Mbits/sec [ 5] 2.00-3.00 sec 112 MBytes 942 Mbits/sec [ 5] 3.00-4.00 sec 112 MBytes 941 Mbits/sec [ 5] 4.00-5.00 sec 112 MBytes 942 Mbits/sec [ 5] 5.00-6.00 sec 112 MBytes 941 Mbits/sec [ 5] 6.00-7.00 sec 112 MBytes 942 Mbits/sec [ 5] 7.00-8.00 sec 112 MBytes 942 Mbits/sec [ 5] 8.00-9.00 sec 112 MBytes 942 Mbits/sec [ 5] 9.00-10.00 sec 112 MBytes 942 Mbits/sec [ 5] 10.00-10.01 sec 1.50 MBytes 913 Mbits/sec - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval Transfer Bitrate [ 5] 0.00-10.01 sec 1.10 GBytes 940 Mbits/sec receiver ----------------------------------------------------------- Tail of lsmod : maxio 12288 1 dwmac_rk 28672 0 stmmac_platform 20480 1 dwmac_rk stmmac 241664 3 stmmac_platform,dwmac_rk pcs_xpcs 24576 1 stmmac rk817_charger 20480 0 rtc_rk808 16384 1 rockchipdrm 180224 8 dw_hdmi_qp 20480 1 rockchipdrm dw_hdmi 45056 2 dw_hdmi_i2s_audio,rockchipdrm cec 45056 2 dw_hdmi_cec,dw_hdmi dw_mipi_dsi 16384 1 rockchipdrm analogix_dp 40960 1 rockchipdrm drm_display_helper 131072 4 rockchipdrm,dw_hdmi,analogix_dp,dw_hdmi_qp hid_logitech_hidpp 49152 0 hid_logitech_dj 32768 0 Edited Monday at 11:19 AM by WINEDS 0 Quote
WINEDS Posted yesterday at 01:12 AM Posted yesterday at 01:12 AM (edited) Bluetooth is fixed with AIC8800 wifi module. Credit to @pocosparc Changed DTS Bluetooth node as per at least change suggestion. @pocosparc did you confirm optical SPDIF as working? My port is not illuminated. Edited yesterday at 01:18 AM by WINEDS 1 Quote
Andre B Posted 3 hours ago Posted 3 hours ago My bluetooth is not working as well, but i fixed it with : rm -fv /lib/firmware/brcm/BCM4335C0.h96-TVbox,rk3566.hcd /lib/firmware/brcm/BCM4335C0.hcd sync wget https://raw.githubusercontent.com/unifreq/openwrt_packit/refs/heads/master/files/firmware/brcm/BCM4335C0.hcd -O /lib/firmware/brcm/BCM4335C0.hcd ln -frsv /lib/firmware/brcm/BCM4335C0.hcd /lib/firmware/brcm/BCM4335C0.h96-TVbox,rk3566.hcd sync reboot now i just need to make the ethernet work. i read @maka's reply to @WINEDS which just simply replace compatible = "ethernet-phy-ieee802.3-c22" line, so i search web for JL2101 compatible = "ethernet-phy-ieee802.3-c22", one of the result is https://blog.csdn.net/zuiaikg703/article/details/123892743 , i translated the top content into (more or less) like bellow : JL2101 is a domestic 1000M PHY IC that is pin-to-pin with Realtek Rtl8211F Since it has the same pin and supply voltage as RTL8211F, we first compiled it directly with the configuration of RK RTL8211F according to RK's suggestion: ICs such as RK3566 and RK3568 need to pay attention to the domain working voltage configuration. According to the actual hardware configuration, the corresponding voltage configuration is made in the software : PMUIO2 Supply Power Voltage1:3300000 VCCIO1 Supply Power Voltage1:3300000 VCCIO3 Supply Power Voltage1:3300000 VCCIO4 Supply Power Voltage1:1800000 VCCIO5 Supply Power Voltage1:3300000 VCCIO6 Supply Power Voltage1:1800000 VCCIO7 Supply Power Voltage1:3300000 @Hqnicolas, would you mind assist me to assign those values to rk3566-h96-tvbox.dtb ? 0 Quote
