OPi PCPlus eMMC testing utility?
Christos
Is there any testing utility/exerciser for OPi PCPlus eMMC?
I'm geting strange problems when fast and large writes happen in eMMC.
/Edit
this is what I get by running 'armbianmonitor -c ~/healthtest'
WARNING: It seems you're not testing the SD card but instead healthtest ()
Starting to fill healthtest with test patterns, please be patient this might take a very long time
Free space: 3.59 GB
Creating file 1.h2w ... OK!
Creating file 2.h2w ... OK!
Creating file 3.h2w ... OK!
Creating file 4.h2w ... OK!
Free space: 369.04 MB
Average writing speed: 6.95 MB/s
Now verifying the written data:
                  SECTORS      ok/corrupted/changed/overwritten
Validating file 1.h2w ... 2097152/        0/      0/      0
Validating file 2.h2w ... 2097152/        0/      0/      0
Validating file 3.h2w ... 2097152/        0/      0/      0
Validating file 4.h2w ...  489264/        0/      0/      0
  Data OK: 3.23 GB (6780720 sectors)
Data LOST: 0.00 Byte (0 sectors)
               Corrupted: 0.00 Byte (0 sectors)
        Slightly changed: 0.00 Byte (0 sectors)
             Overwritten: 0.00 Byte (0 sectors)
Average reading speed: 75.48 MB/s
Starting iozone tests. Be patient, this can take a very long time to complete:
        Iozone: Performance Test of File I/O
                Version $Revision: 3.429 $
                Compiled for 32 bit mode.
                Build: linux
        Contributors:William Norcott, Don Capps, Isom Crawford, Kirby Collins
                     Al Slater, Scott Rhine, Mike Wisner, Ken Goss
                     Steve Landherr, Brad Smith, Mark Kelly, Dr. Alain CYR,
                     Randy Dunlap, Mark Montague, Dan Million, Gavin Brebner,
                     Jean-Marc Zucconi, Jeff Blomberg, Benny Halevy, Dave Boone,
                     Erik Habbinga, Kris Strecker, Walter Wong, Joshua Root,
                     Fabrice Bacchella, Zhenghua Xue, Qin Li, Darren Sawyer,
                     Vangel Bojaxhi, Ben England, Vikentsi Lapa.
        Run began: Tue Nov 15 19:40:24 2016
        Include fsync in write timing
        O_DIRECT feature enabled
        Auto Mode
        File size set to 102400 kB
        Record Size 4 kB
        Record Size 512 kB
        Record Size 16384 kB
        Command line used: iozone -e -I -a -s 100M -r 4k -r 512k -r 16M -i 0 -i 1 -i 2
        Output is in kBytes/sec
        Time Resolution = 0.000001 seconds.
        Processor cache size set to 1024 kBytes.
        Processor cache line size set to 32 bytes.
        File stride size set to 17 * record size.
                                                              random    random     bkwd    record    stride
              kB  reclen    write  rewrite    read    reread    read     write     read   rewrite      read   fwrite frewrite    fread  freread
          102400       4     3805     6622    15955    15988    13659     3863
          102400     512    12115     8113    78890    78923    77726     7646
          102400   16384     8527     8468    80074    80280    79733     8426
iozone test complete.
touch: cannot touch ‘healthtest/cardtest.ZfDdZ7/.starttime’: No such file or directory
Test stopped, read-only filesystem
Please be careful using this media since it seems it's already broken. Exiting test.
christos@orangepipcplus:~$
appart from the "Average writing speed: 6.95 MB/s" is very low
..that final line is really alarming..
Any hints or relevant info on OPi PCPlus eMMC?
Link to comment
Share on other sites
Armbian & Khadas are rewarding contributors
