3dFirefly Posted June 25, 2023 Posted June 25, 2023 (edited) TV Box Name: H96 Pro + CPU : amlogic s912 Armbian build file name: Armbian_23.8.0-trunk.52_Aml-s9xx-box_lunar_edge_6.2.16.img DTB file used: modified dtb: https://github.com/maz-1/h96-pro-plus-armbian-stuff Kernel Version: 6.2.16-meson64 Distribution Installed (focal, buster, etc): lunar Working Ethernet (Yes/No): Yes Max Ethernet Speed that works (100/1000): 1000 Does wifi work (Yes/No): Yes Does bluetooth work (Yes/No): TBD Does HDMI audio work (Yes/No): TBD Additional Comments (provide any additional information you feel is important): benchmark: http://ix.io/4z1N benchmark.txt Edited June 25, 2023 by 3dFirefly 0 Quote
SteeMan Posted June 25, 2023 Posted June 25, 2023 If you submit a PR with the dtb changes they could be in base Armbian. 0 Quote
theslydog Posted August 29, 2023 Posted August 29, 2023 Do you happen to have a link to said image? Armbian_23.8.0-trunk.52_Aml-s9xx-box_lunar_edge_6.2.16.img 0 Quote
SteeMan Posted August 29, 2023 Posted August 29, 2023 @theslydog That image is not a release image and therefore isn't archived anywhere. This is known by the word "trunk" in the name. You can always get the latest development builds like that one from here: https://github.com/armbian/community or you can pull the build framework and build your own build from latest source. Release builds are located here: https://redirect.armbian.com/aml-s9xx-box/archive/ 0 Quote
SteeMan Posted October 15, 2024 Posted October 15, 2024 @MaxMar These forums are for Armbian. You are not using Armbian but a fork of Armbian. The developers behind that fork use the Armbian name without permission. They do not participate in Armbian development nor do they contribute to these forums. All posts regarding their work should be on their forums. 0 Quote
