harry_q Posted November 17, 2016 Posted November 17, 2016 https://evilshit.wordpress.com/2014/01/12/how-to-compile-truecrypt-from-source/ Failed in required package installations, especially wxWidgets. Thank you in advanced for any kind hand!
Dan25 Posted November 18, 2016 Posted November 18, 2016 Why are you using an unmaintained crypto library? Talk about a bad idea, even its own authors have stated people should not use truecrypt! Have you considered just using cryptsetup, its battle tested, well maintained, and has a secure chain of trust & update path through your distro of choice, unlike truecrypt.
nedoskiv Posted November 21, 2016 Posted November 21, 2016 Why are you using an unmaintained crypto library? Talk about a bad idea, even its own authors have stated people should not use truecrypt! Have you considered just using cryptsetup, its battle tested, well maintained, and has a secure chain of trust & update path through your distro of choice, unlike truecrypt. good info, thank you
harry_q Posted November 22, 2016 Author Posted November 22, 2016 (edited) Why are you using an unmaintained crypto library? Talk about a bad idea, even its own authors have stated people should not use truecrypt! Have you considered just using cryptsetup, its battle tested, well maintained, and has a secure chain of trust & update path through your distro of choice, unlike truecrypt. Terrific! cryptsetup can access truecrypted file or device! My solution: $ sudo mount /dev/sda1 /media/HDD333 $ sudo cryptsetup --type tcrypt open /media/HDD333/encHDD333.tc truecrypt1 $ sudo mkdir /media/truecrypt1 $ sudo mount -o uid=1000 /dev/mapper/truecrypt1 /media/truecrypt1 $ cd /media/truecrypt1/ DONE! Detailed info: https://wiki.archlinux.org/index.php/TrueCrypt#Accessing_a_TrueCrypt_container_using_cryptsetup FYI, cjk language filename displaying problem solution: http://askubuntu.com/questions/162391/how-do-i-fix-my-locale-issue * cjk: chinese japanese korean Thank you so much, Dan25! New World to me~! ^^ Edited November 22, 2016 by harry_q
