I installed yesterday armbian on my Odroid C2. I would like to use an USB to serial converter but, the device is not detected by the system.
When I plug the USB device, I just have this message in the kerner.log file and the USB device is not created :
Nov 18 12:04:41 localhost kernel: [59003.780747] usb 1-1.3: new full-speed USB device number 13 using dwc_otg
However, when I run lsusb the device is listed :
root@odroidc2:~# lsusb
Bus 001 Device 013: ID 1a86:7523 QinHeng Electronics HL-340 USB-Serial adapter
Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Did someone already have this issue ?
What do I need to install to get the device to work ?
Let me know if you need more information.
