Connect to your Armbian device via SSH or access its command line interface.
Open the /boot/armbianEnv.txt file using a text editor. You can use the nano editor by running the following command:
sudo nano /boot/armbianEnv.txt
Look for the line that starts with disp_mode or extraargs. If you find extraargs, add disp_mode after it. Modify the line to include the appropriate display resolution. For example: extraargs=fbcon=map:10 console=ttyS0,115200 disp_mode=320x240
Save the changes and exit the text editor. In nano, you can press Ctrl + O to save and Ctrl + X to exit.
Reboot your Armbian device for the changes to take effect. You can do this by running: sudo reboot
After the reboot, the display resolution should be adjusted to fit your TFT LCD.
