mbruck Posted November 19, 2016 Posted November 19, 2016 Hi, I'd like to setup mySql and web server on Banana PI board and sata hard disk. Since I have read from documentation it is possible to boot banana pi board from sd card and system from sata drive,this is prefered boot option. But I can't find any further documentation about this option. Thoes any one know how to move (setup) system to run from hard disk, for purpose mySQl/web server ? Regards ! Mladen
arox Posted November 19, 2016 Posted November 19, 2016 Normally, you should use "nand-sata-install" after installing base system on SDCARD. You then have a system on your SATA disk (only the /boot directory will be on a fs mounted from the sdcard - the rootfs is on the disk). So if you install or have mysql already installed, that will be on your disk (nothing to do).
