OttawaHacker Posted July 7, 2023 Posted July 7, 2023 I need to move my homeassistant from rpi4 to an opi5 but I have some I2C sensors connected. Had anyone any luck configuring python and gpio to work with I2C sensors? This was a bit rough a while ago and the kernel support seems much more limited compared to the rpi4 for this type of use case. Any experience? 0 Quote
renaudrenaud Posted July 15, 2023 Posted July 15, 2023 Seen this https://github.com/renaudrenaud/opi5_lcd_monitor 0 Quote
OttawaHacker Posted July 16, 2023 Author Posted July 16, 2023 18 hours ago, renaudrenaud said: Seen this https://github.com/renaudrenaud/opi5_lcd_monitor that's an interesting find - from what I looked: - the project did not use the default lcd monitor driver, going to guess that there is no direct support for any of the micro python libraries - the project is running the code as root - not sure if there is any way to prevent that Will figure out more once I receive my opi for this project... 0 Quote
OttawaHacker Posted July 22, 2023 Author Posted July 22, 2023 On 7/15/2023 at 6:20 PM, renaudrenaud said: Seen this https://github.com/renaudrenaud/opi5_lcd_monitor I was able to run the adafruit libraries with a BMP 390 on my Orange PI 5. However I had to update couple pin/port combinations in the adafruit libraries. I opened a PR for this added support for i2c1-m4 overlay in orange pi 5 Process was not too complicated: - activate i2c layout in overlays - I only tested i2c1-m4 - install gpio (wiringpi library) to read the pin numbers. It will show the logical pins enabled by the overlay (you need to look at the pinout diagram for physical pins) - I added a combination for SDA/SCL pins that matches the overlay and pins - needs to go in two spots in the adafruit code Btw, kudos to the new 25.8 version - it has python 3.11 out of the box. 0 Quote
martivo Posted August 31, 2023 Posted August 31, 2023 Here is my ansible for running a small LCD over I2C https://github.com/martivo/armbian-orange-pi-5-ansible/tree/main/roles/oledinfo 0 Quote
