I installed Armbian Bookworm Minimal CLI on my Rock 5b and followed the instructions on this post to get the fan to work properly.  Specifically,
git clone https://github.com/lukaszsobala/fan-control-rock5b
cd fan-control-rock5b
make package
sudo dpkg -i fan-control*.deb
sudo systemctl enable fan-control
systemctl start fan-control
However, the software won't start.  When trying to run it manually, I get,
$ sudo /usr/sbin/fan-control
pwmchip: 0
gpio: 0
pwm-period: 20000
temp-map:
  speed: 0, temp: 20, duty: 8400, duration: 10
  speed: 1, temp: 50, duty: 9600, duration: 2
  speed: 2, temp: 60, duty: 10800, duration: 2
  speed: 3, temp: 70, duty: 16000, duration: 5
Failed to export GPIO, No such file or directory
Failed to init GPIO
Looking at the source, I think it is trying to access the file
/sys/devices/platform/fd8b0010.pwm/pwm/pwmchip0/pwm0/export
(among others.) That directory exists only so far as
and doesn't contain pwm0, let alone pwm0/export.
Listing that directory, I have
$ ls -al
total 0
drwxr-xr-x 3 root root    0 Jul 10 15:21 .
drwxr-xr-x 3 root root    0 Jul 10 15:21 ..
lrwxrwxrwx 1 root root    0 Jul 10 16:48 device -> ../../../fd8b0010.pwm
--w------- 1 root root 4096 Jul 10 15:21 export
-r--r--r-- 1 root root 4096 Jul 10 16:48 npwm
drwxr-xr-x 2 root root    0 Jul 10 16:48 power
lrwxrwxrwx 1 root root    0 Jul 10 15:21 subsystem -> ../../../../../class/pwm
-rw-r--r-- 1 root root 4096 Jul 10 15:21 uevent
--w------- 1 root root 4096 Jul 10 15:21 unexport
I believe this Armbian image doesn't include any firmware, right?  So, could I be missing required firmware? Or, could the needed file be elsewhere?
Thanks for any help,
Richard
