following the documentation, I used
nand-sata-install
to
  • boot from SD, system on SATA / USB
without any problems. My backup solution (raspiBackup.sh) now creates a 16GB image for the SD card, even if it is just used to boot.
Is it possible to shrink the partition?
Thank you
René
Here is how to shrink an existing image.
In "gparted", do "edit/resize" of the partition, but leave a certain percentage of free space, then "Apply".
Replace the "endsect" by the actual number shown by fdisk.
sudo modprobe loop
sudo losetup -f
sudo losetup /dev/loop0 myimage.img
sudo partprobe /dev/loop0
sudo gparted /dev/loop0
sudo losetup -d /dev/loop0
fdisk -l myimage.img
truncate --size=$[(endsect+1)*512] myimage.img
If I understand correctly, the steps apply to the already taken backup img file.
After shrinking, I could write it to another SD card and test if the root partition is smaller, correct?
Thank you
Thanks. I though it might be possible to shrink while the system is running, but this is a way I can live with.
I'm still working on this issue.
In the documentation I found that it is possible to specify a size in percentage, that is used to adjust the sd card partition:
I put 25% in the file /root/.rootfs_resize
Then I wanted to run the firstrun script again to apply the change (and create a new ssh key).
But the file is not present on my disk. However I found it under /media/mmc/etc/init.d. I am running "ARMBIAN 5.25 stable Debian GNU/Linux 8 (jessie) 3.4.113-sun8i".
Is the file supposed to be missing after the initial resize and copying everything to the hdd?
