Hello everyone! I will teach you how to install WiringOP on Armbian. It's not the most practical method, but it works.
First, we download the repository from the original website.
$ apt-get update
$ apt-get install -y git
$ git clone https://github.com/orangepi-xunlong/wiringOP.git
Then, we proceed to look for the name of our board that is associated with Armbian.
$ cat /etc/armbian-release | grep "BOARD=" | awk -F'=' '{print $2}'
The previous command will give us the name of the board, which is the following:
root@armbian:~# cat /etc/armbian-release | grep "BOARD=" | awk -F'=' '{print $2}'
orangepi-r1plus-lts
Now, we proceed to go to the WiringOP folder downloaded from Git, and we will modify the "build" file by adding the name of the board in 2 sections.
$ sudo nano wiringOP/build
Inside the "build" file, we will look for the following variable:
 boards=("orangepir1"
                "orangepizero"
                "orangepizero-lts"
                "orangepipc"
                "orangepipch5"
                "orangepipcplus"
                "orangepiplus2e"
                "orangepione"
                "orangepioneh5"
                "orangepilite"
                "orangepiplus"
                "orangepizeroplus2h3"
                "orangepizeroplus"
                "orangepipc2"
                "orangepiprime"
                "orangepizeroplus2h5"
                "orangepiwin"
                "orangepiwinplus"
                "orangepi3"
                "orangepi3-lts"
                "orangepilite2"
                "orangepioneplus"
                "orangepi4"
                "orangepi4-lts"
                "orangepirk3399"
                "orangepi800"
                "orangepizero2"
                "orangepizero2-lts"
                "orangepizero2-b"
                "orangepizero3"
                "orangepir1plus-lts"
                "orangepir1plus"}
At the end of this variable, we add the board ID that we obtained before. It will look like this after adding the board ID:
                "orangepizero"
                "orangepizero-lts"
                "orangepipc"
                "orangepipch5"
                "orangepipcplus"
                "orangepiplus2e"
                "orangepione"
                "orangepioneh5"
                "orangepilite"
                "orangepiplus"
                "orangepizeroplus"
                "orangepipc2"
                "orangepiprime"
                "orangepiwin"
                "orangepiwinplus"
                "orangepi3"
                "orangepi3-lts"
                "orangepilite2"
                "orangepioneplus"
                "orangepi4"
                "orangepi4-lts"
                "orangepirk3399"
                "orangepi800"
                "orangepizero2"
                "orangepizero2-lts"
                "orangepizero2-b"
                "orangepizero3"
                "orangepir1plus"
                "orangepi-r1plus-lts") #<- Here, the board ID was added.
Now, further down in the "Build" file, we will look for the following:
        if [[ -f /etc/orangepi-release ]]; then
                source /etc/orangepi-release
        elif [[ -f /etc/armbian-release ]]; then
                source /etc/armbian-release
                [[ $BOARD == orangepi-r1 ]] && BOARD=orangepir1
                [[ $BOARD == orangepi-rk3399 ]] && BOARD=orangepirk3399
                [[ $BOARD == orangepizeroplus2-h3 ]] && BOARD=orangepizeroplus2h3
                [[ $BOARD == orangepizeroplus2-h5 ]] && BOARD=orangepizeroplus2h5
                						#----->Here new board<---------------
        else
In the brand section of the code above, we will place the following code.
Replace [board_id_goes_here] with the actual board ID that we obtained at the beginning of the tutorial.
[[board_id_goes_here]] && BOARD=orangepir1plus-rk3328
After making the modifications, it will look like this:
                [[ $BOARD == orangepi-r1plus-lts ]] && BOARD=orangepir1plus-rk3328
        else
The last parameter can be modified with a different board, in case of using other versions of OrangePi. You just need to look for the corresponding one in the same "build" file, and replace only the board ID.
Now we can close the file and proceed to apply ./build clean and ./build. However, the current version of OrangePi r1+LTS officially has a problem that we will also fix next.
$ sudo nano wiringOP/wiringPi/OrangePi.h
Inside the file, some #define statements need to be added to resolve the conflicts they are causing. Hopefully, Xunlong will fix this issue in the future. For now, we will apply a patch as I haven't been able to find where to obtain these GPIO_BASE.
Inside the file "Orangepi.h," we will look for the following
//csy 2019.1.8
/*********** OrangePi R1PLUS *************/
#if CONFIG_ORANGEPI_R1PLUS
#define GPIO2_BASE                                                      0xff230000
#define GPIO3_BASE                                                      0xff240000
#define GPIO_NUM                                (0x40)
#define GPIO_SWPORTA_DR_OFFSET                          0x00
#define GPIO_SWPORTA_DDR_OFFSET                         0x04
#define GPIO_EXT_PORTA_OFFSET                           0x50
#define GRF_BASE                                                        0xff100000
#define GRF_GPIO2A_IOMUX_OFFSET                         0x20
#define GRF_GPIO2BL_IOMUX_OFFSET                        0x24
#define GRF_GPIO2BH_IOMUX_OFFSET                        0x28
#define GRF_GPIO2CL_IOMUX_OFFSET                        0x2c
#define GRF_GPIO2CH_IOMUX_OFFSET                        0x30
#define GRF_GPIO2D_IOMUX_OFFSET                         0x34
#define GRF_GPIO3AL_IOMUX_OFFSET                        0x38
#define GRF_GPIO3AH_IOMUX_OFFSET                        0x3c
#define GRF_GPIO3BL_IOMUX_OFFSET                        0x40
#define GRF_GPIO3BH_IOMUX_OFFSET                        0x44
#define GRF_GPIO3C_IOMUX_OFFSET                         0x48
#define GRF_GPIO3D_IOMUX_OFFSET                         0x4c
We will modify this to make it look like the following:
#endif /* CONFIG_ORANGEPI_RK3399 */
//csy 2019.1.8
#define GPIOL_BASE                              (0x0)  #New lines added.
#define GPIO_BASE_MAP                          (0x0)   #New lines added.
#define CRU_BASE                                                        0xff440000
#define CRU_CLKGATE_CON16_OFFSET                        0x0240    //bit 7 8 9 10 9877
We save the changes and apply build clean and build.
The result is:
root@armbian:~/wiringOP# gpio readall
 +------+-----+----------+------+---+ R1 Plus  +---+---+--+----------+-----+------+
 | GPIO | wPi |   Name   | Mode | V | Physical | V | Mode | Name     | wPi | GPIO |
 |      |     | 5V       |      |   |  1 || 2  |   |      | GND      |     |      |
 |   89 |   0 | SDA.0    | ALT2 | 1 |  3 || 4  | 1 | ALT2 | SCK.0    | 1   | 88   |
 |  100 |   2 | TXD.1    | ALT5 | 1 |  5 || 6  | 1 | ALT5 | RXD.1    | 3   | 102  |
 |      |     |          |      |   |  7 || 8  |   |      |          |     |      |
 |      |     |          |      |   |  9 || 10 | 1 | ALT3 | GPIO3_C0 | 4   | 112  |
 |  103 |   5 | CTS.1    | ALT5 | 1 | 11 || 12 | 1 | ALT5 | RTS.1    | 6   | 101  |
 |   66 |   7 | GPIO2_A2 |   IN | 1 | 13 || 14 |   |      |          |     |      |
Edited by Namexx
I did try to follow this instruction with a OrangePiOne, but it fails at:
My fresh build file (on a fresh Armbian install) simply do not contain anything like what is shown in this instruction.
If I just try to build what I got it gives some warnings and what not:
user@orangepione:~/wiringOP$ ./build clean
wiringPi:   [Clean]
DevLib:     [Clean]
gpio:       [Clean]
Examples:   [Clean]
Gertboard:  [Clean]
PiFace:     [Clean]
Quick2Wire: [Clean]
PiGlow:     [Clean]
scrollPhat: [Clean]
Deb:
wiringPi Build script
WiringPi Library
[UnInstall]
[Compile] wiringPi.c
[Compile] wiringSerial.c
[Compile] wiringShift.c
[Compile] piHiPri.c
[Compile] piThread.c
[Compile] wiringPiSPI.c
[Compile] wiringPiI2C.c
[Compile] softPwm.c
[Compile] softTone.c
[Compile] mcp23008.c
wiringPi.c: In function ‘orangepi_pwm_set_act’:
[Compile] mcp23016.c
wiringPi.c:3675:37: warning: comparison of integer expressions of different signedness: ‘int’ and ‘uint32_t’ {aka ‘unsigned int’} [-Wsign-compare]
 3675 |                         if (act_cys >= pwm_period || act_cys < 0)
[Compile] mcp23017.c
wiringPi.c: In function ‘orangepi_get_gpio_mode’:
wiringPi.c:6212:59: warning: comparison of unsigned expression in ‘>= 0’ is always true [-Wtype-limits]
 6212 |                                                 if (index >= 0 && index <= 11)
wiringPi.c:6232:59: warning: comparison of unsigned expression in ‘>= 0’ is always true [-Wtype-limits]
 6232 |                                                 if (index >= 0 && index <= 1)
wiringPi.c:6258:59: warning: comparison of unsigned expression in ‘>= 0’ is always true [-Wtype-limits]
 6258 |                                                 if (index >= 0 && index <= 7)
wiringPi.c:6266:59: warning: comparison of unsigned expression in ‘>= 0’ is always true [-Wtype-limits]
 6266 |                                                 if (index >= 0 && index <= 1)
wiringPi.c:6273:59: warning: comparison of unsigned expression in ‘>= 0’ is always true [-Wtype-limits]
 6273 |                                                 if (index >= 0 && index <= 1)
wiringPi.c:6281:59: warning: comparison of unsigned expression in ‘>= 0’ is always true [-Wtype-limits]
 6281 |                                                 if (index >= 0 && index <= 19)
[Compile] mcp23s08.c
wiringPi.c: In function ‘orangepi_set_gpio_mode’:
wiringPi.c:7349:59: warning: comparison of unsigned expression in ‘>= 0’ is always true [-Wtype-limits]
 7349 |                                                 if (index >= 0 && index <= 11)
wiringPi.c:7369:59: warning: comparison of unsigned expression in ‘>= 0’ is always true [-Wtype-limits]
 7369 |                                                 if (index >= 0 && index <= 1)
wiringPi.c:7381:60: warning: comparison of unsigned expression in ‘>= 0’ is always true [-Wtype-limits]
 7381 |                                                 if( (index >= 0 && index <=1) && PWM_OUTPUT == mode )
wiringPi.c:7399:59: warning: comparison of unsigned expression in ‘>= 0’ is always true [-Wtype-limits]
 7399 |                                                 if (index >= 0 && index <= 7)
wiringPi.c:7408:59: warning: comparison of unsigned expression in ‘>= 0’ is always true [-Wtype-limits]
 7408 |                                                 if (index >= 0 && index <= 1)
wiringPi.c:7415:59: warning: comparison of unsigned expression in ‘>= 0’ is always true [-Wtype-limits]
 7415 |                                                 if (index >= 0 && index <= 1)
wiringPi.c:7424:59: warning: comparison of unsigned expression in ‘>= 0’ is always true [-Wtype-limits]
 7424 |                                                 if (index >= 0 && index <= 19)
wiringPi.c: In function ‘rk3588_set_pwm_reg’:
wiringPi.c:6584:41: warning: this statement may fall through [-Wimplicit-fallthrough=]
 6584 |                                         printf("You can select wiringPi pin 0/2/5/8/9/10/14/16 for PWM pin.\n");
wiringPi.c:6585:33: note: here
 6585 |                                 case PI_MODEL_5B:
[Compile] mcp23s17.c
[Compile] sr595.c
[Compile] pcf8574.c
[Compile] pcf8591.c
[Compile] mcp3002.c
[Compile] mcp3004.c
[Compile] mcp4802.c
[Compile] mcp3422.c
[Compile] max31855.c
[Compile] max5322.c
[Compile] ads1115.c
[Compile] sn3218.c
[Compile] bmp180.c
[Compile] htu21d.c
[Compile] ds18b20.c
[Compile] rht03.c
[Compile] drcSerial.c
[Compile] drcNet.c
[Compile] pseudoPins.c
[Compile] wpiExtensions.c
[Compile] w25q64.c
[Compile] oled.c
[Link (Dynamic)]
[Install Headers]
[Install Dynamic Lib]
WiringPi Devices Library
[UnInstall]
[Compile] ds1302.c
[Compile] maxdetect.c
[Compile] piNes.c
[Compile] gertboard.c
[Compile] piFace.c
[Compile] lcd128x64.c
[Compile] lcd.c
[Compile] scrollPhat.c
[Compile] piGlow.c
[Link (Dynamic)]
[Install Headers]
GPIO Utility
[Compile] gpio.c
[Compile] readall.c
gpio.c: In function ‘doUsbP’:
gpio.c:944:25: warning: unused parameter ‘argc’ [-Wunused-parameter]
  944 | static void doUsbP (int argc, char *argv [])
gpio.c:944:37: warning: unused parameter ‘argv’ [-Wunused-parameter]
readall.c: In function ‘OrangePiReadAll’:
readall.c:2287:25: warning: this statement may fall through [-Wimplicit-fallthrough=]
 2287 |                         printf (" +------+-----+----------+--------+---+  AI PRO  +---+--------+----------+-----+------+\n");
readall.c:2288:17: note: here
 2288 |                 case PI_MODEL_RV:
[Link]
[Install]
chown: warning: '.' should be ':': ‘root.root’
All Done.
NOTE: To compile programs with wiringPi, you need to add:
    -lwiringPi
  to your compile line(s) To use the Gertboard, MaxDetect, etc.
  code (the devLib), you need to also add:
    -lwiringPiDev
  to your compile line(s).
