mhanuel Posted November 23, 2016 Posted November 23, 2016 Dear All, I am just trying to figure how to enable the UART3 to be a 4 wire serial port for Lamobo R1 board. As per the datasheet here, https://drive.google.com/file/d/0B4PAo2nW2KfnNTBaVENGeHZfSzA/view UART3 4 wire signals are routed to J12 connector. I was looking to modify .dtb file, when I realize there is a definitions for PH3 GPIO under DTB file such as usb2_vbus_pin@0 { allwinner,pins = "PH3"; allwinner,function = "gpio_out"; allwinner,drive = <0x0>; allwinner,pull = <0x0>; linux,phandle = <0x42>; phandle = <0x42>; }; PH2 is not defined, looking at schematic I cannot find how VBUS for USB2 works or is connected and how it affects changing the DTB of UART3 such as or if it will actually work as 4 wire UART by doing so. uart3@0 { allwinner,pins = "PH0", "PH1", "PH2", "PH3"; allwinner,function = "uart3"; allwinner,drive = <0x0>; allwinner,pull = <0x0>; }; I really will appreciate any comment, Tkx in advance,
