thatsimonsguy Posted August 1, 2023 Share Posted August 1, 2023 (edited) I've been struggling to get interrupt to work on my 5b with a water flow sensor. Any suggestions or help is appreciated. Here's what I've tried and validated so far: Hardware: The flow sensor signal wire is connected to wiringpi pin 2, which is physical pin 7, gpio pin 54 I've put in a pull-down resistor between the gpio pin and GND I've confirmed with a multi-meter that the signal line has a voltage of 0 when the sensor isn't spinning. I've confirmed that "gpio read 2" shows the pin as 0 in that state I've confirmed that the signal line voltage peaks to around 1.5 vdc when the sensor is spinning. I've confirmed that "gpio read 2" shows the pin pulsing in that state between 1 and 0. Docker: I've exported gpio 54 and set it to in The container runs in privileged mode with volumes to all the important bits mapped Python: I wrote a stupidly simple script just to increment a counter and print its value when the interrupt is called wiringpi correctly reads and sets values for all the other gpio stuff I'm doing on the board (temp sensors and relays), it's only the interrupt job that isn't working Docs for above assertions: Python script: import wiringpi import time # The pin number to which your sensor is connected SENSOR_PIN = 2 # Initialize wiringpi wiringpi.wiringPiSetup() # Set the pin to input mode wiringpi.pinMode(SENSOR_PIN, wiringpi.GPIO.INPUT) # Initialize the counter and the tick counter = 0 def count_pulse(): global counter counter += 1 print(counter) # Set the interrupt to be triggered when the pin's voltage rises from LOW to HIGH wiringpi.wiringPiISR(SENSOR_PIN, wiringpi.GPIO.INT_EDGE_RISING, count_pulse) # To keep the script running try: while True: time.sleep(1) except (KeyboardInterrupt, SystemExit): print(f'Total pulses: {counter}') print('Exiting...') GPIO test output: Pin 2 state: 1 Pin 2 state: 1 Pin 2 state: 1 Pin 2 state: 0 Pin 2 state: 0 Pin 2 state: 0 Pin 2 state: 0 Pin 2 state: 0 Pin 2 state: 0 Pin 2 state: 0 Pin 2 state: 0 Pin 2 state: 1 Pin 2 state: 1 Pin 2 state: 1 Pin 2 state: 1 Pin 2 state: 1 Pin 2 state: 1 Pin 2 state: 1 Pin 2 state: 1 Pin 2 state: 0 Pin 2 state: 0 Pin 2 state: 0 Pin 2 state: 0 Pin 2 state: 0 Dockerfile: FROM python:3.9-slim WORKDIR /usr/src/app/squirtgun LABEL maintainer="github.com/thatsimonsguy" # Prep for downloading and installing wiringOP & wiringOP-python RUN apt-get update && apt-get install -y \ git \ gcc \ swig \ python3-dev \ python3-setuptools \ make \ sudo \ && rm -rf /var/lib/apt/lists/* # Set up wiringOP WORKDIR /usr/src/app/squirtgun RUN git clone https://github.com/orangepi-xunlong/wiringOP.git -b next WORKDIR /usr/src/app/squirtgun/wiringOP RUN ./build clean RUN ./build # Set up wiringOP-Python WORKDIR /usr/src/app/squirtgun RUN git clone --recursive https://github.com/orangepi-xunlong/wiringOP-Python -b next WORKDIR /usr/src/app/squirtgun/wiringOP-Python RUN python3 generate-bindings.py > bindings.i RUN python3 setup.py install # Export GPIO for pin 2 RUN echo 54 > /sys/class/gpio/export RUN echo "in" > /sys/class/gpio/gpio54/direction # Install app and python deps WORKDIR /usr/src/app/squirtgun COPY . . RUN pip install -r requirements.txt EXPOSE 80 ENTRYPOINT ["python", "run.py"] Docker compose: version: '3' services: squirtgun_test: image: squirtgun_test:latest privileged: true volumes: - squirtgun_config:/usr/src/app/squirtgun/config - squirtgun_db:/usr/src/app/squirtgun/db - /etc/orangepi-release:/etc/orangepi-release - /etc/armbian-release:/etc/armbian-release environment: - REGISTRATION_OTP=#### - PARENT_BASE_URL=#### - ZONE_RELAY_PINS=5 - TRANSFORMER_RELAY_PIN=7 - TEMP_SENSOR_PIN_1=8 - TEMP_SENSOR_PIN_2=9 - FLOW_SENSOR_PIN=2 - DEBUG_NO_MTLS=True ports: - "5000:5000" volumes: squirtgun_config: squirtgun_db: (I realize the port mapping between the docker compose and the dockerfile are not aligned. That's on my TODO list, but isn't a factor for this problem. I'm testing by exec'ing into the running docker container after build and executing the test script) Cheers and thanks! Edited August 1, 2023 by thatsimonsguy 0 Quote Link to comment Share on other sites More sharing options...
