EDIT: I am using the Armbian 23.5.5 Orange Pi 5 Plus Jammy Legacy 5.10.160 Gnome Desktop image
Let me preface this with I am a Linux noob and this is one step below black magic voodoo to me.
For some reason my Orange Pi 5 Plus USB 3.0 ports are no longer functioning.
I setup my OPi at my testing station and everything was working fine (except I couldn't get my WiFi dongle to work but that's a different post)
After I turned off my Orange Pi 5 Plus, disconnected it and set it back up where it was going to be staged now the USB 3.0 ports no longer function. Putting in the "lsusb" command shows all my ports, including the non-functional USB 3.0 ports, but I can't get the 3.0 ports to work. The USB 2.0 ports are completely fine and functional.
Does anyone know why the USB 3.0 ports stopped working and how to get them functioning again?
Edited by socal
Updated which image I am using
I have same problem - but with an OrangePi 5 board (not Plus) - the two blue colored USB ports are not working.  I tried OrangePi's Ubuntu OS and that didn't fix the issue.   Wondering if my board has hardware fault :(
Both of you should leave logs.
Is there any voltage on the ports? Might be dead ports. On my OPi5 a cap fell of when unpacking it. But all still works.
What are you plugging into the USB3 ports?  Is your power supply capable of supplying enough current?  If you measure USB3 inline voltage does it drop when you plug in the device?
I am running the same Kernel version on OPi 5+ and my USB3 ports work with externally powered HDD's.
Kernel and firmware upgrades disabled on mine.
My USB3.0 ports (blue colored) on OrangePi 5 are not supplying any power - tested with Anker USB hub and with Realtek BT/Wifi dongle (both work on the USB2.0 port (white colored).
Everything looks fine in the dmesg log, so I'm thinking this hardware issue between the controller and the physical sockets.:
[    3.612366] reg-fixed-voltage vcc5v0-usbdcin: Looking up vin-supply from device tree
[    3.612369] vcc5v0_usbdcin: supplied by vcc12v_dcin
[    3.612386] vcc5v0_usbdcin: 5000 mV, enabled
[    3.612442] reg-fixed-voltage vcc5v0-usbdcin: vcc5v0_usbdcin supplying 5000000uV
[    3.612483] reg-fixed-voltage vcc5v0-usb: Looking up vin-supply from device tree
[    3.612486] vcc5v0_usb: supplied by vcc5v0_usbdcin
[    3.612490] vcc5v0_usbdcin: could not add device link regulator.4: -ENOENT
[    3.612508] vcc5v0_usb: 5000 mV, enabled
[    3.612561] reg-fixed-voltage vcc5v0-usb: vcc5v0_usb supplying 5000000uV
[    3.612711] vbus5v0_typec: supplied by vcc5v0_usb
[    3.674938] usbcore: registered new interface driver usbfs
[    3.674955] usbcore: registered new interface driver hub
[    3.674968] usbcore: registered new device driver usb
[    4.482624] phy phy-fd5d0000.syscon:usb2-phy@0.0: Looking up phy-supply from device tree
[    4.482632] phy phy-fd5d0000.syscon:usb2-phy@0.0: Looking up phy-supply property in node /syscon@fd5d0000/usb2-phy@0/otg-port failed
[    4.482675] phy phy-fd5d0000.syscon:usb2-phy@0.0: Looking up vbus-supply from device tree
[    4.482681] phy phy-fd5d0000.syscon:usb2-phy@0.0: Looking up vbus-supply property in node /syscon@fd5d0000/usb2-phy@0/otg-port failed
[    4.483974] phy phy-fd5d8000.syscon:usb2-phy@8000.1: Looking up phy-supply from device tree
[    4.483982] phy phy-fd5d8000.syscon:usb2-phy@8000.1: Looking up phy-supply property in node /syscon@fd5d8000/usb2-phy@8000/host-port failed
[    4.485089] phy phy-fd5dc000.syscon:usb2-phy@c000.2: Looking up phy-supply from device tree
[    4.485096] phy phy-fd5dc000.syscon:usb2-phy@c000.2: Looking up phy-supply property in node /syscon@fd5dc000/usb2-phy@c000/host-port failed
[    5.159667] usbcore: registered new interface driver rndis_wlan
[    5.159843] usbcore: registered new interface driver asix
[    5.159880] usbcore: registered new interface driver cdc_ether
[    5.159917] usbcore: registered new interface driver rndis_host
[    5.159972] usbcore: registered new interface driver cdc_ncm
[    5.167053] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up usb-supply from device tree
[    5.167108] rockchip-pm-domain fd8d8000.power-management:power-controller: Looking up usb-supply property in node /power-management@fd8d8000/power-controller failed
[    5.173919] ehci-platform fc800000.usb: EHCI Host Controller
[    5.173946] ehci-platform fc800000.usb: new USB bus registered, assigned bus number 1
[    5.174099] ehci-platform fc800000.usb: irq 20, io mem 0xfc800000
[    5.185349] ehci-platform fc800000.usb: USB 2.0 started, EHCI 1.00
[    5.185634] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[    5.185645] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    5.185652] usb usb1: Product: EHCI Host Controller
[    5.185660] usb usb1: Manufacturer: Linux 5.10.160-rockchip ehci_hcd
[    5.185667] usb usb1: SerialNumber: fc800000.usb
[    5.189217] ehci-platform fc880000.usb: EHCI Host Controller
[    5.189242] ehci-platform fc880000.usb: new USB bus registered, assigned bus number 2
[    5.189361] ehci-platform fc880000.usb: irq 22, io mem 0xfc880000
[    5.202019] ehci-platform fc880000.usb: USB 2.0 started, EHCI 1.00
[    5.202264] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[    5.202274] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    5.202282] usb usb2: Product: EHCI Host Controller
[    5.202289] usb usb2: Manufacturer: Linux 5.10.160-rockchip ehci_hcd
[    5.202296] usb usb2: SerialNumber: fc880000.usb
[    5.204233] ohci-platform fc840000.usb: Generic Platform OHCI controller
[    5.204257] ohci-platform fc840000.usb: new USB bus registered, assigned bus number 3
[    5.204361] ohci-platform fc840000.usb: irq 21, io mem 0xfc840000
[    5.262893] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.10
[    5.262903] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    5.262911] usb usb3: Product: Generic Platform OHCI controller
[    5.262918] usb usb3: Manufacturer: Linux 5.10.160-rockchip ohci_hcd
[    5.262925] usb usb3: SerialNumber: fc840000.usb
[    5.264157] ohci-platform fc8c0000.usb: Generic Platform OHCI controller
[    5.264177] ohci-platform fc8c0000.usb: new USB bus registered, assigned bus number 4
[    5.264281] ohci-platform fc8c0000.usb: irq 23, io mem 0xfc8c0000
[    5.322899] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.10
[    5.322909] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    5.322917] usb usb4: Product: Generic Platform OHCI controller
[    5.322924] usb usb4: Manufacturer: Linux 5.10.160-rockchip ohci_hcd
[    5.322931] usb usb4: SerialNumber: fc8c0000.usb
[    5.325536] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[    5.325546] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    5.325553] usb usb5: Product: xHCI Host Controller
[    5.325561] usb usb5: Manufacturer: Linux 5.10.160-rockchip xhci-hcd
[    5.325568] usb usb5: SerialNumber: xhci-hcd.7.auto
[    5.326646] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
[    5.326812] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[    5.326822] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    5.326829] usb usb6: Product: xHCI Host Controller
[    5.326836] usb usb6: Manufacturer: Linux 5.10.160-rockchip xhci-hcd
[    5.326843] usb usb6: SerialNumber: xhci-hcd.7.auto
[    5.327939] usbcore: registered new interface driver cdc_acm
[    5.328155] usbcore: registered new interface driver uas
[    5.328305] usbcore: registered new interface driver usb-storage
[    5.330000] usbcore: registered new interface driver usbtouchscreen
[    5.505827] typec_fusb302 6-0022: Looking up vbus-supply from device tree
[    5.694438] usbcore: registered new interface driver uvcvideo
[    5.759866] usbcore: registered new interface driver usbhid
[    5.759870] usbhid: USB HID core driver
[    5.766752] usbcore: registered new interface driver snd-usb-audio
Edited by chuckles67
... when I run `dmesg -w` and then plug USB hub or USB BT/WiFI dongle into the blue colored USB3.0 ports the dmesg does not update.
