RuDy_74 Posted August 15, 2023 Posted August 15, 2023 Hello all, I'm new member on this forum and I want became new user of armbian to install Home Assistant on my box. My box is a Bqeel K12 but i opened box and I see a label on the mother board where is write Mini M8S pro C. So I try to install armbian debian. I used this version "Armbian_23.5.1_Uefi-arm64_bookworm_current_6.1.30_cinnamon_desktop.img" I followed this topic to find the good dbt file : https://forum.armbian.com/topic/17106-installation-instructions-for-tv-boxes-with-amlogic-cpus/ I found differents dbt files which look like working properly (I have the desktop, I can navigate, open application...) BUT at each time is not possible to acces to internet (with Wifi or lan). I try to configure manually the connection with the tool available on desktop but is not working. a precision : before to install armbian, I totally remove android. Do you think that can be the root cause ? Thanks in advance 0 Quote
SteeMan Posted August 15, 2023 Posted August 15, 2023 1 hour ago, RuDy_74 said: before to install armbian, I totally remove android. Do you think that can be the root cause ? This is one problem. You need the boot loader from android on your emmc in order to boot armbian following the instructions you mentioned. 1 hour ago, RuDy_74 said: o I try to install armbian debian. I used this version "Armbian_23.5.1_Uefi-arm64_bookworm_current_6.1.30_cinnamon_desktop.img" This is not a build suitable for this box. Follow the links in the instructions you mentioned for the correct armbian build. 0 Quote
RuDy_74 Posted August 15, 2023 Author Posted August 15, 2023 @SteeMan, thanks for your answer. I tried with build from your instruction : "Armbian_23.5.1_Aml-s9xx-box_bookworm_current_6.1.30_cinnamon_desktop.img" I did not arrive the armbian installation. I tried several DTB files (not all) without success. Sometime, it ask me root and pasword and after black screen. So I tried with :" Armbian_23.5.1_Aml-s9xx-box_bookworm_current_6.1.30_xfce_desktop.img" installation looks like work properly. I have the desktop armbian but it the same I have not internet connection. Thanks again. 0 Quote
SteeMan Posted August 15, 2023 Posted August 15, 2023 16 minutes ago, RuDy_74 said: but it the same I have not internet connection What internet connection are you trying? wifi or ethernet? 0 Quote
RuDy_74 Posted August 15, 2023 Author Posted August 15, 2023 22 minutes ago, SteeMan said: What internet connection are you trying? wifi or ethernet? Both. For ethernet i didn't try to change parameters. For Wifi, I tried to set manually. I entered SSID and WPAKey with tool "NetworkManager applet" For IP, is automatic (DHCP). 0 Quote
SteeMan Posted August 15, 2023 Posted August 15, 2023 wifi isn't expected to work, but with the correct dtb ethernet should. What dtb files are you trying? The dtb file is the file that describes the hardware to the linux kernel, so it is important to have a dtb file that correctly maps to your hardware (or as close as possible). 0 Quote
RuDy_74 Posted August 16, 2023 Author Posted August 16, 2023 (edited) @SteeMan meson-gxm-q200.dtb I tried another before. I will continue to try another dtb file and recheck my ethernet cable... could you confirm me that the ethernet connection is "automatic" ? (without any manueally parameters) please. Thanks. Edited August 16, 2023 by RuDy_74 0 Quote
RuDy_74 Posted August 16, 2023 Author Posted August 16, 2023 (edited) I install meson-gxm-q201.dtb and ethernet connection work properly. No i will try to install on EMMC. Many thanks. Edited August 16, 2023 by RuDy_74 0 Quote
RuDy_74 Posted August 16, 2023 Author Posted August 16, 2023 (edited) Hello, I tried to install Home Assistant and I have an error "Armbian 23.05.2 is not supported" After some checking it's look like that debian 12 are not suported. I found some archive bullseye version. I'm tring. Thanks. Edited August 16, 2023 by RuDy_74 0 Quote
SteeMan Posted August 16, 2023 Posted August 16, 2023 How are you installing Home Assistant? You may need to install the docker version on Armbian (at least that is how I run it). It has been a couple of years since I installed it, so I don't remember why I chose that method. 0 Quote
ignarissime Posted April 27, 2024 Posted April 27, 2024 (edited) Hello RuDy_74 I try to do same (armbian on Bqeel K12pro S912) and thank you for yours posts. Some directory or links are deads. Can you resume whitch img and dbt files you used for working fine and install home assistant ? Thank you. PS: sorry for my poor english. brant : Bqeel model : K12 Pro CPU : Amlogic S912 Octa core ARM, Cortex-A53 64 bits – Maximum 2 Ghz GPU : Mali T820MP3 mother board : q201_9377 RAM 2 Go DDR3 ROM : 32 Go eMMC Ethernet Gigabit 100/1000M Wifi : b/g/n/ac – 2,4 & 5 Ghz Bluetooth : 4.1 Micro-SD : maximum 32 Go 2x USB 2.0 ports Android 6.0 (Marshmallow) mother board recto verso (left is left, top is bottom, right is right, bottom is top) Edited April 27, 2024 by ignarissime add spaces in my original text, better to read. 0 Quote
lucash78 Posted Wednesday at 09:08 AM Posted Wednesday at 09:08 AM (edited) I've extracted dtbs from my rooted device bqeel K12, could it be useful share them? @RuDy_74 I've used "Magicsee C400 Plus" dtb (I don't remember the exact name) and I got also wifi and bluetooth working. The only issue is ethernet working at 100Mbit instead of 1Gbit Edited Wednesday at 09:12 AM by lucash78 0 Quote
