trying to get the goodix gt911 touch on armbian, rock5a armbian rom
 i am trying to enable touch for the 8 inch display on your build, the display is from radxa, and after enabling the hadware configuration and enabling rock-5a-radxa-display-8hd from the menu, the display is working perfectly, but the touch isnt working, i was searching the official build for the touch related sources, the touch is controlled by godot GT911 driver IC, its using i2c for touch,
https://forums.raspberrypi.com/viewtopic.php?t=284882
how do i get this to work on your image?
attached are images on radxa images for rock 5a
Hi!  did you ever get this working? I had the touch working on a Arch with the radxa 5.10.110 kernel but had had trouble getting other pieces. Have everything working on Armbian except touch.  Couldn't use the included display dtbo, but had to use my Arch working dtbo.
