Orange Pi Lite USB HDD to USB HDD speed under truecrypt
Orange Pi Lite has two USB2.0 ports.
I attached 3.5" 5400rpm HDDs in each ports through SATA adaptors.
Both HDDs have truecrypted_file.tc respectively.
Mounted both .tc files with $ cryptsetup --type tcrypt ********
And $ cp HDD1/big_files HDD2/directory
Then chked file copying speed only to have 6.5MB/s in average.
Is it normal?
Thank you in advance~! ^^
  On 11/27/2016 at 3:11 PM, zador.blood.stained said:
And given that there are no details about algorithm and block size used for this container, I would say on average this is normal
Oh! I missed much! Thank you for your advice. I'll try to collect some details of my environment.
FYI at the moment, just fresh dd jessy img installed this morning.
  On 11/27/2016 at 3:33 PM, zador.blood.stained said:
Also what filesystem is inside the container? NTFS?
yes! NTFS, both of HDDs.
### FYI, raw data (not truecrypted) transfer between two rates 13.3 MB/s. (NTFS)
Edited by harry_q
Well, as already suggested both 'sudo armbianmonitor -m' and htop will show you clearly what's wrong. You use a filesystem that's slow as hell in Linux and add encryption on top. IO bottlenecked by CPU.
