Nick A Posted 21 hours ago Posted 21 hours ago Is this an error in the build or installing jammy? 0 Quote
979101h Posted 12 hours ago Posted 12 hours ago @Nick A It works perfectly now. Thanks a ton! 0 Quote
Alfi ciio Posted 6 hours ago Posted 6 hours ago Quote sudo update-alternatives --set iptables /usr/sbin/iptables-legacy sudo update-alternatives --set ip6tables /usr/sbin/ip6tables-legacy @Nick A Thanks a lot, this helps me as well 0 Quote
svyatoslav Posted 3 hours ago Posted 3 hours ago I have already created a new virtual machine. And again an error. 0 Quote
Werner Posted 2 hours ago Posted 2 hours ago https://github.com/armbian/build/blob/9ff15f78966871bd737f0c8cbd23ee9fdb767b8d/lib/functions/host/prepare-host.sh#L48-L58 setting locale seem to fail. For the BTF thing either give the vm more memory (>8G), disable or enforce it as mentioned in the image and risk getting OOM killed. 0 Quote
svyatoslav Posted 2 hours ago Posted 2 hours ago then there is no more option, all that's left is to accept it 0 Quote
