Nick A Posted February 7 Posted February 7 (edited) @Rodrigo Campos The 20251014 build uses a newer kernel, but audio through the A/V out port is currently broken. I haven't had time to fix it yet, so if you don't need that port, feel free to use this version. 20251226 was a work in progress. Never had time to push it. I'll create a new one soon. Edited February 19 by Nick A 0 Quote
Brow Mosh Posted February 7 Posted February 7 On 2/5/2026 at 7:31 PM, Nick A said: Have you tried extracting your arndroid dts to find the gpio settings for emmc Yes @Nick A. Tried that also. On 2/5/2026 at 7:31 PM, Nick A said: (FEL) Copilot mentioned this to me: 🟦 If you want to keep fighting this board… I can help you explore: - FEL mode flashing - Using the vendor Android recovery to write eMMC - Dumping the vendor kernel and trying to boot it - Porting the vendor MMC driver (very advanced) But I want to be honest with you: none of these paths are easy, and none guarantee success. Now, I asked it to elaborate on the idea: Let’s unpack this in a way that actually makes sense, Brow — because FEL sounds simple (“just plug in USB and flash it”), but on H618 TV boxes it becomes a whole different beast. I’ll keep it clean, structured, and honest. --- 🟦 Why FEL mode sounds easy On paper, FEL is Allwinner’s built‑in USB recovery mode: - You connect the box to a PC - Press a button or short two pads - The SoC enters FEL - You use sunxi-fel to upload U‑Boot or write eMMC In theory, it’s the “ultimate backdoor” for fixing a broken board. --- 🟥 Why FEL is complicated on your specific device Your Transpeed 8K618‑T is not a dev board. It’s a mass‑produced TV box with: - No FEL button - No exposed pads - No documentation - No schematic - No guarantee the USB port even supports FEL - Vendor boot ROM sometimes disables FEL - USB port may be wired through a hub or switch - Some boxes require opening the case and shorting tiny test pads - Some require holding reset while powering - Some require UART strap pins - Some require a special cable - Some simply do not support FEL at all So the first complication is: You don’t know how to enter FEL on this board. --- 🟥 Second complication: FEL only gives you RAM access FEL lets you: - Upload a U‑Boot binary into RAM - Execute it - Use that U‑Boot to access eMMC But here’s the catch: You must provide a U‑Boot binary that supports your hardware. Mainline U‑Boot does not support: - Your weird SD wiring - Your PMIC - Your DRAM timing - Your eMMC layout - Your HDMI - Your regulators Vendor U‑Boot does, but: - You don’t have the vendor U‑Boot binary - You don’t have the vendor DRAM init code - You don’t have the vendor MMC driver - You don’t have the vendor DTB So even if FEL works, you still need a working U‑Boot image to upload — and we don’t have one. --- 🟥 Third complication: writing eMMC through FEL is slow and fragile Even if you get FEL working and even if you get a working U‑Boot: - Writing eMMC over FEL is extremely slow - If the connection drops, you brick the device - You must manually partition eMMC - You must manually install boot0, boot1, U‑Boot, DTB, rootfs - You must manually fix extlinux.conf - You must manually fix environment variables This is not like flashing a Raspberry Pi. It’s more like doing open‑heart surgery with a butter knife. --- 🟥 Fourth complication: your board’s MMC subsystem is already unstable We’ve already seen: - SD card hangs - MMC controller wedges - Linux freezes on /dev/mmcblk* - Armbian initramfs fails - MiniArch freezes - Vendor kernel is the only thing that works If the MMC hardware is unstable under Linux, it may also be unstable under FEL‑booted U‑Boot. Meaning: Even if FEL works, you might not be able to write eMMC reliably. --- 🟦 So why did I say FEL is complicated? Because on a proper Allwinner dev board, FEL is easy. But on a cheap TV box with undocumented wiring, FEL becomes a puzzle with these problems: | Problem | Why it matters | |--------|----------------| | No FEL button | You don’t know how to enter FEL | | Unknown test pads | You may need to open the board | | Vendor may disable FEL | Some boxes block FEL in BOOT0 | | USB wiring unknown | FEL may not work on the exposed port | | Need vendor U‑Boot | Mainline U‑Boot won’t boot your hardware | | Need vendor DRAM init | Otherwise RAM won’t initialize | | Need vendor MMC driver | Otherwise eMMC won’t be writable | | MMC hardware unstable | Even FEL‑booted U‑Boot may hang | This is why FEL is not a magic fix here. --- 🟩 Could we try FEL anyway? Yes — if you want, I can guide you through: - Checking if FEL is available - Finding the FEL pads - Using sunxi-fel - Dumping BOOT0 - Dumping vendor U‑Boot - Rebuilding a hybrid U‑Boot - Flashing eMMC manually But I want you to understand the reality: It’s a research project, not a guaranteed solution. --- 🟦 If you want to try FEL, I can walk you through step 1 right now Step 1 is simple: Connect the box to your PC via USB‑A to USB‑A cable, then power it on. On your PC, run: ` sunxi-fel version ` If it prints something → FEL works. If it says “no device found” → we need to try hardware tricks. Just tell me if you want to go down this path. 0 Quote
Nick A Posted February 7 Posted February 7 (edited) @Brow Mosh AI is wrong. Mainline supports - Your PMIC - Your DRAM timing - Your HDMI (Patches have been around for years but not accepted in mainline yet. I included it in my builds.) - Your regulators Supported in mainline but might need some dts changes. - Your weird SD wiring - Your eMMC layout ( Could be a gpio# issue) If you are booting into the kernel then I believe your SD is somewhat working. Maybe you need few tweaks to your dts or your DRAM settings are off. A failing or cheap SD card could also be your issue. Kernel boots Reaches userspace Shows login banner Without a DTS I can’t help you much. Also, can you post some boot logs. FEL over USB is your last option. It is possible. But I don't think your AI model will help much. I noticed with some AI models they will encourage you to quit when they can't find the correct information. The owner of the AI model wants you to pay for their deep learning version. Edited February 8 by Nick A 0 Quote
BoringName Posted February 13 Posted February 13 I've been trying to get the LCD working on my box. I've used Nicks image - Armbian-unofficial_25.05.0-trunk_X98h_bookworm_edge_6.12.11_xfce_desktop I've followed instructions for OpenVFD and tm16xx on these forums but both result in an Exec Format Error when I try to install the compiled module. From what I have read this is a version mismatch between the kernal and what the module was built with but when I compare uname -r with the vermagic of the module they match. I initially installed the linux headers from Nick's Github: linux-headers-edge-sunxi64_25.05.0-trunk_arm64_6.12.11. After I got the format error I tried installing headers from Armbian-config but get the same result. Make wouldn't work at all initially until I did a symlink between the relevant folders in usr/src and lib/modules. Maybe that stuffed something up? 0 Quote
MeJune Posted February 19 Posted February 19 @Nick A You previously taught how to build an image for Transpeed 8k618-t. If I want to replace the default version kernel with a newer kernel. Could I tell you if there's a way to create one? 0 Quote
Nick A Posted February 19 Posted February 19 (edited) @MeJune You can check out my work starting with the 'Add warpme kernel 6.17' commit here: https://github.com/NickAlilovic/build/commits/v20251014/ I’m using warpme patches from his minimyth2 repo, though I’ve modified them to ensure they apply correctly. I also used my own patches for Transpeed, as his implementation differs from mine. u-boot: https://github.com/warpme/minimyth2/tree/master/script/bootloaders/u-boot-aw/files https://github.com/warpme/minimyth2/blob/master/script/bootloaders/u-boot-aw/Makefile kernel: https://github.com/warpme/minimyth2/tree/master/script/kernel/linux-6.19/files https://github.com/warpme/minimyth2/blob/master/script/kernel/linux-6.19/Makefile An easier way to do this is to create a board config and use the official Armbian patch set. While Transpeed is already mainlined, the implementation is incomplete. You will still need a patch to include your missing Transpeed DTS nodes. If you are happy with 6.17, then use this build: https://github.com/NickAlilovic/build/commits/v20251014/ This build generates a kernel .deb package in output/debs. You can use it to upgrade your existing Armbian installation. I haven't tried this myself, so I make no promises that it will work; please ensure you have a backup before proceeding. Backing Up the SD Card (from another PC) The most reliable way to back up an SD card is to create a full disk image on a separate computer. sudo dd if=/dev/sdX of=armbian_backup.img bs=1M status=progress If your system is running on eMMC, you can back it up to an external USB or SD card using built-in Armbian tools. Using armbian-ddbr: Many Armbian builds include this utility specifically for eMMC backup/restore. Boot Armbian from an external SD card (so the eMMC is not in use). Run the command: sudo armbian-ddbr. Select the backup option to create a compressed image of your internal storage. Using armbian-config: Some versions offer a "Backup" or "Clone" option under the System or Maintenance menus Edited February 19 by Nick A 0 Quote
MeJune Posted February 25 Posted February 25 @Nick A Thank you very much. Newbies will try. 😅 0 Quote
Josh at WLTechBlog Posted March 11 Posted March 11 @Nick A Apologies for going a bit off topic but I've been searching for the SWT6621S driver source for my open source project, and your post is approximately the only reference to it I'm finding. is there any chance you could share? I've attempted to contact the same person you were successful with but as of yet no response. 0 Quote
Taz Posted March 11 Posted March 11 (edited) Howdy hey. What do you guys think of this Android TV Box Q19 Android16 Allwinner H618 https://www.aliexpress.com/item/1005011785087357.html it does claim 8GB ram and price is ~40 euro ? or 95 TV Box Android14 Allwinner H616 https://www.aliexpress.com/item/1005009496923463.html which one is a better bet? Edited March 11 by Taz 0 Quote
Rodrigo Campos Posted March 12 Posted March 12 As I had read, the maximum amount of RAM the H618 handles is 4GB, so, this 8GB TV Box should be a false information. 0 Quote
Taz Posted April 4 Posted April 4 (edited) Okay I think you are right they are shifting the RAM GB numbers so 8 GB is actually 4 GB as the price suggests. Now now, what I ended up doing is I bought a Teclast T60 AI tablet(for 100 euro shipped in EU) with Allwinner A772 which is supported by armbian and comes with 6GB RAM. I do not know if I will be trying to boot armbian on it soon but I was able to root it with Magisk. It did went on quite a journey to get it rooted as I kind of soft bricked it at first. Deepseek was giving me little wrong information but we got there. I think I might need a more competent AI agent like Gemini pro to get display, touch, wifi, bluetooth etc. working with armbian. Perhaps I post about the rooting process elsewhere at some point. Here is some of the gear I have if people are interested: https://www.aliexpress.com/item/1005009330391341.html DUX DUCIS Foldable Bluetooth 5.0 Keyboard with Touchpad & Phone Holder For Phones Tablets PC iOS Android Windows Mac https://www.aliexpress.com/item/1005011827691576.html https://www.aliexpress.com/item/1005009419399930.html HGFRTEE 3840*2160 13.3inch 4K Portable Monitor All in all pretty pleased with it so far, not exactly Surface pro 5/7 which I also have and they all weight about 1000 grams but then on the other hand this tablet did not cost me hundreds of $ so I can be little less nervous about someone stealing it. Edited April 4 by Taz 0 Quote
Rodrigo Campos Posted April 18 Posted April 18 Hi all, I finally could get 4GB in my Transpeed M98 Plus. For everyone that have this same problem, the solution is just use a patch to change 2 archives, the "configs/transpeed-8k618-t_defconfig" and the include/configs/sunxi-common.h to define the maximum dram to 4GB instead 2GB. Just put the patch in build/patch/u-boot/u-boot-aw before the compilation process. To be honest I don't know how Nick could put his box to work with 4GB, because the sunxi-common.h fix in 2GB the maximum amount of dram, #define PHYS_SDRAM_0_SIZE 0x80000000 /* 2 GiB */ instead of #define PHYS_SDRAM_0_SIZE 0x100000000ULL /* 4 GiB */. 174-define-DRAM_MAX_SIZE-to-4GB.patch 0 Quote
Aco Art Posted April 23 Posted April 23 (edited) I published my Vontar H618 bring-up patch set here: https://github.com/aco-art/vontar-h618-armbian-patche It includes the Armbian userpatches, U-Boot/kernel changes, and diagnostics tools I used for this box. Tested on my 4 GiB DDR3 Vontar H618 unit and shared in case it helps with similar H618/H616-class TV boxes. On my tested unit, Wi-Fi, Bluetooth, LAN, HDMI output, and the basic GPU/display path are working with this baseline. Edited April 23 by Aco Art 0 Quote
UnhealthyTweak Posted April 26 Posted April 26 Hi, For Tanix TX68 to get all USB ports working it was enough to toggle status = "disabled" to "okay" in transpeed-8k618 DTS. (unfortunatelly i cannot spin up an external HDD by it while having soldered 2x18650 UPS, to little amps available) Getting WiFi / BT to work on the other hand is not solved. BT: - modules loaded out of the box, no errors in dmesg after changing something in DTS but hcitool dev/scan show nothing WiFi: - modprobe: ERROR: could not insert 'aic8800_fdrv': No such device - I tried modifying parts of Transpeed DTS to align with vendor Android DTS with no result Probably same issue as on T95Z Plus: I tried its image: https://github.com/LYU4662/t95zplus-h618-build same error. I diffed android DTS between T95Z & TX68 - almost identical tp95_android.dts tx68_android.dts 0 Quote
NiTr0 Posted May 12 Posted May 12 (edited) What's right way for kernel updating on old installation of armbian (trixie) on 8k618-t? Will it be enough just to install .apk with new kernel? Edited May 12 by NiTr0 0 Quote
Nick A Posted May 13 Posted May 13 @NiTr0 Are you referring to the deb packages? If you compile my newer kernel version for the 8k618-t, you’ll find the kernel deb packages in the output/debs directory. I haven't had a chance to test this myself yet. I've been buried with the Radxa Cubie A7A/A7S/A7Z projects, so I haven't had the time to update the build. 0 Quote
Rodrigo Campos Posted May 13 Posted May 13 (edited) @Aco Art, Thanks a lot for your sharing. As I had read, this is the most recommended method to include a new board outside of the official Armbian. I'm even thinking of basing on your patch to make one for my Transpeed M98 Plus, which is working very well with Nick's wonderful build, but your patch has the advantage of directly using the official Armbian build, and that's Empowering. But I have a doubt. Why fiz the 2025.05 uboot? Any special reason like a conflict with newer ones? Edited May 13 by Rodrigo Campos 0 Quote
Nick A Posted May 13 Posted May 13 (edited) If you want to use the official Armbian on Transpeed 8K618-T. I think all you really need is a board config file. I believe most of the drivers have been mainlined or included in the armbian patch directory. git clone https://github.com/armbian/build.git --branch v26.02 Copy this file into build/config/boards directory. transpeed-8k618-t.tvb # Allwinner H618 quad core 4GB RAM SoC WiFi USB BOARD_NAME="Transpeed 8k618-t" BOARDFAMILY="sun50iw9" BOARD_MAINTAINER="" BOOTBRANCH="tag:v2026.04" BOOTPATCHDIR="v2026-sunxi" BOOTCONFIG="transpeed-8k618-t_defconfig" OVERLAY_PREFIX="sun50i-h616" BOOT_LOGO="desktop" KERNEL_TARGET="current,edge" ./compile.sh build BOARD=transpeed-8k618-t BRANCH=edge BUILD_DESKTOP=yes BUILD_MINIMAL=no DESKTOP_ENVIRONMENT=xfce DESKTOP_TIER=mid KERNEL_CONFIGURE=no RELEASE=trixie Edited May 13 by Nick A 0 Quote
Aco Art Posted Tuesday at 09:01 PM Posted Tuesday at 09:01 PM @Rodrigo Campos In my case the U-Boot side is not just a generic version choice. That baseline carries the board-specific path I tested: the zero2w-based defconfig, mmc0 broken-CD handling, H616 EMAC1/RMII support, I2C3 enablement, the LAN preinit step, and the extra EMAC-related clock/register writes. Since the kernel LAN attach depends on the board already being prepared by U-Boot, I preferred to keep the bootloader side conservative. So the short answer is: it is pinned because it is the validated baseline, not because I know of a hard conflict with every newer release. 0 Quote
sr4armbian Posted Wednesday at 06:11 AM Posted Wednesday at 06:11 AM @Nick A Thanks for releasing the wonderful Armbian image for the Allwinner H618 and for supporting the community with your valuable suggestions. I recently purchased a TV box with 4GB of RAM and 64GB of storage running Android 12. I downloaded Armbian-unofficial_25.05.0-trunk_Transpeed-8k618-t_bookworm_edge_6.12.11_server.img.xz from here and flashed it to an SD card using BalenaEtcher. The box boots successfully, and I can configure it via the CLI. However, this motherboard is different from the ones previously posted here. The silkscreen on the board reads "X3Plus_H618_4bit_V3.0". Based on the naming convention and the appearance of the device, it seems to be the model available here. This board uses an FD6551 chip for the front VFD display. I have managed to extract .img file from the stock android. Are there any modifications I need to make to get the Wi-Fi, USB ports, and front VFD working? Could you please suggest? Things that are working: HDMI Display LAN Controller 1 out of the 2 USB ports. The port near to SD Card slot more precisely Things that are not working: WiFi - The chip got a metal shield. On top of the shield it is written with W804S1, inside the shield I could find AIC8800D40 chip. 1 x USB Port - Near the top left hand corner Front VFD display. 0 Quote
