MMorales Posted Wednesday at 08:38 PM Share Posted Wednesday at 08:38 PM @firepower i did that and not works. Keeps in the android logo 0 Quote Link to comment Share on other sites More sharing options...
rafman Posted Wednesday at 10:33 PM Share Posted Wednesday at 10:33 PM (edited) 2 hours ago, firepower said: i like to make a bootable micro SDcard with the Vontar H618 Android 12 firmware and see if it would boot on the Tanix Tx6. Use Disks to make an image and restore to sdcard? You can try it but it may fail to boot android for many reasons. When i finally boot my Z1 h313 box with Armbian i made an eMMC backup from a a second Z1 with android, using dd and i tried to restore it to my bricked Z1 device . however when i restore the image Z1 device failed to boot and when i investigate the reason i realize that for some reason gpt partition information was lost on restored device. Chinese manufacturers use common android images for their products, They just customize the logo and boot boot video and some other information including devices firmwares wifi/bt/vfd however in some cases they verify some keys for their boxes on android / vendor partition, and if you try to use unofficial or different manufacturer image does not boot. You can burn a downloaded android image to sd card as startup using PhoenixCard. BUT... When i tried by burning a downloaded firmware image for Transpeed 8k (H618.apollo-p3.T-H618_100M_12_FD650.2023.09.13.17.20.img) using (PhoenixCard.v4.2.4 / Startup ) it stayed on Transpeed logo for Ever. When i have the time, I will try to do it and with Vontar image i download (H618.apollo-p16.VONTAR_H618_100M_12_FD650.2024.05.20.12.40.img) but i believe the the result will be the same because these images are almost identical vontar/transpeed except (logos ) i decompose it both NOTE: If you use PhoenixCard please take care because if you choose product you may erase your eMMC on destination tv-box. Edited Wednesday at 10:49 PM by rafman 0 Quote Link to comment Share on other sites More sharing options...
firepower Posted 15 hours ago Share Posted 15 hours ago (edited) Quote Can someone with a Transpeed 8k618-t measure the 32KHz clock with a Oscilloscope? The 32Khz fanout is routed to PG10 pin on the SOC and connected to the LPO pin of the WiFi/BT chip. @Nick A Vontar H618 HK6334Q this is from data sheet: "Pin 24 LPO External Low Power Clock input (32.768KHz)" measured with Owon HDS2202S hand held Oscilloscope. its 32.768KHz NOT 32kHz AP6330.pdf Edited 15 hours ago by firepower 0 Quote Link to comment Share on other sites More sharing options...
MMorales Posted 15 hours ago Share Posted 15 hours ago @firepower is this the xtal that has 37.400 writen? can you add a picture of it? 0 Quote Link to comment Share on other sites More sharing options...
firepower Posted 14 hours ago Share Posted 14 hours ago (edited) No that Xtal is 37.4MHz or 26MHz used to generate the 2.4 and 5GHz radio fequency. (If no Xtal is used it be using internal oscillator or 24MHz Xtal of the H618 cpu). The Low Power Clock, LPO is used to Clock the wifi chip when off/sleep and turn wifi and bluetooth on and off, 3 clk pulse after the voltage rails are turned on or off. When on it uses high speed clock from Xtal. See Page 17 of datasheet. Its Input Pin 24 of Wifi/BT chip, clk comes from H618/H616 arm CPU. Pin 24 LDO is marked with Pink dot. Edited 10 hours ago by firepower 0 Quote Link to comment Share on other sites More sharing options...
